[Modul] Zigbee2MQTT
hier noch vom systemctl status
● zigbee2mqtt70.service - Zigbee2MQTT service for zigbeeGateway70
     Loaded: loaded (/etc/systemd/system/zigbee2mqtt70.service; enabled; preset: enabled)
     Active: active (running) since Sun 2024-11-17 15:29:06 CET; 38s ago
   Main PID: 4072 (npm start -c /o)
      Tasks: 23 (limit: 4611)
     Memory: 124.1M (peak: 146.7M)
        CPU: 1.702s
     CGroup: /system.slice/zigbee2mqtt70.service
             ├─4072 "npm start -c /opt/zigbee2mqtt70/data/configuration.yaml"
             ├─4083 sh -c "node index.js -c /opt/zigbee2mqtt70/data/configuration.yaml"
             └─4084 node index.js -c /opt/zigbee2mqtt70/data/configuration.yaml
Nov 17 15:29:09 zigbee npm[4084]: [2024-11-17 15:29:09] info:         z2m: 0xa4c138e782e349e9 (0xa4c138e782e349e9): ZMS-102 - Tuya Motion sensor (EndDevice)
Nov 17 15:29:09 zigbee npm[4084]: [2024-11-17 15:29:09] info:         z2m: 0x0ceff6fffe16399b presence bikehouse (0x0ceff6fffe16399b): SNZB-06P - SONOFF Zigbee occupancy sensor (Router)
Nov 17 15:29:09 zigbee npm[4084]: [2024-11-17 15:29:09] info:         z2m: Zigbee: disabling joining new devices.
Nov 17 15:29:09 zigbee npm[4084]: [2024-11-17 15:29:09] info:         z2m: Connecting to MQTT server at mqtt://10.10.20.11:1870
Nov 17 15:29:09 zigbee npm[4084]: [2024-11-17 15:29:09] info:         z2m: Connected to MQTT server
Nov 17 15:29:09 zigbee npm[4084]: [2024-11-17 15:29:09] info:         z2m:mqtt: MQTT publish: topic 'zigbee2mqtt70/bridge/state', payload '{"state":"online"}'
Nov 17 15:29:09 zigbee npm[4084]: [2024-11-17 15:29:09] info:         z2m: Started frontend on port 10070
Nov 17 15:29:09 zigbee npm[4084]: [2024-11-17 15:29:09] info:         z2m:mqtt: MQTT publish: topic 'zigbee2mqtt70/0xa4c138e782e349e9', payload '{"battery":100,"battery_low":false,"keep_time":60,"linkquali>
Nov 17 15:29:09 zigbee npm[4084]: [2024-11-17 15:29:09] info:         z2m:mqtt: MQTT publish: topic 'zigbee2mqtt70/0x0ceff6fffe16399b presence bikehouse', payload '{"illumination":"bright","linkquality":25>
Nov 17 15:29:09 zigbee npm[4084]: [2024-11-17 15:29:09] info:         z2m: Zigbee2MQTT started!
sowas ist mir passiert, wenn der MQTT Base Topic zwischen Z2M und IPS nicht gleich war. Diesmal habe ich es 500x kontrolliert, es scheint an was anderem zu liegen.
Hast du gemäß Anleitung die Erweiterung installiert? Aktuelle Beta vom Modul installiert?
Alternativ die Bridge Instanz in Symcon erstellen und damit die Erweiterung installieren.
ahhh, muss man die Extension für jeden Koordinator getrennt installieren? Ich vergesse es immer wieder, bald brauche ich wohl das (erst letzte Wohe zugelassene) Lecanemab… :slight_smile:
Für Z2M Installationen braucht eine.
Keine Ahnung warum du fünf Stück installiert hast. :laughing:
ahhh, danke, jetzt gehts!!!
(Ich habe 5 SMlights, ich habe je eine Instanz von z2m auf einer Linux-VM laufen. Ich wollte keine Mesh, ich dachte es sei sauberer, 5 getrennte Zigbee-Netzwerke zu haben. Es ist ein grosses Haus mit viel Umschwung.
Bist Du Dir sicher, dass es die aktuelle .js ist (4.4.5)?
Kann man am besten ermitteln, wenn eine Bridge installiert wurde. Wurde weiter oben schon erwähnt. Aber gerne nochmal: Die Bridge hat dank @Nall-chan einige Funktionen, die Einem das Leben erleichtern.
Wobei der Fehler woanders liegen dürfte. Das scheint mir ein Zigbee2MQTT-Fehler zu sein. Kannst Du mal in der configuration.yaml schauen, welche Werte da für das Leuchtmittel drin stehen (suche in der configuration.yaml nach dem friendly_name des Leuchtmittels). Lösche bitte mal alles zur Device raus, ausser die IEEE-Adresse und den friendly name.
Dann zigbee2MQTT neu starten und schauen, ob es geht.
Welche Zigbee2MQTT-Version läuft bei Dir?
Burkhard
10 Beiträge wurden in ein existierendes Thema verschoben: Zigbee2mqtt
da ich bisher nichts anderes im Topic gefunden habe, wollte ich nochmal kurz nachfragen:
Gibt es außer RequestAction($HelligkeitID, $WertHelligkeit) noch eine eine „smoothere“ Möglichkeit, eine HUE Lampe zu dimmen? Ich dimme über einen KNX-Taster und dieser wirft mir bei langem drücken hintereinander -7 für abdimmen und +7 für hochdimmen aus. Ich kann zwar mit jedem ausgeworfenen Wert die Helligkeit um zB ±3% rauf oder runterdimmen, das sieht allerdings nicht sehr elegant aus, da das Dimmen dann stufenweise erfolgt. Stufenloses Dimmen wäre natürlich schöner, ich weiß aber (bisher) nicht, ob das auch möglich ist.
LG Marc
vielleicht nur feste Stufen definieren und dann mit der transition time arbeiten. Ich schalte meine Lampen (fast) nie an/aus sondern benutze immer Helligkeit 20% oder 0 mit transition time von 2 Sekunden. So dimmt die Lampe so smooth wie sie kann.
Ralf
Hi Ralf,
hat geklappt, funktioniert hervorragend.
Hab aber keine festen Dimmstufen eingestellt, sondern dimme den aktuellen Helligkeitswert weiterhin schrittweise hoch. Aber die transition macht es schön „smoothy“
Es dimmt nun genau nach meinem Geschmack :wink:
Danke für den Tipp.
Marc
ich habe einen IKEA Somrig-Button bei dem das „action“-expose fehlt.
dump.txt (11,7 KB)
Vielen Dank für alles
Frank
Moin moin,
ich habe seit heute ein Bosch Raumthermostat II. In Zigbee2mqtt passt es, vermutlich gibt es in IPS noch keine Exposé dafür.
Wäre cool wenn ihr das integrieren würdet.
Danke und Gruß Michael
dump.txt.txt (31,3 KB)
Und wenn ja, und sie noch immer fehlen, das Debug gemäß Anleitung erstellen.
Hallo Michael,
gem. Bridge habe ich die V4.4.5, sollte somit aktuell sein. Anbei dann das Dump von „Geräteinfo abrufen“. Auch wird es nicht im Konfigurator angezeigt.
Gruß Michael
dump.txt (6,5 KB)
Das ist die Version der Extension und war nicht meine Frage.
Also entweder werden alle Geräte im Konfigurator angezeigt oder gar keins (weil z.b. die Erweiterung mehrfach oder gar nicht installiert ist).
Das ein einzelnes Geräte im Konfigurator fehlt kann eigentlich nicht sein.
Da in deinem Debug aber die Antwort der Extension komplett fehlt, gehe ich davon aus, dass du mehrere Symcon Extension in Z2M hast.
Lösch die mal raus.
danke und nun prima. Habe eine Extension gelöscht und schon funktioniert alles. Hatte länger nix neues installiert. Die Geräte sind im Configurator, und auch das Bosch ist dabei.
Im Modul (Beta) steht V4.4.
Danke dir und noch einen schönen Abend.
Gruß Michael
Es wäre auch sehr seltsam gewesen, den Burki24 hat ja extra dafür geworben. :face_with_hand_over_mouth:
Hi Burkhard,
welche Zigbee Schaltsteckdosen (inkl. Repeaterfunktion :wink: ) kannst Du empfehlen ?
Seit dem Einsatz des zweiten Aeotec Range Extender Zi Zigbee Repeater ist hier nix mehr hübsch.
Mit dem Ersten war noch alles schick - aber jetzt … isses seltsam.
LG Tom
Einfach ein paar Beiträge hochscrollen
https://community.symcon.de/t/modul-zigbee2mqtt/49507/3781?u=boui
