[QUOTE=CarnivoreD;422907]Hier steht eigentlich alles mit Beispielen:
Einfach die Class als Skript in IPS einfügen, Config-Skript einfügen und die Zugriffs-Skripts… Wenn ich mal mehr Zeit habe, poste ich gerne die Skripte, die ich mir gebastelt habe…
Viele Grüße![/QUOTE]
So, hier die Skripte:
Skript anlegen mit der Unifi-API-Class und GROSSBUCHSTBEN in den ersten drei Zeilen unter „private properties“ anpassen (ggf. sind weitere Anpassungen erforderlich):
* This file is part of the art-of-wifi/unifi-api-client package
* This UniFi API client is based on the work done by the following developers:
* domwo: http://community.ubnt.com/t5/UniFi-Wireless/little-php-class-for-unifi-api/m-p/603051
* fbagnol: https://github.com/fbagnol/class.unifi.php
* and the API as published by Ubiquiti:
* https://www.ubnt.com/downloads/unifi/<UniFi controller version number>/unifi_sh_api
* Copyright (c) 2017, Art of WiFi <info@artofwifi.net>
* This source file is subject to the MIT license that is bundled
* with this package in the file LICENSE.md
namespace UniFi_API;
* the UniFi API client class
class Client
* private properties
protected $baseurl = 'Z.B. https://127.0.0.1:8443';
protected $user = 'USERNAME CONTROLLER';
protected $password = 'PASSWORD CONTROLLER';
protected $site = 'default';
protected $version = '5.6.39';
protected $debug = false;
protected $is_loggedin = false;
private $cookies = '';
private $request_type = 'POST';
private $connect_timeout = 10;
private $last_results_raw = null;
private $last_error_message = null;
private $curl_ssl_verify_peer = false;
private $curl_ssl_verify_host = false;
* Construct an instance of the UniFi API client class
* return a new class instance
* required parameter <user> = string; user name to use when connecting to the UniFi controller
* required parameter <password> = string; password to use when connecting to the UniFi controller
* optional parameter <baseurl> = string; base URL of the UniFi controller, *must* include "https://" prefix and port suffix (:8443)
* optional parameter <site> = string; short site name to access, defaults to "default"
* optional parameter <version> = string; the version number of the controller, defaults to "5.4.16"
* optional parameter <ssl_verify> = boolean; whether to validate the controller's SSL certificate or not, a value of true is
* recommended for production environments to prevent potential MitM attacks, default value (false)
* is to not validate the controller certificate
public function __construct($user, $password, $baseurl = '', $site = '', $version = '', $ssl_verify = false)
if (!extension_loaded('curl')) {
trigger_error('The PHP curl extension is not loaded. Please correct this before proceeding!');
$this->user = trim($user);
$this->password = trim($password);
if (!empty($baseurl)) {
$this->baseurl = trim($baseurl);
if (!empty($site)) {
$this->site = trim($site);
if (!empty($version)) {
$this->version = trim($version);
if ($ssl_verify === true) {
$this->curl_ssl_verify_peer = true;
$this->curl_ssl_verify_host = 2;
$this->check_base_url();
$this->check_site($this->site);
$this->update_unificookie();
public function __destruct()
* if user has $_SESSION['unificookie'] set, do not logout here
if (isset($_SESSION['unificookie'])) {
return;
* logout, if needed
if ($this->is_loggedin) {
$this->logout();
* Login to UniFi Controller
* returns true upon success
public function login()
* if $_SESSION['unificookie'] is set, skip the login
return $this->is_loggedin = true;
if (!is_resource($ch = $this->get_curl_resource())) {
trigger_error('$ch as returned by get_curl_resource() is not a resource');
} else {
curl_setopt($ch, CURLOPT_HEADER, 1);
curl_setopt($ch, CURLOPT_REFERER, $this->baseurl . '/login');
curl_setopt($ch, CURLOPT_URL, $this->baseurl . '/api/login');
curl_setopt($ch, CURLOPT_POSTFIELDS, json_encode(['username' => $this->user, 'password' => $this->password]));
* execute the cURL request
$content = curl_exec($ch);
if (curl_errno($ch)) {
trigger_error('cURL error: ' . curl_error($ch));
if ($this->debug) {
curl_setopt($ch, CURLOPT_VERBOSE, true);
print '<pre>';
print PHP_EOL . '-----------LOGIN-------------' . PHP_EOL;
print_r(curl_getinfo($ch));
print PHP_EOL . '----------RESPONSE-----------' . PHP_EOL;
print $content;
print PHP_EOL . '-----------------------------' . PHP_EOL;
print '</pre>';
$header_size = curl_getinfo($ch, CURLINFO_HEADER_SIZE);
$headers = substr($content, 0, $header_size);
$body = trim(substr($content, $header_size));
$http_code = curl_getinfo($ch, CURLINFO_HTTP_CODE);
curl_close($ch);
preg_match_all('|Set-Cookie: (.*);|Ui', $headers, $results);
if (isset($results[1])) {
$this->cookies = implode(';', $results[1]);
if (!empty($body)) {
if (($http_code >= 200) && ($http_code < 400)) {
if (strpos($this->cookies, 'unifises') !== false) {
if ($http_code === 400) {
trigger_error('We have received an HTTP response status: 400. Probably a controller login failure');
return $http_code;
return false;
* Logout from UniFi Controller
public function logout()
if (!$this->is_loggedin) {
return false;
$this->exec_curl('/logout');
$this->is_loggedin = false;
$this->cookies = '';
return true;
* Functions to access UniFi controller API routes from here:
* Authorize a client device
* return true on success
* required parameter <mac> = client MAC address
* required parameter <minutes> = minutes (from now) until authorization expires
* optional parameter <up> = upload speed limit in kbps
* optional parameter <down> = download speed limit in kbps
* optional parameter <MBytes> = data transfer limit in MB
* optional parameter <ap_mac> = AP MAC address to which client is connected, should result in faster authorization
public function authorize_guest($mac, $minutes, $up = null, $down = null, $MBytes = null, $ap_mac = null)
return false;
$payload = ['cmd' => 'authorize-guest', 'mac' => strtolower($mac), 'minutes' => intval($minutes)];
* if we have received values for up/down/MBytes/ap_mac we append them to the payload array to be submitted
if (!empty($up)) {
$payload['up'] = intval($up);
if (!empty($down)) {
$payload['down'] = intval($down);
if (!empty($MBytes)) {
$payload['bytes'] = intval($MBytes);
if (isset($ap_mac)) {
$payload['ap_mac'] = strtolower($ap_mac);
$response = $this->exec_curl('/api/s/' . $this->site . '/cmd/stamgr', $payload);
return $this->process_response_boolean($response);
* Unauthorize a client device
public function unauthorize_guest($mac)
return false;
$payload = ['cmd' => 'unauthorize-guest', 'mac' => strtolower($mac)];
* Reconnect a client device
public function reconnect_sta($mac)
return false;
$payload = ['cmd' => 'kick-sta', 'mac' => strtolower($mac)];
* Block a client device
public function block_sta($mac)
return false;
$payload = ['cmd' => 'block-sta', 'mac' => strtolower($mac)];
* Unblock a client device
public function unblock_sta($mac)
return false;
$payload = ['cmd' => 'unblock-sta', 'mac' => strtolower($mac)];
* Forget one or more client devices
* required parameter <macs> = array of client MAC addresses
* NOTE:
* only supported with controller versions 5.9.X and higher
public function forget_sta($macs)
return false;
$macs = array_map('strtolower', $macs);
$payload = ['cmd' => 'forget-sta', 'macs' => $macs];
* Create a new user/client-device
* return an array with a single object containing details of the new user/client-device on success, else return false
* required parameter <user_group_id> = _id value for the user group the new user/client-device should belong to which
* can be obtained from the output of list_usergroups()
* optional parameter <name> = name to be given to the new user/client-device
* optional parameter <note> = note to be applied to the new user/client-device
public function create_user($mac, $user_group_id, $name = null, $note = null)
return false;
$this->request_type = 'POST';
$new_user = ['mac' => strtolower($mac), 'usergroup_id' => $user_group_id];
if (!is_null($name)) {
$new_user['name'] = $name;
if (!is_null($note)) {
$new_user['note'] = $note;
$new_user['noted'] = true;
$payload = ['objects' => [['data' => $new_user]]];
$response = $this->exec_curl('/api/s/' . $this->site . '/group/user', $payload);
return $this->process_response($response);
* Add/modify/remove a client-device note
* required parameter <user_id> = id of the client-device to be modified
* optional parameter <note> = note to be applied to the client-device
* NOTES:
* - when note is empty or not set, the existing note for the client-device will be removed and "noted" attribute set to false
public function set_sta_note($user_id, $note = null)
return false;
$noted = (is_null($note)) || (empty($note)) ? false : true;
$payload = ['note' => $note, 'noted' => $noted];
$response = $this->exec_curl('/api/s/' . $this->site . '/upd/user/' . trim($user_id), $payload);
* Add/modify/remove a client device name
* required parameter <user_id> = id of the client device to be modified
* optional parameter <name> = name to be applied to the client device
* NOTES:
* - when name is empty or not set, the existing name for the client device will be removed
public function set_sta_name($user_id, $name = null)
return false;
$payload = ['name' => $name];
* 5 minutes site stats method
* returns an array of 5-minute stats objects for the current site
* optional parameter <start> = Unix timestamp in milliseconds
* optional parameter <end> = Unix timestamp in milliseconds
* NOTES:
* - defaults to the past 12 hours
* - this function/method is only supported on controller versions 5.5.* and later
* - make sure that the retention policy for 5 minutes stats is set to the correct value in
* the controller settings
public function stat_5minutes_site($start = null, $end = null)
return false;
$end = is_null($end) ? (time() * 1000) : intval($end);
$start = is_null($start) ? $end - (12 * 3600 * 1000) : intval($start);
$attributes = [
'bytes',
'wan-tx_bytes',
'wan-rx_bytes',
'wlan_bytes',
'num_sta',
'lan-num_sta',
'wlan-num_sta',
'time'
$payload = ['attrs' => $attributes, 'start' => $start, 'end' => $end];
$response = $this->exec_curl('/api/s/' . $this->site . '/stat/report/5minutes.site', $payload);
* Hourly site stats method
* returns an array of hourly stats objects for the current site
* NOTES:
* - defaults to the past 7*24 hours
* - "bytes" are no longer returned with controller version 4.9.1 and later
public function stat_hourly_site($start = null, $end = null)
return false;
$start = is_null($start) ? $end - (7 * 24 * 3600 * 1000) : intval($start);
$attributes = [
'bytes',
'wan-tx_bytes',
'wan-rx_bytes',
'wlan_bytes',
'num_sta',
'lan-num_sta',
'wlan-num_sta',
'time'
$response = $this->exec_curl('/api/s/' . $this->site . '/stat/report/hourly.site', $payload);
* Daily site stats method
* returns an array of daily stats objects for the current site
* NOTES:
* - defaults to the past 52*7*24 hours
public function stat_daily_site($start = null, $end = null)
return false;
$end = is_null($end) ? ((time() - (time() % 3600)) * 1000) : intval($end);
$start = is_null($start) ? $end - (52 * 7 * 24 * 3600 * 1000) : intval($start);
$attributes = [
'bytes',
'wan-tx_bytes',
'wan-rx_bytes',
'wlan_bytes',
'num_sta',
'lan-num_sta',
'wlan-num_sta',
'time'
$response = $this->exec_curl('/api/s/' . $this->site . '/stat/report/daily.site', $payload);
* 5 minutes stats method for a single access point or all access points
* optional parameter <mac> = AP MAC address to return stats for
* NOTES:
public function stat_5minutes_aps($start = null, $end = null, $mac = null)
return false;
$attributes = ['bytes', 'num_sta', 'time'];
if (!is_null($mac)) {
$payload['mac'] = strtolower($mac);
$response = $this->exec_curl('/api/s/' . $this->site . '/stat/report/5minutes.ap', $payload);
* Hourly stats method for a single access point or all access points
* NOTES:
* - UniFi controller does not keep these stats longer than 5 hours with versions < 4.6.6
public function stat_hourly_aps($start = null, $end = null, $mac = null)
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/stat/report/hourly.ap', $payload);
* Daily stats method for a single access point or all access points
* NOTES:
public function stat_daily_aps($start = null, $end = null, $mac = null)
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/stat/report/daily.ap', $payload);
* 5 minutes stats method for a single user/client device
* required parameter <mac> = MAC address of user/client device to return stats for
* optional parameter <attribs> = array containing attributes (strings) to be returned, valid values are:
* rx_bytes, tx_bytes, signal, rx_rate, tx_rate, rx_retries, tx_retries, rx_packets, tx_packets
* default is ['rx_bytes', 'tx_bytes']
* NOTES:
* - only supported with UniFi controller versions 5.8.X and higher
* - make sure that "Clients Historical Data" has been enabled in the UniFi controller settings in the Maintenance section
public function stat_5minutes_user($mac, $start = null, $end = null, $attribs = null)
return false;
$attribs = is_null($attribs) ? ['time', 'rx_bytes', 'tx_bytes'] : array_merge(['time'], $attribs);
$payload = ['attrs' => $attribs, 'start' => $start, 'end' => $end, 'mac' => strtolower($mac)];
$response = $this->exec_curl('/api/s/' . $this->site . '/stat/report/5minutes.user', $payload);
* Hourly stats method for a a single user/client device
* NOTES:
public function stat_hourly_user($mac, $start = null, $end = null, $attribs = null)
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/stat/report/hourly.user', $payload);
* Daily stats method for a single user/client device
* NOTES:
public function stat_daily_user($mac, $start = null, $end = null, $attribs = null)
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/stat/report/daily.user', $payload);
* 5 minutes gateway stats method
* returns an array of 5-minute stats objects for the gateway belonging to the current site
* mem, cpu, loadavg_5, lan-rx_errors, lan-tx_errors, lan-rx_bytes,
* lan-tx_bytes, lan-rx_packets, lan-tx_packets, lan-rx_dropped, lan-tx_dropped
* default is ['time', 'mem', 'cpu', 'loadavg_5']
* NOTES:
* - requires a USG
public function stat_5minutes_gateway($start = null, $end = null, $attribs = null)
return false;
$attribs = is_null($attribs) ? ['time', 'mem', 'cpu', 'loadavg_5'] : array_merge(['time'], $attribs);
$payload = ['attrs' => $attribs, 'start' => $start, 'end' => $end];
$response = $this->exec_curl('/api/s/' . $this->site . '/stat/report/5minutes.gw', $payload);
* Hourly gateway stats method
* returns an array of hourly stats objects for the gateway belonging to the current site
* NOTES:
* - requires a USG
public function stat_hourly_gateway($start = null, $end = null, $attribs = null)
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/stat/report/hourly.gw', $payload);
* Daily gateway stats method
* returns an array of daily stats objects for the gateway belonging to the current site
* NOTES:
* - requires a USG
public function stat_daily_gateway($start = null, $end = null, $attribs = null)
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/stat/report/daily.gw', $payload);
* Method to fetch speed test results
* returns an array of speed test result objects
* NOTES:
* - defaults to the past 24 hours
* - requires a USG
public function stat_speedtest_results($start = null, $end = null)
return false;
$start = is_null($start) ? $end - (24 * 3600 * 1000) : intval($start);
$payload = ['attrs' => ['xput_download', 'xput_upload', 'latency', 'time'], 'start' => $start, 'end' => $end];
$response = $this->exec_curl('/api/s/' . $this->site . '/stat/report/archive.speedtest', $payload);
* Method to fetch IPS/IDS event
* returns an array of IPS/IDS event objects
* optional parameter <limit> = Maximum number of events to return, defaults to 10000
* NOTES:
* - requires a USG
* - supported in UniFi controller versions 5.9.X and higher
public function stat_ips_events($start = null, $end = null, $limit = null)
return false;
$limit = is_null($limit) ? 10000 : intval($limit);
$payload = ['start' => $start, 'end' => $end, '_limit' => $limit];
$response = $this->exec_curl('/api/s/' . $this->site . '/stat/ips/event', $payload);
* Show all login sessions
* returns an array of login session objects for all devices or a single device
* optional parameter <start> = Unix timestamp in seconds
* optional parameter <end> = Unix timestamp in seconds
* optional parameter <mac> = client MAC address to return sessions for (can only be used when start and end are also provided)
* optional parameter <type> = client type to return sessions for, can be 'all', 'guest' or 'user'; default value is 'all'
* NOTES:
public function stat_sessions($start = null, $end = null, $mac = null, $type = 'all')
return false;
if (!in_array($type, ['all', 'guest', 'user'])) {
return false;
$end = is_null($end) ? time() : intval($end);
$start = is_null($start) ? $end - (7 * 24 * 3600) : intval($start);
$payload = ['type' => $type, 'start' => $start, 'end' => $end];
$response = $this->exec_curl('/api/s/' . $this->site . '/stat/session', $payload);
* Show latest 'n' login sessions for a single client device
* returns an array of latest login session objects for given client device
* optional parameter <limit> = maximum number of sessions to get (default value is 5)
public function stat_sta_sessions_latest($mac, $limit = null)
return false;
$limit = is_null($limit) ? 5 : intval($limit);
$payload = ['mac' => strtolower($mac), '_limit' => $limit, '_sort'=> '-assoc_time'];
* Show all authorizations
* returns an array of authorization objects
* NOTES:
public function stat_auths($start = null, $end = null)
return false;
$payload = ['start' => $start, 'end' => $end];
$response = $this->exec_curl('/api/s/' . $this->site . '/stat/authorization', $payload);
* List all client devices ever connected to the site
* returns an array of client device objects
* optional parameter <historyhours> = hours to go back (default is 8760 hours or 1 year)
* NOTES:
* - <historyhours> is only used to select clients that were online within that period,
* the returned stats per client are all-time totals, irrespective of the value of <historyhours>
public function stat_allusers($historyhours = 8760)
return false;
$payload = ['type' => 'all', 'conn' => 'all', 'within' => intval($historyhours)];
$response = $this->exec_curl('/api/s/' . $this->site . '/stat/alluser', $payload);
* List guest devices
* returns an array of guest device objects with valid access
* optional parameter <within> = time frame in hours to go back to list guests with valid access (default = 24*365 hours)
public function list_guests($within = 8760)
return false;
$payload = ['within' => intval($within)];
$response = $this->exec_curl('/api/s/' . $this->site . '/stat/guest', $payload);
* List online client device(s)
* returns an array of online client device objects, or in case of a single device request, returns a single client device object
* optional parameter <client_mac> = the MAC address of a single online client device for which the call must be made
public function list_clients($client_mac = null)
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/stat/sta/' . strtolower(trim($client_mac)));
* Get details for a single client device
* returns an object with the client device information
* required parameter <client_mac> = client device MAC address
public function stat_client($client_mac)
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/stat/user/' . strtolower(trim($client_mac)));
* Assign client device to another group
* required parameter <user_id> = id of the user device to be modified
* required parameter <group_id> = id of the user group to assign user to
public function set_usergroup($user_id, $group_id)
return false;
$payload = ['usergroup_id' => $group_id];
* Update client fixedip (using REST)
* returns an array containing a single object with attributes of the updated client on success
* required parameter <client_id> = _id value for the client
* required parameter <use_fixedip> = boolean defining whether if use_fixedip is true or false
* optional parameter <network_id> = _id value for the network where the ip belongs to
* optional parameter <fixed_ip> = value of client's fixed_ip field
public function edit_client_fixedip($client_id, $use_fixedip, $network_id = null, $fixed_ip = null)
return false;
if (!is_bool($use_fixedip)) {
return false;
$this->request_type = 'PUT';
$payload = ['_id' => $client_id, 'use_fixedip' => $use_fixedip];
if ($use_fixedip) {
if ($network_id) {
$payload['network_id'] = $network_id;
if ($fixed_ip) {
$payload['fixed_ip'] = $fixed_ip;
$response = $this->exec_curl('/api/s/' . $this->site . '/rest/user/' . trim($client_id), $payload);
* List user groups
* returns an array of user group objects
public function list_usergroups()
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/list/usergroup');
* Create user group (using REST)
* returns an array containing a single object with attributes of the new usergroup ("_id", "name", "qos_rate_max_down", "qos_rate_max_up", "site_id") on success
* required parameter <group_name> = name of the user group
* optional parameter <group_dn> = limit download bandwidth in Kbps (default = -1, which sets bandwidth to unlimited)
* optional parameter <group_up> = limit upload bandwidth in Kbps (default = -1, which sets bandwidth to unlimited)
public function create_usergroup($group_name, $group_dn = -1, $group_up = -1)
return false;
$payload = ['name' => $group_name, 'qos_rate_max_down' => intval($group_dn), 'qos_rate_max_up' => intval($group_up)];
$response = $this->exec_curl('/api/s/' . $this->site . '/rest/usergroup', $payload);
* Modify user group (using REST)
* returns an array containing a single object with attributes of the updated usergroup on success
* required parameter <group_id> = _id value of the user group
* required parameter <site_id> = _id value of the site
public function edit_usergroup($group_id, $site_id, $group_name, $group_dn = -1, $group_up = -1)
return false;
$payload = [
'_id' => $group_id,
'qos_rate_max_up' => intval($group_up),
'site_id' => $site_id
$response = $this->exec_curl('/api/s/' . $this->site . '/rest/usergroup/' . trim($group_id), $payload);
* Delete user group (using REST)
* returns true on success
public function delete_usergroup($group_id)
return false;
$this->request_type = 'DELETE';
$response = $this->exec_curl('/api/s/' . $this->site . '/rest/usergroup/' . trim($group_id));
* List firewall groups (using REST)
* returns an array containing the current firewall groups or the selected firewall group on success
* optional parameter <group_id> = _id value of the single firewall group to list
public function list_firewallgroups($group_id = null)
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/rest/firewallgroup/' . trim($group_id));
* Create firewall group (using REST)
* returns an array containing a single object with attributes of the new firewall group on success
* required parameter <group_name> = name to assign to the firewall group
* required parameter <group_type> = firewall group type; valid values are address-group, ipv6-address-group, port-group
* optional parameter <group_members> = array containing the members of the new group (IPv4 addresses, IPv6 addresses or port numbers)
* (default is an empty array)
public function create_firewallgroup($group_name, $group_type, $group_members = [])
return false;
if (!in_array($group_type, ['address-group', 'ipv6-address-group', 'port-group'])) {
return false;
$payload = ['name' => $group_name, 'group_type' => $group_type, 'group_members' => $group_members];
$response = $this->exec_curl('/api/s/' . $this->site . '/rest/firewallgroup', $payload);
* Modify firewall group (using REST)
* returns an array containing a single object with attributes of the updated firewall group on success
* required parameter <group_id> = _id value of the firewall group to modify
* required parameter <site_id> = site_id value of the firewall group to modify
* required parameter <group_name> = name of the firewall group
* required parameter <group_type> = firewall group type; valid values are address-group, ipv6-address-group, port-group,
* group_type cannot be changed for an existing firewall group!
* optional parameter <group_members> = array containing the members of the group (IPv4 addresses, IPv6 addresses or port numbers)
* which will overwrite the existing group_members (default is an empty array)
public function edit_firewallgroup($group_id, $site_id, $group_name, $group_type, $group_members = [])
return false;
return false;
$payload = [
'_id' => $group_id,
'group_members' => $group_members,
$response = $this->exec_curl('/api/s/' . $this->site . '/rest/firewallgroup/' . trim($group_id), $payload);
* Delete firewall group (using REST)
* required parameter <group_id> = _id value of the firewall group to delete
public function delete_firewallgroup($group_id)
return false;
* List firewall rules (using REST)
* returns an array containing the current firewall rules on success
public function list_firewallrules()
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/rest/firewallrule');
* List health metrics
* returns an array of health metric objects
public function list_health()
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/stat/health');
* List dashboard metrics
* returns an array of dashboard metric objects (available since controller version 4.9.1.alpha)
* optional parameter <five_minutes> = boolean; if true, return stats based on 5 minute intervals,
* returns hourly stats by default (supported on controller versions 5.5.* and higher)
public function list_dashboard($five_minutes = false)
return false;
$url_suffix = $five_minutes ? '?scale=5minutes' : null;
$response = $this->exec_curl('/api/s/' . $this->site . '/stat/dashboard' . $url_suffix);
* List client devices
* returns an array of known client device objects
public function list_users()
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/list/user');
* List access points and other devices under management of the controller (USW and/or USG devices)
* returns an array of known device objects (or a single device when using the <device_mac> parameter)
* optional parameter <device_mac> = the MAC address of a single device for which the call must be made
public function list_devices($device_mac = null)
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/stat/device/' . strtolower(trim($device_mac)));
* List (device) tags (using REST)
* returns an array of known device tag objects
* NOTES: this endpoint was introduced with controller versions 5.5.X
public function list_tags()
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/rest/tag');
* List rogue/neighboring access points
* returns an array of rogue/neighboring access point objects
* optional parameter <within> = hours to go back to list discovered "rogue" access points (default = 24 hours)
public function list_rogueaps($within = 24)
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/stat/rogueap', $payload);
* List known rogue access points
* returns an array of known rogue access point objects
public function list_known_rogueaps()
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/rest/rogueknown');
* List auto backups
* return an array containing objects with backup details on success
public function list_backups()
return false;
$payload = ['cmd' => 'list-backups'];
$response = $this->exec_curl('/api/s/' . $this->site . '/cmd/backup', $payload);
* List sites
* returns a list sites hosted on this controller with some details
public function list_sites()
return false;
$response = $this->exec_curl('/api/self/sites');
* List sites stats
* returns statistics for all sites hosted on this controller
* NOTES: this endpoint was introduced with controller version 5.2.9
public function stat_sites()
return false;
$response = $this->exec_curl('/api/stat/sites');
* Create a site
* returns an array containing a single object with attributes of the new site ("_id", "desc", "name") on success
* required parameter <description> = the long name for the new site
* NOTES: immediately after being added, the new site will be available in the output of the "list_sites" function
public function create_site($description)
return false;
$payload = ['desc' => $description, 'cmd' => 'add-site'];
$response = $this->exec_curl('/api/s/' . $this->site . '/cmd/sitemgr', $payload);
* Delete a site
* required parameter <site_id> = 24 char string; _id value of the site to delete
public function delete_site($site_id)
return false;
$payload = ['site' => $site_id, 'cmd' => 'delete-site'];
* Change the current site's name
* required parameter <site_name> = string; the new long name for the current site
* NOTES: immediately after being changed, the site will be available in the output of the list_sites() function
public function set_site_name($site_name)
return false;
$payload = ['cmd' => 'update-site', 'desc' => $site_name];
* Set site country
* required parameter <payload> = stdClass object or associative array containing the configuration to apply to the network, must be a (partial)
* object structured in the same manner as is returned by list_settings() for the "country" key.
* Valid country codes can be obtained using the list_country_codes() function/method.
* Do not include the _id property, it will be assigned by the controller and returned upon success.
public function set_site_country($country_id, $payload)
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/rest/setting/country/' . trim($country_id), $payload);
* Set site locale
* object structured in the same manner as is returned by list_settings() for the "locale" key.
public function set_site_locale($locale_id, $payload)
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/rest/setting/locale/' . trim($locale_id), $payload);
* Set site snmp
* object structured in the same manner as is returned by list_settings() for the "snmp" key.
public function set_site_snmp($snmp_id, $payload)
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/rest/setting/snmp/' . trim($snmp_id), $payload);
* Set site mgmt
* object structured in the same manner as is returned by list_settings() for the "mgmt" key.
public function set_site_mgmt($mgmt_id, $payload)
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/rest/setting/mgmt/' . trim($mgmt_id), $payload);
* Set site guest access
* object structured in the same manner as is returned by list_settings() for the "guest_access" key.
public function set_site_guest_access($guest_access_id, $payload)
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/rest/setting/guest_access/' . trim($guest_access_id), $payload);
* Set site ntp
* object structured in the same manner as is returned by list_settings() for the "ntp" key.
public function set_site_ntp($ntp_id, $payload)
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/rest/setting/ntp/' . trim($ntp_id), $payload);
* Set site connectivity
* object structured in the same manner as is returned by list_settings() for the "connectivity" key.
public function set_site_connectivity($connectivity_id, $payload)
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/rest/setting/connectivity/' . trim($connectivity_id), $payload);
* List admins
* returns an array containing administrator objects for selected site
public function list_admins()
return false;
$payload = ['cmd' => 'get-admins'];
* List all admins
* returns an array containing administrator objects for all sites
public function list_all_admins()
return false;
$response = $this->exec_curl('/api/stat/admin');
* Invite a new admin for access to the current site
* required parameter <name> = string, name to assign to the new admin user
* required parameter <email> = email address to assign to the new admin user
* optional parameter <enable_sso> = boolean, whether or not SSO will be allowed for the new admin
* default value is true which enables the SSO capability
* optional parameter <readonly> = boolean, whether or not the new admin will have readonly
* permissions, default value is false which gives the new admin
* Administrator permissions
* optional parameter <device_adopt> = boolean, whether or not the new admin will have permissions to
* adopt devices, default value is false. With versions < 5.9.X this only applies
* when readonly is true.
* optional parameter <device_restart> = boolean, whether or not the new admin will have permissions to
* restart devices, default value is false. With versions < 5.9.X this only applies
* NOTES:
* - after issuing a valid request, an invite will be sent to the email address provided
* - issuing this command against an existing admin will trigger a "re-invite"
public function invite_admin(
$name,
$email,
$enable_sso = true,
$readonly = false,
$device_adopt = false,
$device_restart = false
return false;
$email_valid = filter_var(trim($email), FILTER_VALIDATE_EMAIL);
if (!$email_valid) {
trigger_error('The email address provided is invalid!');
return false;
$permissions = [];
$payload = ['name' => trim($name), 'email' => trim($email), 'for_sso' => $enable_sso, 'cmd' => 'invite-admin', 'role' => 'admin'];
if ($readonly) {
$payload['role'] = 'readonly';
if ($device_adopt) {
$permissions[] = 'API_DEVICE_ADOPT';
if ($device_restart) {
$permissions[] = 'API_DEVICE_RESTART';
$payload['permissions'] = $permissions;
* Assign an existing admin to the current site
* required parameter <admin_id> = 24 char string; _id value of the admin user to assign, can be obtained using the
* list_all_admins() method/function
public function assign_existing_admin(
$admin_id,
$readonly = false,
return false;
$permissions = [];
$payload = ['cmd' => 'grant-admin', 'admin' => trim($admin_id), 'role' => 'admin'];
if ($readonly) {
* Revoke an admin from the current site
* required parameter <admin_id> = _id value of the admin to revoke, can be obtained using the
* NOTES:
* only non-superadmin accounts can be revoked
public function revoke_admin($admin_id)
return false;
$payload = ['cmd' => 'revoke-admin', 'admin' => $admin_id];
* List wlan_groups
* returns an array containing known wlan_groups
public function list_wlan_groups()
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/list/wlangroup');
* Show sysinfo
* returns an array of known sysinfo data
public function stat_sysinfo()
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/stat/sysinfo');
* Get controller status
* returns true upon success (controller is online)
* NOTES: in order to get useful results (e.g. controller version) you can call get_last_results_raw()
* immediately after this method
public function stat_status()
$response = $this->exec_curl('/status');
* List self
* returns an array of information about the logged in user
public function list_self()
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/self');
* List vouchers
* returns an array of hotspot voucher objects
* optional parameter <create_time> = Unix timestamp in seconds
public function stat_voucher($create_time = null)
return false;
$payload = (trim($create_time) != null) ? ['create_time' => intval($create_time)] : [];
$response = $this->exec_curl('/api/s/' . $this->site . '/stat/voucher', $payload);
* List payments
* returns an array of hotspot payments
* optional parameter <within> = number of hours to go back to fetch payments
public function stat_payment($within = null)
return false;
$url_suffix = (($within != null) ? '?within=' . intval($within) : '');
$response = $this->exec_curl('/api/s/' . $this->site . '/stat/payment' . $url_suffix);
* Create hotspot operator (using REST)
* return true upon success
* required parameter <name> = name for the hotspot operator
* required parameter <x_password> = clear text password for the hotspot operator
* optional parameter <note> = note to attach to the hotspot operator
public function create_hotspotop($name, $x_password, $note = null)
return false;
$payload = ['name' => $name, 'x_password' => $x_password];
if (isset($note)) {
$payload['note'] = trim($note);
$response = $this->exec_curl('/api/s/' . $this->site . '/rest/hotspotop', $payload);
* List hotspot operators (using REST)
* returns an array of hotspot operators
public function list_hotspotop()
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/rest/hotspotop');
* Create voucher(s)
* returns an array containing a single object which contains the create_time(stamp) of the voucher(s) created
* required parameter <minutes> = minutes the voucher is valid after activation (expiration time)
* optional parameter <count> = number of vouchers to create, default value is 1
* optional parameter <quota> = single-use or multi-use vouchers, value '0' is for multi-use, '1' is for single-use,
* 'n' is for multi-use n times
* optional parameter <note> = note text to add to voucher when printing
* NOTES: please use the stat_voucher() method/function to retrieve the newly created voucher(s) by create_time
public function create_voucher(
$minutes,
$count = 1,
$quota = 0,
$note = null,
$up = null,
$down = null,
$MBytes = null
return false;
$payload = [
'cmd' => 'create-voucher',
'expire' => intval($minutes),
'n' => intval($count),
'quota' => intval($quota)
if (isset($note)) {
if (!empty($up)) {
$response = $this->exec_curl('/api/s/' . $this->site . '/cmd/hotspot', $payload);
* Revoke voucher
* required parameter <voucher_id> = 24 char string; _id value of the voucher to revoke
public function revoke_voucher($voucher_id)
return false;
$payload = ['_id' => $voucher_id, 'cmd' => 'delete-voucher'];
* Extend guest validity
* required parameter <guest_id> = 24 char string; _id value of the guest to extend validity
public function extend_guest_validity($guest_id)
return false;
$payload = ['_id' => $guest_id, 'cmd' => 'extend'];
* List port forwarding stats
* returns an array of port forwarding stats
public function list_portforward_stats()
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/stat/portforward');
* List DPI stats
* returns an array of DPI stats
public function list_dpi_stats()
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/stat/dpi');
* List current channels
* returns an array of currently allowed channels
public function list_current_channels()
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/stat/current-channel');
* List country codes
* returns an array of available country codes
* NOTES:
* these codes following the ISO standard:
* https://en.wikipedia.org/wiki/ISO_3166-1_numeric
public function list_country_codes()
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/stat/ccode');
* List port forwarding settings
* returns an array of port forwarding settings
public function list_portforwarding()
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/list/portforward');
* List dynamic DNS settings
* returns an array of dynamic DNS settings
public function list_dynamicdns()
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/list/dynamicdns');
* List port configurations
* returns an array of port configurations
public function list_portconf()
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/list/portconf');
* List VoIP extensions
* returns an array of VoIP extensions
public function list_extension()
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/list/extension');
* List site settings
* returns an array of site configuration settings
public function list_settings()
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/get/setting');
* Adopt a device to the selected site
* required parameter <mac> = device MAC address
public function adopt_device($mac)
return false;
$payload = ['mac' => strtolower($mac), 'cmd' => 'adopt'];
$response = $this->exec_curl('/api/s/' . $this->site . '/cmd/devmgr', $payload);
* Reboot a device
* optional parameter <type> = string; two options: 'soft' or 'hard', defaults to soft
* soft can be used for all devices, requests a plain restart of that device
* hard is special for PoE switches and besides the restart also requests a
* power cycle on all PoE capable ports. Keep in mind that a 'hard' reboot
* does *NOT* trigger a factory-reset, as it somehow could suggest.
public function restart_device($mac, $type = 'soft')
return false;
$payload = ['cmd' => 'restart', 'mac' => strtolower($mac)];
if (!is_null($type) && in_array($type, ['soft', 'hard'])) {
$payload['type'] = strtolower($type);
* Disable/enable an access point (using REST)
* required parameter <ap_id> = 24 char string; value of _id for the access point which can be obtained from the device list
* required parameter <disable> = boolean; true will disable the device, false will enable the device
* NOTES:
* - a disabled device will be excluded from the dashboard status and device count and its LED and WLAN will be turned off
* - appears to only be supported for access points
* - available since controller versions 5.2.X
public function disable_ap($ap_id, $disable)
return false;
if (!is_bool($disable)) {
return false;
$payload = ['disabled' => $disable];
$response = $this->exec_curl('/api/s/' . $this->site . '/rest/device/' . trim($ap_id), $payload);
* Override LED mode for a device (using REST)
* required parameter <device_id> = 24 char string; value of _id for the device which can be obtained from the device list
* required parameter <override_mode> = string, off/on/default; "off" will disable the LED of the device,
* "on" will enable the LED of the device,
* "default" will apply the site-wide setting for device LEDs
* NOTES:
public function led_override($device_id, $override_mode)
return false;
if (!in_array($override_mode, ['off', 'on', 'default'])) {
return false;
$payload = ['led_override' => $override_mode];
$response = $this->exec_curl('/api/s/' . $this->site . '/rest/device/' . trim($device_id), $payload);
* Toggle flashing LED of an access point for locating purposes
* required parameter <enable> = boolean; true will enable flashing LED, false will disable
* NOTES:
* replaces the old set_locate_ap() and unset_locate_ap() methods/functions
public function locate_ap($mac, $enable)
return false;
if (!is_bool($enable)) {
return false;
$cmd = (($enable) ? 'set-locate' : 'unset-locate');
$payload = ['cmd' => $cmd, 'mac' => strtolower($mac)];
* Toggle LEDs of all the access points ON or OFF
* required parameter <enable> = boolean; true will switch LEDs of all the access points ON, false will switch them OFF
public function site_leds($enable)
return false;
return false;
$payload = ['led_enabled' => $enable];
$response = $this->exec_curl('/api/s/' . $this->site . '/set/setting/mgmt', $payload);
* Update access point radio settings
* required parameter <ap_id> = the "_id" value for the access point you wish to update
* required parameter <radio>(default=ng)
* required parameter <channel>
* required parameter <ht>(default=20)
* required parameter <tx_power_mode>
* required parameter <tx_power>(default=0)
* NOTES:
* - only supported on pre-5.X.X controller versions
public function set_ap_radiosettings($ap_id, $radio, $channel, $ht, $tx_power_mode, $tx_power)
return false;
$payload = [
'radio_table' => [
'radio' => $radio,
'channel' => $channel,
'ht' => $ht,
'tx_power_mode' => $tx_power_mode,
'tx_power' => $tx_power
$response = $this->exec_curl('/api/s/' . $this->site . '/upd/device/' . trim($ap_id), $payload);
* Assign access point to another WLAN group
* required parameter <wlantype_id> = string; WLAN type, can be either 'ng' (for WLANs 2G (11n/b/g)) or 'na' (WLANs 5G (11n/a/ac))
* required parameter <device_id> = string; _id value of the access point to be modified
* required parameter <wlangroup_id> = string; _id value of the WLAN group to assign device to
public function set_ap_wlangroup($wlantype_id, $device_id, $wlangroup_id)
return false;
if (!in_array($wlantype_id, ['ng', 'na'])) {
return false;
$payload = [
'wlan_overrides' => [],
'wlangroup_id_' . $wlantype_id => $wlangroup_id
$response = $this->exec_curl('/api/s/' . $this->site . '/upd/device/' . trim($device_id), $payload);
* Update guest login settings
* required parameter <portal_enabled> = boolean; enable/disable the captive portal
* required parameter <portal_customized> = boolean; enable/disable captive portal customizations
* required parameter <redirect_enabled> = boolean; enable/disable captive portal redirect
* required parameter <redirect_url> = string; url to redirect to, must include the http/https prefix, no trailing slashes
* required parameter <x_password> = string; the captive portal (simple) password
* required parameter <expire_number> = numeric; number of units for the authorization expiry
* required parameter <expire_unit> = numeric; number of minutes within a unit (a value 60 is required for hours)
* required parameter <section_id> = 24 char string; value of _id for the site settings section where key = "guest_access", settings can be obtained
* using the list_settings() function
* NOTES:
* - both portal parameters are set to the same value!
public function set_guestlogin_settings(
$portal_enabled,
$portal_customized,
$redirect_enabled,
$redirect_url,
$x_password,
$expire_number,
$expire_unit,
$section_id
return false;
$payload = [
'portal_enabled' => $portal_enabled,
'portal_customized' => $portal_customized,
'redirect_enabled' => $redirect_enabled,
'redirect_url' => $redirect_url,
'x_password' => $x_password,
'expire_number' => $expire_number,
'expire_unit' => $expire_unit,
'_id' => $section_id
$response = $this->exec_curl('/api/s/' . $this->site . '/set/setting/guest_access', $payload);
* Update guest login settings, base
* required parameter <payload> = stdClass object or associative array containing the configuration to apply to the guest login, must be a (partial)
* object/array structured in the same manner as is returned by list_settings() for the "guest_access" section.
public function set_guestlogin_settings_base($payload)
return false;
* Update IPS/IDS settings, base
* required parameter <payload> = stdClass object or associative array containing the IPS/IDS settings to apply, must be a (partial)
* object/array structured in the same manner as is returned by list_settings() for the "ips" section.
public function set_ips_settings_base($payload)
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/set/setting/ips', $payload);
* Update "Super Management" settings, base
* required parameter <settings_id> = 24 char string; value of _id for the site settings section where key = "super_mgmt", settings can be obtained
* required parameter <payload> = stdClass object or associative array containing the "Super Management" settings to apply, must be a (partial)
* object/array structured in the same manner as is returned by list_settings() for the "super_mgmt" section.
public function set_super_mgmt_settings_base($settings_id, $payload)
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/set/setting/super_mgmt/' . trim($settings_id), $payload);
* Update "Super SMTP" settings, base
* required parameter <settings_id> = 24 char string; value of _id for the site settings section where key = "super_smtp", settings can be obtained
* required parameter <payload> = stdClass object or associative array containing the "Super SMTP" settings to apply, must be a (partial)
* object/array structured in the same manner as is returned by list_settings() for the "super_smtp" section.
public function set_super_smtp_settings_base($settings_id, $payload)
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/set/setting/super_smtp/' . trim($settings_id), $payload);
* Update "Super Controller Identity" settings, base
* required parameter <settings_id> = 24 char string; value of _id for the site settings section where key = "super_identity", settings can be obtained
* required parameter <payload> = stdClass object or associative array containing the "Super Controller Identity" settings to apply, must be a (partial)
* object/array structured in the same manner as is returned by list_settings() for the "super_identity" section.
public function set_super_identity_settings_base($settings_id, $payload)
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/set/setting/super_identity/' . trim($settings_id), $payload);
* Rename access point
* required parameter <apname>
public function rename_ap($ap_id, $apname)
return false;
$payload = ['name' => $apname];
* Move a device to another site
* required parameter <mac> = string; MAC address of the device to move
* required parameter <site_id> = 24 char string; _id of the site to move the device to
public function move_device($mac, $site_id)
return false;
$payload = ['site' => $site_id, 'mac' => strtolower($mac), 'cmd' => 'move-device'];
* Delete a device from the current site
* required parameter <mac> = string; MAC address of the device to delete
public function delete_device($mac)
return false;
$payload = ['mac' => strtolower($mac), 'cmd' => 'delete-device'];
* List network settings (using REST)
* returns an array of (non-wireless) networks and their settings
* optional parameter <network_id> = string; _id value of the network to get settings for
public function list_networkconf($network_id = '')
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/rest/networkconf/' . trim($network_id));
* Create a network (using REST)
* return an array with a single object containing details of the new network on success, else return false
* object structured in the same manner as is returned by list_networkconf() for the specific network type.
public function create_network($payload)
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/rest/networkconf', $payload);
* Update network settings, base (using REST)
* required parameter <network_id> = the "_id" value for the network you wish to update
* object/array structured in the same manner as is returned by list_networkconf() for the network.
public function set_networksettings_base($network_id, $payload)
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/rest/networkconf/' . trim($network_id), $payload);
* Delete a network (using REST)
* required parameter <network_id> = 24 char string; _id value of the network which can be found with the list_networkconf() function
public function delete_network($network_id)
return false;
* List wlan settings (using REST)
* returns an array of wireless networks and their settings, or an array containing a single wireless network when using
* the <wlan_id> parameter
* optional parameter <wlan_id> = 24 char string; _id value of the wlan to fetch the settings for
public function list_wlanconf($wlan_id = null)
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/rest/wlanconf/' . trim($wlan_id));
* Create a wlan
* required parameter <name> = string; SSID
* required parameter <x_passphrase> = string; new pre-shared key, minimal length is 8 characters, maximum length is 63,
* assign a value of null when security = 'open'
* required parameter <usergroup_id> = string; user group id that can be found using the list_usergroups() function
* required parameter <wlangroup_id> = string; wlan group id that can be found using the list_wlan_groups() function
* optional parameter <enabled> = boolean; enable/disable wlan
* optional parameter <hide_ssid> = boolean; hide/unhide wlan SSID
* optional parameter <is_guest> = boolean; apply guest policies or not
* optional parameter <security> = string; security type (open, wep, wpapsk, wpaeap)
* optional parameter <wpa_mode> = string; wpa mode (wpa, wpa2, ..)
* optional parameter <wpa_enc> = string; encryption (auto, ccmp)
* optional parameter <vlan_enabled> = boolean; enable/disable vlan for this wlan
* optional parameter <vlan> = string; vlan id
* optional parameter <uapsd_enabled> = boolean; enable/disable Unscheduled Automatic Power Save Delivery
* optional parameter <schedule_enabled> = boolean; enable/disable wlan schedule
* optional parameter <schedule> = string; schedule rules
* TODO: Check parameter values
public function create_wlan(
$name,
$x_passphrase,
$usergroup_id,
$wlangroup_id,
$enabled = true,
$hide_ssid = false,
$is_guest = false,
$security = 'open',
$wpa_mode = 'wpa2',
$wpa_enc = 'ccmp',
$vlan_enabled = false,
$vlan = null,
$uapsd_enabled = false,
$schedule_enabled = false,
$schedule = []
return false;
$payload = [
'name' => $name,
'usergroup_id' => $usergroup_id,
'wlangroup_id' => $wlangroup_id,
'enabled' => $enabled,
'hide_ssid' => $hide_ssid,
'is_guest' => $is_guest,
'security' => $security,
'wpa_mode' => $wpa_mode,
'wpa_enc' => $wpa_enc,
'vlan_enabled' => $vlan_enabled,
'uapsd_enabled' => $uapsd_enabled,
'schedule_enabled' => $schedule_enabled,
'schedule' => $schedule,
if (!is_null($vlan) && $vlan_enabled) {
$payload['vlan'] = $vlan;
if (!empty($x_passphrase) && $security !== 'open') {
$payload['x_passphrase'] = $x_passphrase;
$response = $this->exec_curl('/api/s/' . $this->site . '/add/wlanconf', $payload);
* Update wlan settings, base (using REST)
* required parameter <wlan_id> = the "_id" value for the WLAN you wish to update
* required parameter <payload> = stdClass object or associative array containing the configuration to apply to the wlan, must be a
* (partial) object/array structured in the same manner as is returned by list_wlanconf() for the wlan.
public function set_wlansettings_base($wlan_id, $payload)
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/rest/wlanconf/' . trim($wlan_id), $payload);
* Update basic wlan settings
* required parameter <x_passphrase> = new pre-shared key, minimal length is 8 characters, maximum length is 63,
* will be ignored if set to null
public function set_wlansettings($wlan_id, $x_passphrase, $name = null)
$payload = [];
if (!is_null($x_passphrase)) {
$payload['x_passphrase'] = trim($x_passphrase);
$payload['name'] = trim($name);
return $this->set_wlansettings_base($wlan_id, $payload);
* Disable/Enable wlan
* required parameter <disable> = boolean; true disables the wlan, false enables it
public function disable_wlan($wlan_id, $disable)
return false;
$action = $disable ? false : true;
$payload = ['enabled' => $action];
* Delete a wlan (using REST)
* required parameter <wlan_id> = 24 char string; _id of the wlan which can be found with the list_wlanconf() function
public function delete_wlan($wlan_id)
return false;
* Update MAC filter for a wlan
* required parameter <mac_filter_policy> = string, "allow" or "deny"; default MAC policy to apply
* required parameter <mac_filter_enabled> = boolean; true enables the policy, false disables it
* required parameter <macs> = array; must contain valid MAC strings to be placed in the MAC filter list,
* replacing existing values. Existing MAC filter list can be obtained
* through list_wlanconf().
public function set_wlan_mac_filter($wlan_id, $mac_filter_policy, $mac_filter_enabled, array $macs)
if (!is_bool($mac_filter_enabled)) {
return false;
if (!in_array($mac_filter_policy, ['allow', 'deny'])) {
return false;
$payload = [
'mac_filter_enabled' => (bool) $mac_filter_enabled,
'mac_filter_policy' => $mac_filter_policy,
'mac_filter_list' => $macs
* List events
* returns an array of known events
* optional parameter <historyhours> = hours to go back, default value is 720 hours
* optional parameter <start> = which event number to start with (useful for paging of results), default value is 0
* optional parameter <limit> = number of events to return, default value is 3000
public function list_events($historyhours = 720, $start = 0, $limit = 3000)
return false;
$payload = [
'_sort' => '-time',
'within' => intval($historyhours),
'type' => null,
'_start' => intval($start),
'_limit' => intval($limit)
$response = $this->exec_curl('/api/s/' . $this->site . '/stat/event', $payload);
* List alarms
* returns an array of known alarms
public function list_alarms()
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/list/alarm');
* Count alarms
* returns an array containing the alarm count
* optional parameter <archived> = boolean; if true all alarms will be counted, if false only non-archived (active) alarms will be counted
public function count_alarms($archived = null)
return false;
$url_suffix = ($archived === false) ? '?archived=false' : null;
$response = $this->exec_curl('/api/s/' . $this->site . '/cnt/alarm' . $url_suffix);
* Archive alarms(s)
* optional parameter <alarm_id> = 24 char string; _id of the alarm to archive which can be found with the list_alarms() function,
* if not provided, *all* un-archived alarms for the current site will be archived!
public function archive_alarm($alarm_id = null)
return false;
$payload = ['cmd' => 'archive-all-alarms'];
if (!is_null($alarm_id)) {
$payload = ['_id' => $alarm_id, 'cmd' => 'archive-alarm'];
$response = $this->exec_curl('/api/s/' . $this->site . '/cmd/evtmgr', $payload);
* Upgrade a device to the latest firmware
* required parameter <device_mac> = MAC address of the device to upgrade
* NOTES:
* - updates the device to the latest firmware known to the controller
public function upgrade_device($device_mac)
return false;
$payload = ['mac' => strtolower($device_mac)];
$response = $this->exec_curl('/api/s/' . $this->site . '/cmd/devmgr/upgrade', $payload);
* Upgrade a device to a specific firmware file
* required parameter <firmware_url> = URL for the firmware file to upgrade the device to
* NOTES:
* - updates the device to the firmware file at the given URL
* - please take great care to select a valid firmware file for the device!
public function upgrade_device_external($firmware_url, $device_mac)
return false;
$payload = ['url' => filter_var($firmware_url, FILTER_SANITIZE_URL), 'mac' => strtolower($device_mac)];
$response = $this->exec_curl('/api/s/' . $this->site . '/cmd/devmgr/upgrade-external', $payload);
* Start rolling upgrade
* NOTES:
* - updates all access points to the latest firmware known to the controller in a
* staggered/rolling fashion
public function start_rolling_upgrade()
return false;
$payload = ['cmd' => 'set-rollupgrade'];
* Cancel rolling upgrade
public function cancel_rolling_upgrade()
return false;
$payload = ['cmd' => 'unset-rollupgrade'];
* Power-cycle the PoE output of a switch port
* required parameter <switch_mac> = string; main MAC address of the switch
* required parameter <port_idx> = integer; port number/index of the port to be affected
* NOTES:
* - only applies to switches and their PoE ports...
* - port must be actually providing power
public function power_cycle_switch_port($switch_mac, $port_idx)
return false;
$payload = ['mac' => strtolower($switch_mac), 'port_idx' => intval($port_idx), 'cmd' => 'power-cycle'];
* Trigger an RF scan by an AP
* required parameter <ap_mac> = MAC address of the AP
public function spectrum_scan($ap_mac)
return false;
$payload = ['cmd' => 'spectrum-scan', 'mac' => strtolower($ap_mac)];
* Check the RF scanning state of an AP
* returns an object with relevant information (results if available) regarding the RF scanning state of the AP
public function spectrum_scan_state($ap_mac)
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/stat/spectrum-scan/' . strtolower(trim($ap_mac)));
* Update device settings, base (using REST)
* required parameter <device_id> = 24 char string; _id of the device which can be found with the list_devices() function
* required parameter <payload> = stdClass object or associative array containing the configuration to apply to the device, must be a
* (partial) object/array structured in the same manner as is returned by list_devices() for the device.
public function set_device_settings_base($device_id, $payload)
return false;
* List Radius profiles (using REST)
* returns an array of objects containing all Radius profiles for the current site
* NOTES:
* - this function/method is only supported on controller versions 5.5.19 and later
public function list_radius_profiles()
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/rest/radiusprofile');
* List Radius user accounts (using REST)
* returns an array of objects containing all Radius accounts for the current site
* NOTES:
public function list_radius_accounts()
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/rest/account');
* Create a Radius user account (using REST)
* returns an array containing a single object for the newly created account upon success, else returns false
* required parameter <name> = string; name for the new account
* required parameter <x_password> = string; password for the new account
* required parameter <tunnel_type> = integer; must be one of the following values:
* 1 Point-to-Point Tunneling Protocol (PPTP)
* 2 Layer Two Forwarding (L2F)
* 3 Layer Two Tunneling Protocol (L2TP)
* 4 Ascend Tunnel Management Protocol (ATMP)
* 5 Virtual Tunneling Protocol (VTP)
* 6 IP Authentication Header in the Tunnel-mode (AH)
* 7 IP-in-IP Encapsulation (IP-IP)
* 8 Minimal IP-in-IP Encapsulation (MIN-IP-IP)
* 9 IP Encapsulating Security Payload in the Tunnel-mode (ESP)
* 10 Generic Route Encapsulation (GRE)
* 11 Bay Dial Virtual Services (DVS)
* 12 IP-in-IP Tunneling
* 13 Virtual LANs (VLAN)
* required parameter <tunnel_medium_type> = integer; must be one of the following values:
* 1 IPv4 (IP version 4)
* 2 IPv6 (IP version 6)
* 3 NSAP
* 4 HDLC (8-bit multidrop)
* 5 BBN 1822
* 6 802 (includes all 802 media plus Ethernet "canonical format")
* 7 E.163 (POTS)
* 8 E.164 (SMDS, Frame Relay, ATM)
* 9 F.69 (Telex)
* 10 X.121 (X.25, Frame Relay)
* 11 IPX
* 12 Appletalk
* 13 Decnet IV
* 14 Banyan Vines
* 15 E.164 with NSAP format subaddress
* optional parameter <vlan> = integer; VLAN to assign to the account
* NOTES:
public function create_radius_account($name, $x_password, $tunnel_type, $tunnel_medium_type, $vlan = null)
return false;
$tunnel_types = [1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13];
$tunnel_medium_types = [1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15];
if (!in_array($tunnel_type, $tunnel_types) || !in_array($tunnel_medium_type, $tunnel_medium_types)) {
return false;
$payload = [
'name' => $name,
'tunnel_type' => (int) $tunnel_type,
'tunnel_medium_type' => (int) $tunnel_medium_type
if (isset($vlan)) {
$payload['vlan'] = (int) $vlan;
$response = $this->exec_curl('/api/s/' . $this->site . '/rest/account', $payload);
* Update Radius account, base (using REST)
* required parameter <account_id> = 24 char string; _id of the account which can be found with the list_radius_accounts() function
* required parameter <payload> = stdClass object or associative array containing the new profile to apply to the account, must be a (partial)
* object/array structured in the same manner as is returned by list_radius_accounts() for the account.
* NOTES:
public function set_radius_account_base($account_id, $payload)
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/rest/account/' . trim($account_id), $payload);
* Delete a Radius account (using REST)
* NOTES:
public function delete_radius_account($account_id)
return false;
$response = $this->exec_curl('/api/s/' . $this->site . '/rest/account/' . trim($account_id));
* Execute specific command
* required parameter <command> = string; command to execute, known valid values
* 'reset-dpi': reset all DPI counters for the current site
* NOTE:
* the provided <command> parameter isn't validated so make sure you're using a correct value
public function cmd_stat($command)
return false;
$payload = ['cmd' => trim($command)];
$response = $this->exec_curl('/api/s/' . $this->site . '/cmd/stat', $payload);
* "Aliases" for deprecated functions from here, to support
* backward compatibility:
* NOTE:
* changed function/method name to fit it's purpose
public function list_aps($device_mac = null)
trigger_error(
'Function list_aps() has been deprecated, use list_devices() instead.',
E_USER_DEPRECATED
return $this->list_devices($device_mac);
* Start flashing LED of an access point for locating purposes
public function set_locate_ap($mac)
trigger_error(
'Function set_locate_ap() has been deprecated, use locate_ap() instead.',
E_USER_DEPRECATED
return $this->locate_ap($mac, true);
* Stop flashing LED of an access point for locating purposes
public function unset_locate_ap($mac)
trigger_error(
'Function unset_locate_ap() has been deprecated, use locate_ap() instead.',
E_USER_DEPRECATED
return $this->locate_ap($mac, false);
* Switch LEDs of all the access points ON
public function site_ledson()
trigger_error(
'Function site_ledson() has been deprecated, use site_leds() instead.',
E_USER_DEPRECATED
return $this->site_leds(true);
* Switch LEDs of all the access points OFF
public function site_ledsoff()
trigger_error(
'Function site_ledsoff() has been deprecated, use site_leds() instead.',
E_USER_DEPRECATED
return $this->site_leds(false);
* Reboot an access point
* return true on success
public function restart_ap($mac)
trigger_error(
'Function restart_ap() has been deprecated, use restart_device() instead.',
E_USER_DEPRECATED
return $this->restart_device($mac);
* Custom API request
* returns results as requested, returns false on incorrect parameters
* required parameter <path> = string; suffix of the URL (following the port number) to pass request to, *must* start with a "/" character
* optional parameter <request_type> = string; HTTP request type, can be GET (default), POST, PUT, or DELETE
* optional parameter <payload> = stdClass object or associative array containing the payload to pass
* optional parameter <return> = string; determines how to return results, value must be "boolean" when the method must return a
* boolean result (true/false) or "array" when the method must return data as an array
* NOTE:
* Only use this method when you fully understand the behavior of the UniFi controller API. No input validation is performed, to be used with care!
public function custom_api_request($path, $request_type = 'GET', $payload = null, $return = 'array')
if (!$this->is_loggedin) {
return false;
$this->request_type = $request_type;
$response = $this->exec_curl($path, $payload);
if ($return === 'array') {
} elseif ($return === 'boolean') {
return $this->process_response_boolean($response);
return false;
* setter/getter functions from here:
* Set site
* modify the private property site, returns the new (short) site name
* required parameter <site> = string; must be the short site name of a site to which the
* provided credentials have access
* NOTE:
* this method can be useful when switching between sites
public function set_site($site)
$this->check_site($site);
$this->site = trim($site);
return $this->site;
* Get site
* get the value of private property site, returns the current (short) site name
public function get_site()
return $this->site;
* Set debug mode
* sets debug mode to true or false, returns false if a non-boolean parameter was passed
* required parameter <enable> = boolean; true will enable debug mode, false will disable it
public function set_debug($enable)
if ($enable === true || $enable === false) {
$this->debug = $enable;
return true;
trigger_error('Error: the parameter for set_debug() must be boolean');
return false;
* Get debug mode
* get the value of private property debug, returns the current boolean value for debug
public function get_debug()
return $this->debug;
* Get last raw results
* returns the raw results of the last method called, returns false if unavailable
* optional parameter <return_json> = boolean; true will return the results in "pretty printed" json format,
* PHP stdClass Object format is returned by default
public function get_last_results_raw($return_json = false)
if ($this->last_results_raw !== null) {
if ($return_json) {
return json_encode($this->last_results_raw, JSON_PRETTY_PRINT);
return $this->last_results_raw;
return false;
* Get last error message
* returns the error message of the last method called in PHP stdClass Object format, returns false if unavailable
public function get_last_error_message()
if ($this->last_error_message !== null) {
return $this->last_error_message;
return false;
* Get Cookie from UniFi Controller
* returns the UniFi controller cookie
* NOTES:
* - when the results from this method are stored in $_SESSION['unificookie'], the class will initially not
* log in to the controller when a subsequent request is made using a new instance. This speeds up the
* overall request considerably. If that subsequent request fails (e.g. cookies have expired), a new login
* is executed automatically and the value of $_SESSION['unificookie'] is updated.
public function get_cookie()
return false;
return $this->cookies;
* other getter/setter functions/methods from here, use with care!
public function get_cookies()
public function get_request_type()
return $this->request_type;
public function get_ssl_verify_peer()
return $this->curl_ssl_verify_peer;
public function get_ssl_verify_host()
return $this->curl_ssl_verify_host;
public function set_cookies($cookies_value)
$this->cookies = $cookies_value;
public function set_request_type($request_type)
public function set_connection_timeout($timeout)
$this->connect_timeout = $timeout;
public function set_last_results_raw($last_results)
$this->last_results_raw = $last_results;
public function set_last_error_message($last_error_message)
$this->last_error_message = $last_error_message;
public function set_ssl_verify_peer($ssl_verify_peer)
$this->curl_ssl_verify_peer = $ssl_verify_peer;
* set the value for cURL option CURLOPT_SSL_VERIFYHOST, should be 0/false or 2
public function set_ssl_verify_host($ssl_verify_host)
$this->curl_ssl_verify_host = $ssl_verify_host;
* internal (private and protected) functions from here:
* Process regular responses where output is the content of the data array
protected function process_response($response_json)
$response = json_decode($response_json);
$this->catch_json_last_error();
$this->last_results_raw = $response;
if (isset($response->meta->rc)) {
if ($response->meta->rc === 'ok') {
$this->last_error_message = null;
if (is_array($response->data)) {
return $response->data;
return true;
} elseif ($response->meta->rc === 'error') {
* we have an error:
* set $this->set last_error_message if the returned error message is available
if (isset($response->meta->msg)) {
$this->last_error_message = $response->meta->msg;
if ($this->debug) {
trigger_error('Debug: Last error message: ' . $this->last_error_message);
return false;
* Process responses where output should be boolean (true/false)
protected function process_response_boolean($response_json)
return true;
* we have an error:
* set $this->last_error_message if the returned error message is available
if ($this->debug) {
return false;
* Capture the latest JSON error when $this->debug is true
private function catch_json_last_error()
if ($this->debug) {
switch (json_last_error()) {
case JSON_ERROR_NONE:
// JSON is valid, no error has occurred
$error = '';
break;
case JSON_ERROR_DEPTH:
$error = 'The maximum stack depth has been exceeded';
break;
case JSON_ERROR_STATE_MISMATCH:
$error = 'Invalid or malformed JSON.';
break;
case JSON_ERROR_CTRL_CHAR:
$error = 'Control character error, possibly incorrectly encoded';
break;
case JSON_ERROR_SYNTAX:
$error = 'Syntax error, malformed JSON.';
break;
case JSON_ERROR_UTF8:
// PHP >= 5.3.3
$error = 'Malformed UTF-8 characters, possibly incorrectly encoded';
break;
case JSON_ERROR_RECURSION:
// PHP >= 5.5.0
$error = 'One or more recursive references in the value to be encoded';
break;
case JSON_ERROR_INF_OR_NAN:
// PHP >= 5.5.0
$error = 'One or more NAN or INF values in the value to be encoded';
break;
case JSON_ERROR_UNSUPPORTED_TYPE:
$error = 'A value of a type that cannot be encoded was given';
break;
case JSON_ERROR_INVALID_PROPERTY_NAME:
// PHP >= 7.0.0
$error = 'A property name that cannot be encoded was given';
break;
case JSON_ERROR_UTF16:
// PHP >= 7.0.0
$error = 'Malformed UTF-16 characters, possibly incorrectly encoded';
break;
default:
// we have an unknown error
$error = 'Unknown JSON error occured.';
break;
if ($error !== '') {
trigger_error('JSON decode error: ' . $error);
return false;
return true;
* Check the submitted base URL
private function check_base_url()
$url_valid = filter_var($this->baseurl, FILTER_VALIDATE_URL);
if (!$url_valid) {
trigger_error('The URL provided is incomplete or invalid!');
return false;
$base_url_components = parse_url($this->baseurl);
if (empty($base_url_components['port'])) {
trigger_error('The URL provided does not have a port suffix, normally this is :8443');
return false;
return true;
* Check the (short) site name
private function check_site($site)
if ($this->debug && strlen($site) !== 8 && $site !== 'default') {
error_log('The provided (short) site name is probably incorrect');
* Update the unificookie
private function update_unificookie()
if (isset($_SESSION['unificookie'])) {
$this->cookies = $_SESSION['unificookie'];
* Execute the cURL request
protected function exec_curl($path, $payload = '')
if (!is_resource($ch = $this->get_curl_resource())) {
trigger_error('$ch as returned by get_curl_resource() is not a resource');
} else {
$json_payload = '';
$url = $this->baseurl . $path;
curl_setopt($ch, CURLOPT_URL, $url);
if (!empty($payload)) {
$json_payload = json_encode($payload, JSON_UNESCAPED_SLASHES);
curl_setopt($ch, CURLOPT_POSTFIELDS, $json_payload);
if ($this->request_type === 'PUT') {
curl_setopt($ch, CURLOPT_HTTPHEADER,
['Content-Type: application/json', 'Content-Length: ' . strlen($json_payload)]);
curl_setopt($ch, CURLOPT_CUSTOMREQUEST, 'PUT');
} else {
curl_setopt($ch, CURLOPT_HTTPHEADER, ['Content-Type: application/json']);
} else {
curl_setopt($ch, CURLOPT_POST, false);
if ($this->request_type === 'DELETE') {
curl_setopt($ch, CURLOPT_CUSTOMREQUEST, 'DELETE');
* execute the cURL request
$content = curl_exec($ch);
if (curl_errno($ch)) {
trigger_error('cURL error: ' . curl_error($ch));
* has the session timed out? If so, we need to login again.
$http_code = curl_getinfo($ch, CURLINFO_HTTP_CODE);
if ($http_code == 401) {
$json_decoded_content = json_decode($content, true);
if (isset($json_decoded_content['meta']['msg']) && $json_decoded_content['meta']['msg'] === 'api.err.LoginRequired') {
if ($this->debug) {
error_log('cURL debug: Needed to reconnect to UniFi Controller');
* explicitly unset the old cookie now
unset($_SESSION['unificookie']);
* then login again
$this->login();
* when login was successful, execute the same command again
if ($this->is_loggedin) {
curl_close($ch);
* setup the cookie for the user within $_SESSION, if $_SESSION['unificookie'] does not exist
if (!isset($_SESSION['unificookie']) && session_status() != PHP_SESSION_DISABLED) {
$_SESSION['unificookie'] = $this->cookies;
return $this->exec_curl($path, $payload);
unset($json_decoded_content);
if ($this->debug) {
print PHP_EOL . '<pre>';
print PHP_EOL . '---------cURL INFO-----------' . PHP_EOL;
print_r(curl_getinfo($ch));
print PHP_EOL . '-------URL & PAYLOAD---------' . PHP_EOL;
print $url . PHP_EOL;
if (empty($json_payload)) {
print 'empty payload';
} else {
print $json_payload;
print PHP_EOL . '----------RESPONSE-----------' . PHP_EOL;
print $content;
print PHP_EOL . '-----------------------------' . PHP_EOL;
print '</pre>' . PHP_EOL;
curl_close($ch);
* set request_type value back to default, just in case
$this->request_type = 'POST';
return $content;
return false;
* Create a new cURL resource and return a cURL handle,
* returns false on errors
protected function get_curl_resource()
$ch = curl_init();
curl_setopt($ch, CURLOPT_POST, true);
curl_setopt($ch, CURLOPT_SSL_VERIFYPEER, $this->curl_ssl_verify_peer);
curl_setopt($ch, CURLOPT_SSL_VERIFYHOST, $this->curl_ssl_verify_host);
curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
curl_setopt($ch, CURLOPT_CONNECTTIMEOUT, $this->connect_timeout);
curl_setopt($ch, CURLINFO_HEADER_OUT, true);
if ($this->debug) {
curl_setopt($ch, CURLOPT_VERBOSE, true);
if ($this->cookies != '') {
curl_setopt($ch, CURLOPT_COOKIESESSION, true);
curl_setopt($ch, CURLOPT_COOKIE, $this->cookies);
return $ch;
Config-Skript anlegen und GROSSBUCHSTBEN anpassen:
* Copyright (c) 2017, Art of WiFi
* This file is subject to the MIT license that is bundled
* with this package in the file LICENSE.md
* Controller configuration
* Copy this file to your working directory, rename it to config.php and update the section below with your UniFi
* controller details and credentials
$controlleruser = 'USERNAME UNIFI-CONTROLLER'; // the user name for access to the UniFi Controller
$controllerpassword = 'PASSWORD UNIFI-CONTROLLER'; // the password for access to the UniFi Controller
$controllerurl = 'URL UNIFI-CONTROLLER'; // full url to the UniFi Controller, eg. 'https://22.22.11.11:8443'
$controllerversion = 'VERSION UNIFI-CONTROLLER'; // the version of the Controller software, eg. '4.6.6' (must be at least 4.0.0)
* set to true (without quotes) to enable debug output to the browser and the PHP error log
$debug = false;
Steuerungsskripte anlegen - Beispiele gibt es unter GitHub (vgl. URL in meinem Vor-Post), z.B.:
Steuerungsskript (User-List) - GROSSBUCHSTABEN anzupassen; die Liste wird in einem Array ausgegeben:
* PHP API usage example
* contributed by: @gahujipo
* description: example to pull connected users and their details from the UniFi controller and output the results
* in JSON format
* include class
require_once('PFAD ZU CLASS-SKRIPT, Z.B. /var/lib/symcon/scripts/SKRIPT-ID.ips.php');
* include the config file (place your credentials etc there if not already present)
* see the config.template.php file for an example
require_once('PFAD ZU CONFIG-SKRIPT, Z.B. /var/lib/symcon/scripts/SKRIPT-ID.ips.php');
* the short name of the site which you wish to query
$site_id = 'default';
* initialize the UniFi API connection class and log in to the controller and pull the requested data
$unifi_connection = new UniFi_API\Client($controlleruser, $controllerpassword, $controllerurl, $site_id, $controllerversion);
$set_debug_mode = $unifi_connection->set_debug($debug);
$loginresults = $unifi_connection->login();
* command
$clients_array = $unifi_connection->list_clients();
print_r($clients_array);
* output the results in JSON format
* header('Content-Type: application/json; charset=utf-8');
* echo json_encode($clients_array);
Steuerungsskript WLan an-/ausschalten (hier habe ich vorher für jedes WLan eine Bool (ID-Bool) angelegt, um schalten zu können, das Steuerungsskript wird jeweils getriggert auf Änderung der Bools (ID-EVENT) - GROSSBUCHSTBEN sind wieder anzupassen):
* in JSON format
* include class
* command
if ($_IPS['EVENT'] ==ID-EVENT1)
$wlan_id="WLAN-ID1 AUS CONTROLLER";
if (GetValue(ID-BOOL1))
$enable_result = $unifi_connection->disable_wlan($wlan_id, false);
$wlan_array = $unifi_connection->list_wlanconf();
$status=$wlan_array[1]->enabled;
if ($status=="1")
SetValue(ID-BOOL1, true);
else
SetValue(ID-BOOL1, false);
else
$disable_result = $unifi_connection->disable_wlan($wlan_id, true);
if ($status=="1")
else
if ($_IPS['EVENT'] ==ID-EVENT2)
$wlan_id="WLAN-ID2 AUS CONTROLLER";
if (GetValue(ID-BOOL2))
if ($status=="1")
SetValue(ID-BOOL2, true);
else
SetValue(ID-BOOL2, false);
else
if ($status=="1")
else
Usw…
Hoffe, das hilft dem einen oder anderen.
Viele Grüße und schöne Ostern…!
