Irgendwie ist der Wechsel meinem System nicht bekommen. Es wurde ein Logfile von 720MB für 3.5 Stunden angelegt (üblich sind ca. 60MB/Tag). Normaler Verlauf bis 02:59:59, ab dann
02:00:09 | 00000 | MESSAGE | ScriptEngine | Too many scripts at once. Dropping execution...
02:00:09 | 16466 | MESSAGE | VariableManager | [Zentral_Skripte\Unwetterzentrale\Unwetterzentrale\Regenwert] = 2646
02:00:09 | 12647 | DEBUG | ScriptEngine | Executed Event 12647 ~ Sender: TimerEvent
02:00:09 | 12647 | WARNING | ScriptEngine | Result for Event 12647
<br />
<b>Warning</b>: imagecreatefrompng(): gd-png: fatal libpng error: IDAT: CRC error in <b>/var/lib/symcon/modules/SymconMisc/Unwetterzentrale/module.php</b> on line <b>96</b><br />
<br />
<b>Warning</b>: imagecreatefrompng(): gd-png error: setjmp returns error condition in <b>/var/lib/symcon/modules/SymconMisc/Unwetterzentrale/module.php</b> on line <b>96</b><br />
<br />
<b>Warning</b>: imagecreatefrompng(): '/var/lib/symcon/media/radar42839.png' is not a valid PNG file in <b>/var/lib/symcon/modules/SymconMisc/Unwetterzentrale/module.php</b> on line <b>96</b><br />
<br />
<b>Warning</b>: imagecolorresolve() expects parameter 1 to be resource, boolean given in <b>/var/lib/symcon/modules/SymconMisc/Unwetterzentrale/module.php</b> on line <b>99</b><br />
<br />
<b>Warning</b>: imagecolorresolve() expects parameter 1 to be resource, boolean given in <b>/var/lib/symcon/modules/SymconMisc/Unwetterzentrale/module.php</b> on line <b>100</b><br />
<br />
<b>Warning</b>: imagecolorresolve() expects parameter 1 to be resource, boolean given in <b>/var/lib/symcon/modules/SymconMisc/Unwetterzentrale/module.php</b> on line <b>101</b><br />
<br />
<b>Warning</b>: imagecolorresolve() expects parameter 1 to be resource, boolean given in <b>/var/lib/symcon/modules/SymconMisc/Unwetterzentrale/module.php</b> on line <b>102</b><br />
<br />
<b>Warning</b>: imagecolorresolve() expects parameter 1 to be resource, boolean given in <b>/var/lib/symcon/modules/SymconMisc/Unwetterzentrale/module.php</b> on line <b>103</b><br />
<br />
<b>Warning</b>: imagecolorresolve() expects parameter 1 to be resource, boolean given in <b>/var/lib/symcon/modules/SymconMisc/Unwetterzentrale/module.php</b> on line <b>104</b><br />
<br />
<b>Warning</b>: imagecolorat() expects parameter 1 to be resource, boolean given in <b>/var/lib/symcon/modules/SymconMisc/Unwetterzentrale/module.php</b> on line <b>110</b><br />
<br />
Seit dem Neustart nach 03:00 ist alles wieder normal. Was läuft da schief? Hab ich was übersehen, was hätte geändert werden müssen?
Um 3:00Uhr (auf 2:00Uhr) die Rückstellung der Zeit…
IPS lebte dann noch 15min und hat sich beendet.
Durch meinen watchdog wurde IPS auf dem Pi um 2:15 WINTERZEIT wieder gestartet, und läuft bis jetzt wieder rund.
So wie ich sehe, hat es bisher nur die Pi Version zum Absturz gebracht, oder?
Ich glaube es gibt insgesamt zwei Probleme zu lösen:
a) Warum führt IP-Symcon beim Zeitsprung Skripte, die genau um 02:00:00 starten, mehrfach aus?
b) Warum greift das „Verwerfe Ausführung…“ korrekt, aber IP-Symcon stürzt (auf Pi) ab.
Mein d
pi + ips 4 ist auch durchgelaufen. Meiner hat auf Basis der astrofunktion die Jalousien passend geöffnet und läuft brav vor sich hin… Ohne absturz
Auch bei mir (Pi3, Testing V4.1) beim Sprung von 2:59:59 auf 2:00:00 (Winterzeit) das total Chaos.
Siehe Vorredner.
Aber ab 3:00:00 beruhigt es sich schlagartig. KEIN ABSTURZ Ich denke es sind die Timer und Ereignisse, die da mit der rückversetzten Zeit nicht mehr klargekommen sind.
Habe gerade bemerkt, das meine Heizung nicht mehr abgefragt wird !
-> Die Registervariable des ClientSocket meines Exsys6034 reicht nicht mehr an das Script durch !!!
Alle Versuche es wieder zum laufen zu bekommen scheitern.
