[Modul] Shelly
Teste mal bitte folgendes Script:
 * This script will use BLE observer to listen for advertising data from nearby Shelly BLU devices,
 * decodes the data using a BTHome data structure, and emits the decoded data for further processing.
 * This script DOESN'T execute actions, only emit events. Can be used with `ble-events-handler.js` example.
 * You can configure the event name, by default its `shelly-blu`, the body of the event contains all the data
 * parsed from the BLE device
 * Represents data provided by each device.
 * Every value illustrating a sensor reading (e.g., button) may be a singular sensor value or
 * an array of values if the object has multiple instances.
 * @typedef {Object} DeviceData
 * @property {number} pid - Packet ID.
 * @property {number} battery - The battery level of the device in percentage (%).
 * @property {number} rssi - The signal strength in decibels (dB).
 * @property {string} address - The MAC address of the Shelly BLU device.
 * @property {string} model - The model of the Shelly BLU device.
 * @property {number | number[]} [temperature] - The temperature value in degrees Celsius if the device has a temperature sensor. (Can be an array if has multiple instances)
 * @property {number | number[]} [humidity] - The humidity value in percentage (%) if the device has a humidity sensor. (Can be an array if has multiple instances)
 * @property {number | number[]} [illuminance] - The illuminance value in lux if the device has a light sensor. (Can be an array if has multiple instances)
 * @property {number | number[]} [motion] - Motion status: 0 for clear, 1 for motion (if the device has a motion sensor). (Can be an array if has multiple instances)
 * @property {number | number[]} [window] - Window status: 0 for closed, 1 for open (if the device has a reed switch). (Can be an array if has multiple instances)
 * @property {number | number[]} [button] - The number of presses if the device has a button. (Can be an array if has multiple instances)
 * @property {number | number[]} [rotation] - The angle of rotation in degrees if the device has a gyroscope. (Can be an array if has multiple instances)
 * @example
 * {"component":"script:*","name":"script","id":*,"now":*,"info":{"component":"script:*","id":*,"event":"shelly-blu","data":{"encryption":false,"BTHome_version":2,"pid":118,"battery":100,"button":1,"rssi":-76,"address":*},"ts":*}}
/******************* START CHANGE HERE *******************/
const CONFIG = {
  // Specify the destination event where the decoded BLE data will be emitted. It allows for easy identification by other applications/scripts
  eventName: "shelly-blu",
  // If the script owns the scanner and this value is set to true, the scan will be active.
  // If the script does not own the scanner, it may remain passive even when set to true.
  // Active scan means the scanner will ping back the Bluetooth device to receive all its data, but it will drain the battery faster
  active: false,
  // When set to true, debug messages will be logged to the console
  debug: false,
/******************* STOP CHANGE HERE *******************/
const BTHOME_SVC_ID_STR = "fcd2";
const uint8 = 0;
const int8 = 1;
const uint16 = 2;
const int16 = 3;
const uint24 = 4;
const int24 = 5;
// The BTH object defines the structure of the BTHome data
const BTH = {
  0x00: { n: "pid", t: uint8 },
  0x01: { n: "battery", t: uint8, u: "%" },
  0x02: { n: "temperature", t: int16, f: 0.01, u: "tC" },
  0x03: { n: "humidity", t: uint16, f: 0.01, u: "%" },
  0x05: { n: "illuminance", t: uint24, f: 0.01 },
  0x21: { n: "motion", t: uint8 },
  0x2d: { n: "window", t: uint8 },
  0x2e: { n: "humidity", t: uint8, u: "%" },
  0x3a: { n: "button", t: uint8 },
  0x3f: { n: "rotation", t: int16, f: 0.1 },
  0x45: { n: "temperature", t: int16, f: 0.1, u: "tC" },
function getByteSize(type) {
  if (type === uint8 || type === int8) return 1;
  if (type === uint16 || type === int16) return 2;
  if (type === uint24 || type === int24) return 3;
  //impossible as advertisements are much smaller;
  return 255;
// functions for decoding and unpacking the service data from Shelly BLU devices
const BTHomeDecoder = {
  utoi: function (num, bitsz) {
    const mask = 1 << (bitsz - 1);
    return num & mask ? num - (1 << bitsz) : num;
  getUInt8: function (buffer) {
    return buffer.at(0);
  getInt8: function (buffer) {
    return this.utoi(this.getUInt8(buffer), 8);
  getUInt16LE: function (buffer) {
    return 0xffff & ((buffer.at(1) << 8) | buffer.at(0));
  getInt16LE: function (buffer) {
    return this.utoi(this.getUInt16LE(buffer), 16);
  getUInt24LE: function (buffer) {
    return (
      0x00ffffff & ((buffer.at(2) << 16) | (buffer.at(1) << 8) | buffer.at(0))
  getInt24LE: function (buffer) {
    return this.utoi(this.getUInt24LE(buffer), 24);
  getBufValue: function (type, buffer) {
    if (buffer.length < getByteSize(type)) return null;
    let res = null;
    if (type === uint8) res = this.getUInt8(buffer);
    if (type === int8) res = this.getInt8(buffer);
    if (type === uint16) res = this.getUInt16LE(buffer);
    if (type === int16) res = this.getInt16LE(buffer);
    if (type === uint24) res = this.getUInt24LE(buffer);
    if (type === int24) res = this.getInt24LE(buffer);
    return res;
  // Unpacks the service data buffer from a Shelly BLU device
  unpack: function (buffer) {
    //beacons might not provide BTH service data
    if (typeof buffer !== "string" || buffer.length === 0) return null;
    let result = {};
    let _dib = buffer.at(0);
    result["encryption"] = _dib & 0x1 ? true : false;
    result["BTHome_version"] = _dib >> 5;
    if (result["BTHome_version"] !== 2) return null;
    //can not handle encrypted data
    if (result["encryption"]) return result;
    buffer = buffer.slice(1);
    let _bth;
    let _value;
    while (buffer.length > 0) {
      _bth = BTH[buffer.at(0)];
      if (typeof _bth === "undefined") {
        console.log("BTH: Unknown type");
        break;
      _value = this.getBufValue(_bth.t, buffer);
      if (_value === null) break;
      if (typeof _bth.f !== "undefined") _value = _value * _bth.f;
      if (typeof result[_bth.n] === "undefined") {
        result[_bth.n] = _value;
      else {
        if (Array.isArray(result[_bth.n])) {
          result[_bth.n].push(_value);
        else {
          result[_bth.n] = [
            result[_bth.n],
            _value
      buffer = buffer.slice(getByteSize(_bth.t));
    return result;
 * Еmitting the decoded BLE data to a specified event. It allows other scripts to receive and process the emitted data
 * @param {DeviceData} data
function emitData(data) {
  if (typeof data !== "object") {
    return;
  Shelly.emitEvent(CONFIG.eventName, data);
//saving the id of the last packet, this is used to filter the duplicated packets
let lastPacketId = 0x100;
// Callback for the BLE scanner object
function BLEScanCallback(event, result) {
  //exit if not a result of a scan
  if (event !== BLE.Scanner.SCAN_RESULT) {
    return;
  //exit if service_data member is missing
  if (
    typeof result.service_data === "undefined" ||
    typeof result.service_data[BTHOME_SVC_ID_STR] === "undefined"
    return;
  let unpackedData = BTHomeDecoder.unpack(
  //exit if unpacked data is null or the device is encrypted
  if (
    unpackedData === null ||
    typeof unpackedData === "undefined" ||
    unpackedData["encryption"]
    console.log("Error: Encrypted devices are not supported");
    return;
  //exit if the event is duplicated
  if (lastPacketId === unpackedData.pid) {
    return;
  lastPacketId = unpackedData.pid;
  unpackedData.rssi = result.rssi;
  unpackedData.address = result.addr;
  unpackedData.model = result.local_name;
  emitData(unpackedData);
// Initializes the script and performs the necessary checks and configurations
function init() {
  //exit if can't find the config
  if (typeof CONFIG === "undefined") {
    console.log("Error: Undefined config");
    return;
  //get the config of ble component
  const BLEConfig = Shelly.getComponentConfig("ble");
  //exit if the BLE isn't enabled
  if (!BLEConfig.enable) {
    console.log(
      "Error: The Bluetooth is not enabled, please enable it from settings"
    return;
  //check if the scanner is already running
  if (BLE.Scanner.isRunning()) {
    console.log("Info: The BLE gateway is running, the BLE scan configuration is managed by the device");
  else {
    //start the scanner
    const bleScanner = BLE.Scanner.Start({
        duration_ms: BLE.Scanner.INFINITE_SCAN,
        active: CONFIG.active
    if(!bleScanner) {
      console.log("Error: Can not start new scanner");
  //subscribe a callback to BLE scanner
  BLE.Scanner.Subscribe(BLEScanCallback);
  // disable console.log when logs are disabled
  if (!CONFIG.debug) {
    console.log = function() {};
init();
Das ist bei mir auf dem Gateway und damit funktioniert es.
