Bis jetzt läuft es gut mit dem MCP.
Habe hier noch ne Frage, ich hab an einen Tasmota quasi 2 Switches noch im Topic.
Einer ist ein Bewegungsmelder der andere Eingangstür.
Habe ich vielleicht was falsch gemacht? Da er mir diese nicht zeigt.
16:14:29 RUL: SWITCH1#STATE performs "publish /device/Bad_unten_Bewegungsmelder/status {"devicename":"Bad-Bewegungsmelder","model":"motiondection","room":"Badunten","infoart":"switch","value":"1"}"
16:14:29 MQT: /device/Bad_unten_Bewegungsmelder/status = {"devicename":"Bad-Bewegungsmelder","model":"motiondection","room":"Badunten","infoart":"switch","value":"1"}
16:14:32 MQT: tele/Badunten-Input-Modul-Bad-Unten/STATE = {"Time":"2019-11-23T16:14:32","Uptime":"0T00:01:06","Vcc":3.048,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":21,"Wifi":{"AP":1,"SSId":"....","BSSId":"04:BD:88:F0:17:80","Channel":1,"RSSI":74,"LinkCount":1,"Downtime":"0T00:00:06"}}
16:14:32 MQT: tele/Badunten-Input-Modul-Bad-Unten/SENSOR = {"Time":"2019-11-23T16:14:32","Switch1":"ON","Switch2":"ON","BME280":{"Temperature":23.0,"Humidity":43.6,"Pressure":981.6},"BH1750":{"Illuminance":0},"PressureUnit":"hPa","TempUnit":"C"}
16:14:32 RUL: SWITCH1#STATE performs "publish /device/Bad_unten_Bewegungsmelder/status {"devicename":"Bad-Bewegungsmelder","model":"motiondection","room":"Badunten","infoart":"switch","value":"0"}"
Kann aber sein das ich damals mal was am Topic geändert hatte. Ist schon lange her.
Wie könnte ich doch switch1 und switch2 im IPS sehen?
Edit: Also das wäre Switch1:
Switch2:
21:47:31 RUL: SWITCH2#STATE performs "publish /device/Treppenhaus_Tuerkontakt/status {"devicename":"Treppenhaus-Tuersensor","model":"doorsensor","room":"Treppenhaus","infoart":"switch","value":"0"}"
21:47:31 MQT: /device/Treppenhaus_Tuerkontakt/status = {"devicename":"Treppenhaus-Tuersensor","model":"doorsensor","room":"Treppenhaus","infoart":"switch","value":"0"}
21:47:32 RUL: SWITCH2#STATE performs "publish /device/Treppenhaus_Tuerkontakt/status {"devicename":"Treppenhaus-Tuersensor","model":"doorsensor","room":"Treppenhaus","infoart":"switch","value":"1"}"
21:47:32 MQT: /device/Treppenhaus_Tuerkontakt/status = {"devicename":"Treppenhaus-Tuersensor","model":"doorsensor","room":"Treppenhaus","infoart":"switch","value":"1"}
Oder könnt Ihr vielleicht auf die sprünge helfen wie ich an die 1 und 0 per Script komme?
