Ich habe das jetzt nochmal probiert.
Im Debug kommt folgendes:
13.03.2023, 09:48:25 | mapExposesToVariables:: All Exposes | [{"type":"binary","name":"smoke","property":"smoke","access":5,"value_on":true,"value_off":false,"description":"Indicates whether the device detected smoke"},{"type":"numeric","name":"smoke_density","property":"smoke_density","access":5,"description":"Value of smoke concentration"},{"type":"numeric","name":"smoke_density_dbm","property":"smoke_density_dbm","access":1,"unit":"dB\/m","description":"Value of smoke concentration in dB\/m"},{"type":"enum","name":"selftest","property":"selftest","access":2,"values":["Test"],"description":"Starts the self-test process (checking the indicator light and buzzer work properly)"},{"type":"binary","name":"test","property":"test","access":1,"value_on":true,"value_off":false,"description":"Self-test in progress"},{"type":"enum","name":"mute_buzzer","property":"mute_buzzer","access":2,"values":["Mute"],"description":"Mute the buzzer for 80 seconds (buzzer cannot be pre-muted, because this function only works when the alarm is triggered)"},{"type":"binary","name":"mute","property":"mute","access":5,"value_on":true,"value_off":false,"description":"Buzzer muted"},{"type":"binary","name":"heartbeat_indicator","property":"heartbeat_indicator","access":7,"value_on":true,"value_off":false,"description":"When this option is enabled then in the normal monitoring state, the green indicator light flashes every 60 seconds"},{"type":"binary","name":"linkage_alarm","property":"linkage_alarm","access":7,"value_on":true,"value_off":false,"description":"When this option is enabled and a smoke is detected, other detectors with this option enabled will also sound the alarm buzzer"},{"type":"numeric","name":"device_temperature","property":"device_temperature","access":1,"unit":"\u00b0C","description":"Temperature of the device"},{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %","value_min":0,"value_max":100},{"type":"numeric","name":"voltage","property":"voltage","access":1,"unit":"mV","description":"Voltage of the battery in millivolts"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}]
13.03.2023, 09:48:25 | mapExposesToVariables:: Missed Exposes | {"light":[],"switch":[],"climate":[],"lock":[],"0":{"type":"enum","name":"mute_buzzer","property":"mute_buzzer","access":2,"values":["Mute"],"description":"Mute the buzzer for 80 seconds (buzzer cannot be pre-muted, because this function only works when the alarm is triggered)"},"1":{"type":"binary","name":"mute","property":"mute","access":5,"value_on":true,"value_off":false,"description":"Buzzer muted"}}
Auch ein löschen der Variablen brachte keine Änderung, die Variable wird nicht angelegt. Was mach ich falsch bzw. was kann ich ändern?
Stephan
