Great work, thanks! I now understand why I had the extra sockets and gateways.
I have an extra feature request: do you see a way to read the state codes of the fronius? Last week it was 36 degrees and the fronius rebooted a couple of times. Fronius Solar web didn’t mentioned anything was wrong. Later I looked manually at the state codes (using code 37767) and noticed that is was a little bit to hot. Why Fronius makes it impossible to read the state codes by using the webpage of the converter puzzles me. Maybe you have a solution and we can combine the explanation of the codes also (now you get a code 307 or a 317 that I need to lookup on the internet).
An additional feature request: please don’t change the Interval when you do an update. Some I have changed and the program changes them back to 60000 miliseconds. Please respect the changes that have been done to the Interval ;).
thank you!
I’m happy, that the SmartMeter is working for you.
St and StVnd will not help identifying the error.
Have you had a look to Evt1, Evt2, EvtVnd1, EvtVnd2 and EvtVnd3?
Below this Modbus-Instances you can find boolean variables representing the different error states.
E.g. The over temperature error can be found under „Evt1“ –> „I_EVENT_OVER_TEMP“ or under „EvtVnd1“ –> „OVER_TEMP“
Is this what you are looking for?
Ja, ich sehe nur das der Wechselrichter Modbus TCP unterstützen muss.
Aber meine Frage war eher allgemeiner Natur, welchen würdet ihr mir Empfehlen, er sollte natürlich mit deinem Modul funktionieren…
es spielt keine Rolle, ob Galvo, Primo, Symo oder Symo Hybrid. Alle aktuellen Wechselrichter von Fronius unterstützen aktuell Modbus TCP.
Mit Batteriespeicher kannst du eigentlich nur den Symo Hybrid nehmen, außer du hast eine zusätzliche Ladeelektronik in deinem Speicher. Kompatible Batterien
An meinem Wechselrichter ist per S0 Schnittstelle ein Finder Zähler angeschlossen der den elektrischen Verbrauch unseres Hauses misst und an den Wechselrichter weiter gibt. Zudem habe ich ja den Bezugs- und Verkaufszähler. Für die Meldung an das Finanzamt ziehe ich den Wert des Bezugs vom Hausverbrauch ab = Eigenverbrauch.
Den Zählerstand von Bezug und Abgabe habe ich via Discovergy in IP-Symcon. Muss aber trotzdem jedes mal in den Keller wegen dem blöden Hausverbrauch.
Gibt es eine Möglichkeit einen Zählerstand via dem Gleichrichter zu generieren ?
Registriert der Wechselrichter auch nachts die Signale über die S0 Schnittstelle?
Wird der Wert des Eigenverbrauchs (aktueller) bzw Hausverbrauch überhaupt per Modbus ausgegeben ?
ich hatte das vor einiger Zeit schon mal durchgelesen, ohne mir aber die einzelnen gelieferten Werte anzuschauen.
Ich habe Dein Modul auch noch nicht im Einsatz und deshalb nicht intensiv auseinander gesetzt.
Ich vermute aber nachdem ich heute nochmal darüber nachgedacht habe sowie mir die Daten im Fronius Solar Web angeschaut habe, dass mein Vorhaben nicht so einfach geht. Der Wechselrichter liefert ja nur die Werte des Eigenverbrauchs tagsüber, ich möchte aber den Zählerstand des Gesamthauszählers. Ich vermute einen verlässlichen Zählerstand zu erhalten ist nicht so einfach.
den Fronius SmartMeter kannst du direkt mit der ID 240 ansprechen und auch mit diesem Fronius Modul verwenden. Mit dem Fronius SmartMeter kannst du natürlich den Hausverbrauch ermitteln, sofern er an geeigneter Stelle verbaut wird.
Hallo Brovning,
sein Modul ist super - Vielen Dank dafür.
So gut, das ich es ein weiteres mal installieren möchte-
Ich habe eine weitere Anlage, in der 3 x einphasige Galvo 2,5 über Fronius-Bus zusammengeschaltet sind.
Wenn ich im Modulstore jedoch auf ein weiteres mal installieren klicke, wird keine weitere Instanz angelegt.
Ist das so gewollt oder was mache ich falsch ?
Ja, das funktioniert. Du musst in dem gewünschten Ordner, im welchem das neue Modul erstellt werden soll einen rechtsklick machen –> Add Object –> Instance.
Im neuen Fenster nach „Fronius“ filter.
Mein Modul auswählen.
Name festlegen und Ok klicken.
Fertig!
