@Burki24
Hallo Burkhard,
ich habe jetzt mal in den MQTT-Explorer geschaut. Was genau brauchst du da?
Ist das richtig, kannst du damit etwas anfangen??
{"zh":{"_events":{},"_eventsCount":0,"ID":30,"_type":"EndDevice","_ieeeAddr":"0x54ef441000712f79","_networkAddress":7055,"_manufacturerID":4447,"_endpoints":[{"_events":{},"_eventsCount":0,"ID":1,"profileID":260,"deviceID":1026,"inputClusters":[0,1280,3,1],"outputClusters":[25],"deviceNetworkAddress":7055,"deviceIeeeAddress":"0x54ef441000712f79","clusters":{"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b002291d7b6","zoneState":1}},"genPowerCfg":{"attributes":{"batteryVoltage":32}},"aqaraOpple":{"attributes":{"294":0,"314":0,"315":0,"316":0,"331":0}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_smoke.acn03","_applicationVersion":17,"_stackVersion":2,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"20220617","_softwareBuildID":"2019\u0000www.","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":-2092783939},"_lastSeen":1678728355159,"_defaultSendRequestWhen":"immediate","_linkquality":75,"_deleted":false},"_definition":{"zigbeeModel":["lumi.sensor_smoke.acn03"],"model":"JY-GZ-01AQ","vendor":"Xiaomi","description":"Aqara smart smoke detector","fromZigbee":[{"cluster":"aqaraOpple","type":["attributeReport","readResponse"]},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["gas","smoke"]},{"key":["gas_density","smoke_density"]},{"key":["selftest"]},{"key":["mute_buzzer"]},{"key":["mute"]},{"key":["heartbeat_indicator"]},{"key":["linkage_alarm"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]}],"exposes":[{"type":"binary","name":"smoke","property":"smoke","access":5,"value_on":true,"value_off":false,"description":"Indicates whether the device detected smoke"},{"type":"numeric","name":"smoke_density","property":"smoke_density","access":5,"description":"Value of smoke concentration"},{"type":"numeric","name":"smoke_density_dbm","property":"smoke_density_dbm","access":1,"unit":"dB/m","description":"Value of smoke concentration in dB/m"},{"type":"enum","name":"selftest","property":"selftest","access":2,"values":["Test"],"description":"Starts the self-test process (checking the indicator light and buzzer work properly)"},{"type":"binary","name":"test","property":"test","access":1,"value_on":true,"value_off":false,"description":"Self-test in progress"},{"type":"enum","name":"mute_buzzer","property":"mute_buzzer","access":2,"values":["Mute"],"description":"Mute the buzzer for 80 seconds (buzzer cannot be pre-muted, because this function only works when the alarm is triggered)"},{"type":"binary","name":"mute","property":"mute","access":5,"value_on":true,"value_off":false,"description":"Buzzer muted"},{"type":"binary","name":"heartbeat_indicator","property":"heartbeat_indicator","access":7,"value_on":true,"value_off":false,"description":"When this option is enabled then in the normal monitoring state, the green indicator light flashes every 60 seconds"},{"type":"binary","name":"linkage_alarm","property":"linkage_alarm","access":7,"value_on":true,"value_off":false,"description":"When this option is enabled and a smoke is detected, other detectors with this option enabled will also sound the alarm buzzer"},{"type":"numeric","name":"device_temperature","property":"device_temperature","access":1,"unit":"°C","description":"Temperature of the device"},{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %","value_min":0,"value_max":100},{"type":"numeric","name":"voltage","property":"voltage","access":1,"unit":"mV","description":"Voltage of the battery in millivolts"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"meta":{"battery":{"voltageToPercentage":"3V_2850_3000_log"}},"ota":{},"options":[{"type":"numeric","name":"device_temperature_precision","property":"device_temperature_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for device_temperature, takes into effect on next report of device."},{"type":"numeric","name":"device_temperature_calibration","property":"device_temperature_calibration","access":2,"description":"Calibrates the device_temperature value (absolute offset), takes into effect on next report of device."}]},"_definitionModelID":"lumi.sensor_smoke.acn03"}
Ich hätte auch noch eine Frage, im MQTT-Explorer gibt es zwei Bereiche mit Zigbee2MQTT.
Im ersten sind wie es aussieht die meisten Geräte, weiter unten ist dann nur der Rauchmelder.
Warum? Hat das was zu bedeuten?
Danke schon mal und Grüße
Stephan
