so sieht das aus bei dem Shelly 2.5:
07.01.2021, 17:59:55 | sendMQTTMQTT Server | {"DataID":"{043EA491-0325-4ADD-8FC2-A30C8EEB4D3F}","PacketType":3,"QualityOfService":0,"Retain":false,"Topic":"shellies/shellies/shellyswitch25-40F5202E0C22//roller/0/command","Payload":"stop"}
07.01.2021, 17:59:55 | sendMQTTMQTT Client | {"DataID":"{97475B04-67C3-A74D-C970-E9409B0EFA1D}","Buffer":"{\"PacketType\":3,\"QualityOfService\":0,\"Retain\":false,\"Topic\":\"shellies\/shellies\/shellyswitch25-40F5202E0C22\/\/roller\/0\/command\",\"Payload\":\"stop\"}"}
07.01.2021, 17:59:56 | sendMQTTMQTT Server | {"DataID":"{043EA491-0325-4ADD-8FC2-A30C8EEB4D3F}","PacketType":3,"QualityOfService":0,"Retain":false,"Topic":"shellies/shellies/shellyswitch25-40F5202E0C22//roller/0/command","Payload":"open"}
07.01.2021, 17:59:56 | sendMQTTMQTT Client | {"DataID":"{97475B04-67C3-A74D-C970-E9409B0EFA1D}","Buffer":"{\"PacketType\":3,\"QualityOfService\":0,\"Retain\":false,\"Topic\":\"shellies\/shellies\/shellyswitch25-40F5202E0C22\/\/roller\/0\/command\",\"Payload\":\"open\"}"}
07.01.2021, 17:59:57 | sendMQTTMQTT Server | {"DataID":"{043EA491-0325-4ADD-8FC2-A30C8EEB4D3F}","PacketType":3,"QualityOfService":0,"Retain":false,"Topic":"shellies/shellies/shellyswitch25-40F5202E0C22//roller/0/command","Payload":"close"}
07.01.2021, 17:59:57 | sendMQTTMQTT Client | {"DataID":"{97475B04-67C3-A74D-C970-E9409B0EFA1D}","Buffer":"{\"PacketType\":3,\"QualityOfService\":0,\"Retain\":false,\"Topic\":\"shellies\/shellies\/shellyswitch25-40F5202E0C22\/\/roller\/0\/command\",\"Payload\":\"close\"}"}
07.01.2021, 17:59:58 | RequestAction Value Shelly_RollerPosition | 57
07.01.2021, 17:59:58 | sendMQTTMQTT Server | {"DataID":"{043EA491-0325-4ADD-8FC2-A30C8EEB4D3F}","PacketType":3,"QualityOfService":0,"Retain":false,"Topic":"shellies/shellies/shellyswitch25-40F5202E0C22//roller/0/command/pos","Payload":"57"}
07.01.2021, 17:59:58 | sendMQTTMQTT Client | {"DataID":"{97475B04-67C3-A74D-C970-E9409B0EFA1D}","Buffer":"{\"PacketType\":3,\"QualityOfService\":0,\"Retain\":false,\"Topic\":\"shellies\/shellies\/shellyswitch25-40F5202E0C22\/\/roller\/0\/command\/pos\",\"Payload\":\"57\"}"}
07.01.2021, 18:00:00 | RequestAction Value Shelly_RollerPosition | 100
07.01.2021, 18:00:00 | sendMQTTMQTT Server | {"DataID":"{043EA491-0325-4ADD-8FC2-A30C8EEB4D3F}","PacketType":3,"QualityOfService":0,"Retain":false,"Topic":"shellies/shellies/shellyswitch25-40F5202E0C22//roller/0/command/pos","Payload":"100"}
07.01.2021, 18:00:00 | sendMQTTMQTT Client | {"DataID":"{97475B04-67C3-A74D-C970-E9409B0EFA1D}","Buffer":"{\"PacketType\":3,\"QualityOfService\":0,\"Retain\":false,\"Topic\":\"shellies\/shellies\/shellyswitch25-40F5202E0C22\/\/roller\/0\/command\/pos\",\"Payload\":\"100\"}"}
Bei dem Dimmer 2 sieht es so aus:
07.01.2021, 17:52:32 | sendMQTTMQTT Server | {"DataID":"{043EA491-0325-4ADD-8FC2-A30C8EEB4D3F}","PacketType":3,"QualityOfService":0,"Retain":false,"Topic":"shellies/shellies/shellydimmer2-40F520017789//light/0/command","Payload":"on"}
07.01.2021, 17:52:32 | sendMQTTMQTT Client | {"DataID":"{97475B04-67C3-A74D-C970-E9409B0EFA1D}","Buffer":"{\"PacketType\":3,\"QualityOfService\":0,\"Retain\":false,\"Topic\":\"shellies\/shellies\/shellydimmer2-40F520017789\/\/light\/0\/command\",\"Payload\":\"on\"}"}
07.01.2021, 17:52:34 | sendMQTTMQTT Server | {"DataID":"{043EA491-0325-4ADD-8FC2-A30C8EEB4D3F}","PacketType":3,"QualityOfService":0,"Retain":false,"Topic":"shellies/shellies/shellydimmer2-40F520017789//light/0/command","Payload":"off"}
07.01.2021, 17:52:34 | sendMQTTMQTT Client | {"DataID":"{97475B04-67C3-A74D-C970-E9409B0EFA1D}","Buffer":"{\"PacketType\":3,\"QualityOfService\":0,\"Retain\":false,\"Topic\":\"shellies\/shellies\/shellydimmer2-40F520017789\/\/light\/0\/command\",\"Payload\":\"off\"}"}
07.01.2021, 17:52:42 | sendMQTTMQTT Server | {"DataID":"{043EA491-0325-4ADD-8FC2-A30C8EEB4D3F}","PacketType":3,"QualityOfService":0,"Retain":false,"Topic":"shellies/shellies/shellydimmer2-40F520017789//light/0/set","Payload":"{\"turn\":\"on\",\"brightness\":\"63\"}"}
07.01.2021, 17:52:42 | sendMQTTMQTT Client | {"DataID":"{97475B04-67C3-A74D-C970-E9409B0EFA1D}","Buffer":"{\"PacketType\":3,\"QualityOfService\":0,\"Retain\":false,\"Topic\":\"shellies\/shellies\/shellydimmer2-40F520017789\/\/light\/0\/set\",\"Payload\":\"{\\\"turn\\\":\\\"on\\\",\\\"brightness\\\":\\\"63\\\"}\"}"}
07.01.2021, 17:52:43 | sendMQTTMQTT Server | {"DataID":"{043EA491-0325-4ADD-8FC2-A30C8EEB4D3F}","PacketType":3,"QualityOfService":0,"Retain":false,"Topic":"shellies/shellies/shellydimmer2-40F520017789//light/0/set","Payload":"{\"turn\":\"on\",\"brightness\":\"21\"}"}
07.01.2021, 17:52:43 | sendMQTTMQTT Client | {"DataID":"{97475B04-67C3-A74D-C970-E9409B0EFA1D}","Buffer":"{\"PacketType\":3,\"QualityOfService\":0,\"Retain\":false,\"Topic\":\"shellies\/shellies\/shellydimmer2-40F520017789\/\/light\/0\/set\",\"Payload\":\"{\\\"turn\\\":\\\"on\\\",\\\"brightness\\\":\\\"21\\\"}\"}"}
07.01.2021, 17:52:45 | sendMQTTMQTT Server | {"DataID":"{043EA491-0325-4ADD-8FC2-A30C8EEB4D3F}","PacketType":3,"QualityOfService":0,"Retain":false,"Topic":"shellies/shellies/shellydimmer2-40F520017789//light/0/command","Payload":"on"}
07.01.2021, 17:52:45 | sendMQTTMQTT Client | {"DataID":"{97475B04-67C3-A74D-C970-E9409B0EFA1D}","Buffer":"{\"PacketType\":3,\"QualityOfService\":0,\"Retain\":false,\"Topic\":\"shellies\/shellies\/shellydimmer2-40F520017789\/\/light\/0\/command\",\"Payload\":\"on\"}"}
07.01.2021, 17:52:46 | sendMQTTMQTT Server | {"DataID":"{043EA491-0325-4ADD-8FC2-A30C8EEB4D3F}","PacketType":3,"QualityOfService":0,"Retain":false,"Topic":"shellies/shellies/shellydimmer2-40F520017789//light/0/command","Payload":"on"}
07.01.2021, 17:52:46 | sendMQTTMQTT Client | {"DataID":"{97475B04-67C3-A74D-C970-E9409B0EFA1D}","Buffer":"{\"PacketType\":3,\"QualityOfService\":0,\"Retain\":false,\"Topic\":\"shellies\/shellies\/shellydimmer2-40F520017789\/\/light\/0\/command\",\"Payload\":\"on\"}"}
