Merci! So sieht das Ergebnis im zigbee2mqtt IPS Modul aus
Dazu der passende Zigbee2MQTT Debug
debug 2023-10-09 16:36:49Received MQTT message on 'zigbee2mqtt/0xb43a31fffef53c9a/set' with data '{"learn_ir_code":"ON"}'
debug 2023-10-09 16:36:49Publishing 'set' 'learn_ir_code' to '0xb43a31fffef53c9a'
debug 2023-10-09 16:36:49Starting IR Code Learning...
debug 2023-10-09 16:36:49IR Code Learning started.
debug 2023-10-09 16:36:51Received Zigbee message from '0xb43a31fffef53c9a', type 'commandZosungSendIRCode00', cluster 'zosungIRTransmit', data '{"cmd":4,"length":84,"seq":17,"unk1":0,"unk2":57348,"unk3":1,"unk4":0}' from endpoint 1 with groupID 0
debug 2023-10-09 16:36:51"IR-Message-Code00" received (msg:{"seq":17,"length":84,"unk1":0,"unk2":57348,"unk3":1,"cmd":4,"unk4":0})
debug 2023-10-09 16:36:51"IR-Message-Code00" response sent.
debug 2023-10-09 16:36:51"IR-Message-Code00" transfer started.
debug 2023-10-09 16:36:52Received Zigbee message from '0xb43a31fffef53c9a', type 'zosungSendIRCode03Resp', cluster 'zosungIRTransmit', data '{"msgpart":{"data":[5,110,34,157,17,52,2,64,1,1,126,6,224,3,3,0,96,224,0,15,64,1,3,126,6,52,2,224,15,1,192,27,224,13,7,2,96,2,52,32,1,1,126,6,64,7,5,96,2,126,6,52,2,64,1],"type":"Buffer"},"msgpartcrc":24,"position":0,"seq":17,"zero":0}' from endpoint 1 with groupID 0
debug 2023-10-09 16:36:52"IR-Message-Code03" received (msg:{"zero":0,"seq":17,"position":0,"msgpart":{"type":"Buffer","data":[5,110,34,157,17,52,2,64,1,1,126,6,224,3,3,0,96,224,0,15,64,1,3,126,6,52,2,224,15,1,192,27,224,13,7,2,96,2,52,32,1,1,126,6,64,7,5,96,2,126,6,52,2,64,1]},"msgpartcrc":24})
debug 2023-10-09 16:36:5255 bytes received.
error 2023-10-09 16:36:52Unexpected IR code position: {"zero":0,"seq":17,"position":0,"msgpart":{"type":"Buffer","data":[5,110,34,157,17,52,2,64,1,1,126,6,224,3,3,0,96,224,0,15,64,1,3,126,6,52,2,224,15,1,192,27,224,13,7,2,96,2,52,32,1,1,126,6,64,7,5,96,2,126,6,52,2,64,1]},"msgpartcrc":24}, expecting: 55.
debug 2023-10-09 16:36:52Received Zigbee message from '0xb43a31fffef53c9a', type 'zosungSendIRCode03Resp', cluster 'zosungIRTransmit', data '{"msgpart":{"data":[224,3,7,64,11,9,155,157,110,34,176,8,52,2,255,255,64,7,9,96,2,255,255,110,34,176,8,52,2],"type":"Buffer"},"msgpartcrc":32,"position":55,"seq":17,"zero":0}' from endpoint 1 with groupID 0
debug 2023-10-09 16:36:52"IR-Message-Code03" received (msg:{"zero":0,"seq":17,"position":55,"msgpart":{"type":"Buffer","data":[224,3,7,64,11,9,155,157,110,34,176,8,52,2,255,255,64,7,9,96,2,255,255,110,34,176,8,52,2]},"msgpartcrc":32})
debug 2023-10-09 16:36:5229 bytes received.
debug 2023-10-09 16:36:53Received Zigbee message from '0xb43a31fffef53c9a', type 'zosungSendIRCode03Resp', cluster 'zosungIRTransmit', data '{"msgpart":{"data":[224,3,7,64,11,9,155,157,110,34,176,8,52,2,255,255,64,7,9,96,2,255,255,110,34,176,8,52,2],"type":"Buffer"},"msgpartcrc":32,"position":55,"seq":17,"zero":0}' from endpoint 1 with groupID 0
debug 2023-10-09 16:36:53"IR-Message-Code03" received (msg:{"zero":0,"seq":17,"position":55,"msgpart":{"type":"Buffer","data":[224,3,7,64,11,9,155,157,110,34,176,8,52,2,255,255,64,7,9,96,2,255,255,110,34,176,8,52,2]},"msgpartcrc":32})
error 2023-10-09 16:36:53Unexpected IR code position: {"zero":0,"seq":17,"position":55,"msgpart":{"type":"Buffer","data":[224,3,7,64,11,9,155,157,110,34,176,8,52,2,255,255,64,7,9,96,2,255,255,110,34,176,8,52,2]},"msgpartcrc":32}, expecting: 84.
debug 2023-10-09 16:36:53Received Zigbee message from '0xb43a31fffef53c9a', type 'zosungSendIRCode05Resp', cluster 'zosungIRTransmit', data '{"seq":17,"zero":0}' from endpoint 1 with groupID 0
debug 2023-10-09 16:36:53"IR-Message-Code05" received (msg:{"seq":17,"zero":0})
debug 2023-10-09 16:36:53Received: BW4inRE0AkABAX4G4AMDAGDgAA9AAQN+BjQC4A8BwBvgDQcCYAI0IAEBfgZABwVgAn4GNAJAAeADB0ALCZudbiKwCDQC//9ABwlgAv//biKwCDQC
info 2023-10-09 16:36:53MQTT publish: topic 'zigbee2mqtt/0xb43a31fffef53c9a', payload '{"battery":28,"learned_ir_code":"BW4inRE0AkABAX4G4AMDAGDgAA9AAQN+BjQC4A8BwBvgDQcCYAI0IAEBfgZABwVgAn4GNAJAAeADB0ALCZudbiKwCDQC//9ABwlgAv//biKwCDQC","linkquality":174,"voltage":1200}'
Parallel habe ich im 2ten Schritt das MQTT IPS Modul zusätzlich aktiviert und hier siehts dann so aus.
Warum hier der gelernte IR Code jetzt auftaucht und im Zigbee2MQTT IPS Modul nicht … und es fehlt bei beiden das Feld zum Senden eines IR Codes
debug 2023-10-09 16:51:27Received MQTT message on 'zigbee2mqtt/0xb43a31fffe25683a/set' with data '{"ir_code_to_send":"-sende IR-Code-"}'
debug 2023-10-09 16:51:27Publishing 'set' 'ir_code_to_send' to '0xb43a31fffe25683a'
debug 2023-10-09 16:51:27Sending IR code: "-sende IR-Code-"
debug 2023-10-09 16:51:28Sending IR code initiated.
debug 2023-10-09 16:51:28Received Zigbee message from '0xb43a31fffe25683a', type 'commandZosungSendIRCode01', cluster 'zosungIRTransmit', data '{"cmd":2,"length":93,"seq":0,"unk1":0,"unk2":57348,"unk3":1,"unk4":0,"zero":0}' from endpoint 1 with groupID 0
debug 2023-10-09 16:51:28"IR-Message-Code01" received (msg:{"zero":0,"seq":0,"length":93,"unk1":0,"unk2":57348,"unk3":1,"cmd":2,"unk4":0})
debug 2023-10-09 16:51:28IRCode to send: "{\"key_num\":1,\"delay\":300,\"key1\":{\"num\":1,\"freq\":38000,\"type\":1,\"key_code\":\"-sende IR-Code-\"}}" (seq:0)
debug 2023-10-09 16:51:28Received Zigbee message from '0xb43a31fffe25683a', type 'commandZosungSendIRCode02', cluster 'zosungIRTransmit', data '{"maxlen":64,"position":0,"seq":0}' from endpoint 1 with groupID 0
debug 2023-10-09 16:51:28"IR-Message-Code02" received (msg:{"seq":0,"position":0,"maxlen":64})
debug 2023-10-09 16:51:28Sent IRCode part: {"key_num":1,"delay":300,"key1":{"num":1,"freq":38 (sum: 207, seq:0)
debug 2023-10-09 16:51:28Received Zigbee message from '0xb43a31fffe25683a', type 'commandZosungSendIRCode02', cluster 'zosungIRTransmit', data '{"maxlen":64,"position":50,"seq":0}' from endpoint 1 with groupID 0
debug 2023-10-09 16:51:28"IR-Message-Code02" received (msg:{"seq":0,"position":50,"maxlen":64})
debug 2023-10-09 16:51:28Sent IRCode part: 000,"type":1,"key_code":"-sende IR-Code-"}} (sum: 36, seq:0)
debug 2023-10-09 16:51:28Received Zigbee message from '0xb43a31fffe25683a', type 'commandZosungSendIRCode04', cluster 'zosungIRTransmit', data '{"seq":0,"zero0":0,"zero1":0}' from endpoint 1 with groupID 0
debug 2023-10-09 16:51:28"IR-Message-Code04" received (msg:{"zero0":0,"seq":0,"zero1":0})
debug 2023-10-09 16:51:28IRCode has been successfuly sent. (seq:0)
LG,
Udo
