TXT: 03.12.2021, 14:52:07 | MQTT Topic | shellypro4pm-84cca87ef618/status/switch:3
HEX: 03.12.2021, 14:52:07 | MQTT Topic | 73 68 65 6C 6C 79 70 72 6F 34 70 6D 2D 38 34 63 63 61 38 37 65 66 36 31 38 2F 73 74 61 74 75 73 2F 73 77 69 74 63 68 3A 33
TXT: 03.12.2021, 14:52:07 | JSON | {"DataID":"{7F7632D9-FA40-4F38-8DEA-C83CD4325A32}","PacketType":3,"QualityOfService":2,"Retain":false,"Topic":"shellypro4pm-84cca87ef618/status/switch:3","Payload":"{\"id\": 3, \"source\": \"init\", \"output\": true, \"apower\": 133.957, \"voltage\": 238.127, \"current\": 0.714, \"pf\": 0.746, \"aenergy\": {\"total\":2461.403,\"by_minute\":[256.573,1906.992,1929.786],\"minute_ts\":1638539527},\"temperature\":{\"tC\":41.0, \"tF\":105.8}}"}
HEX: 03.12.2021, 14:52:07 | JSON | 7B 22 44 61 74 61 49 44 22 3A 22 7B 37 46 37 36 33 32 44 39 2D 46 41 34 30 2D 34 46 33 38 2D 38 44 45 41 2D 43 38 33 43 44 34 33 32 35 41 33 32 7D 22 2C 22 50 61 63 6B 65 74 54 79 70 65 22 3A 33 2C 22 51 75 61 6C 69 74 79 4F 66 53 65 72 76 69 63 65 22 3A 32 2C 22 52 65 74 61 69 6E 22 3A 66 61 6C 73 65 2C 22 54 6F 70 69 63 22 3A 22 73 68 65 6C 6C 79 70 72 6F 34 70 6D 2D 38 34 63 63 61 38 37 65 66 36 31 38 2F 73 74 61 74 75 73 2F 73 77 69 74 63 68 3A 33 22 2C 22 50 61 79 6C 6F 61 64 22 3A 22 7B 5C 22 69 64 5C 22 3A 20 33 2C 20 5C 22 73 6F 75 72 63 65 5C 22 3A 20 5C 22 69 6E 69 74 5C 22 2C 20 5C 22 6F 75 74 70 75 74 5C 22 3A 20 74 72 75 65 2C 20 5C 22 61 70 6F 77 65 72 5C 22 3A 20 31 33 33 2E 39 35 37 2C 20 5C 22 76 6F 6C 74 61 67 65 5C 22 3A 20 32 33 38 2E 31 32 37 2C 20 5C 22 63 75 72 72 65 6E 74 5C 22 3A 20 30 2E 37 31 34 2C 20 5C 22 70 66 5C 22 3A 20 30 2E 37 34 36 2C 20 5C 22 61 65 6E 65 72 67 79 5C 22 3A 20 7B 5C 22 74 6F 74 61 6C 5C 22 3A 32 34 36 31 2E 34 30 33 2C 5C 22 62 79 5F 6D 69 6E 75 74 65 5C 22 3A 5B 32 35 36 2E 35 37 33 2C 31 39 30 36 2E 39 39 32 2C 31 39 32 39 2E 37 38 36 5D 2C 5C 22 6D 69 6E 75 74 65 5F 74 73 5C 22 3A 31 36 33 38 35 33 39 35 32 37 7D 2C 5C 22 74 65 6D 70 65 72 61 74 75 72 65 5C 22 3A 7B 5C 22 74 43 5C 22 3A 34 31 2E 30 2C 20 5C 22 74 46 5C 22 3A 31 30 35 2E 38 7D 7D 22 7D
TXT: 03.12.2021, 14:52:07 | JSON | {"DataID":"{7F7632D9-FA40-4F38-8DEA-C83CD4325A32}","PacketType":3,"QualityOfService":1,"Retain":false,"Topic":"shellypro4pm-84cca87ef618/events/rpc","Payload":"{\"src\":\"shellypro4pm-84cca87ef618\",\"dst\":\"shellypro4pm-84cca87ef618/events\",\"method\":\"NotifyStatus\",\"params\":{\"ts\":1638539528.58,\"switch:3\":{\"id\":3,\"current\":0.685}}}"}
HEX: 03.12.2021, 14:52:07 | JSON | 7B 22 44 61 74 61 49 44 22 3A 22 7B 37 46 37 36 33 32 44 39 2D 46 41 34 30 2D 34 46 33 38 2D 38 44 45 41 2D 43 38 33 43 44 34 33 32 35 41 33 32 7D 22 2C 22 50 61 63 6B 65 74 54 79 70 65 22 3A 33 2C 22 51 75 61 6C 69 74 79 4F 66 53 65 72 76 69 63 65 22 3A 31 2C 22 52 65 74 61 69 6E 22 3A 66 61 6C 73 65 2C 22 54 6F 70 69 63 22 3A 22 73 68 65 6C 6C 79 70 72 6F 34 70 6D 2D 38 34 63 63 61 38 37 65 66 36 31 38 2F 65 76 65 6E 74 73 2F 72 70 63 22 2C 22 50 61 79 6C 6F 61 64 22 3A 22 7B 5C 22 73 72 63 5C 22 3A 5C 22 73 68 65 6C 6C 79 70 72 6F 34 70 6D 2D 38 34 63 63 61 38 37 65 66 36 31 38 5C 22 2C 5C 22 64 73 74 5C 22 3A 5C 22 73 68 65 6C 6C 79 70 72 6F 34 70 6D 2D 38 34 63 63 61 38 37 65 66 36 31 38 2F 65 76 65 6E 74 73 5C 22 2C 5C 22 6D 65 74 68 6F 64 5C 22 3A 5C 22 4E 6F 74 69 66 79 53 74 61 74 75 73 5C 22 2C 5C 22 70 61 72 61 6D 73 5C 22 3A 7B 5C 22 74 73 5C 22 3A 31 36 33 38 35 33 39 35 32 38 2E 35 38 2C 5C 22 73 77 69 74 63 68 3A 33 5C 22 3A 7B 5C 22 69 64 5C 22 3A 33 2C 5C 22 63 75 72 72 65 6E 74 5C 22 3A 30 2E 36 38 35 7D 7D 7D 22 7D
TXT: 03.12.2021, 14:52:07 | MQTT Topic | shellypro4pm-84cca87ef618/events/rpc
HEX: 03.12.2021, 14:52:07 | MQTT Topic | 73 68 65 6C 6C 79 70 72 6F 34 70 6D 2D 38 34 63 63 61 38 37 65 66 36 31 38 2F 65 76 65 6E 74 73 2F 72 70 63
TXT: 03.12.2021, 14:52:10 | sendMQTTMQTT Server | {"DataID":"{043EA491-0325-4ADD-8FC2-A30C8EEB4D3F}","PacketType":3,"QualityOfService":0,"Retain":false,"Topic":"shellypro4pm-84cca87ef618/rpc","Payload":"{\"id\":1,\"src\":\"user_1\",\"method\":\"Switch.Set\",\"params\":{\"id\":0,\"on\":true}}"}
HEX: 03.12.2021, 14:52:10 | sendMQTTMQTT Server | 7B 22 44 61 74 61 49 44 22 3A 22 7B 30 34 33 45 41 34 39 31 2D 30 33 32 35 2D 34 41 44 44 2D 38 46 43 32 2D 41 33 30 43 38 45 45 42 34 44 33 46 7D 22 2C 22 50 61 63 6B 65 74 54 79 70 65 22 3A 33 2C 22 51 75 61 6C 69 74 79 4F 66 53 65 72 76 69 63 65 22 3A 30 2C 22 52 65 74 61 69 6E 22 3A 66 61 6C 73 65 2C 22 54 6F 70 69 63 22 3A 22 73 68 65 6C 6C 79 70 72 6F 34 70 6D 2D 38 34 63 63 61 38 37 65 66 36 31 38 2F 72 70 63 22 2C 22 50 61 79 6C 6F 61 64 22 3A 22 7B 5C 22 69 64 5C 22 3A 31 2C 5C 22 73 72 63 5C 22 3A 5C 22 75 73 65 72 5F 31 5C 22 2C 5C 22 6D 65 74 68 6F 64 5C 22 3A 5C 22 53 77 69 74 63 68 2E 53 65 74 5C 22 2C 5C 22 70 61 72 61 6D 73 5C 22 3A 7B 5C 22 69 64 5C 22 3A 30 2C 5C 22 6F 6E 5C 22 3A 74 72 75 65 7D 7D 22 7D
TXT: 03.12.2021, 14:52:10 | sendMQTTMQTT Client | {"DataID":"{97475B04-67C3-A74D-C970-E9409B0EFA1D}","Buffer":"{\"PacketType\":3,\"QualityOfService\":0,\"Retain\":false,\"Topic\":\"shellypro4pm-84cca87ef618\/rpc\",\"Payload\":\"{\\\"id\\\":1,\\\"src\\\":\\\"user_1\\\",\\\"method\\\":\\\"Switch.Set\\\",\\\"params\\\":{\\\"id\\\":0,\\\"on\\\":true}}\"}"}
HEX: 03.12.2021, 14:52:10 | sendMQTTMQTT Client | 7B 22 44 61 74 61 49 44 22 3A 22 7B 39 37 34 37 35 42 30 34 2D 36 37 43 33 2D 41 37 34 44 2D 43 39 37 30 2D 45 39 34 30 39 42 30 45 46 41 31 44 7D 22 2C 22 42 75 66 66 65 72 22 3A 22 7B 5C 22 50 61 63 6B 65 74 54 79 70 65 5C 22 3A 33 2C 5C 22 51 75 61 6C 69 74 79 4F 66 53 65 72 76 69 63 65 5C 22 3A 30 2C 5C 22 52 65 74 61 69 6E 5C 22 3A 66 61 6C 73 65 2C 5C 22 54 6F 70 69 63 5C 22 3A 5C 22 73 68 65 6C 6C 79 70 72 6F 34 70 6D 2D 38 34 63 63 61 38 37 65 66 36 31 38 5C 2F 72 70 63 5C 22 2C 5C 22 50 61 79 6C 6F 61 64 5C 22 3A 5C 22 7B 5C 5C 5C 22 69 64 5C 5C 5C 22 3A 31 2C 5C 5C 5C 22 73 72 63 5C 5C 5C 22 3A 5C 5C 5C 22 75 73 65 72 5F 31 5C 5C 5C 22 2C 5C 5C 5C 22 6D 65 74 68 6F 64 5C 5C 5C 22 3A 5C 5C 5C 22 53 77 69 74 63 68 2E 53 65 74 5C 5C 5C 22 2C 5C 5C 5C 22 70 61 72 61 6D 73 5C 5C 5C 22 3A 7B 5C 5C 5C 22 69 64 5C 5C 5C 22 3A 30 2C 5C 5C 5C 22 6F 6E 5C 5C 5C 22 3A 74 72 75 65 7D 7D 5C 22 7D 22 7D
TXT: 03.12.2021, 14:52:10 | JSON | {"DataID":"{7F7632D9-FA40-4F38-8DEA-C83CD4325A32}","PacketType":3,"QualityOfService":1,"Retain":false,"Topic":"user_1/rpc","Payload":"{\"id\":1,\"src\":\"shellypro4pm-84cca87ef618\",\"dst\":\"user_1\",\"result\":{\"was_on\":false}}"}
HEX: 03.12.2021, 14:52:10 | JSON | 7B 22 44 61 74 61 49 44 22 3A 22 7B 37 46 37 36 33 32 44 39 2D 46 41 34 30 2D 34 46 33 38 2D 38 44 45 41 2D 43 38 33 43 44 34 33 32 35 41 33 32 7D 22 2C 22 50 61 63 6B 65 74 54 79 70 65 22 3A 33 2C 22 51 75 61 6C 69 74 79 4F 66 53 65 72 76 69 63 65 22 3A 31 2C 22 52 65 74 61 69 6E 22 3A 66 61 6C 73 65 2C 22 54 6F 70 69 63 22 3A 22 75 73 65 72 5F 31 2F 72 70 63 22 2C 22 50 61 79 6C 6F 61 64 22 3A 22 7B 5C 22 69 64 5C 22 3A 31 2C 5C 22 73 72 63 5C 22 3A 5C 22 73 68 65 6C 6C 79 70 72 6F 34 70 6D 2D 38 34 63 63 61 38 37 65 66 36 31 38 5C 22 2C 5C 22 64 73 74 5C 22 3A 5C 22 75 73 65 72 5F 31 5C 22 2C 5C 22 72 65 73 75 6C 74 5C 22 3A 7B 5C 22 77 61 73 5F 6F 6E 5C 22 3A 66 61 6C 73 65 7D 7D 22 7D
TXT: 03.12.2021, 14:52:10 | MQTT Topic | user_1/rpc
HEX: 03.12.2021, 14:52:10 | MQTT Topic | 75 73 65 72 5F 31 2F 72 70 63
TXT: 03.12.2021, 14:52:10 | JSON | {"DataID":"{7F7632D9-FA40-4F38-8DEA-C83CD4325A32}","PacketType":3,"QualityOfService":2,"Retain":false,"Topic":"shellypro4pm-84cca87ef618/status/switch:0","Payload":"{\"id\": 0, \"source\": \"MQTT\", \"output\": true, \"apower\": 0.000, \"voltage\": 238.353, \"current\": 0.000, \"pf\": 0.000, \"aenergy\": {\"total\":0.000,\"by_minute\":[0.000,0.000,0.000],\"minute_ts\":1638539529},\"temperature\":{\"tC\":40.9, \"tF\":105.6}}"}
HEX: 03.12.2021, 14:52:10 | JSON | 7B 22 44 61 74 61 49 44 22 3A 22 7B 37 46 37 36 33 32 44 39 2D 46 41 34 30 2D 34 46 33 38 2D 38 44 45 41 2D 43 38 33 43 44 34 33 32 35 41 33 32 7D 22 2C 22 50 61 63 6B 65 74 54 79 70 65 22 3A 33 2C 22 51 75 61 6C 69 74 79 4F 66 53 65 72 76 69 63 65 22 3A 32 2C 22 52 65 74 61 69 6E 22 3A 66 61 6C 73 65 2C 22 54 6F 70 69 63 22 3A 22 73 68 65 6C 6C 79 70 72 6F 34 70 6D 2D 38 34 63 63 61 38 37 65 66 36 31 38 2F 73 74 61 74 75 73 2F 73 77 69 74 63 68 3A 30 22 2C 22 50 61 79 6C 6F 61 64 22 3A 22 7B 5C 22 69 64 5C 22 3A 20 30 2C 20 5C 22 73 6F 75 72 63 65 5C 22 3A 20 5C 22 4D 51 54 54 5C 22 2C 20 5C 22 6F 75 74 70 75 74 5C 22 3A 20 74 72 75 65 2C 20 5C 22 61 70 6F 77 65 72 5C 22 3A 20 30 2E 30 30 30 2C 20 5C 22 76 6F 6C 74 61 67 65 5C 22 3A 20 32 33 38 2E 33 35 33 2C 20 5C 22 63 75 72 72 65 6E 74 5C 22 3A 20 30 2E 30 30 30 2C 20 5C 22 70 66 5C 22 3A 20 30 2E 30 30 30 2C 20 5C 22 61 65 6E 65 72 67 79 5C 22 3A 20 7B 5C 22 74 6F 74 61 6C 5C 22 3A 30 2E 30 30 30 2C 5C 22 62 79 5F 6D 69 6E 75 74 65 5C 22 3A 5B 30 2E 30 30 30 2C 30 2E 30 30 30 2C 30 2E 30 30 30 5D 2C 5C 22 6D 69 6E 75 74 65 5F 74 73 5C 22 3A 31 36 33 38 35 33 39 35 32 39 7D 2C 5C 22 74 65 6D 70 65 72 61 74 75 72 65 5C 22 3A 7B 5C 22 74 43 5C 22 3A 34 30 2E 39 2C 20 5C 22 74 46 5C 22 3A 31 30 35 2E 36 7D 7D 22 7D
TXT: 03.12.2021, 14:52:10 | MQTT Topic | shellypro4pm-84cca87ef618/status/switch:0
HEX: 03.12.2021, 14:52:10 | MQTT Topic | 73 68 65 6C 6C 79 70 72 6F 34 70 6D 2D 38 34 63 63 61 38 37 65 66 36 31 38 2F 73 74 61 74 75 73 2F 73 77 69 74 63 68 3A 30
TXT: 03.12.2021, 14:52:10 | JSON | {"DataID":"{7F7632D9-FA40-4F38-8DEA-C83CD4325A32}","PacketType":3,"QualityOfService":1,"Retain":false,"Topic":"shellypro4pm-84cca87ef618/events/rpc","Payload":"{\"src\":\"shellypro4pm-84cca87ef618\",\"dst\":\"shellypro4pm-84cca87ef618/events\",\"method\":\"NotifyStatus\",\"params\":{\"ts\":1638539530.77,\"switch:0\":{\"id\":0,\"output\":true,\"source\":\"MQTT\"}}}"}
HEX: 03.12.2021, 14:52:10 | JSON | 7B 22 44 61 74 61 49 44 22 3A 22 7B 37 46 37 36 33 32 44 39 2D 46 41 34 30 2D 34 46 33 38 2D 38 44 45 41 2D 43 38 33 43 44 34 33 32 35 41 33 32 7D 22 2C 22 50 61 63 6B 65 74 54 79 70 65 22 3A 33 2C 22 51 75 61 6C 69 74 79 4F 66 53 65 72 76 69 63 65 22 3A 31 2C 22 52 65 74 61 69 6E 22 3A 66 61 6C 73 65 2C 22 54 6F 70 69 63 22 3A 22 73 68 65 6C 6C 79 70 72 6F 34 70 6D 2D 38 34 63 63 61 38 37 65 66 36 31 38 2F 65 76 65 6E 74 73 2F 72 70 63 22 2C 22 50 61 79 6C 6F 61 64 22 3A 22 7B 5C 22 73 72 63 5C 22 3A 5C 22 73 68 65 6C 6C 79 70 72 6F 34 70 6D 2D 38 34 63 63 61 38 37 65 66 36 31 38 5C 22 2C 5C 22 64 73 74 5C 22 3A 5C 22 73 68 65 6C 6C 79 70 72 6F 34 70 6D 2D 38 34 63 63 61 38 37 65 66 36 31 38 2F 65 76 65 6E 74 73 5C 22 2C 5C 22 6D 65 74 68 6F 64 5C 22 3A 5C 22 4E 6F 74 69 66 79 53 74 61 74 75 73 5C 22 2C 5C 22 70 61 72 61 6D 73 5C 22 3A 7B 5C 22 74 73 5C 22 3A 31 36 33 38 35 33 39 35 33 30 2E 37 37 2C 5C 22 73 77 69 74 63 68 3A 30 5C 22 3A 7B 5C 22 69 64 5C 22 3A 30 2C 5C 22 6F 75 74 70 75 74 5C 22 3A 74 72 75 65 2C 5C 22 73 6F 75 72 63 65 5C 22 3A 5C 22 4D 51 54 54 5C 22 7D 7D 7D 22 7D
TXT: 03.12.2021, 14:52:10 | MQTT Topic | shellypro4pm-84cca87ef618/events/rpc
HEX: 03.12.2021, 14:52:10 | MQTT Topic | 73 68 65 6C 6C 79 70 72 6F 34 70 6D 2D 38 34 63 63 61 38 37 65 66 36 31 38 2F 65 76 65 6E 74 73 2F 72 70 63
TXT: 03.12.2021, 14:52:11 | JSON | {"DataID":"{7F7632D9-FA40-4F38-8DEA-C83CD4325A32}","PacketType":3,"QualityOfService":1,"Retain":false,"Topic":"shellypro4pm-84cca87ef618/events/rpc","Payload":"{\"src\":\"shellypro4pm-84cca87ef618\",\"dst\":\"shellypro4pm-84cca87ef618/events\",\"method\":\"NotifyStatus\",\"params\":{\"ts\":1638539532.58,\"switch:3\":{\"id\":3,\"apower\":147.849}}}"}
HEX: 03.12.2021, 14:52:11 | JSON | 7B 22 44 61 74 61 49 44 22 3A 22 7B 37 46 37 36 33 32 44 39 2D 46 41 34 30 2D 34 46 33 38 2D 38 44 45 41 2D 43 38 33 43 44 34 33 32 35 41 33 32 7D 22 2C 22 50 61 63 6B 65 74 54 79 70 65 22 3A 33 2C 22 51 75 61 6C 69 74 79 4F 66 53 65 72 76 69 63 65 22 3A 31 2C 22 52 65 74 61 69 6E 22 3A 66 61 6C 73 65 2C 22 54 6F 70 69 63 22 3A 22 73 68 65 6C 6C 79 70 72 6F 34 70 6D 2D 38 34 63 63 61 38 37 65 66 36 31 38 2F 65 76 65 6E 74 73 2F 72 70 63 22 2C 22 50 61 79 6C 6F 61 64 22 3A 22 7B 5C 22 73 72 63 5C 22 3A 5C 22 73 68 65 6C 6C 79 70 72 6F 34 70 6D 2D 38 34 63 63 61 38 37 65 66 36 31 38 5C 22 2C 5C 22 64 73 74 5C 22 3A 5C 22 73 68 65 6C 6C 79 70 72 6F 34 70 6D 2D 38 34 63 63 61 38 37 65 66 36 31 38 2F 65 76 65 6E 74 73 5C 22 2C 5C 22 6D 65 74 68 6F 64 5C 22 3A 5C 22 4E 6F 74 69 66 79 53 74 61 74 75 73 5C 22 2C 5C 22 70 61 72 61 6D 73 5C 22 3A 7B 5C 22 74 73 5C 22 3A 31 36 33 38 35 33 39 35 33 32 2E 35 38 2C 5C 22 73 77 69 74 63 68 3A 33 5C 22 3A 7B 5C 22 69 64 5C 22 3A 33 2C 5C 22 61 70 6F 77 65 72 5C 22 3A 31 34 37 2E 38 34 39 7D 7D 7D 22 7D
