Hallo Burkhard,
ich habe die Geräteinformationen abgerufen und im Debug-Log steht folgendes:
TXT: 06.01.2023, 08:56:10 | symconExtensionCommand Topic | symcon/zigbee2mqtt/getDevice
HEX: 06.01.2023, 08:56:10 | symconExtensionCommand Topic | 73 79 6D 63 6F 6E 2F 7A 69 67 62 65 65 32 6D 71 74 74 2F 67 65 74 44 65 76 69 63 65
TXT: 06.01.2023, 08:56:10 | symconExtensionCommand Payload | Gästebad Wandlampe
HEX: 06.01.2023, 08:56:10 | symconExtensionCommand Payload | 47 C3 A4 73 74 65 62 61 64 20 57 61 6E 64 6C 61 6D 70 65
TXT: 06.01.2023, 08:56:10 | MQTT Topic | symcon/zigbee2mqtt/Gästebad Wandlampe/deviceInfo
HEX: 06.01.2023, 08:56:10 | MQTT Topic | 73 79 6D 63 6F 6E 2F 7A 69 67 62 65 65 32 6D 71 74 74 2F 47 C3 A4 73 74 65 62 61 64 20 57 61 6E 64 6C 61 6D 70 65 2F 64 65 76 69 63 65 49 6E 66 6F
TXT: 06.01.2023, 08:56:10 | MQTT Payload | {"zh":{"_events":{},"_eventsCount":0,"ID":84,"_type":"Router","_ieeeAddr":"0x001788010be84b0c","_networkAddress":47756,"_manufacturerID":4107,"_endpoints":[{"_events":{},"_eventsCount":0,"ID":11,"profileID":260,"deviceID":268,"inputClusters":[0,3,4,5,6,8,4096,64515,768],"outputClusters":[25],"deviceNetworkAddress":47756,"deviceIeeeAddress":"0x001788010be84b0c","clusters":{"genBasic":{"attributes":{"modelId":"929003056001","manufacturerName":"Philips","powerSource":1,"zclVersion":2,"appVersion":2,"stackVersion":1,"hwVersion":0,"dateCode":"20220502","swBuildId":"1.93.11"}},"lightingColorCtrl":{"attributes":{"colorCapabilities":16,"colorTempPhysicalMin":153,"colorTempPhysicalMax":454,"colorMode":2,"colorTemperature":370}},"genOnOff":{"attributes":{"onOff":1}},"genLevelCtrl":{"attributes":{"currentLevel":254}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"_events":{},"_eventsCount":0,"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":47756,"deviceIeeeAddress":"0x001788010be84b0c","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"Philips","_powerSource":"Mains (single phase)","_modelID":"929003056001","_applicationVersion":2,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":0,"_dateCode":"20220502","_softwareBuildID":"1.93.11","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":2},"_lastSeen":1672991759807,"_defaultSendRequestWhen":"immediate","_linkquality":66},"_definition":{"exposes":[{"type":"light","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE","description":"On/off state of this light"},{"type":"numeric","name":"brightness","property":"brightness","access":7,"value_min":0,"value_max":254,"description":"Brightness of this light"},{"type":"numeric","name":"color_temp","property":"color_temp","access":7,"unit":"mired","value_min":153,"value_max":454,"description":"Color temperature of this light","presets":[{"name":"coolest","value":153,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":454,"description":"Warmest temperature supported"}]},{"type":"numeric","name":"color_temp_startup","property":"color_temp_startup","access":7,"unit":"mired","value_min":153,"value_max":454,"description":"Color temperature after cold power on of this light","presets":[{"name":"coolest","value":153,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":454,"description":"Warmest temperature supported"},{"name":"previous","value":65535,"description":"Restore previous color_temp on cold power on"}]}]},{"type":"enum","name":"effect","property":"effect","access":2,"values":["blink","breathe","okay","channel_change","finish_effect","stop_effect"],"description":"Triggers an effect on the light (e.g. make light blink for a few seconds)"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"lightingColorCtrl","type":["attributeReport","readResponse"],"options":[{"type":"binary","name":"color_sync","property":"color_sync","access":2,"value_on":true,"value_off":false,"description":"When enabled colors will be synced, e.g. if the light supports both color x/y and color temperature a conversion from color x/y to color temperature will be done when setting the x/y color (default true)."}]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","brightness","brightness_percent","on_time"],"options":[{"type":"numeric","name":"transition","property":"transition","access":2,"value_min":0,"description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition)."}]},{"key":["color_temp","color_temp_percent"],"options":[{"type":"binary","name":"color_sync","property":"color_sync","access":2,"value_on":true,"value_off":false,"description":"When enabled colors will be synced, e.g. if the light supports both color x/y and color temperature a conversion from color x/y to color temperature will be done when setting the x/y color (default true)."},{"type":"numeric","name":"transition","property":"transition","access":2,"value_min":0,"description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition)."}]},{"key":["transition"],"attr":[]},{"key":["rate"],"attr":[]},{"key":["brightness_move","brightness_move_onoff"]},{"key":["colortemp_move","color_temp_move"]},{"key":["brightness_step","brightness_step_onoff"],"options":[{"type":"numeric","name":"transition","property":"transition","access":2,"value_min":0,"description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition)."}]},{"key":["color_temp_step"],"options":[{"type":"numeric","name":"transition","property":"transition","access":2,"value_min":0,"description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition)."}]},{"key":["color_temp_startup"]},{"key":["level_config"]},{"key":["color_options"]},{"key":["color_mode"]},{"key":["effect","alert","flash"]},{"key":["power_on_behavior"]},{"key":["hue_power_on_behavior"]},{"key":["hue_power_on_brightness","hue_power_on_color_temperature","hue_power_on_color"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]}],"ota":{},"meta":{"turnsOffAtBrightness1":true},"zigbeeModel":["929003056001"],"model":"929003056001","vendor":"Philips","description":"Hue white ambiance Adore bathroom mirror light with Bluetooth","options":[{"type":"numeric","name":"transition","property":"transition","access":2,"value_min":0,"description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition)."},{"type":"binary","name":"color_sync","property":"color_sync","access":2,"value_on":true,"value_off":false,"description":"When enabled colors will be synced, e.g. if the light supports both color x/y and color temperature a conversion from color x/y to color temperature will be done when setting the x/y color (default true)."}]},"_definitionModelID":"929003056001"}
HEX: 06.01.2023, 08:56:10 | MQTT Payload | 7B 22 7A 68 22 3A 7B 22 5F 65 76 65 6E 74 73 22 3A 7B 7D 2C 22 5F 65 76 65 6E 74 73 43 6F 75 6E 74 22 3A 30 2C 22 49 44 22 3A 38 34 2C 22 5F 74 79 70 65 22 3A 22 52 6F 75 74 65 72 22 2C 22 5F 69 65 65 65 41 64 64 72 22 3A 22 30 78 30 30 31 37 38 38 30 31 30 62 65 38 34 62 30 63 22 2C 22 5F 6E 65 74 77 6F 72 6B 41 64 64 72 65 73 73 22 3A 34 37 37 35 36 2C 22 5F 6D 61 6E 75 66 61 63 74 75 72 65 72 49 44 22 3A 34 31 30 37 2C 22 5F 65 6E 64 70 6F 69 6E 74 73 22 3A 5B 7B 22 5F 65 76 65 6E 74 73 22 3A 7B 7D 2C 22 5F 65 76 65 6E 74 73 43 6F 75 6E 74 22 3A 30 2C 22 49 44 22 3A 31 31 2C 22 70 72 6F 66 69 6C 65 49 44 22 3A 32 36 30 2C 22 64 65 76 69 63 65 49 44 22 3A 32 36 38 2C 22 69 6E 70 75 74 43 6C 75 73 74 65 72 73 22 3A 5B 30 2C 33 2C 34 2C 35 2C 36 2C 38 2C 34 30 39 36 2C 36 34 35 31 35 2C 37 36 38 5D 2C 22 6F 75 74 70 75 74 43 6C 75 73 74 65 72 73 22 3A 5B 32 35 5D 2C 22 64 65 76 69 63 65 4E 65 74 77 6F 72 6B 41 64 64 72 65 73 73 22 3A 34 37 37 35 36 2C 22 64 65 76 69 63 65 49 65 65 65 41 64 64 72 65 73 73 22 3A 22 30 78 30 30 31 37 38 38 30 31 30 62 65 38 34 62 30 63 22 2C 22 63 6C 75 73 74 65 72 73 22 3A 7B 22 67 65 6E 42 61 73 69 63 22 3A 7B 22 61 74 74 72 69 62 75 74 65 73 22 3A 7B 22 6D 6F 64 65 6C 49 64 22 3A 22 39 32 39 30 30 33 30 35 36 30 30 31 22 2C 22 6D 61 6E 75 66 61 63 74 75 72 65 72 4E 61 6D 65 22 3A 22 50 68 69 6C 69 70 73 22 2C 22 70 6F 77 65 72 53 6F 75 72 63 65 22 3A 31 2C 22 7A 63 6C 56 65 72 73 69 6F 6E 22 3A 32 2C 22 61 70 70 56 65 72 73 69 6F 6E 22 3A 32 2C 22 73 74 61 63 6B 56 65 72 73 69 6F 6E 22 3A 31 2C 22 68 77 56 65 72 73 69 6F 6E 22 3A 30 2C 22 64 61 74 65 43 6F 64 65 22 3A 22 32 30 32 32 30 35 30 32 22 2C 22 73 77 42 75 69 6C 64 49 64 22 3A 22 31 2E 39 33 2E 31 31 22 7D 7D 2C 22 6C 69 67 68 74 69 6E 67 43 6F 6C 6F 72 43 74 72 6C 22 3A 7B 22 61 74 74 72 69 62 75 74 65 73 22 3A 7B 22 63 6F 6C 6F 72 43 61 70 61 62 69 6C 69 74 69 65 73 22 3A 31 36 2C 22 63 6F 6C 6F 72 54 65 6D 70 50 68 79 73 69 63 61 6C 4D 69 6E 22 3A 31 35 33 2C 22 63 6F 6C 6F 72 54 65 6D 70 50 68 79 73 69 63 61 6C 4D 61 78 22 3A 34 35 34 2C 22 63 6F 6C 6F 72 4D 6F 64 65 22 3A 32 2C 22 63 6F 6C 6F 72 54 65 6D 70 65 72 61 74 75 72 65 22 3A 33 37 30 7D 7D 2C 22 67 65 6E 4F 6E 4F 66 66 22 3A 7B 22 61 74 74 72 69 62 75 74 65 73 22 3A 7B 22 6F 6E 4F 66 66 22 3A 31 7D 7D 2C 22 67 65 6E 4C 65 76 65 6C 43 74 72 6C 22 3A 7B 22 61 74 74 72 69 62 75 74 65 73 22 3A 7B 22 63 75 72 72 65 6E 74 4C 65 76 65 6C 22 3A 32 35 34 7D 7D 7D 2C 22 5F 62 69 6E 64 73 22 3A 5B 5D 2C 22 5F 63 6F 6E 66 69 67 75 72 65 64 52 65 70 6F 72 74 69 6E 67 73 22 3A 5B 5D 2C 22 6D 65 74 61 22 3A 7B 7D 2C 22 70 65 6E 64 69 6E 67 52 65 71 75 65 73 74 73 22 3A 5B 5D 7D 2C 7B 22 5F 65 76 65 6E 74 73 22 3A 7B 7D 2C 22 5F 65 76 65 6E 74 73 43 6F 75 6E 74 22 3A 30 2C 22 49 44 22 3A 32 34 32 2C 22 70 72 6F 66 69 6C 65 49 44 22 3A 34 31 34 34 30 2C 22 64 65 76 69 63 65 49 44 22 3A 39 37 2C 22 69 6E 70 75 74 43 6C 75 73 74 65 72 73 22 3A 5B 5D 2C 22 6F 75 74 70 75 74 43 6C 75 73 74 65 72 73 22 3A 5B 33 33 5D 2C 22 64 65 76 69 63 65 4E 65 74 77 6F 72 6B 41 64 64 72 65 73 73 22 3A 34 37 37 35 36 2C 22 64 65 76 69 63 65 49 65 65 65 41 64 64 72 65 73 73 22 3A 22 30 78 30 30 31 37 38 38 30 31 30 62 65 38 34 62 30 63 22 2C 22 63 6C 75 73 74 65 72 73 22 3A 7B 7D 2C 22 5F 62 69 6E 64 73 22 3A 5B 5D 2C 22 5F 63 6F 6E 66 69 67 75 72 65 64 52 65 70 6F 72 74 69 6E 67 73 22 3A 5B 5D 2C 22 6D 65 74 61 22 3A 7B 7D 2C 22 70 65 6E 64 69 6E 67 52 65 71 75 65 73 74 73 22 3A 5B 5D 7D 5D 2C 22 5F 6D 61 6E 75 66 61 63 74 75 72 65 72 4E 61 6D 65 22 3A 22 50 68 69 6C 69 70 73 22 2C 22 5F 70 6F 77 65 72 53 6F 75 72 63 65 22 3A 22 4D 61 69 6E 73 20 28 73 69 6E 67 6C 65 20 70 68 61 73 65 29 22 2C 22 5F 6D 6F 64 65 6C 49 44 22 3A 22 39 32 39 30 30 33 30 35 36 30 30 31 22 2C 22 5F 61 70 70 6C 69 63 61 74 69 6F 6E 56 65 72 73 69 6F 6E 22 3A 32 2C 22 5F 73 74 61 63 6B 56 65 72 73 69 6F 6E 22 3A 31 2C 22 5F 7A 63 6C 56 65 72 73 69 6F 6E 22 3A 32 2C 22 5F 68 61 72 64 77 61 72 65 56 65 72 73 69 6F 6E 22 3A 30 2C 22 5F 64 61 74 65 43 6F 64 65 22 3A 22 32 30 32 32 30 35 30 32 22 2C 22 5F 73 6F 66 74 77 61 72 65 42 75 69 6C 64 49 44 22 3A 22 31 2E 39 33 2E 31 31 22 2C 22 5F 69 6E 74 65 72 76 69 65 77 43 6F 6D 70 6C 65 74 65 64 22 3A 74 72 75 65 2C 22 5F 69 6E 74 65 72 76 69 65 77 69 6E 67 22 3A 66 61 6C 73 65 2C 22 5F 73 6B 69 70 44 65 66 61 75 6C 74 52 65 73 70 6F 6E 73 65 22 3A 66 61 6C 73 65 2C 22 5F 73 6B 69 70 54 69 6D 65 52 65 73 70 6F 6E 73 65 22 3A 66 61 6C 73 65 2C 22 6D 65 74 61 22 3A 7B 22 63 6F 6E 66 69 67 75 72 65 64 22 3A 32 7D 2C 22 5F 6C 61 73 74 53 65 65 6E 22 3A 31 36 37 32 39 39 31 37 35 39 38 30 37 2C 22 5F 64 65 66 61 75 6C 74 53 65 6E 64 52 65 71 75 65 73 74 57 68 65 6E 22 3A 22 69 6D 6D 65 64 69 61 74 65 22 2C 22 5F 6C 69 6E 6B 71 75 61 6C 69 74 79 22 3A 36 36 7D 2C 22 5F 64 65 66 69 6E 69 74 69 6F 6E 22 3A 7B 22 65 78 70 6F 73 65 73 22 3A 5B 7B 22 74 79 70 65 22 3A 22 6C 69 67 68 74 22 2C 22 66 65 61 74 75 72 65 73 22 3A 5B 7B 22 74 79 70 65 22 3A 22 62 69 6E 61 72 79 22 2C 22 6E 61 6D 65 22 3A 22 73 74 61 74 65 22 2C 22 70 72 6F 70 65 72 74 79 22 3A 22 73 74 61 74 65 22 2C 22 61 63 63 65 73 73 22 3A 37 2C 22 76 61 6C 75 65 5F 6F 6E 22 3A 22 4F 4E 22 2C 22 76 61 6C 75 65 5F 6F 66 66 22 3A 22 4F 46 46 22 2C 22 76 61 6C 75 65 5F 74 6F 67 67 6C 65 22 3A 22 54 4F 47 47 4C 45 22 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 4F 6E 2F 6F 66 66 20 73 74 61 74 65 20 6F 66 20 74 68 69 73 20 6C 69 67 68 74 22 7D 2C 7B 22 74 79 70 65 22 3A 22 6E 75 6D 65 72 69 63 22 2C 22 6E 61 6D 65 22 3A 22 62 72 69 67 68 74 6E 65 73 73 22 2C 22 70 72 6F 70 65 72 74 79 22 3A 22 62 72 69 67 68 74 6E 65 73 73 22 2C 22 61 63 63 65 73 73 22 3A 37 2C 22 76 61 6C 75 65 5F 6D 69 6E 22 3A 30 2C 22 76 61 6C 75 65 5F 6D 61 78 22 3A 32 35 34 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 42 72 69 67 68 74 6E 65 73 73 20 6F 66 20 74 68 69 73 20 6C 69 67 68 74 22 7D 2C 7B 22 74 79 70 65 22 3A 22 6E 75 6D 65 72 69 63 22 2C 22 6E 61 6D 65 22 3A 22 63 6F 6C 6F 72 5F 74 65 6D 70 22 2C 22 70 72 6F 70 65 72 74 79 22 3A 22 63 6F 6C 6F 72 5F 74 65 6D 70 22 2C 22 61 63 63 65 73 73 22 3A 37 2C 22 75 6E 69 74 22 3A 22 6D 69 72 65 64 22 2C 22 76 61 6C 75 65 5F 6D 69 6E 22 3A 31 35 33 2C 22 76 61 6C 75 65 5F 6D 61 78 22 3A 34 35 34 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 43 6F 6C 6F 72 20 74 65 6D 70 65 72 61 74 75 72 65 20 6F 66 20 74 68 69 73 20 6C 69 67 68 74 22 2C 22 70 72 65 73 65 74 73 22 3A 5B 7B 22 6E 61 6D 65 22 3A 22 63 6F 6F 6C 65 73 74 22 2C 22 76 61 6C 75 65 22 3A 31 35 33 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 43 6F 6F 6C 65 73 74 20 74 65 6D 70 65 72 61 74 75 72 65 20 73 75 70 70 6F 72 74 65 64 22 7D 2C 7B 22 6E 61 6D 65 22 3A 22 63 6F 6F 6C 22 2C 22 76 61 6C 75 65 22 3A 32 35 30 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 43 6F 6F 6C 20 74 65 6D 70 65 72 61 74 75 72 65 20 28 32 35 30 20 6D 69 72 65 64 73 20 2F 20 34 30 30 30 20 4B 65 6C 76 69 6E 29 22 7D 2C 7B 22 6E 61 6D 65 22 3A 22 6E 65 75 74 72 61 6C 22 2C 22 76 61 6C 75 65 22 3A 33 37 30 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 4E 65 75 74 72 61 6C 20 74 65 6D 70 65 72 61 74 75 72 65 20 28 33 37 30 20 6D 69 72 65 64 73 20 2F 20 32 37 30 30 20 4B 65 6C 76 69 6E 29 22 7D 2C 7B 22 6E 61 6D 65 22 3A 22 77 61 72 6D 22 2C 22 76 61 6C 75 65 22 3A 34 35 34 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 57 61 72 6D 20 74 65 6D 70 65 72 61 74 75 72 65 20 28 34 35 34 20 6D 69 72 65 64 73 20 2F 20 32 32 30 30 20 4B 65 6C 76 69 6E 29 22 7D 2C 7B 22 6E 61 6D 65 22 3A 22 77 61 72 6D 65 73 74 22 2C 22 76 61 6C 75 65 22 3A 34 35 34 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 57 61 72 6D 65 73 74 20 74 65 6D 70 65 72 61 74 75 72 65 20 73 75 70 70 6F 72 74 65 64 22 7D 5D 7D 2C 7B 22 74 79 70 65 22 3A 22 6E 75 6D 65 72 69 63 22 2C 22 6E 61 6D 65 22 3A 22 63 6F 6C 6F 72 5F 74 65 6D 70 5F 73 74 61 72 74 75 70 22 2C 22 70 72 6F 70 65 72 74 79 22 3A 22 63 6F 6C 6F 72 5F 74 65 6D 70 5F 73 74 61 72 74 75 70 22 2C 22 61 63 63 65 73 73 22 3A 37 2C 22 75 6E 69 74 22 3A 22 6D 69 72 65 64 22 2C 22 76 61 6C 75 65 5F 6D 69 6E 22 3A 31 35 33 2C 22 76 61 6C 75 65 5F 6D 61 78 22 3A 34 35 34 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 43 6F 6C 6F 72 20 74 65 6D 70 65 72 61 74 75 72 65 20 61 66 74 65 72 20 63 6F 6C 64 20 70 6F 77 65 72 20 6F 6E 20 6F 66 20 74 68 69 73 20 6C 69 67 68 74 22 2C 22 70 72 65 73 65 74 73 22 3A 5B 7B 22 6E 61 6D 65 22 3A 22 63 6F 6F 6C 65 73 74 22 2C 22 76 61 6C 75 65 22 3A 31 35 33 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 43 6F 6F 6C 65 73 74 20 74 65 6D 70 65 72 61 74 75 72 65 20 73 75 70 70 6F 72 74 65 64 22 7D 2C 7B 22 6E 61 6D 65 22 3A 22 63 6F 6F 6C 22 2C 22 76 61 6C 75 65 22 3A 32 35 30 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 43 6F 6F 6C 20 74 65 6D 70 65 72 61 74 75 72 65 20 28 32 35 30 20 6D 69 72 65 64 73 20 2F 20 34 30 30 30 20 4B 65 6C 76 69 6E 29 22 7D 2C 7B 22 6E 61 6D 65 22 3A 22 6E 65 75 74 72 61 6C 22 2C 22 76 61 6C 75 65 22 3A 33 37 30 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 4E 65 75 74 72 61 6C 20 74 65 6D 70 65 72 61 74 75 72 65 20 28 33 37 30 20 6D 69 72 65 64 73 20 2F 20 32 37 30 30 20 4B 65 6C 76 69 6E 29 22 7D 2C 7B 22 6E 61 6D 65 22 3A 22 77 61 72 6D 22 2C 22 76 61 6C 75 65 22 3A 34 35 34 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 57 61 72 6D 20 74 65 6D 70 65 72 61 74 75 72 65 20 28 34 35 34 20 6D 69 72 65 64 73 20 2F 20 32 32 30 30 20 4B 65 6C 76 69 6E 29 22 7D 2C 7B 22 6E 61 6D 65 22 3A 22 77 61 72 6D 65 73 74 22 2C 22 76 61 6C 75 65 22 3A 34 35 34 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 57 61 72 6D 65 73 74 20 74 65 6D 70 65 72 61 74 75 72 65 20 73 75 70 70 6F 72 74 65 64 22 7D 2C 7B 22 6E 61 6D 65 22 3A 22 70 72 65 76 69 6F 75 73 22 2C 22 76 61 6C 75 65 22 3A 36 35 35 33 35 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 52 65 73 74 6F 72 65 20 70 72 65 76 69 6F 75 73 20 63 6F 6C 6F 72 5F 74 65 6D 70 20 6F 6E 20 63 6F 6C 64 20 70 6F 77 65 72 20 6F 6E 22 7D 5D 7D 5D 7D 2C 7B 22 74 79 70 65 22 3A 22 65 6E 75 6D 22 2C 22 6E 61 6D 65 22 3A 22 65 66 66 65 63 74 22 2C 22 70 72 6F 70 65 72 74 79 22 3A 22 65 66 66 65 63 74 22 2C 22 61 63 63 65 73 73 22 3A 32 2C 22 76 61 6C 75 65 73 22 3A 5B 22 62 6C 69 6E 6B 22 2C 22 62 72 65 61 74 68 65 22 2C 22 6F 6B 61 79 22 2C 22 63 68 61 6E 6E 65 6C 5F 63 68 61 6E 67 65 22 2C 22 66 69 6E 69 73 68 5F 65 66 66 65 63 74 22 2C 22 73 74 6F 70 5F 65 66 66 65 63 74 22 5D 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 54 72 69 67 67 65 72 73 20 61 6E 20 65 66 66 65 63 74 20 6F 6E 20 74 68 65 20 6C 69 67 68 74 20 28 65 2E 67 2E 20 6D 61 6B 65 20 6C 69 67 68 74 20 62 6C 69 6E 6B 20 66 6F 72 20 61 20 66 65 77 20 73 65 63 6F 6E 64 73 29 22 7D 2C 7B 22 74 79 70 65 22 3A 22 6E 75 6D 65 72 69 63 22 2C 22 6E 61 6D 65 22 3A 22 6C 69 6E 6B 71 75 61 6C 69 74 79 22 2C 22 70 72 6F 70 65 72 74 79 22 3A 22 6C 69 6E 6B 71 75 61 6C 69 74 79 22 2C 22 61 63 63 65 73 73 22 3A 31 2C 22 75 6E 69 74 22 3A 22 6C 71 69 22 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 4C 69 6E 6B 20 71 75 61 6C 69 74 79 20 28 73 69 67 6E 61 6C 20 73 74 72 65 6E 67 74 68 29 22 2C 22 76 61 6C 75 65 5F 6D 69 6E 22 3A 30 2C 22 76 61 6C 75 65 5F 6D 61 78 22 3A 32 35 35 7D 5D 2C 22 66 72 6F 6D 5A 69 67 62 65 65 22 3A 5B 7B 22 63 6C 75 73 74 65 72 22 3A 22 6C 69 67 68 74 69 6E 67 43 6F 6C 6F 72 43 74 72 6C 22 2C 22 74 79 70 65 22 3A 5B 22 61 74 74 72 69 62 75 74 65 52 65 70 6F 72 74 22 2C 22 72 65 61 64 52 65 73 70 6F 6E 73 65 22 5D 2C 22 6F 70 74 69 6F 6E 73 22 3A 5B 7B 22 74 79 70 65 22 3A 22 62 69 6E 61 72 79 22 2C 22 6E 61 6D 65 22 3A 22 63 6F 6C 6F 72 5F 73 79 6E 63 22 2C 22 70 72 6F 70 65 72 74 79 22 3A 22 63 6F 6C 6F 72 5F 73 79 6E 63 22 2C 22 61 63 63 65 73 73 22 3A 32 2C 22 76 61 6C 75 65 5F 6F 6E 22 3A 74 72 75 65 2C 22 76 61 6C 75 65 5F 6F 66 66 22 3A 66 61 6C 73 65 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 57 68 65 6E 20 65 6E 61 62 6C 65 64 20 63 6F 6C 6F 72 73 20 77 69 6C 6C 20 62 65 20 73 79 6E 63 65 64 2C 20 65 2E 67 2E 20 69 66 20 74 68 65 20 6C 69 67 68 74 20 73 75 70 70 6F 72 74 73 20 62 6F 74 68 20 63 6F 6C 6F 72 20 78 2F 79 20 61 6E 64 20 63 6F 6C 6F 72 20 74 65 6D 70 65 72 61 74 75 72 65 20 61 20 63 6F 6E 76 65 72 73 69 6F 6E 20 66 72 6F 6D 20 63 6F 6C 6F 72 20 78 2F 79 20 74 6F 20 63 6F 6C 6F 72 20 74 65 6D 70 65 72 61 74 75 72 65 20 77 69 6C 6C 20 62 65 20 64 6F 6E 65 20 77 68 65 6E 20 73 65 74 74 69 6E 67 20 74 68 65 20 78 2F 79 20 63 6F 6C 6F 72 20 28 64 65 66 61 75 6C 74 20 74 72 75 65 29 2E 22 7D 5D 7D 2C 7B 22 63 6C 75 73 74 65 72 22 3A 22 67 65 6E 4F 6E 4F 66 66 22 2C 22 74 79 70 65 22 3A 5B 22 61 74 74 72 69 62 75 74 65 52 65 70 6F 72 74 22 2C 22 72 65 61 64 52 65 73 70 6F 6E 73 65 22 5D 7D 2C 7B 22 63 6C 75 73 74 65 72 22 3A 22 67 65 6E 4C 65 76 65 6C 43 74 72 6C 22 2C 22 74 79 70 65 22 3A 5B 22 61 74 74 72 69 62 75 74 65 52 65 70 6F 72 74 22 2C 22 72 65 61 64 52 65 73 70 6F 6E 73 65 22 5D 7D 2C 7B 22 63 6C 75 73 74 65 72 22 3A 22 67 65 6E 4C 65 76 65 6C 43 74 72 6C 22 2C 22 74 79 70 65 22 3A 5B 22 61 74 74 72 69 62 75 74 65 52 65 70 6F 72 74 22 2C 22 72 65 61 64 52 65 73 70 6F 6E 73 65 22 5D 7D 2C 7B 22 63 6C 75 73 74 65 72 22 3A 22 67 65 6E 42 61 73 69 63 22 2C 22 74 79 70 65 22 3A 5B 22 61 74 74 72 69 62 75 74 65 52 65 70 6F 72 74 22 2C 22 72 65 61 64 52 65 73 70 6F 6E 73 65 22 5D 7D 2C 7B 22 63 6C 75 73 74 65 72 22 3A 22 67 65 6E 4F 6E 4F 66 66 22 2C 22 74 79 70 65 22 3A 5B 22 61 74 74 72 69 62 75 74 65 52 65 70 6F 72 74 22 2C 22 72 65 61 64 52 65 73 70 6F 6E 73 65 22 5D 7D 5D 2C 22 74 6F 5A 69 67 62 65 65 22 3A 5B 7B 22 6B 65 79 22 3A 5B 22 73 74 61 74 65 22 2C 22 62 72 69 67 68 74 6E 65 73 73 22 2C 22 62 72 69 67 68 74 6E 65 73 73 5F 70 65 72 63 65 6E 74 22 2C 22 6F 6E 5F 74 69 6D 65 22 5D 2C 22 6F 70 74 69 6F 6E 73 22 3A 5B 7B 22 74 79 70 65 22 3A 22 6E 75 6D 65 72 69 63 22 2C 22 6E 61 6D 65 22 3A 22 74 72 61 6E 73 69 74 69 6F 6E 22 2C 22 70 72 6F 70 65 72 74 79 22 3A 22 74 72 61 6E 73 69 74 69 6F 6E 22 2C 22 61 63 63 65 73 73 22 3A 32 2C 22 76 61 6C 75 65 5F 6D 69 6E 22 3A 30 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 43 6F 6E 74 72 6F 6C 73 20 74 68 65 20 74 72 61 6E 73 69 74 69 6F 6E 20 74 69 6D 65 20 28 69 6E 20 73 65 63 6F 6E 64 73 29 20 6F 66 20 6F 6E 2F 6F 66 66 2C 20 62 72 69 67 68 74 6E 65 73 73 2C 20 63 6F 6C 6F 72 20 74 65 6D 70 65 72 61 74 75 72 65 20 28 69 66 20 61 70 70 6C 69 63 61 62 6C 65 29 20 61 6E 64 20 63 6F 6C 6F 72 20 28 69 66 20 61 70 70 6C 69 63 61 62 6C 65 29 20 63 68 61 6E 67 65 73 2E 20 44 65 66 61 75 6C 74 73 20 74 6F 20 60 30 60 20 28 6E 6F 20 74 72 61 6E 73 69 74 69 6F 6E 29 2E 22 7D 5D 7D 2C 7B 22 6B 65 79 22 3A 5B 22 63 6F 6C 6F 72 5F 74 65 6D 70 22 2C 22 63 6F 6C 6F 72 5F 74 65 6D 70 5F 70 65 72 63 65 6E 74 22 5D 2C 22 6F 70 74 69 6F 6E 73 22 3A 5B 7B 22 74 79 70 65 22 3A 22 62 69 6E 61 72 79 22 2C 22 6E 61 6D 65 22 3A 22 63 6F 6C 6F 72 5F 73 79 6E 63 22 2C 22 70 72 6F 70 65 72 74 79 22 3A 22 63 6F 6C 6F 72 5F 73 79 6E 63 22 2C 22 61 63 63 65 73 73 22 3A 32 2C 22 76 61 6C 75 65 5F 6F 6E 22 3A 74 72 75 65 2C 22 76 61 6C 75 65 5F 6F 66 66 22 3A 66 61 6C 73 65 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 57 68 65 6E 20 65 6E 61 62 6C 65 64 20 63 6F 6C 6F 72 73 20 77 69 6C 6C 20 62 65 20 73 79 6E 63 65 64 2C 20 65 2E 67 2E 20 69 66 20 74 68 65 20 6C 69 67 68 74 20 73 75 70 70 6F 72 74 73 20 62 6F 74 68 20 63 6F 6C 6F 72 20 78 2F 79 20 61 6E 64 20 63 6F 6C 6F 72 20 74 65 6D 70 65 72 61 74 75 72 65 20 61 20 63 6F 6E 76 65 72 73 69 6F 6E 20 66 72 6F 6D 20 63 6F 6C 6F 72 20 78 2F 79 20 74 6F 20 63 6F 6C 6F 72 20 74 65 6D 70 65 72 61 74 75 72 65 20 77 69 6C 6C 20 62 65 20 64 6F 6E 65 20 77 68 65 6E 20 73 65 74 74 69 6E 67 20 74 68 65 20 78 2F 79 20 63 6F 6C 6F 72 20 28 64 65 66 61 75 6C 74 20 74 72 75 65 29 2E 22 7D 2C 7B 22 74 79 70 65 22 3A 22 6E 75 6D 65 72 69 63 22 2C 22 6E 61 6D 65 22 3A 22 74 72 61 6E 73 69 74 69 6F 6E 22 2C 22 70 72 6F 70 65 72 74 79 22 3A 22 74 72 61 6E 73 69 74 69 6F 6E 22 2C 22 61 63 63 65 73 73 22 3A 32 2C 22 76 61 6C 75 65 5F 6D 69 6E 22 3A 30 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 43 6F 6E 74 72 6F 6C 73 20 74 68 65 20 74 72 61 6E 73 69 74 69 6F 6E 20 74 69 6D 65 20 28 69 6E 20 73 65 63 6F 6E 64 73 29 20 6F 66 20 6F 6E 2F 6F 66 66 2C 20 62 72 69 67 68 74 6E 65 73 73 2C 20 63 6F 6C 6F 72 20 74 65 6D 70 65 72 61 74 75 72 65 20 28 69 66 20 61 70 70 6C 69 63 61 62 6C 65 29 20 61 6E 64 20 63 6F 6C 6F 72 20 28 69 66 20 61 70 70 6C 69 63 61 62 6C 65 29 20 63 68 61 6E 67 65 73 2E 20 44 65 66 61 75 6C 74 73 20 74 6F 20 60 30 60 20 28 6E 6F 20 74 72 61 6E 73 69 74 69 6F 6E 29 2E 22 7D 5D 7D 2C 7B 22 6B 65 79 22 3A 5B 22 74 72 61 6E 73 69 74 69 6F 6E 22 5D 2C 22 61 74 74 72 22 3A 5B 5D 7D 2C 7B 22 6B 65 79 22 3A 5B 22 72 61 74 65 22 5D 2C 22 61 74 74 72 22 3A 5B 5D 7D 2C 7B 22 6B 65 79 22 3A 5B 22 62 72 69 67 68 74 6E 65 73 73 5F 6D 6F 76 65 22 2C 22 62 72 69 67 68 74 6E 65 73 73 5F 6D 6F 76 65 5F 6F 6E 6F 66 66 22 5D 7D 2C 7B 22 6B 65 79 22 3A 5B 22 63 6F 6C 6F 72 74 65 6D 70 5F 6D 6F 76 65 22 2C 22 63 6F 6C 6F 72 5F 74 65 6D 70 5F 6D 6F 76 65 22 5D 7D 2C 7B 22 6B 65 79 22 3A 5B 22 62 72 69 67 68 74 6E 65 73 73 5F 73 74 65 70 22 2C 22 62 72 69 67 68 74 6E 65 73 73 5F 73 74 65 70 5F 6F 6E 6F 66 66 22 5D 2C 22 6F 70 74 69 6F 6E 73 22 3A 5B 7B 22 74 79 70 65 22 3A 22 6E 75 6D 65 72 69 63 22 2C 22 6E 61 6D 65 22 3A 22 74 72 61 6E 73 69 74 69 6F 6E 22 2C 22 70 72 6F 70 65 72 74 79 22 3A 22 74 72 61 6E 73 69 74 69 6F 6E 22 2C 22 61 63 63 65 73 73 22 3A 32 2C 22 76 61 6C 75 65 5F 6D 69 6E 22 3A 30 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 43 6F 6E 74 72 6F 6C 73 20 74 68 65 20 74 72 61 6E 73 69 74 69 6F 6E 20 74 69 6D 65 20 28 69 6E 20 73 65 63 6F 6E 64 73 29 20 6F 66 20 6F 6E 2F 6F 66 66 2C 20 62 72 69 67 68 74 6E 65 73 73 2C 20 63 6F 6C 6F 72 20 74 65 6D 70 65 72 61 74 75 72 65 20 28 69 66 20 61 70 70 6C 69 63 61 62 6C 65 29 20 61 6E 64 20 63 6F 6C 6F 72 20 28 69 66 20 61 70 70 6C 69 63 61 62 6C 65 29 20 63 68 61 6E 67 65 73 2E 20 44 65 66 61 75 6C 74 73 20 74 6F 20 60 30 60 20 28 6E 6F 20 74 72 61 6E 73 69 74 69 6F 6E 29 2E 22 7D 5D 7D 2C 7B 22 6B 65 79 22 3A 5B 22 63 6F 6C 6F 72 5F 74 65 6D 70 5F 73 74 65 70 22 5D 2C 22 6F 70 74 69 6F 6E 73 22 3A 5B 7B 22 74 79 70 65 22 3A 22 6E 75 6D 65 72 69 63 22 2C 22 6E 61 6D 65 22 3A 22 74 72 61 6E 73 69 74 69 6F 6E 22 2C 22 70 72 6F 70 65 72 74 79 22 3A 22 74 72 61 6E 73 69 74 69 6F 6E 22 2C 22 61 63 63 65 73 73 22 3A 32 2C 22 76 61 6C 75 65 5F 6D 69 6E 22 3A 30 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 43 6F 6E 74 72 6F 6C 73 20 74 68 65 20 74 72 61 6E 73 69 74 69 6F 6E 20 74 69 6D 65 20 28 69 6E 20 73 65 63 6F 6E 64 73 29 20 6F 66 20 6F 6E 2F 6F 66 66 2C 20 62 72 69 67 68 74 6E 65 73 73 2C 20 63 6F 6C 6F 72 20 74 65 6D 70 65 72 61 74 75 72 65 20 28 69 66 20 61 70 70 6C 69 63 61 62 6C 65 29 20 61 6E 64 20 63 6F 6C 6F 72 20 28 69 66 20 61 70 70 6C 69 63 61 62 6C 65 29 20 63 68 61 6E 67 65 73 2E 20 44 65 66 61 75 6C 74 73 20 74 6F 20 60 30 60 20 28 6E 6F 20 74 72 61 6E 73 69 74 69 6F 6E 29 2E 22 7D 5D 7D 2C 7B 22 6B 65 79 22 3A 5B 22 63 6F 6C 6F 72 5F 74 65 6D 70 5F 73 74 61 72 74 75 70 22 5D 7D 2C 7B 22 6B 65 79 22 3A 5B 22 6C 65 76 65 6C 5F 63 6F 6E 66 69 67 22 5D 7D 2C 7B 22 6B 65 79 22 3A 5B 22 63 6F 6C 6F 72 5F 6F 70 74 69 6F 6E 73 22 5D 7D 2C 7B 22 6B 65 79 22 3A 5B 22 63 6F 6C 6F 72 5F 6D 6F 64 65 22 5D 7D 2C 7B 22 6B 65 79 22 3A 5B 22 65 66 66 65 63 74 22 2C 22 61 6C 65 72 74 22 2C 22 66 6C 61 73 68 22 5D 7D 2C 7B 22 6B 65 79 22 3A 5B 22 70 6F 77 65 72 5F 6F 6E 5F 62 65 68 61 76 69 6F 72 22 5D 7D 2C 7B 22 6B 65 79 22 3A 5B 22 68 75 65 5F 70 6F 77 65 72 5F 6F 6E 5F 62 65 68 61 76 69 6F 72 22 5D 7D 2C 7B 22 6B 65 79 22 3A 5B 22 68 75 65 5F 70 6F 77 65 72 5F 6F 6E 5F 62 72 69 67 68 74 6E 65 73 73 22 2C 22 68 75 65 5F 70 6F 77 65 72 5F 6F 6E 5F 63 6F 6C 6F 72 5F 74 65 6D 70 65 72 61 74 75 72 65 22 2C 22 68 75 65 5F 70 6F 77 65 72 5F 6F 6E 5F 63 6F 6C 6F 72 22 5D 7D 2C 7B 22 6B 65 79 22 3A 5B 22 73 63 65 6E 65 5F 73 74 6F 72 65 22 5D 7D 2C 7B 22 6B 65 79 22 3A 5B 22 73 63 65 6E 65 5F 72 65 63 61 6C 6C 22 5D 7D 2C 7B 22 6B 65 79 22 3A 5B 22 73 63 65 6E 65 5F 61 64 64 22 5D 7D 2C 7B 22 6B 65 79 22 3A 5B 22 73 63 65 6E 65 5F 72 65 6D 6F 76 65 22 5D 7D 2C 7B 22 6B 65 79 22 3A 5B 22 73 63 65 6E 65 5F 72 65 6D 6F 76 65 5F 61 6C 6C 22 5D 7D 2C 7B 22 6B 65 79 22 3A 5B 22 72 65 61 64 22 5D 7D 2C 7B 22 6B 65 79 22 3A 5B 22 77 72 69 74 65 22 5D 7D 2C 7B 22 6B 65 79 22 3A 5B 22 63 6F 6D 6D 61 6E 64 22 5D 7D 5D 2C 22 6F 74 61 22 3A 7B 7D 2C 22 6D 65 74 61 22 3A 7B 22 74 75 72 6E 73 4F 66 66 41 74 42 72 69 67 68 74 6E 65 73 73 31 22 3A 74 72 75 65 7D 2C 22 7A 69 67 62 65 65 4D 6F 64 65 6C 22 3A 5B 22 39 32 39 30 30 33 30 35 36 30 30 31 22 5D 2C 22 6D 6F 64 65 6C 22 3A 22 39 32 39 30 30 33 30 35 36 30 30 31 22 2C 22 76 65 6E 64 6F 72 22 3A 22 50 68 69 6C 69 70 73 22 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 48 75 65 20 77 68 69 74 65 20 61 6D 62 69 61 6E 63 65 20 41 64 6F 72 65 20 62 61 74 68 72 6F 6F 6D 20 6D 69 72 72 6F 72 20 6C 69 67 68 74 20 77 69 74 68 20 42 6C 75 65 74 6F 6F 74 68 22 2C 22 6F 70 74 69 6F 6E 73 22 3A 5B 7B 22 74 79 70 65 22 3A 22 6E 75 6D 65 72 69 63 22 2C 22 6E 61 6D 65 22 3A 22 74 72 61 6E 73 69 74 69 6F 6E 22 2C 22 70 72 6F 70 65 72 74 79 22 3A 22 74 72 61 6E 73 69 74 69 6F 6E 22 2C 22 61 63 63 65 73 73 22 3A 32 2C 22 76 61 6C 75 65 5F 6D 69 6E 22 3A 30 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 43 6F 6E 74 72 6F 6C 73 20 74 68 65 20 74 72 61 6E 73 69 74 69 6F 6E 20 74 69 6D 65 20 28 69 6E 20 73 65 63 6F 6E 64 73 29 20 6F 66 20 6F 6E 2F 6F 66 66 2C 20 62 72 69 67 68 74 6E 65 73 73 2C 20 63 6F 6C 6F 72 20 74 65 6D 70 65 72 61 74 75 72 65 20 28 69 66 20 61 70 70 6C 69 63 61 62 6C 65 29 20 61 6E 64 20 63 6F 6C 6F 72 20 28 69 66 20 61 70 70 6C 69 63 61 62 6C 65 29 20 63 68 61 6E 67 65 73 2E 20 44 65 66 61 75 6C 74 73 20 74 6F 20 60 30 60 20 28 6E 6F 20 74 72 61 6E 73 69 74 69 6F 6E 29 2E 22 7D 2C 7B 22 74 79 70 65 22 3A 22 62 69 6E 61 72 79 22 2C 22 6E 61 6D 65 22 3A 22 63 6F 6C 6F 72 5F 73 79 6E 63 22 2C 22 70 72 6F 70 65 72 74 79 22 3A 22 63 6F 6C 6F 72 5F 73 79 6E 63 22 2C 22 61 63 63 65 73 73 22 3A 32 2C 22 76 61 6C 75 65 5F 6F 6E 22 3A 74 72 75 65 2C 22 76 61 6C 75 65 5F 6F 66 66 22 3A 66 61 6C 73 65 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 57 68 65 6E 20 65 6E 61 62 6C 65 64 20 63 6F 6C 6F 72 73 20 77 69 6C 6C 20 62 65 20 73 79 6E 63 65 64 2C 20 65 2E 67 2E 20 69 66 20 74 68 65 20 6C 69 67 68 74 20 73 75 70 70 6F 72 74 73 20 62 6F 74 68 20 63 6F 6C 6F 72 20 78 2F 79 20 61 6E 64 20 63 6F 6C 6F 72 20 74 65 6D 70 65 72 61 74 75 72 65 20 61 20 63 6F 6E 76 65 72 73 69 6F 6E 20 66 72 6F 6D 20 63 6F 6C 6F 72 20 78 2F 79 20 74 6F 20 63 6F 6C 6F 72 20 74 65 6D 70 65 72 61 74 75 72 65 20 77 69 6C 6C 20 62 65 20 64 6F 6E 65 20 77 68 65 6E 20 73 65 74 74 69 6E 67 20 74 68 65 20 78 2F 79 20 63 6F 6C 6F 72 20 28 64 65 66 61 75 6C 74 20 74 72 75 65 29 2E 22 7D 5D 7D 2C 22 5F 64 65 66 69 6E 69 74 69 6F 6E 4D 6F 64 65 6C 49 44 22 3A 22 39 32 39 30 30 33 30 35 36 30 30 31 22 7D
TXT: 06.01.2023, 08:56:10 | mapExposesToVariables:: All Exposes | [{"type":"light","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE","description":"On\/off state of this light"},{"type":"numeric","name":"brightness","property":"brightness","access":7,"value_min":0,"value_max":254,"description":"Brightness of this light"},{"type":"numeric","name":"color_temp","property":"color_temp","access":7,"unit":"mired","value_min":153,"value_max":454,"description":"Color temperature of this light","presets":[{"name":"coolest","value":153,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds \/ 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds \/ 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds \/ 2200 Kelvin)"},{"name":"warmest","value":454,"description":"Warmest temperature supported"}]},{"type":"numeric","name":"color_temp_startup","property":"color_temp_startup","access":7,"unit":"mired","value_min":153,"value_max":454,"description":"Color temperature after cold power on of this light","presets":[{"name":"coolest","value":153,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds \/ 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds \/ 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds \/ 2200 Kelvin)"},{"name":"warmest","value":454,"description":"Warmest temperature supported"},{"name":"previous","value":65535,"description":"Restore previous color_temp on cold power on"}]}]},{"type":"enum","name":"effect","property":"effect","access":2,"values":["blink","breathe","okay","channel_change","finish_effect","stop_effect"],"description":"Triggers an effect on the light (e.g. make light blink for a few seconds)"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}]
HEX: 06.01.2023, 08:56:10 | mapExposesToVariables:: All Exposes | 5B 7B 22 74 79 70 65 22 3A 22 6C 69 67 68 74 22 2C 22 66 65 61 74 75 72 65 73 22 3A 5B 7B 22 74 79 70 65 22 3A 22 62 69 6E 61 72 79 22 2C 22 6E 61 6D 65 22 3A 22 73 74 61 74 65 22 2C 22 70 72 6F 70 65 72 74 79 22 3A 22 73 74 61 74 65 22 2C 22 61 63 63 65 73 73 22 3A 37 2C 22 76 61 6C 75 65 5F 6F 6E 22 3A 22 4F 4E 22 2C 22 76 61 6C 75 65 5F 6F 66 66 22 3A 22 4F 46 46 22 2C 22 76 61 6C 75 65 5F 74 6F 67 67 6C 65 22 3A 22 54 4F 47 47 4C 45 22 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 4F 6E 5C 2F 6F 66 66 20 73 74 61 74 65 20 6F 66 20 74 68 69 73 20 6C 69 67 68 74 22 7D 2C 7B 22 74 79 70 65 22 3A 22 6E 75 6D 65 72 69 63 22 2C 22 6E 61 6D 65 22 3A 22 62 72 69 67 68 74 6E 65 73 73 22 2C 22 70 72 6F 70 65 72 74 79 22 3A 22 62 72 69 67 68 74 6E 65 73 73 22 2C 22 61 63 63 65 73 73 22 3A 37 2C 22 76 61 6C 75 65 5F 6D 69 6E 22 3A 30 2C 22 76 61 6C 75 65 5F 6D 61 78 22 3A 32 35 34 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 42 72 69 67 68 74 6E 65 73 73 20 6F 66 20 74 68 69 73 20 6C 69 67 68 74 22 7D 2C 7B 22 74 79 70 65 22 3A 22 6E 75 6D 65 72 69 63 22 2C 22 6E 61 6D 65 22 3A 22 63 6F 6C 6F 72 5F 74 65 6D 70 22 2C 22 70 72 6F 70 65 72 74 79 22 3A 22 63 6F 6C 6F 72 5F 74 65 6D 70 22 2C 22 61 63 63 65 73 73 22 3A 37 2C 22 75 6E 69 74 22 3A 22 6D 69 72 65 64 22 2C 22 76 61 6C 75 65 5F 6D 69 6E 22 3A 31 35 33 2C 22 76 61 6C 75 65 5F 6D 61 78 22 3A 34 35 34 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 43 6F 6C 6F 72 20 74 65 6D 70 65 72 61 74 75 72 65 20 6F 66 20 74 68 69 73 20 6C 69 67 68 74 22 2C 22 70 72 65 73 65 74 73 22 3A 5B 7B 22 6E 61 6D 65 22 3A 22 63 6F 6F 6C 65 73 74 22 2C 22 76 61 6C 75 65 22 3A 31 35 33 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 43 6F 6F 6C 65 73 74 20 74 65 6D 70 65 72 61 74 75 72 65 20 73 75 70 70 6F 72 74 65 64 22 7D 2C 7B 22 6E 61 6D 65 22 3A 22 63 6F 6F 6C 22 2C 22 76 61 6C 75 65 22 3A 32 35 30 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 43 6F 6F 6C 20 74 65 6D 70 65 72 61 74 75 72 65 20 28 32 35 30 20 6D 69 72 65 64 73 20 5C 2F 20 34 30 30 30 20 4B 65 6C 76 69 6E 29 22 7D 2C 7B 22 6E 61 6D 65 22 3A 22 6E 65 75 74 72 61 6C 22 2C 22 76 61 6C 75 65 22 3A 33 37 30 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 4E 65 75 74 72 61 6C 20 74 65 6D 70 65 72 61 74 75 72 65 20 28 33 37 30 20 6D 69 72 65 64 73 20 5C 2F 20 32 37 30 30 20 4B 65 6C 76 69 6E 29 22 7D 2C 7B 22 6E 61 6D 65 22 3A 22 77 61 72 6D 22 2C 22 76 61 6C 75 65 22 3A 34 35 34 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 57 61 72 6D 20 74 65 6D 70 65 72 61 74 75 72 65 20 28 34 35 34 20 6D 69 72 65 64 73 20 5C 2F 20 32 32 30 30 20 4B 65 6C 76 69 6E 29 22 7D 2C 7B 22 6E 61 6D 65 22 3A 22 77 61 72 6D 65 73 74 22 2C 22 76 61 6C 75 65 22 3A 34 35 34 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 57 61 72 6D 65 73 74 20 74 65 6D 70 65 72 61 74 75 72 65 20 73 75 70 70 6F 72 74 65 64 22 7D 5D 7D 2C 7B 22 74 79 70 65 22 3A 22 6E 75 6D 65 72 69 63 22 2C 22 6E 61 6D 65 22 3A 22 63 6F 6C 6F 72 5F 74 65 6D 70 5F 73 74 61 72 74 75 70 22 2C 22 70 72 6F 70 65 72 74 79 22 3A 22 63 6F 6C 6F 72 5F 74 65 6D 70 5F 73 74 61 72 74 75 70 22 2C 22 61 63 63 65 73 73 22 3A 37 2C 22 75 6E 69 74 22 3A 22 6D 69 72 65 64 22 2C 22 76 61 6C 75 65 5F 6D 69 6E 22 3A 31 35 33 2C 22 76 61 6C 75 65 5F 6D 61 78 22 3A 34 35 34 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 43 6F 6C 6F 72 20 74 65 6D 70 65 72 61 74 75 72 65 20 61 66 74 65 72 20 63 6F 6C 64 20 70 6F 77 65 72 20 6F 6E 20 6F 66 20 74 68 69 73 20 6C 69 67 68 74 22 2C 22 70 72 65 73 65 74 73 22 3A 5B 7B 22 6E 61 6D 65 22 3A 22 63 6F 6F 6C 65 73 74 22 2C 22 76 61 6C 75 65 22 3A 31 35 33 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 43 6F 6F 6C 65 73 74 20 74 65 6D 70 65 72 61 74 75 72 65 20 73 75 70 70 6F 72 74 65 64 22 7D 2C 7B 22 6E 61 6D 65 22 3A 22 63 6F 6F 6C 22 2C 22 76 61 6C 75 65 22 3A 32 35 30 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 43 6F 6F 6C 20 74 65 6D 70 65 72 61 74 75 72 65 20 28 32 35 30 20 6D 69 72 65 64 73 20 5C 2F 20 34 30 30 30 20 4B 65 6C 76 69 6E 29 22 7D 2C 7B 22 6E 61 6D 65 22 3A 22 6E 65 75 74 72 61 6C 22 2C 22 76 61 6C 75 65 22 3A 33 37 30 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 4E 65 75 74 72 61 6C 20 74 65 6D 70 65 72 61 74 75 72 65 20 28 33 37 30 20 6D 69 72 65 64 73 20 5C 2F 20 32 37 30 30 20 4B 65 6C 76 69 6E 29 22 7D 2C 7B 22 6E 61 6D 65 22 3A 22 77 61 72 6D 22 2C 22 76 61 6C 75 65 22 3A 34 35 34 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 57 61 72 6D 20 74 65 6D 70 65 72 61 74 75 72 65 20 28 34 35 34 20 6D 69 72 65 64 73 20 5C 2F 20 32 32 30 30 20 4B 65 6C 76 69 6E 29 22 7D 2C 7B 22 6E 61 6D 65 22 3A 22 77 61 72 6D 65 73 74 22 2C 22 76 61 6C 75 65 22 3A 34 35 34 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 57 61 72 6D 65 73 74 20 74 65 6D 70 65 72 61 74 75 72 65 20 73 75 70 70 6F 72 74 65 64 22 7D 2C 7B 22 6E 61 6D 65 22 3A 22 70 72 65 76 69 6F 75 73 22 2C 22 76 61 6C 75 65 22 3A 36 35 35 33 35 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 52 65 73 74 6F 72 65 20 70 72 65 76 69 6F 75 73 20 63 6F 6C 6F 72 5F 74 65 6D 70 20 6F 6E 20 63 6F 6C 64 20 70 6F 77 65 72 20 6F 6E 22 7D 5D 7D 5D 7D 2C 7B 22 74 79 70 65 22 3A 22 65 6E 75 6D 22 2C 22 6E 61 6D 65 22 3A 22 65 66 66 65 63 74 22 2C 22 70 72 6F 70 65 72 74 79 22 3A 22 65 66 66 65 63 74 22 2C 22 61 63 63 65 73 73 22 3A 32 2C 22 76 61 6C 75 65 73 22 3A 5B 22 62 6C 69 6E 6B 22 2C 22 62 72 65 61 74 68 65 22 2C 22 6F 6B 61 79 22 2C 22 63 68 61 6E 6E 65 6C 5F 63 68 61 6E 67 65 22 2C 22 66 69 6E 69 73 68 5F 65 66 66 65 63 74 22 2C 22 73 74 6F 70 5F 65 66 66 65 63 74 22 5D 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 54 72 69 67 67 65 72 73 20 61 6E 20 65 66 66 65 63 74 20 6F 6E 20 74 68 65 20 6C 69 67 68 74 20 28 65 2E 67 2E 20 6D 61 6B 65 20 6C 69 67 68 74 20 62 6C 69 6E 6B 20 66 6F 72 20 61 20 66 65 77 20 73 65 63 6F 6E 64 73 29 22 7D 2C 7B 22 74 79 70 65 22 3A 22 6E 75 6D 65 72 69 63 22 2C 22 6E 61 6D 65 22 3A 22 6C 69 6E 6B 71 75 61 6C 69 74 79 22 2C 22 70 72 6F 70 65 72 74 79 22 3A 22 6C 69 6E 6B 71 75 61 6C 69 74 79 22 2C 22 61 63 63 65 73 73 22 3A 31 2C 22 75 6E 69 74 22 3A 22 6C 71 69 22 2C 22 64 65 73 63 72 69 70 74 69 6F 6E 22 3A 22 4C 69 6E 6B 20 71 75 61 6C 69 74 79 20 28 73 69 67 6E 61 6C 20 73 74 72 65 6E 67 74 68 29 22 2C 22 76 61 6C 75 65 5F 6D 69 6E 22 3A 30 2C 22 76 61 6C 75 65 5F 6D 61 78 22 3A 32 35 35 7D 5D
TXT: 06.01.2023, 08:56:10 | mapExposesToVariables:: Missed Exposes | {"light":[],"switch":[],"climate":[],"lock":[]}
HEX: 06.01.2023, 08:56:10 | mapExposesToVariables:: Missed Exposes | 7B 22 6C 69 67 68 74 22 3A 5B 5D 2C 22 73 77 69 74 63 68 22 3A 5B 5D 2C 22 63 6C 69 6D 61 74 65 22 3A 5B 5D 2C 22 6C 6F 63 6B 22 3A 5B 5D 7D
In den letzten zwei Zeilen sind auch Missed Exposes aufgeführt.
Der Fehler erscheint leider weiterhin bei jedem Schaltvorgang.
