Ich habe hier das gleiche Problem.
Alles korrekt eingerichtet (denke ich) und laut Debug Protokoll kommen auch Daten an.
Diese allerdings werden nicht in die Variablen eingetragen.
Ich benutze nur Counter4 (Wasserzähler) und habe den Standardnamen geändert.
Laut Dump werden sämtliche Counter (auch Nr4, mein Wasserzähler) zwar korrekt ausgelesen aber ignoeriert (ignore ident=PULSE_wasser_zaehler_m3, value=272,501).
Ach ja, die Variablen „Uptime“ und „Wifi-Signal“ werden korrekt beschickt.
Hier der Dump:
TXT: 27.10.2022, 07:04:22 | ReceiveData | 192.168.168.47:54356 => connected
TXT: 27.10.2022, 07:04:22 | ReceiveData | 192.168.168.47:54356 => received: {"modultyp":"PULSECOUNTER","vars":[{"name":"0","homematic_name":"PULSE_counterIP","desc":"ip des pulsecounters","type":"string","unit":"","value":"192.168.168.47"},{"name":"11","homematic_name":"PULSE_counter1","desc":"w_counter_1","type":"number","unit":"KWh","value":0.000},{"name":"12","homematic_name":"PULSE_power1","desc":"w_power_1","type":"number","unit":"KW","value":0.000},{"name":"13","homematic_name":"PULSE_counter2","desc":"w_counter_2","type":"number","unit":"KWh","value":0.000},{"name":"14","homematic_name":"PULSE_power2","desc":"w_power_2","type":"number","unit":"KW","value":0.000},{"name":"15","homematic_name":"PULSE_counter3","desc":"w_counter_3","type":"number","unit":"KWh","value":0.000},{"name":"16","homematic_name":"PULSE_power3","desc":"w_power_3","type":"number","unit":"KW","value":0.000},{"name":"17","homematic_name":"PULSE_wasser_zaehler_m3","desc":"w_counter_4","type":"number","unit":"m3","value":272.501},{"name":"18","homematic_name":"PULSE_wasser_zaehler_m3proh","desc":"w_power_4","type":"number","unit":"m3/h","value":0.008}],"Systeminfo":{"MAC-Adresse":"DE:AD:BE:EF:FE:00","Homematic_CCU_ip":"192.168.168.44","sec_seit_reset":"138099","zeitpunkt":"2022.10.27 /07h04","firmware":"counter_LAN29"}}<EOT>
TXT: 27.10.2022, 07:04:22 | ReceiveData | 192.168.168.47:54356 => disonnected
TXT: 27.10.2022, 07:04:22 | ProcessData | data=Array<LF>(<LF> [modultyp] => PULSECOUNTER<LF> [vars] => Array<LF> (<LF> [0] => Array<LF> (<LF> [name] => 0<LF> [homematic_name] => PULSE_counterIP<LF> [desc] => ip des pulsecounters<LF> [type] => string<LF> [unit] => <LF> [value] => 192.168.168.47<LF> )<LF><LF> [1] => Array<LF> (<LF> [name] => 11<LF> [homematic_name] => PULSE_counter1<LF> [desc] => w_counter_1<LF> [type] => number<LF> [unit] => KWh<LF> [value] => 0<LF> )<LF><LF> [2] => Array<LF> (<LF> [name] => 12<LF> [homematic_name] => PULSE_power1<LF> [desc] => w_power_1<LF> [type] => number<LF> [unit] => KW<LF> [value] => 0<LF> )<LF><LF> [3] => Array<LF> (<LF> [name] => 13<LF> [homematic_name] => PULSE_counter2<LF> [desc] => w_counter_2<LF> [type] => number<LF> [unit] => KWh<LF> [value] => 0<LF> )<LF><LF> [4] => Array<LF> (<LF> [name] => 14<LF> [homematic_name] => PULSE_power2<LF> [desc] => w_power_2<LF> [type] => number<LF> [unit] => KW<LF> [value] => 0<LF> )<LF><LF> [5] => Array<LF> (<LF> [name] => 15<LF> [homematic_name] => PULSE_counter3<LF> [desc] => w_counter_3<LF> [type] => number<LF> [unit] => KWh<LF> [value] => 0<LF> )<LF><LF> [6] => Array<LF> (<LF> [name] => 16<LF> [homematic_name] => PULSE_power3<LF> [desc] => w_power_3<LF> [type] => number<LF> [unit] => KW<LF> [value] => 0<LF> )<LF><LF> [7] => Array<LF> (<LF> [name] => 17<LF> [homematic_name] => PULSE_wasser_zaehler_m3<LF> [desc] => w_counter_4<LF> [type] => number<LF> [unit] => m3<LF> [value] => 272,501<LF> )<LF><LF> [8] => Array<LF> (<LF> [name] => 18<LF> [homematic_name] => PULSE_wasser_zaehler_m3proh<LF> [desc] => w_power_4<LF> [type] => number<LF> [unit] => m3/h<LF> [value] => 0,008<LF> )<LF><LF> )<LF><LF> [Systeminfo] => Array<LF> (<LF> [MAC-Adresse] => DE:AD:BE:EF:FE:00<LF> [Homematic_CCU_ip] => 192.168.168.44<LF> [sec_seit_reset] => 138099<LF> [zeitpunkt] => 2022.10.27 /07h04<LF> [firmware] => counter_LAN29<LF> )<LF><LF>)<LF>
TXT: 27.10.2022, 07:04:22 | ProcessData | Systeminfo=Array<LF>(<LF> [MAC-Adresse] => DE:AD:BE:EF:FE:00<LF> [Homematic_CCU_ip] => 192.168.168.44<LF> [sec_seit_reset] => 138099<LF> [zeitpunkt] => 2022.10.27 /07h04<LF> [firmware] => counter_LAN29<LF>)<LF>
TXT: 27.10.2022, 07:04:22 | SetValue | mismatch of value "" for variable WifiStrength
TXT: 27.10.2022, 07:04:22 | ProcessData | modultyp=PULSECOUNTER, measure=27.10.2022 07:04:00, rssi=, uptime=138099s
TXT: 27.10.2022, 07:04:22 | ProcessData | vars=Array<LF>(<LF> [0] => Array<LF> (<LF> [name] => 0<LF> [homematic_name] => PULSE_counterIP<LF> [desc] => ip des pulsecounters<LF> [type] => string<LF> [unit] => <LF> [value] => 192.168.168.47<LF> )<LF><LF> [1] => Array<LF> (<LF> [name] => 11<LF> [homematic_name] => PULSE_counter1<LF> [desc] => w_counter_1<LF> [type] => number<LF> [unit] => KWh<LF> [value] => 0<LF> )<LF><LF> [2] => Array<LF> (<LF> [name] => 12<LF> [homematic_name] => PULSE_power1<LF> [desc] => w_power_1<LF> [type] => number<LF> [unit] => KW<LF> [value] => 0<LF> )<LF><LF> [3] => Array<LF> (<LF> [name] => 13<LF> [homematic_name] => PULSE_counter2<LF> [desc] => w_counter_2<LF> [type] => number<LF> [unit] => KWh<LF> [value] => 0<LF> )<LF><LF> [4] => Array<LF> (<LF> [name] => 14<LF> [homematic_name] => PULSE_power2<LF> [desc] => w_power_2<LF> [type] => number<LF> [unit] => KW<LF> [value] => 0<LF> )<LF><LF> [5] => Array<LF> (<LF> [name] => 15<LF> [homematic_name] => PULSE_counter3<LF> [desc] => w_counter_3<LF> [type] => number<LF> [unit] => KWh<LF> [value] => 0<LF> )<LF><LF> [6] => Array<LF> (<LF> [name] => 16<LF> [homematic_name] => PULSE_power3<LF> [desc] => w_power_3<LF> [type] => number<LF> [unit] => KW<LF> [value] => 0<LF> )<LF><LF> [7] => Array<LF> (<LF> [name] => 17<LF> [homematic_name] => PULSE_wasser_zaehler_m3<LF> [desc] => w_counter_4<LF> [type] => number<LF> [unit] => m3<LF> [value] => 272,501<LF> )<LF><LF> [8] => Array<LF> (<LF> [name] => 18<LF> [homematic_name] => PULSE_wasser_zaehler_m3proh<LF> [desc] => w_power_4<LF> [type] => number<LF> [unit] => m3/h<LF> [value] => 0,008<LF> )<LF><LF>)<LF>
TXT: 27.10.2022, 07:04:22 | ProcessData | ignore ident=PULSE_counterIP, value=192.168.168.47
TXT: 27.10.2022, 07:04:22 | ProcessData | ignore ident=PULSE_counter1, value=0
TXT: 27.10.2022, 07:04:22 | ProcessData | ignore ident=PULSE_power1, value=0
TXT: 27.10.2022, 07:04:22 | ProcessData | ignore ident=PULSE_counter2, value=0
TXT: 27.10.2022, 07:04:22 | ProcessData | ignore ident=PULSE_power2, value=0
TXT: 27.10.2022, 07:04:22 | ProcessData | ignore ident=PULSE_counter3, value=0
TXT: 27.10.2022, 07:04:22 | ProcessData | ignore ident=PULSE_power3, value=0
TXT: 27.10.2022, 07:04:22 | ProcessData | ignore ident=PULSE_wasser_zaehler_m3, value=272,501
TXT: 27.10.2022, 07:04:22 | ProcessData | ignore ident=PULSE_wasser_zaehler_m3proh, value=0,008
TXT: 27.10.2022, 07:05:22 | ReceiveData | 192.168.168.47:54357 => connected
TXT: 27.10.2022, 07:05:22 | ReceiveData | 192.168.168.47:54357 => received: {"modultyp":"PULSECOUNTER","vars":[{"name":"0","homematic_name":"PULSE_counterIP","desc":"ip des pulsecounters","type":"string","unit":"","value":"192.168.168.47"},{"name":"11","homematic_name":"PULSE_counter1","desc":"w_counter_1","type":"number","unit":"KWh","value":0.000},{"name":"12","homematic_name":"PULSE_power1","desc":"w_power_1","type":"number","unit":"KW","value":0.000},{"name":"13","homematic_name":"PULSE_counter2","desc":"w_counter_2","type":"number","unit":"KWh","value":0.000},{"name":"14","homematic_name":"PULSE_power2","desc":"w_power_2","type":"number","unit":"KW","value":0.000},{"name":"15","homematic_name":"PULSE_counter3","desc":"w_counter_3","type":"number","unit":"KWh","value":0.000},{"name":"16","homematic_name":"PULSE_power3","desc":"w_power_3","type":"number","unit":"KW","value":0.000},{"name":"17","homematic_name":"PULSE_wasser_zaehler_m3","desc":"w_counter_4","type":"number","unit":"m3","value":272.501},{"name":"18","homematic_name":"PULSE_wasser_zaehler_m3proh","desc":"w_power_4","type":"number","unit":"m3/h","value":0.008}],"Systeminfo":{"MAC-Adresse":"DE:AD:BE:EF:FE:00","Homematic_CCU_ip":"192.168.168.44","sec_seit_reset":"138159","zeitpunkt":"2022.10.27 /07h05","firmware":"counter_LAN29"}}<EOT>
TXT: 27.10.2022, 07:05:22 | ReceiveData | 192.168.168.47:54357 => disonnected
TXT: 27.10.2022, 07:05:22 | ProcessData | data=Array<LF>(<LF> [modultyp] => PULSECOUNTER<LF> [vars] => Array<LF> (<LF> [0] => Array<LF> (<LF> [name] => 0<LF> [homematic_name] => PULSE_counterIP<LF> [desc] => ip des pulsecounters<LF> [type] => string<LF> [unit] => <LF> [value] => 192.168.168.47<LF> )<LF><LF> [1] => Array<LF> (<LF> [name] => 11<LF> [homematic_name] => PULSE_counter1<LF> [desc] => w_counter_1<LF> [type] => number<LF> [unit] => KWh<LF> [value] => 0<LF> )<LF><LF> [2] => Array<LF> (<LF> [name] => 12<LF> [homematic_name] => PULSE_power1<LF> [desc] => w_power_1<LF> [type] => number<LF> [unit] => KW<LF> [value] => 0<LF> )<LF><LF> [3] => Array<LF> (<LF> [name] => 13<LF> [homematic_name] => PULSE_counter2<LF> [desc] => w_counter_2<LF> [type] => number<LF> [unit] => KWh<LF> [value] => 0<LF> )<LF><LF> [4] => Array<LF> (<LF> [name] => 14<LF> [homematic_name] => PULSE_power2<LF> [desc] => w_power_2<LF> [type] => number<LF> [unit] => KW<LF> [value] => 0<LF> )<LF><LF> [5] => Array<LF> (<LF> [name] => 15<LF> [homematic_name] => PULSE_counter3<LF> [desc] => w_counter_3<LF> [type] => number<LF> [unit] => KWh<LF> [value] => 0<LF> )<LF><LF> [6] => Array<LF> (<LF> [name] => 16<LF> [homematic_name] => PULSE_power3<LF> [desc] => w_power_3<LF> [type] => number<LF> [unit] => KW<LF> [value] => 0<LF> )<LF><LF> [7] => Array<LF> (<LF> [name] => 17<LF> [homematic_name] => PULSE_wasser_zaehler_m3<LF> [desc] => w_counter_4<LF> [type] => number<LF> [unit] => m3<LF> [value] => 272,501<LF> )<LF><LF> [8] => Array<LF> (<LF> [name] => 18<LF> [homematic_name] => PULSE_wasser_zaehler_m3proh<LF> [desc] => w_power_4<LF> [type] => number<LF> [unit] => m3/h<LF> [value] => 0,008<LF> )<LF><LF> )<LF><LF> [Systeminfo] => Array<LF> (<LF> [MAC-Adresse] => DE:AD:BE:EF:FE:00<LF> [Homematic_CCU_ip] => 192.168.168.44<LF> [sec_seit_reset] => 138159<LF> [zeitpunkt] => 2022.10.27 /07h05<LF> [firmware] => counter_LAN29<LF> )<LF><LF>)<LF>
TXT: 27.10.2022, 07:05:22 | ProcessData | Systeminfo=Array<LF>(<LF> [MAC-Adresse] => DE:AD:BE:EF:FE:00<LF> [Homematic_CCU_ip] => 192.168.168.44<LF> [sec_seit_reset] => 138159<LF> [zeitpunkt] => 2022.10.27 /07h05<LF> [firmware] => counter_LAN29<LF>)<LF>
TXT: 27.10.2022, 07:05:22 | SetValue | mismatch of value "" for variable WifiStrength
TXT: 27.10.2022, 07:05:22 | ProcessData | modultyp=PULSECOUNTER, measure=27.10.2022 07:05:00, rssi=, uptime=138159s
TXT: 27.10.2022, 07:05:22 | ProcessData | vars=Array<LF>(<LF> [0] => Array<LF> (<LF> [name] => 0<LF> [homematic_name] => PULSE_counterIP<LF> [desc] => ip des pulsecounters<LF> [type] => string<LF> [unit] => <LF> [value] => 192.168.168.47<LF> )<LF><LF> [1] => Array<LF> (<LF> [name] => 11<LF> [homematic_name] => PULSE_counter1<LF> [desc] => w_counter_1<LF> [type] => number<LF> [unit] => KWh<LF> [value] => 0<LF> )<LF><LF> [2] => Array<LF> (<LF> [name] => 12<LF> [homematic_name] => PULSE_power1<LF> [desc] => w_power_1<LF> [type] => number<LF> [unit] => KW<LF> [value] => 0<LF> )<LF><LF> [3] => Array<LF> (<LF> [name] => 13<LF> [homematic_name] => PULSE_counter2<LF> [desc] => w_counter_2<LF> [type] => number<LF> [unit] => KWh<LF> [value] => 0<LF> )<LF><LF> [4] => Array<LF> (<LF> [name] => 14<LF> [homematic_name] => PULSE_power2<LF> [desc] => w_power_2<LF> [type] => number<LF> [unit] => KW<LF> [value] => 0<LF> )<LF><LF> [5] => Array<LF> (<LF> [name] => 15<LF> [homematic_name] => PULSE_counter3<LF> [desc] => w_counter_3<LF> [type] => number<LF> [unit] => KWh<LF> [value] => 0<LF> )<LF><LF> [6] => Array<LF> (<LF> [name] => 16<LF> [homematic_name] => PULSE_power3<LF> [desc] => w_power_3<LF> [type] => number<LF> [unit] => KW<LF> [value] => 0<LF> )<LF><LF> [7] => Array<LF> (<LF> [name] => 17<LF> [homematic_name] => PULSE_wasser_zaehler_m3<LF> [desc] => w_counter_4<LF> [type] => number<LF> [unit] => m3<LF> [value] => 272,501<LF> )<LF><LF> [8] => Array<LF> (<LF> [name] => 18<LF> [homematic_name] => PULSE_wasser_zaehler_m3proh<LF> [desc] => w_power_4<LF> [type] => number<LF> [unit] => m3/h<LF> [value] => 0,008<LF> )<LF><LF>)<LF>
TXT: 27.10.2022, 07:05:22 | ProcessData | ignore ident=PULSE_counterIP, value=192.168.168.47
TXT: 27.10.2022, 07:05:22 | ProcessData | ignore ident=PULSE_counter1, value=0
TXT: 27.10.2022, 07:05:22 | ProcessData | ignore ident=PULSE_power1, value=0
TXT: 27.10.2022, 07:05:22 | ProcessData | ignore ident=PULSE_counter2, value=0
TXT: 27.10.2022, 07:05:22 | ProcessData | ignore ident=PULSE_power2, value=0
TXT: 27.10.2022, 07:05:22 | ProcessData | ignore ident=PULSE_counter3, value=0
TXT: 27.10.2022, 07:05:22 | ProcessData | ignore ident=PULSE_power3, value=0
TXT: 27.10.2022, 07:05:22 | ProcessData | ignore ident=PULSE_wasser_zaehler_m3, value=272,501
TXT: 27.10.2022, 07:05:22 | ProcessData | ignore ident=PULSE_wasser_zaehler_m3proh, value=0,008
