[QUOTE=richimaint;427462]Hallo @Kai,
nach Update auf FW 1.70 beim RGBW2 bekomme ich folgender Fehlermeldungen:
07.06.2020, 10:00:23 | FlowHandler | Kann Daten nicht zur Instanz #43880 weiterleiten: <br />
<b>Notice</b>: Undefined property: stdClass::$power in <b>C:\ProgramData\Symcon\modules\.store\info.schnittcher.ips.shelly\ShellyRGBW2\module.php</b> on line <b>204</b><br />
<br />
<b>Notice</b>: Undefined property: stdClass::$overpower in <b>C:\ProgramData\Symcon\modules\.store\info.schnittcher.ips.shelly\ShellyRGBW2\module.php</b> on line <b>205</b><br />
RESULT:
richimaint[/QUOTE]
[QUOTE=richimaint;427879]Hier der Debug:
TXT: 12.06.2020, 09:31:10 | ShellyRGBW2 Payload | off
HEX: 12.06.2020, 09:31:10 | ShellyRGBW2 Payload | 6F 66 66
TXT: 12.06.2020, 09:31:10 | ShellyRGBW2 Channel | white
HEX: 12.06.2020, 09:31:10 | ShellyRGBW2 Channel | 77 68 69 74 65
TXT: 12.06.2020, 09:31:10 | ShlleyRGBW2 Mode | White
HEX: 12.06.2020, 09:31:10 | ShlleyRGBW2 Mode | 57 68 69 74 65
TXT: 12.06.2020, 09:31:10 | JSON | {"DataID":"{7F7632D9-FA40-4F38-8DEA-C83CD4325A32}","PacketType":3,"QualityOfService":0,"Retain":true,"Topic":"shellies/shellyrgbw2-6622B0/white/2/status","Payload":"{\"ison\":false,\"has_timer\":false,\"timer_started\":0,\"timer_duration\":0,\"timer_remaining\":0,\"mode\":\"white\",\"brightness\":12}"}
HEX: 12.06.2020, 09:31:10 | JSON | 7B 22 44 61 74 61 49 44 22 3A 22 7B 37 46 37 36 33 32 44 39 2D 46 41 34 30 2D 34 46 33 38 2D 38 44 45 41 2D 43 38 33 43 44 34 33 32 35 41 33 32 7D 22 2C 22 50 61 63 6B 65 74 54 79 70 65 22 3A 33 2C 22 51 75 61 6C 69 74 79 4F 66 53 65 72 76 69 63 65 22 3A 30 2C 22 52 65 74 61 69 6E 22 3A 74 72 75 65 2C 22 54 6F 70 69 63 22 3A 22 73 68 65 6C 6C 69 65 73 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 2F 77 68 69 74 65 2F 32 2F 73 74 61 74 75 73 22 2C 22 50 61 79 6C 6F 61 64 22 3A 22 7B 5C 22 69 73 6F 6E 5C 22 3A 66 61 6C 73 65 2C 5C 22 68 61 73 5F 74 69 6D 65 72 5C 22 3A 66 61 6C 73 65 2C 5C 22 74 69 6D 65 72 5F 73 74 61 72 74 65 64 5C 22 3A 30 2C 5C 22 74 69 6D 65 72 5F 64 75 72 61 74 69 6F 6E 5C 22 3A 30 2C 5C 22 74 69 6D 65 72 5F 72 65 6D 61 69 6E 69 6E 67 5C 22 3A 30 2C 5C 22 6D 6F 64 65 5C 22 3A 5C 22 77 68 69 74 65 5C 22 2C 5C 22 62 72 69 67 68 74 6E 65 73 73 5C 22 3A 31 32 7D 22 7D
TXT: 12.06.2020, 09:31:10 | MQTT Topic | shellies/shellyrgbw2-6622B0/white/2/status
HEX: 12.06.2020, 09:31:10 | MQTT Topic | 73 68 65 6C 6C 69 65 73 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 2F 77 68 69 74 65 2F 32 2F 73 74 61 74 75 73
TXT: 12.06.2020, 09:31:10 | ShellyRGBW2 Payload | {"ison":false,"has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"mode":"white","brightness":12}
HEX: 12.06.2020, 09:31:10 | ShellyRGBW2 Payload | 7B 22 69 73 6F 6E 22 3A 66 61 6C 73 65 2C 22 68 61 73 5F 74 69 6D 65 72 22 3A 66 61 6C 73 65 2C 22 74 69 6D 65 72 5F 73 74 61 72 74 65 64 22 3A 30 2C 22 74 69 6D 65 72 5F 64 75 72 61 74 69 6F 6E 22 3A 30 2C 22 74 69 6D 65 72 5F 72 65 6D 61 69 6E 69 6E 67 22 3A 30 2C 22 6D 6F 64 65 22 3A 22 77 68 69 74 65 22 2C 22 62 72 69 67 68 74 6E 65 73 73 22 3A 31 32 7D
TXT: 12.06.2020, 09:31:10 | ShellyRGBW2 Channel | 2
HEX: 12.06.2020, 09:31:10 | ShellyRGBW2 Channel | 32
TXT: 12.06.2020, 09:31:10 | JSON | {"DataID":"{7F7632D9-FA40-4F38-8DEA-C83CD4325A32}","PacketType":3,"QualityOfService":0,"Retain":true,"Topic":"shellies/shellyrgbw2-6622B0/white/3","Payload":"off"}
HEX: 12.06.2020, 09:31:10 | JSON | 7B 22 44 61 74 61 49 44 22 3A 22 7B 37 46 37 36 33 32 44 39 2D 46 41 34 30 2D 34 46 33 38 2D 38 44 45 41 2D 43 38 33 43 44 34 33 32 35 41 33 32 7D 22 2C 22 50 61 63 6B 65 74 54 79 70 65 22 3A 33 2C 22 51 75 61 6C 69 74 79 4F 66 53 65 72 76 69 63 65 22 3A 30 2C 22 52 65 74 61 69 6E 22 3A 74 72 75 65 2C 22 54 6F 70 69 63 22 3A 22 73 68 65 6C 6C 69 65 73 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 2F 77 68 69 74 65 2F 33 22 2C 22 50 61 79 6C 6F 61 64 22 3A 22 6F 66 66 22 7D
TXT: 12.06.2020, 09:31:10 | MQTT Topic | shellies/shellyrgbw2-6622B0/white/3
HEX: 12.06.2020, 09:31:10 | MQTT Topic | 73 68 65 6C 6C 69 65 73 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 2F 77 68 69 74 65 2F 33
TXT: 12.06.2020, 09:31:10 | JSON | {"DataID":"{7F7632D9-FA40-4F38-8DEA-C83CD4325A32}","PacketType":3,"QualityOfService":0,"Retain":true,"Topic":"shellies/shellyrgbw2-6622B0/white/3/status","Payload":"{\"ison\":false,\"has_timer\":false,\"timer_started\":0,\"timer_duration\":0,\"timer_remaining\":0,\"mode\":\"white\",\"brightness\":12}"}
HEX: 12.06.2020, 09:31:10 | JSON | 7B 22 44 61 74 61 49 44 22 3A 22 7B 37 46 37 36 33 32 44 39 2D 46 41 34 30 2D 34 46 33 38 2D 38 44 45 41 2D 43 38 33 43 44 34 33 32 35 41 33 32 7D 22 2C 22 50 61 63 6B 65 74 54 79 70 65 22 3A 33 2C 22 51 75 61 6C 69 74 79 4F 66 53 65 72 76 69 63 65 22 3A 30 2C 22 52 65 74 61 69 6E 22 3A 74 72 75 65 2C 22 54 6F 70 69 63 22 3A 22 73 68 65 6C 6C 69 65 73 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 2F 77 68 69 74 65 2F 33 2F 73 74 61 74 75 73 22 2C 22 50 61 79 6C 6F 61 64 22 3A 22 7B 5C 22 69 73 6F 6E 5C 22 3A 66 61 6C 73 65 2C 5C 22 68 61 73 5F 74 69 6D 65 72 5C 22 3A 66 61 6C 73 65 2C 5C 22 74 69 6D 65 72 5F 73 74 61 72 74 65 64 5C 22 3A 30 2C 5C 22 74 69 6D 65 72 5F 64 75 72 61 74 69 6F 6E 5C 22 3A 30 2C 5C 22 74 69 6D 65 72 5F 72 65 6D 61 69 6E 69 6E 67 5C 22 3A 30 2C 5C 22 6D 6F 64 65 5C 22 3A 5C 22 77 68 69 74 65 5C 22 2C 5C 22 62 72 69 67 68 74 6E 65 73 73 5C 22 3A 31 32 7D 22 7D
TXT: 12.06.2020, 09:31:10 | MQTT Topic | shellies/shellyrgbw2-6622B0/white/3/status
HEX: 12.06.2020, 09:31:10 | MQTT Topic | 73 68 65 6C 6C 69 65 73 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 2F 77 68 69 74 65 2F 33 2F 73 74 61 74 75 73
TXT: 12.06.2020, 09:31:10 | ShellyRGBW2 Channel | 3
HEX: 12.06.2020, 09:31:10 | ShellyRGBW2 Channel | 33
TXT: 12.06.2020, 09:31:10 | sendMQTTMQTT Client | {"DataID":"{97475B04-67C3-A74D-C970-E9409B0EFA1D}","Buffer":"{\"PacketType\":3,\"QualityOfService\":0,\"Retain\":false,\"Topic\":\"shellies\/shellyrgbw2-6622B0\/white\/0\/command\",\"Payload\":\"on\"}"}
HEX: 12.06.2020, 09:31:10 | sendMQTTMQTT Client | 7B 22 44 61 74 61 49 44 22 3A 22 7B 39 37 34 37 35 42 30 34 2D 36 37 43 33 2D 41 37 34 44 2D 43 39 37 30 2D 45 39 34 30 39 42 30 45 46 41 31 44 7D 22 2C 22 42 75 66 66 65 72 22 3A 22 7B 5C 22 50 61 63 6B 65 74 54 79 70 65 5C 22 3A 33 2C 5C 22 51 75 61 6C 69 74 79 4F 66 53 65 72 76 69 63 65 5C 22 3A 30 2C 5C 22 52 65 74 61 69 6E 5C 22 3A 66 61 6C 73 65 2C 5C 22 54 6F 70 69 63 5C 22 3A 5C 22 73 68 65 6C 6C 69 65 73 5C 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 5C 2F 77 68 69 74 65 5C 2F 30 5C 2F 63 6F 6D 6D 61 6E 64 5C 22 2C 5C 22 50 61 79 6C 6F 61 64 5C 22 3A 5C 22 6F 6E 5C 22 7D 22 7D
TXT: 12.06.2020, 09:31:11 | ShlleyRGBW2 Mode | White
HEX: 12.06.2020, 09:31:11 | ShlleyRGBW2 Mode | 57 68 69 74 65
TXT: 12.06.2020, 09:31:11 | JSON | {"DataID":"{7F7632D9-FA40-4F38-8DEA-C83CD4325A32}","PacketType":3,"QualityOfService":0,"Retain":true,"Topic":"shellies/shellyrgbw2-6622B0/white/0","Payload":"on"}
HEX: 12.06.2020, 09:31:11 | JSON | 7B 22 44 61 74 61 49 44 22 3A 22 7B 37 46 37 36 33 32 44 39 2D 46 41 34 30 2D 34 46 33 38 2D 38 44 45 41 2D 43 38 33 43 44 34 33 32 35 41 33 32 7D 22 2C 22 50 61 63 6B 65 74 54 79 70 65 22 3A 33 2C 22 51 75 61 6C 69 74 79 4F 66 53 65 72 76 69 63 65 22 3A 30 2C 22 52 65 74 61 69 6E 22 3A 74 72 75 65 2C 22 54 6F 70 69 63 22 3A 22 73 68 65 6C 6C 69 65 73 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 2F 77 68 69 74 65 2F 30 22 2C 22 50 61 79 6C 6F 61 64 22 3A 22 6F 6E 22 7D
TXT: 12.06.2020, 09:31:11 | MQTT Topic | shellies/shellyrgbw2-6622B0/white/0
HEX: 12.06.2020, 09:31:11 | MQTT Topic | 73 68 65 6C 6C 69 65 73 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 2F 77 68 69 74 65 2F 30
TXT: 12.06.2020, 09:31:11 | ShellyRGBW2 Payload | on
HEX: 12.06.2020, 09:31:11 | ShellyRGBW2 Payload | 6F 6E
TXT: 12.06.2020, 09:31:11 | ShellyRGBW2 Channel | white
HEX: 12.06.2020, 09:31:11 | ShellyRGBW2 Channel | 77 68 69 74 65
TXT: 12.06.2020, 09:31:11 | JSON | {"DataID":"{7F7632D9-FA40-4F38-8DEA-C83CD4325A32}","PacketType":3,"QualityOfService":0,"Retain":true,"Topic":"shellies/shellyrgbw2-6622B0/white/0/status","Payload":"{\"ison\":true,\"has_timer\":false,\"timer_started\":0,\"timer_duration\":0,\"timer_remaining\":0,\"mode\":\"white\",\"brightness\":41}"}
HEX: 12.06.2020, 09:31:11 | JSON | 7B 22 44 61 74 61 49 44 22 3A 22 7B 37 46 37 36 33 32 44 39 2D 46 41 34 30 2D 34 46 33 38 2D 38 44 45 41 2D 43 38 33 43 44 34 33 32 35 41 33 32 7D 22 2C 22 50 61 63 6B 65 74 54 79 70 65 22 3A 33 2C 22 51 75 61 6C 69 74 79 4F 66 53 65 72 76 69 63 65 22 3A 30 2C 22 52 65 74 61 69 6E 22 3A 74 72 75 65 2C 22 54 6F 70 69 63 22 3A 22 73 68 65 6C 6C 69 65 73 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 2F 77 68 69 74 65 2F 30 2F 73 74 61 74 75 73 22 2C 22 50 61 79 6C 6F 61 64 22 3A 22 7B 5C 22 69 73 6F 6E 5C 22 3A 74 72 75 65 2C 5C 22 68 61 73 5F 74 69 6D 65 72 5C 22 3A 66 61 6C 73 65 2C 5C 22 74 69 6D 65 72 5F 73 74 61 72 74 65 64 5C 22 3A 30 2C 5C 22 74 69 6D 65 72 5F 64 75 72 61 74 69 6F 6E 5C 22 3A 30 2C 5C 22 74 69 6D 65 72 5F 72 65 6D 61 69 6E 69 6E 67 5C 22 3A 30 2C 5C 22 6D 6F 64 65 5C 22 3A 5C 22 77 68 69 74 65 5C 22 2C 5C 22 62 72 69 67 68 74 6E 65 73 73 5C 22 3A 34 31 7D 22 7D
TXT: 12.06.2020, 09:31:11 | MQTT Topic | shellies/shellyrgbw2-6622B0/white/0/status
HEX: 12.06.2020, 09:31:11 | MQTT Topic | 73 68 65 6C 6C 69 65 73 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 2F 77 68 69 74 65 2F 30 2F 73 74 61 74 75 73
TXT: 12.06.2020, 09:31:11 | ShellyRGBW2 Payload | {"ison":true,"has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"mode":"white","brightness":41}
HEX: 12.06.2020, 09:31:11 | ShellyRGBW2 Payload | 7B 22 69 73 6F 6E 22 3A 74 72 75 65 2C 22 68 61 73 5F 74 69 6D 65 72 22 3A 66 61 6C 73 65 2C 22 74 69 6D 65 72 5F 73 74 61 72 74 65 64 22 3A 30 2C 22 74 69 6D 65 72 5F 64 75 72 61 74 69 6F 6E 22 3A 30 2C 22 74 69 6D 65 72 5F 72 65 6D 61 69 6E 69 6E 67 22 3A 30 2C 22 6D 6F 64 65 22 3A 22 77 68 69 74 65 22 2C 22 62 72 69 67 68 74 6E 65 73 73 22 3A 34 31 7D
TXT: 12.06.2020, 09:31:11 | ShellyRGBW2 Channel | 0
HEX: 12.06.2020, 09:31:11 | ShellyRGBW2 Channel | 30
TXT: 12.06.2020, 09:31:11 | JSON | {"DataID":"{7F7632D9-FA40-4F38-8DEA-C83CD4325A32}","PacketType":3,"QualityOfService":0,"Retain":true,"Topic":"shellies/shellyrgbw2-6622B0/white/1","Payload":"off"}
HEX: 12.06.2020, 09:31:11 | JSON | 7B 22 44 61 74 61 49 44 22 3A 22 7B 37 46 37 36 33 32 44 39 2D 46 41 34 30 2D 34 46 33 38 2D 38 44 45 41 2D 43 38 33 43 44 34 33 32 35 41 33 32 7D 22 2C 22 50 61 63 6B 65 74 54 79 70 65 22 3A 33 2C 22 51 75 61 6C 69 74 79 4F 66 53 65 72 76 69 63 65 22 3A 30 2C 22 52 65 74 61 69 6E 22 3A 74 72 75 65 2C 22 54 6F 70 69 63 22 3A 22 73 68 65 6C 6C 69 65 73 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 2F 77 68 69 74 65 2F 31 22 2C 22 50 61 79 6C 6F 61 64 22 3A 22 6F 66 66 22 7D
TXT: 12.06.2020, 09:31:11 | MQTT Topic | shellies/shellyrgbw2-6622B0/white/1
HEX: 12.06.2020, 09:31:11 | MQTT Topic | 73 68 65 6C 6C 69 65 73 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 2F 77 68 69 74 65 2F 31
TXT: 12.06.2020, 09:31:11 | ShellyRGBW2 Payload | off
HEX: 12.06.2020, 09:31:11 | ShellyRGBW2 Payload | 6F 66 66
TXT: 12.06.2020, 09:31:11 | JSON | {"DataID":"{7F7632D9-FA40-4F38-8DEA-C83CD4325A32}","PacketType":3,"QualityOfService":0,"Retain":true,"Topic":"shellies/shellyrgbw2-6622B0/white/1/status","Payload":"{\"ison\":false,\"has_timer\":false,\"timer_started\":0,\"timer_duration\":0,\"timer_remaining\":0,\"mode\":\"white\",\"brightness\":12}"}
HEX: 12.06.2020, 09:31:11 | JSON | 7B 22 44 61 74 61 49 44 22 3A 22 7B 37 46 37 36 33 32 44 39 2D 46 41 34 30 2D 34 46 33 38 2D 38 44 45 41 2D 43 38 33 43 44 34 33 32 35 41 33 32 7D 22 2C 22 50 61 63 6B 65 74 54 79 70 65 22 3A 33 2C 22 51 75 61 6C 69 74 79 4F 66 53 65 72 76 69 63 65 22 3A 30 2C 22 52 65 74 61 69 6E 22 3A 74 72 75 65 2C 22 54 6F 70 69 63 22 3A 22 73 68 65 6C 6C 69 65 73 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 2F 77 68 69 74 65 2F 31 2F 73 74 61 74 75 73 22 2C 22 50 61 79 6C 6F 61 64 22 3A 22 7B 5C 22 69 73 6F 6E 5C 22 3A 66 61 6C 73 65 2C 5C 22 68 61 73 5F 74 69 6D 65 72 5C 22 3A 66 61 6C 73 65 2C 5C 22 74 69 6D 65 72 5F 73 74 61 72 74 65 64 5C 22 3A 30 2C 5C 22 74 69 6D 65 72 5F 64 75 72 61 74 69 6F 6E 5C 22 3A 30 2C 5C 22 74 69 6D 65 72 5F 72 65 6D 61 69 6E 69 6E 67 5C 22 3A 30 2C 5C 22 6D 6F 64 65 5C 22 3A 5C 22 77 68 69 74 65 5C 22 2C 5C 22 62 72 69 67 68 74 6E 65 73 73 5C 22 3A 31 32 7D 22 7D
TXT: 12.06.2020, 09:31:11 | MQTT Topic | shellies/shellyrgbw2-6622B0/white/1/status
HEX: 12.06.2020, 09:31:11 | MQTT Topic | 73 68 65 6C 6C 69 65 73 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 2F 77 68 69 74 65 2F 31 2F 73 74 61 74 75 73
TXT: 12.06.2020, 09:31:11 | ShellyRGBW2 Payload | {"ison":false,"has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"mode":"white","brightness":12}
HEX: 12.06.2020, 09:31:11 | ShellyRGBW2 Payload | 7B 22 69 73 6F 6E 22 3A 66 61 6C 73 65 2C 22 68 61 73 5F 74 69 6D 65 72 22 3A 66 61 6C 73 65 2C 22 74 69 6D 65 72 5F 73 74 61 72 74 65 64 22 3A 30 2C 22 74 69 6D 65 72 5F 64 75 72 61 74 69 6F 6E 22 3A 30 2C 22 74 69 6D 65 72 5F 72 65 6D 61 69 6E 69 6E 67 22 3A 30 2C 22 6D 6F 64 65 22 3A 22 77 68 69 74 65 22 2C 22 62 72 69 67 68 74 6E 65 73 73 22 3A 31 32 7D
TXT: 12.06.2020, 09:31:11 | ShellyRGBW2 Channel | 1
HEX: 12.06.2020, 09:31:11 | ShellyRGBW2 Channel | 31
TXT: 12.06.2020, 09:31:11 | JSON | {"DataID":"{7F7632D9-FA40-4F38-8DEA-C83CD4325A32}","PacketType":3,"QualityOfService":0,"Retain":true,"Topic":"shellies/shellyrgbw2-6622B0/white/2","Payload":"off"}
HEX: 12.06.2020, 09:31:11 | JSON | 7B 22 44 61 74 61 49 44 22 3A 22 7B 37 46 37 36 33 32 44 39 2D 46 41 34 30 2D 34 46 33 38 2D 38 44 45 41 2D 43 38 33 43 44 34 33 32 35 41 33 32 7D 22 2C 22 50 61 63 6B 65 74 54 79 70 65 22 3A 33 2C 22 51 75 61 6C 69 74 79 4F 66 53 65 72 76 69 63 65 22 3A 30 2C 22 52 65 74 61 69 6E 22 3A 74 72 75 65 2C 22 54 6F 70 69 63 22 3A 22 73 68 65 6C 6C 69 65 73 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 2F 77 68 69 74 65 2F 32 22 2C 22 50 61 79 6C 6F 61 64 22 3A 22 6F 66 66 22 7D
TXT: 12.06.2020, 09:31:11 | MQTT Topic | shellies/shellyrgbw2-6622B0/white/2
HEX: 12.06.2020, 09:31:11 | MQTT Topic | 73 68 65 6C 6C 69 65 73 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 2F 77 68 69 74 65 2F 32
TXT: 12.06.2020, 09:31:11 | JSON | {"DataID":"{7F7632D9-FA40-4F38-8DEA-C83CD4325A32}","PacketType":3,"QualityOfService":0,"Retain":true,"Topic":"shellies/shellyrgbw2-6622B0/white/2/status","Payload":"{\"ison\":false,\"has_timer\":false,\"timer_started\":0,\"timer_duration\":0,\"timer_remaining\":0,\"mode\":\"white\",\"brightness\":12}"}
HEX: 12.06.2020, 09:31:11 | JSON | 7B 22 44 61 74 61 49 44 22 3A 22 7B 37 46 37 36 33 32 44 39 2D 46 41 34 30 2D 34 46 33 38 2D 38 44 45 41 2D 43 38 33 43 44 34 33 32 35 41 33 32 7D 22 2C 22 50 61 63 6B 65 74 54 79 70 65 22 3A 33 2C 22 51 75 61 6C 69 74 79 4F 66 53 65 72 76 69 63 65 22 3A 30 2C 22 52 65 74 61 69 6E 22 3A 74 72 75 65 2C 22 54 6F 70 69 63 22 3A 22 73 68 65 6C 6C 69 65 73 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 2F 77 68 69 74 65 2F 32 2F 73 74 61 74 75 73 22 2C 22 50 61 79 6C 6F 61 64 22 3A 22 7B 5C 22 69 73 6F 6E 5C 22 3A 66 61 6C 73 65 2C 5C 22 68 61 73 5F 74 69 6D 65 72 5C 22 3A 66 61 6C 73 65 2C 5C 22 74 69 6D 65 72 5F 73 74 61 72 74 65 64 5C 22 3A 30 2C 5C 22 74 69 6D 65 72 5F 64 75 72 61 74 69 6F 6E 5C 22 3A 30 2C 5C 22 74 69 6D 65 72 5F 72 65 6D 61 69 6E 69 6E 67 5C 22 3A 30 2C 5C 22 6D 6F 64 65 5C 22 3A 5C 22 77 68 69 74 65 5C 22 2C 5C 22 62 72 69 67 68 74 6E 65 73 73 5C 22 3A 31 32 7D 22 7D
TXT: 12.06.2020, 09:31:11 | MQTT Topic | shellies/shellyrgbw2-6622B0/white/2/status
HEX: 12.06.2020, 09:31:11 | MQTT Topic | 73 68 65 6C 6C 69 65 73 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 2F 77 68 69 74 65 2F 32 2F 73 74 61 74 75 73
TXT: 12.06.2020, 09:31:11 | ShellyRGBW2 Channel | 2
HEX: 12.06.2020, 09:31:11 | ShellyRGBW2 Channel | 32
TXT: 12.06.2020, 09:31:11 | JSON | {"DataID":"{7F7632D9-FA40-4F38-8DEA-C83CD4325A32}","PacketType":3,"QualityOfService":0,"Retain":true,"Topic":"shellies/shellyrgbw2-6622B0/white/3","Payload":"off"}
HEX: 12.06.2020, 09:31:11 | JSON | 7B 22 44 61 74 61 49 44 22 3A 22 7B 37 46 37 36 33 32 44 39 2D 46 41 34 30 2D 34 46 33 38 2D 38 44 45 41 2D 43 38 33 43 44 34 33 32 35 41 33 32 7D 22 2C 22 50 61 63 6B 65 74 54 79 70 65 22 3A 33 2C 22 51 75 61 6C 69 74 79 4F 66 53 65 72 76 69 63 65 22 3A 30 2C 22 52 65 74 61 69 6E 22 3A 74 72 75 65 2C 22 54 6F 70 69 63 22 3A 22 73 68 65 6C 6C 69 65 73 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 2F 77 68 69 74 65 2F 33 22 2C 22 50 61 79 6C 6F 61 64 22 3A 22 6F 66 66 22 7D
TXT: 12.06.2020, 09:31:11 | MQTT Topic | shellies/shellyrgbw2-6622B0/white/3
HEX: 12.06.2020, 09:31:11 | MQTT Topic | 73 68 65 6C 6C 69 65 73 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 2F 77 68 69 74 65 2F 33
TXT: 12.06.2020, 09:31:11 | JSON | {"DataID":"{7F7632D9-FA40-4F38-8DEA-C83CD4325A32}","PacketType":3,"QualityOfService":0,"Retain":true,"Topic":"shellies/shellyrgbw2-6622B0/white/3/status","Payload":"{\"ison\":false,\"has_timer\":false,\"timer_started\":0,\"timer_duration\":0,\"timer_remaining\":0,\"mode\":\"white\",\"brightness\":12}"}
HEX: 12.06.2020, 09:31:11 | JSON | 7B 22 44 61 74 61 49 44 22 3A 22 7B 37 46 37 36 33 32 44 39 2D 46 41 34 30 2D 34 46 33 38 2D 38 44 45 41 2D 43 38 33 43 44 34 33 32 35 41 33 32 7D 22 2C 22 50 61 63 6B 65 74 54 79 70 65 22 3A 33 2C 22 51 75 61 6C 69 74 79 4F 66 53 65 72 76 69 63 65 22 3A 30 2C 22 52 65 74 61 69 6E 22 3A 74 72 75 65 2C 22 54 6F 70 69 63 22 3A 22 73 68 65 6C 6C 69 65 73 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 2F 77 68 69 74 65 2F 33 2F 73 74 61 74 75 73 22 2C 22 50 61 79 6C 6F 61 64 22 3A 22 7B 5C 22 69 73 6F 6E 5C 22 3A 66 61 6C 73 65 2C 5C 22 68 61 73 5F 74 69 6D 65 72 5C 22 3A 66 61 6C 73 65 2C 5C 22 74 69 6D 65 72 5F 73 74 61 72 74 65 64 5C 22 3A 30 2C 5C 22 74 69 6D 65 72 5F 64 75 72 61 74 69 6F 6E 5C 22 3A 30 2C 5C 22 74 69 6D 65 72 5F 72 65 6D 61 69 6E 69 6E 67 5C 22 3A 30 2C 5C 22 6D 6F 64 65 5C 22 3A 5C 22 77 68 69 74 65 5C 22 2C 5C 22 62 72 69 67 68 74 6E 65 73 73 5C 22 3A 31 32 7D 22 7D
TXT: 12.06.2020, 09:31:11 | MQTT Topic | shellies/shellyrgbw2-6622B0/white/3/status
HEX: 12.06.2020, 09:31:11 | MQTT Topic | 73 68 65 6C 6C 69 65 73 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 2F 77 68 69 74 65 2F 33 2F 73 74 61 74 75 73
TXT: 12.06.2020, 09:31:11 | ShellyRGBW2 Channel | 3
HEX: 12.06.2020, 09:31:11 | ShellyRGBW2 Channel | 33
TXT: 12.06.2020, 09:31:14 | sendMQTTMQTT Server | {"DataID":"{043EA491-0325-4ADD-8FC2-A30C8EEB4D3F}","PacketType":3,"QualityOfService":0,"Retain":false,"Topic":"shellies/shellyrgbw2-6622B0/white/0/command","Payload":"off"}
HEX: 12.06.2020, 09:31:14 | sendMQTTMQTT Server | 7B 22 44 61 74 61 49 44 22 3A 22 7B 30 34 33 45 41 34 39 31 2D 30 33 32 35 2D 34 41 44 44 2D 38 46 43 32 2D 41 33 30 43 38 45 45 42 34 44 33 46 7D 22 2C 22 50 61 63 6B 65 74 54 79 70 65 22 3A 33 2C 22 51 75 61 6C 69 74 79 4F 66 53 65 72 76 69 63 65 22 3A 30 2C 22 52 65 74 61 69 6E 22 3A 66 61 6C 73 65 2C 22 54 6F 70 69 63 22 3A 22 73 68 65 6C 6C 69 65 73 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 2F 77 68 69 74 65 2F 30 2F 63 6F 6D 6D 61 6E 64 22 2C 22 50 61 79 6C 6F 61 64 22 3A 22 6F 66 66 22 7D
TXT: 12.06.2020, 09:31:14 | sendMQTTMQTT Client | {"DataID":"{97475B04-67C3-A74D-C970-E9409B0EFA1D}","Buffer":"{\"PacketType\":3,\"QualityOfService\":0,\"Retain\":false,\"Topic\":\"shellies\/shellyrgbw2-6622B0\/white\/0\/command\",\"Payload\":\"off\"}"}
HEX: 12.06.2020, 09:31:14 | sendMQTTMQTT Client | 7B 22 44 61 74 61 49 44 22 3A 22 7B 39 37 34 37 35 42 30 34 2D 36 37 43 33 2D 41 37 34 44 2D 43 39 37 30 2D 45 39 34 30 39 42 30 45 46 41 31 44 7D 22 2C 22 42 75 66 66 65 72 22 3A 22 7B 5C 22 50 61 63 6B 65 74 54 79 70 65 5C 22 3A 33 2C 5C 22 51 75 61 6C 69 74 79 4F 66 53 65 72 76 69 63 65 5C 22 3A 30 2C 5C 22 52 65 74 61 69 6E 5C 22 3A 66 61 6C 73 65 2C 5C 22 54 6F 70 69 63 5C 22 3A 5C 22 73 68 65 6C 6C 69 65 73 5C 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 5C 2F 77 68 69 74 65 5C 2F 30 5C 2F 63 6F 6D 6D 61 6E 64 5C 22 2C 5C 22 50 61 79 6C 6F 61 64 5C 22 3A 5C 22 6F 66 66 5C 22 7D 22 7D
TXT: 12.06.2020, 09:31:15 | ShlleyRGBW2 Mode | White
HEX: 12.06.2020, 09:31:15 | ShlleyRGBW2 Mode | 57 68 69 74 65
TXT: 12.06.2020, 09:31:15 | JSON | {"DataID":"{7F7632D9-FA40-4F38-8DEA-C83CD4325A32}","PacketType":3,"QualityOfService":0,"Retain":true,"Topic":"shellies/shellyrgbw2-6622B0/white/0","Payload":"off"}
HEX: 12.06.2020, 09:31:15 | JSON | 7B 22 44 61 74 61 49 44 22 3A 22 7B 37 46 37 36 33 32 44 39 2D 46 41 34 30 2D 34 46 33 38 2D 38 44 45 41 2D 43 38 33 43 44 34 33 32 35 41 33 32 7D 22 2C 22 50 61 63 6B 65 74 54 79 70 65 22 3A 33 2C 22 51 75 61 6C 69 74 79 4F 66 53 65 72 76 69 63 65 22 3A 30 2C 22 52 65 74 61 69 6E 22 3A 74 72 75 65 2C 22 54 6F 70 69 63 22 3A 22 73 68 65 6C 6C 69 65 73 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 2F 77 68 69 74 65 2F 30 22 2C 22 50 61 79 6C 6F 61 64 22 3A 22 6F 66 66 22 7D
TXT: 12.06.2020, 09:31:15 | MQTT Topic | shellies/shellyrgbw2-6622B0/white/0
HEX: 12.06.2020, 09:31:15 | MQTT Topic | 73 68 65 6C 6C 69 65 73 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 2F 77 68 69 74 65 2F 30
TXT: 12.06.2020, 09:31:15 | ShellyRGBW2 Payload | off
HEX: 12.06.2020, 09:31:15 | ShellyRGBW2 Payload | 6F 66 66
TXT: 12.06.2020, 09:31:15 | ShellyRGBW2 Channel | white
HEX: 12.06.2020, 09:31:15 | ShellyRGBW2 Channel | 77 68 69 74 65
TXT: 12.06.2020, 09:31:15 | JSON | {"DataID":"{7F7632D9-FA40-4F38-8DEA-C83CD4325A32}","PacketType":3,"QualityOfService":0,"Retain":true,"Topic":"shellies/shellyrgbw2-6622B0/white/0/status","Payload":"{\"ison\":false,\"has_timer\":false,\"timer_started\":0,\"timer_duration\":0,\"timer_remaining\":0,\"mode\":\"white\",\"brightness\":41}"}
HEX: 12.06.2020, 09:31:15 | JSON | 7B 22 44 61 74 61 49 44 22 3A 22 7B 37 46 37 36 33 32 44 39 2D 46 41 34 30 2D 34 46 33 38 2D 38 44 45 41 2D 43 38 33 43 44 34 33 32 35 41 33 32 7D 22 2C 22 50 61 63 6B 65 74 54 79 70 65 22 3A 33 2C 22 51 75 61 6C 69 74 79 4F 66 53 65 72 76 69 63 65 22 3A 30 2C 22 52 65 74 61 69 6E 22 3A 74 72 75 65 2C 22 54 6F 70 69 63 22 3A 22 73 68 65 6C 6C 69 65 73 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 2F 77 68 69 74 65 2F 30 2F 73 74 61 74 75 73 22 2C 22 50 61 79 6C 6F 61 64 22 3A 22 7B 5C 22 69 73 6F 6E 5C 22 3A 66 61 6C 73 65 2C 5C 22 68 61 73 5F 74 69 6D 65 72 5C 22 3A 66 61 6C 73 65 2C 5C 22 74 69 6D 65 72 5F 73 74 61 72 74 65 64 5C 22 3A 30 2C 5C 22 74 69 6D 65 72 5F 64 75 72 61 74 69 6F 6E 5C 22 3A 30 2C 5C 22 74 69 6D 65 72 5F 72 65 6D 61 69 6E 69 6E 67 5C 22 3A 30 2C 5C 22 6D 6F 64 65 5C 22 3A 5C 22 77 68 69 74 65 5C 22 2C 5C 22 62 72 69 67 68 74 6E 65 73 73 5C 22 3A 34 31 7D 22 7D
TXT: 12.06.2020, 09:31:15 | MQTT Topic | shellies/shellyrgbw2-6622B0/white/0/status
HEX: 12.06.2020, 09:31:15 | MQTT Topic | 73 68 65 6C 6C 69 65 73 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 2F 77 68 69 74 65 2F 30 2F 73 74 61 74 75 73
TXT: 12.06.2020, 09:31:15 | ShellyRGBW2 Payload | {"ison":false,"has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"mode":"white","brightness":41}
HEX: 12.06.2020, 09:31:15 | ShellyRGBW2 Payload | 7B 22 69 73 6F 6E 22 3A 66 61 6C 73 65 2C 22 68 61 73 5F 74 69 6D 65 72 22 3A 66 61 6C 73 65 2C 22 74 69 6D 65 72 5F 73 74 61 72 74 65 64 22 3A 30 2C 22 74 69 6D 65 72 5F 64 75 72 61 74 69 6F 6E 22 3A 30 2C 22 74 69 6D 65 72 5F 72 65 6D 61 69 6E 69 6E 67 22 3A 30 2C 22 6D 6F 64 65 22 3A 22 77 68 69 74 65 22 2C 22 62 72 69 67 68 74 6E 65 73 73 22 3A 34 31 7D
TXT: 12.06.2020, 09:31:15 | ShellyRGBW2 Channel | 0
HEX: 12.06.2020, 09:31:15 | ShellyRGBW2 Channel | 30
TXT: 12.06.2020, 09:31:15 | JSON | {"DataID":"{7F7632D9-FA40-4F38-8DEA-C83CD4325A32}","PacketType":3,"QualityOfService":0,"Retain":true,"Topic":"shellies/shellyrgbw2-6622B0/white/1","Payload":"off"}
HEX: 12.06.2020, 09:31:15 | JSON | 7B 22 44 61 74 61 49 44 22 3A 22 7B 37 46 37 36 33 32 44 39 2D 46 41 34 30 2D 34 46 33 38 2D 38 44 45 41 2D 43 38 33 43 44 34 33 32 35 41 33 32 7D 22 2C 22 50 61 63 6B 65 74 54 79 70 65 22 3A 33 2C 22 51 75 61 6C 69 74 79 4F 66 53 65 72 76 69 63 65 22 3A 30 2C 22 52 65 74 61 69 6E 22 3A 74 72 75 65 2C 22 54 6F 70 69 63 22 3A 22 73 68 65 6C 6C 69 65 73 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 2F 77 68 69 74 65 2F 31 22 2C 22 50 61 79 6C 6F 61 64 22 3A 22 6F 66 66 22 7D
TXT: 12.06.2020, 09:31:15 | MQTT Topic | shellies/shellyrgbw2-6622B0/white/1
HEX: 12.06.2020, 09:31:15 | MQTT Topic | 73 68 65 6C 6C 69 65 73 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 2F 77 68 69 74 65 2F 31
TXT: 12.06.2020, 09:31:15 | JSON | {"DataID":"{7F7632D9-FA40-4F38-8DEA-C83CD4325A32}","PacketType":3,"QualityOfService":0,"Retain":true,"Topic":"shellies/shellyrgbw2-6622B0/white/1/status","Payload":"{\"ison\":false,\"has_timer\":false,\"timer_started\":0,\"timer_duration\":0,\"timer_remaining\":0,\"mode\":\"white\",\"brightness\":12}"}
HEX: 12.06.2020, 09:31:15 | JSON | 7B 22 44 61 74 61 49 44 22 3A 22 7B 37 46 37 36 33 32 44 39 2D 46 41 34 30 2D 34 46 33 38 2D 38 44 45 41 2D 43 38 33 43 44 34 33 32 35 41 33 32 7D 22 2C 22 50 61 63 6B 65 74 54 79 70 65 22 3A 33 2C 22 51 75 61 6C 69 74 79 4F 66 53 65 72 76 69 63 65 22 3A 30 2C 22 52 65 74 61 69 6E 22 3A 74 72 75 65 2C 22 54 6F 70 69 63 22 3A 22 73 68 65 6C 6C 69 65 73 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 2F 77 68 69 74 65 2F 31 2F 73 74 61 74 75 73 22 2C 22 50 61 79 6C 6F 61 64 22 3A 22 7B 5C 22 69 73 6F 6E 5C 22 3A 66 61 6C 73 65 2C 5C 22 68 61 73 5F 74 69 6D 65 72 5C 22 3A 66 61 6C 73 65 2C 5C 22 74 69 6D 65 72 5F 73 74 61 72 74 65 64 5C 22 3A 30 2C 5C 22 74 69 6D 65 72 5F 64 75 72 61 74 69 6F 6E 5C 22 3A 30 2C 5C 22 74 69 6D 65 72 5F 72 65 6D 61 69 6E 69 6E 67 5C 22 3A 30 2C 5C 22 6D 6F 64 65 5C 22 3A 5C 22 77 68 69 74 65 5C 22 2C 5C 22 62 72 69 67 68 74 6E 65 73 73 5C 22 3A 31 32 7D 22 7D
TXT: 12.06.2020, 09:31:15 | MQTT Topic | shellies/shellyrgbw2-6622B0/white/1/status
HEX: 12.06.2020, 09:31:15 | MQTT Topic | 73 68 65 6C 6C 69 65 73 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 2F 77 68 69 74 65 2F 31 2F 73 74 61 74 75 73
TXT: 12.06.2020, 09:31:15 | ShellyRGBW2 Payload | {"ison":false,"has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"mode":"white","brightness":12}
HEX: 12.06.2020, 09:31:15 | ShellyRGBW2 Payload | 7B 22 69 73 6F 6E 22 3A 66 61 6C 73 65 2C 22 68 61 73 5F 74 69 6D 65 72 22 3A 66 61 6C 73 65 2C 22 74 69 6D 65 72 5F 73 74 61 72 74 65 64 22 3A 30 2C 22 74 69 6D 65 72 5F 64 75 72 61 74 69 6F 6E 22 3A 30 2C 22 74 69 6D 65 72 5F 72 65 6D 61 69 6E 69 6E 67 22 3A 30 2C 22 6D 6F 64 65 22 3A 22 77 68 69 74 65 22 2C 22 62 72 69 67 68 74 6E 65 73 73 22 3A 31 32 7D
TXT: 12.06.2020, 09:31:15 | ShellyRGBW2 Channel | 1
HEX: 12.06.2020, 09:31:15 | ShellyRGBW2 Channel | 31
TXT: 12.06.2020, 09:31:15 | JSON | {"DataID":"{7F7632D9-FA40-4F38-8DEA-C83CD4325A32}","PacketType":3,"QualityOfService":0,"Retain":true,"Topic":"shellies/shellyrgbw2-6622B0/white/2","Payload":"off"}
HEX: 12.06.2020, 09:31:15 | JSON | 7B 22 44 61 74 61 49 44 22 3A 22 7B 37 46 37 36 33 32 44 39 2D 46 41 34 30 2D 34 46 33 38 2D 38 44 45 41 2D 43 38 33 43 44 34 33 32 35 41 33 32 7D 22 2C 22 50 61 63 6B 65 74 54 79 70 65 22 3A 33 2C 22 51 75 61 6C 69 74 79 4F 66 53 65 72 76 69 63 65 22 3A 30 2C 22 52 65 74 61 69 6E 22 3A 74 72 75 65 2C 22 54 6F 70 69 63 22 3A 22 73 68 65 6C 6C 69 65 73 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 2F 77 68 69 74 65 2F 32 22 2C 22 50 61 79 6C 6F 61 64 22 3A 22 6F 66 66 22 7D
TXT: 12.06.2020, 09:31:15 | MQTT Topic | shellies/shellyrgbw2-6622B0/white/2
HEX: 12.06.2020, 09:31:15 | MQTT Topic | 73 68 65 6C 6C 69 65 73 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 2F 77 68 69 74 65 2F 32
TXT: 12.06.2020, 09:31:15 | JSON | {"DataID":"{7F7632D9-FA40-4F38-8DEA-C83CD4325A32}","PacketType":3,"QualityOfService":0,"Retain":true,"Topic":"shellies/shellyrgbw2-6622B0/white/2/status","Payload":"{\"ison\":false,\"has_timer\":false,\"timer_started\":0,\"timer_duration\":0,\"timer_remaining\":0,\"mode\":\"white\",\"brightness\":12}"}
HEX: 12.06.2020, 09:31:15 | JSON | 7B 22 44 61 74 61 49 44 22 3A 22 7B 37 46 37 36 33 32 44 39 2D 46 41 34 30 2D 34 46 33 38 2D 38 44 45 41 2D 43 38 33 43 44 34 33 32 35 41 33 32 7D 22 2C 22 50 61 63 6B 65 74 54 79 70 65 22 3A 33 2C 22 51 75 61 6C 69 74 79 4F 66 53 65 72 76 69 63 65 22 3A 30 2C 22 52 65 74 61 69 6E 22 3A 74 72 75 65 2C 22 54 6F 70 69 63 22 3A 22 73 68 65 6C 6C 69 65 73 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 2F 77 68 69 74 65 2F 32 2F 73 74 61 74 75 73 22 2C 22 50 61 79 6C 6F 61 64 22 3A 22 7B 5C 22 69 73 6F 6E 5C 22 3A 66 61 6C 73 65 2C 5C 22 68 61 73 5F 74 69 6D 65 72 5C 22 3A 66 61 6C 73 65 2C 5C 22 74 69 6D 65 72 5F 73 74 61 72 74 65 64 5C 22 3A 30 2C 5C 22 74 69 6D 65 72 5F 64 75 72 61 74 69 6F 6E 5C 22 3A 30 2C 5C 22 74 69 6D 65 72 5F 72 65 6D 61 69 6E 69 6E 67 5C 22 3A 30 2C 5C 22 6D 6F 64 65 5C 22 3A 5C 22 77 68 69 74 65 5C 22 2C 5C 22 62 72 69 67 68 74 6E 65 73 73 5C 22 3A 31 32 7D 22 7D
TXT: 12.06.2020, 09:31:15 | MQTT Topic | shellies/shellyrgbw2-6622B0/white/2/status
HEX: 12.06.2020, 09:31:15 | MQTT Topic | 73 68 65 6C 6C 69 65 73 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 2F 77 68 69 74 65 2F 32 2F 73 74 61 74 75 73
TXT: 12.06.2020, 09:31:15 | ShellyRGBW2 Channel | 2
HEX: 12.06.2020, 09:31:15 | ShellyRGBW2 Channel | 32
TXT: 12.06.2020, 09:31:15 | JSON | {"DataID":"{7F7632D9-FA40-4F38-8DEA-C83CD4325A32}","PacketType":3,"QualityOfService":0,"Retain":true,"Topic":"shellies/shellyrgbw2-6622B0/white/3","Payload":"off"}
HEX: 12.06.2020, 09:31:15 | JSON | 7B 22 44 61 74 61 49 44 22 3A 22 7B 37 46 37 36 33 32 44 39 2D 46 41 34 30 2D 34 46 33 38 2D 38 44 45 41 2D 43 38 33 43 44 34 33 32 35 41 33 32 7D 22 2C 22 50 61 63 6B 65 74 54 79 70 65 22 3A 33 2C 22 51 75 61 6C 69 74 79 4F 66 53 65 72 76 69 63 65 22 3A 30 2C 22 52 65 74 61 69 6E 22 3A 74 72 75 65 2C 22 54 6F 70 69 63 22 3A 22 73 68 65 6C 6C 69 65 73 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 2F 77 68 69 74 65 2F 33 22 2C 22 50 61 79 6C 6F 61 64 22 3A 22 6F 66 66 22 7D
TXT: 12.06.2020, 09:31:15 | MQTT Topic | shellies/shellyrgbw2-6622B0/white/3
HEX: 12.06.2020, 09:31:15 | MQTT Topic | 73 68 65 6C 6C 69 65 73 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 2F 77 68 69 74 65 2F 33
TXT: 12.06.2020, 09:31:15 | JSON | {"DataID":"{7F7632D9-FA40-4F38-8DEA-C83CD4325A32}","PacketType":3,"QualityOfService":0,"Retain":true,"Topic":"shellies/shellyrgbw2-6622B0/white/3/status","Payload":"{\"ison\":false,\"has_timer\":false,\"timer_started\":0,\"timer_duration\":0,\"timer_remaining\":0,\"mode\":\"white\",\"brightness\":12}"}
HEX: 12.06.2020, 09:31:15 | JSON | 7B 22 44 61 74 61 49 44 22 3A 22 7B 37 46 37 36 33 32 44 39 2D 46 41 34 30 2D 34 46 33 38 2D 38 44 45 41 2D 43 38 33 43 44 34 33 32 35 41 33 32 7D 22 2C 22 50 61 63 6B 65 74 54 79 70 65 22 3A 33 2C 22 51 75 61 6C 69 74 79 4F 66 53 65 72 76 69 63 65 22 3A 30 2C 22 52 65 74 61 69 6E 22 3A 74 72 75 65 2C 22 54 6F 70 69 63 22 3A 22 73 68 65 6C 6C 69 65 73 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 2F 77 68 69 74 65 2F 33 2F 73 74 61 74 75 73 22 2C 22 50 61 79 6C 6F 61 64 22 3A 22 7B 5C 22 69 73 6F 6E 5C 22 3A 66 61 6C 73 65 2C 5C 22 68 61 73 5F 74 69 6D 65 72 5C 22 3A 66 61 6C 73 65 2C 5C 22 74 69 6D 65 72 5F 73 74 61 72 74 65 64 5C 22 3A 30 2C 5C 22 74 69 6D 65 72 5F 64 75 72 61 74 69 6F 6E 5C 22 3A 30 2C 5C 22 74 69 6D 65 72 5F 72 65 6D 61 69 6E 69 6E 67 5C 22 3A 30 2C 5C 22 6D 6F 64 65 5C 22 3A 5C 22 77 68 69 74 65 5C 22 2C 5C 22 62 72 69 67 68 74 6E 65 73 73 5C 22 3A 31 32 7D 22 7D
TXT: 12.06.2020, 09:31:15 | MQTT Topic | shellies/shellyrgbw2-6622B0/white/3/status
HEX: 12.06.2020, 09:31:15 | MQTT Topic | 73 68 65 6C 6C 69 65 73 2F 73 68 65 6C 6C 79 72 67 62 77 32 2D 36 36 32 32 42 30 2F 77 68 69 74 65 2F 33 2F 73 74 61 74 75 73
TXT: 12.06.2020, 09:31:15 | ShellyRGBW2 Channel | 3
HEX: 12.06.2020, 09:31:15 | ShellyRGBW2 Channel | 33
[/QUOTE]
@Kais
Mit dem Firmware Update auf 1.7.2 sind die Meldungen weg. Lag dann wohl am Shelly.
Richimaint
