Meinst du mit Dump ein Debug?
also sowas?
TXT: 10.01.2023, 21:25:44 | Request PostData: |
HEX: 10.01.2023, 21:25:44 | Request PostData: |
TXT: 10.01.2023, 21:25:44 | Request Result:prtg-version | 22.4.81.1532
HEX: 10.01.2023, 21:25:44 | Request Result:prtg-version | 32 32 2E 34 2E 38 31 2E 31 35 33 32
TXT: 10.01.2023, 21:25:44 | Request Result:treesize | 1
HEX: 10.01.2023, 21:25:44 | Request Result:treesize | 31
TXT: 10.01.2023, 21:25:44 | Request Result:sensors:0:objid | 10664
HEX: 10.01.2023, 21:25:44 | Request Result:sensors:0:objid | 31 30 36 36 34
TXT: 10.01.2023, 21:25:44 | Request Result:sensors:0:objid_raw | 10664
HEX: 10.01.2023, 21:25:44 | Request Result:sensors:0:objid_raw | 31 30 36 36 34
TXT: 10.01.2023, 21:25:44 | Request Result:sensors:0:lastvalue | 1,17 Mbit/Sek.
HEX: 10.01.2023, 21:25:44 | Request Result:sensors:0:lastvalue | 31 2C 31 37 20 4D 62 69 74 2F 53 65 6B 2E
TXT: 10.01.2023, 21:25:44 | Request Result:sensors:0:lastvalue_raw | 145705,4
HEX: 10.01.2023, 21:25:44 | Request Result:sensors:0:lastvalue_raw | 31 34 35 37 30 35 2C 34
TXT: 10.01.2023, 21:25:44 | Request Result:sensors:0:device | Router
HEX: 10.01.2023, 21:25:44 | Request Result:sensors:0:device | 52 6F 75 74 65 72 20 44 61 76 65 72 64 65 6E
TXT: 10.01.2023, 21:25:44 | Request Result:sensors:0:device_raw | Router
HEX: 10.01.2023, 21:25:44 | Request Result:sensors:0:device_raw | 52 6F 75 74 65 72 20 44 61 76 65 72 64 65 6E
TXT: 10.01.2023, 21:25:44 | Request Result:sensors:0:status | OK
HEX: 10.01.2023, 21:25:44 | Request Result:sensors:0:status | 4F 4B
TXT: 10.01.2023, 21:25:44 | Request Result:sensors:0:status_raw | 3
HEX: 10.01.2023, 21:25:44 | Request Result:sensors:0:status_raw | 33
TXT: 10.01.2023, 21:25:44 | Request Result:sensors:0:name | (012) pppoe_WAN Traffic
HEX: 10.01.2023, 21:25:44 | Request Result:sensors:0:name | 28 30 31 32 29 20 70 70 70 6F 65 5F 57 41 4E 20 54 72 61 66 66 69 63
TXT: 10.01.2023, 21:25:44 | Request Result:sensors:0:name_raw | (012) pppoe_WAN Traffic
HEX: 10.01.2023, 21:25:44 | Request Result:sensors:0:name_raw | 28 30 31 32 29 20 70 70 70 6F 65 5F 57 41 4E 20 54 72 61 66 66 69 63
TXT: 10.01.2023, 21:25:44 | Request Result:sensors:0:interval | 5 Sek.
HEX: 10.01.2023, 21:25:44 | Request Result:sensors:0:interval | 35 20 53 65 6B 2E
TXT: 10.01.2023, 21:25:44 | Request Result:sensors:0:interval_raw | 5
HEX: 10.01.2023, 21:25:44 | Request Result:sensors:0:interval_raw | 35
TXT: 10.01.2023, 21:25:44 | Request Result:sensors:0:active | TRUE
HEX: 10.01.2023, 21:25:44 | Request Result:sensors:0:active | 54 52 55 45
TXT: 10.01.2023, 21:25:44 | Request Result:sensors:0:active_raw | -1
HEX: 10.01.2023, 21:25:44 | Request Result:sensors:0:active_raw | 2D 31
TXT: 10.01.2023, 21:25:44 | Request Uri: | api/table.json
HEX: 10.01.2023, 21:25:44 | Request Uri: | 61 70 69 2F 74 61 62 6C 65 2E 6A 73 6F 6E
TXT: 10.01.2023, 21:25:44 | Request QueryData::content | channels
HEX: 10.01.2023, 21:25:44 | Request QueryData::content | 63 68 61 6E 6E 65 6C 73
TXT: 10.01.2023, 21:25:44 | Request QueryData::columns | objid,lastvalue,name
HEX: 10.01.2023, 21:25:44 | Request QueryData::columns | 6F 62 6A 69 64 2C 6C 61 73 74 76 61 6C 75 65 2C 6E 61 6D 65
TXT: 10.01.2023, 21:25:44 | Request QueryData::id | 10664
HEX: 10.01.2023, 21:25:44 | Request QueryData::id | 31 30 36 36 34
TXT: 10.01.2023, 21:25:44 | Request Result:treesize | 0
HEX: 10.01.2023, 21:25:44 | Request Result:treesize | 30
TXT: 10.01.2023, 21:25:44 | Request Result:channels:0:objid | 0
HEX: 10.01.2023, 21:25:44 | Request Result:channels:0:objid | 30
TXT: 10.01.2023, 21:25:44 | Request Result:channels:0:objid_raw | 0
HEX: 10.01.2023, 21:25:44 | Request Result:channels:0:objid_raw | 30
TXT: 10.01.2023, 21:25:44 | Request Result:channels:0:lastvalue | 0,68 Mbit/Sek.
HEX: 10.01.2023, 21:25:44 | Request Result:channels:0:lastvalue | 30 2C 36 38 20 4D 62 69 74 2F 53 65 6B 2E
TXT: 10.01.2023, 21:25:44 | Request Result:channels:0:lastvalue_raw | 85619,6464
HEX: 10.01.2023, 21:25:44 | Request Result:channels:0:lastvalue_raw | 38 35 36 31 39 2C 36 34 36 34
TXT: 10.01.2023, 21:25:44 | Request Result:channels:0:name | Datenverkehr eingehend
HEX: 10.01.2023, 21:25:44 | Request Result:channels:0:name | 44 61 74 65 6E 76 65 72 6B 65 68 72 20 65 69 6E 67 65 68 65 6E 64
TXT: 10.01.2023, 21:25:44 | Request Result:channels:0:name_raw | Datenverkehr eingehend
HEX: 10.01.2023, 21:25:44 | Request Result:channels:0:name_raw | 44 61 74 65 6E 76 65 72 6B 65 68 72 20 65 69 6E 67 65 68 65 6E 64
TXT: 10.01.2023, 21:25:44 | Request Result:channels:1:objid | -1
HEX: 10.01.2023, 21:25:44 | Request Result:channels:1:objid | 2D 31
TXT: 10.01.2023, 21:25:44 | Request Result:channels:1:objid_raw | *000000001
HEX: 10.01.2023, 21:25:44 | Request Result:channels:1:objid_raw | 2A 30 30 30 30 30 30 30 30 31
TXT: 10.01.2023, 21:25:44 | Request Result:channels:1:lastvalue | 0,20 Mbit/Sek.
HEX: 10.01.2023, 21:25:44 | Request Result:channels:1:lastvalue | 30 2C 32 30 20 4D 62 69 74 2F 53 65 6B 2E
TXT: 10.01.2023, 21:25:44 | Request Result:channels:1:lastvalue_raw | 25232,613
HEX: 10.01.2023, 21:25:44 | Request Result:channels:1:lastvalue_raw | 32 35 32 33 32 2C 36 31 33
TXT: 10.01.2023, 21:25:44 | Request Result:channels:1:name | Datenverkehr Summe
HEX: 10.01.2023, 21:25:44 | Request Result:channels:1:name | 44 61 74 65 6E 76 65 72 6B 65 68 72 20 53 75 6D 6D 65
TXT: 10.01.2023, 21:25:44 | Request Result:channels:1:name_raw | Datenverkehr Summe
HEX: 10.01.2023, 21:25:44 | Request Result:channels:1:name_raw | 44 61 74 65 6E 76 65 72 6B 65 68 72 20 53 75 6D 6D 65
TXT: 10.01.2023, 21:25:44 | Request Result:channels:2:objid | -4
HEX: 10.01.2023, 21:25:44 | Request Result:channels:2:objid | 2D 34
TXT: 10.01.2023, 21:25:44 | Request Result:channels:2:objid_raw | *000000004
HEX: 10.01.2023, 21:25:44 | Request Result:channels:2:objid_raw | 2A 30 30 30 30 30 30 30 30 34
TXT: 10.01.2023, 21:25:44 | Request Result:channels:2:lastvalue |
HEX: 10.01.2023, 21:25:44 | Request Result:channels:2:lastvalue |
TXT: 10.01.2023, 21:25:44 | Request Result:channels:2:lastvalue_raw |
HEX: 10.01.2023, 21:25:44 | Request Result:channels:2:lastvalue_raw |
TXT: 10.01.2023, 21:25:44 | Request Result:channels:2:name | Ausfallzeit
HEX: 10.01.2023, 21:25:44 | Request Result:channels:2:name | 41 75 73 66 61 6C 6C 7A 65 69 74
TXT: 10.01.2023, 21:25:44 | Request Result:channels:2:name_raw | Ausfallzeit
HEX: 10.01.2023, 21:25:44 | Request Result:channels:2:name_raw | 41 75 73 66 61 6C 6C 7A 65 69 74
TXT: 10.01.2023, 21:25:44 | Request Result:channels:3:objid | 1
HEX: 10.01.2023, 21:25:44 | Request Result:channels:3:objid | 31
TXT: 10.01.2023, 21:25:44 | Request Result:channels:3:objid_raw | 1
HEX: 10.01.2023, 21:25:44 | Request Result:channels:3:objid_raw | 31
TXT: 10.01.2023, 21:25:44 | Request Result:channels:3:lastvalue | 0,46 Mbit/Sek.
HEX: 10.01.2023, 21:25:44 | Request Result:channels:3:lastvalue | 30 2C 34 36 20 4D 62 69 74 2F 53 65 6B 2E
TXT: 10.01.2023, 21:25:44 | Request Result:channels:3:lastvalue_raw | 57509,4303
HEX: 10.01.2023, 21:25:44 | Request Result:channels:3:lastvalue_raw | 35 37 35 30 39 2C 34 33 30 33
TXT: 10.01.2023, 21:25:44 | Request Result:channels:3:name | Datenverkehr ausgehend
HEX: 10.01.2023, 21:25:44 | Request Result:channels:3:name | 44 61 74 65 6E 76 65 72 6B 65 68 72 20 61 75 73 67 65 68 65 6E 64
TXT: 10.01.2023, 21:25:44 | Request Result:channels:3:name_raw | Datenverkehr ausgehend
HEX: 10.01.2023, 21:25:44 | Request Result:channels:3:name_raw | 44 61 74 65 6E 76 65 72 6B 65 68 72 20 61 75 73 67 65 68 65 6E 64
TXT: 10.01.2023, 21:25:50 | Request Uri: | api/table.json
HEX: 10.01.2023, 21:25:50 | Request Uri: | 61 70 69 2F 74 61 62 6C 65 2E 6A 73 6F 6E
TXT: 10.01.2023, 21:25:50 | Request QueryData::content | sensors
HEX: 10.01.2023, 21:25:50 | Request QueryData::content | 73 65 6E 73 6F 72 73
TXT: 10.01.2023, 21:25:50 | Request QueryData::columns | objid,lastvalue,device,status,name,interval,active
HEX: 10.01.2023, 21:25:50 | Request QueryData::columns | 6F 62 6A 69 64 2C 6C 61 73 74 76 61 6C 75 65 2C 64 65 76 69 63 65 2C 73 74 61 74 75 73 2C 6E 61 6D 65 2C 69 6E 74 65 72 76 61 6C 2C 61 63 74 69 76 65
TXT: 10.01.2023, 21:25:50 | Request QueryData::filter_objid | 10664
HEX: 10.01.2023, 21:25:50 | Request QueryData::filter_objid | 31 30 36 36 34
TXT: 10.01.2023, 21:25:50 | Request PostData: |
HEX: 10.01.2023, 21:25:50 | Request PostData: |
TXT: 10.01.2023, 21:25:50 | Request Result:prtg-version | 22.4.81.1532
HEX: 10.01.2023, 21:25:50 | Request Result:prtg-version | 32 32 2E 34 2E 38 31 2E 31 35 33 32
TXT: 10.01.2023, 21:25:50 | Request Result:treesize | 1
HEX: 10.01.2023, 21:25:50 | Request Result:treesize | 31
TXT: 10.01.2023, 21:25:50 | Request Result:sensors:0:objid | 10664
HEX: 10.01.2023, 21:25:50 | Request Result:sensors:0:objid | 31 30 36 36 34
TXT: 10.01.2023, 21:25:50 | Request Result:sensors:0:objid_raw | 10664
HEX: 10.01.2023, 21:25:50 | Request Result:sensors:0:objid_raw | 31 30 36 36 34
TXT: 10.01.2023, 21:25:50 | Request Result:sensors:0:lastvalue | 0,52 Mbit/Sek.
HEX: 10.01.2023, 21:25:50 | Request Result:sensors:0:lastvalue | 30 2C 35 32 20 4D 62 69 74 2F 53 65 6B 2E
TXT: 10.01.2023, 21:25:50 | Request Result:sensors:0:lastvalue_raw | 64761,6327
HEX: 10.01.2023, 21:25:50 | Request Result:sensors:0:lastvalue_raw | 36 34 37 36 31 2C 36 33 32 37
TXT: 10.01.2023, 21:25:50 | Request Result:sensors:0:device | Router
HEX: 10.01.2023, 21:25:50 | Request Result:sensors:0:device | 52 6F 75 74 65 72 20 44 61 76 65 72 64 65 6E
TXT: 10.01.2023, 21:25:50 | Request Result:sensors:0:device_raw | Router
HEX: 10.01.2023, 21:25:50 | Request Result:sensors:0:device_raw | 52 6F 75 74 65 72 20 44 61 76 65 72 64 65 6E
TXT: 10.01.2023, 21:25:50 | Request Result:sensors:0:status | OK
HEX: 10.01.2023, 21:25:50 | Request Result:sensors:0:status | 4F 4B
TXT: 10.01.2023, 21:25:50 | Request Result:sensors:0:status_raw | 3
HEX: 10.01.2023, 21:25:50 | Request Result:sensors:0:status_raw | 33
TXT: 10.01.2023, 21:25:50 | Request Result:sensors:0:name | (012) pppoe_WAN Traffic
HEX: 10.01.2023, 21:25:50 | Request Result:sensors:0:name | 28 30 31 32 29 20 70 70 70 6F 65 5F 57 41 4E 20 54 72 61 66 66 69 63
TXT: 10.01.2023, 21:25:50 | Request Result:sensors:0:name_raw | (012) pppoe_WAN Traffic
HEX: 10.01.2023, 21:25:50 | Request Result:sensors:0:name_raw | 28 30 31 32 29 20 70 70 70 6F 65 5F 57 41 4E 20 54 72 61 66 66 69 63
TXT: 10.01.2023, 21:25:50 | Request Result:sensors:0:interval | 5 Sek.
HEX: 10.01.2023, 21:25:50 | Request Result:sensors:0:interval | 35 20 53 65 6B 2E
TXT: 10.01.2023, 21:25:50 | Request Result:sensors:0:interval_raw | 5
HEX: 10.01.2023, 21:25:50 | Request Result:sensors:0:interval_raw | 35
TXT: 10.01.2023, 21:25:50 | Request Result:sensors:0:active | TRUE
HEX: 10.01.2023, 21:25:50 | Request Result:sensors:0:active | 54 52 55 45
TXT: 10.01.2023, 21:25:50 | Request Result:sensors:0:active_raw | -1
HEX: 10.01.2023, 21:25:50 | Request Result:sensors:0:active_raw | 2D 31
TXT: 10.01.2023, 21:25:50 | Request QueryData::content | channels
HEX: 10.01.2023, 21:25:50 | Request QueryData::content | 63 68 61 6E 6E 65 6C 73
TXT: 10.01.2023, 21:25:50 | Request QueryData::columns | objid,lastvalue,name
HEX: 10.01.2023, 21:25:50 | Request QueryData::columns | 6F 62 6A 69 64 2C 6C 61 73 74 76 61 6C 75 65 2C 6E 61 6D 65
TXT: 10.01.2023, 21:25:50 | Request QueryData::id | 10664
HEX: 10.01.2023, 21:25:50 | Request QueryData::id | 31 30 36 36 34
TXT: 10.01.2023, 21:25:50 | Request Result:treesize | 0
HEX: 10.01.2023, 21:25:50 | Request Result:treesize | 30
TXT: 10.01.2023, 21:25:50 | Request Result:channels:0:objid | 0
HEX: 10.01.2023, 21:25:50 | Request Result:channels:0:objid | 30
TXT: 10.01.2023, 21:25:50 | Request Result:channels:0:objid_raw | 0
HEX: 10.01.2023, 21:25:50 | Request Result:channels:0:objid_raw | 30
TXT: 10.01.2023, 21:25:50 | Request Result:channels:0:lastvalue | 0,41 Mbit/Sek.
HEX: 10.01.2023, 21:25:50 | Request Result:channels:0:lastvalue | 30 2C 34 31 20 4D 62 69 74 2F 53 65 6B 2E
TXT: 10.01.2023, 21:25:50 | Request Result:channels:0:lastvalue_raw | 50896,1224
HEX: 10.01.2023, 21:25:50 | Request Result:channels:0:lastvalue_raw | 35 30 38 39 36 2C 31 32 32 34
TXT: 10.01.2023, 21:25:50 | Request Result:channels:0:name | Datenverkehr eingehend
HEX: 10.01.2023, 21:25:50 | Request Result:channels:0:name | 44 61 74 65 6E 76 65 72 6B 65 68 72 20 65 69 6E 67 65 68 65 6E 64
TXT: 10.01.2023, 21:25:50 | Request Result:channels:0:name_raw | Datenverkehr eingehend
HEX: 10.01.2023, 21:25:50 | Request Result:channels:0:name_raw | 44 61 74 65 6E 76 65 72 6B 65 68 72 20 65 69 6E 67 65 68 65 6E 64
TXT: 10.01.2023, 21:25:50 | Request Result:channels:1:objid | -1
HEX: 10.01.2023, 21:25:50 | Request Result:channels:1:objid | 2D 31
TXT: 10.01.2023, 21:25:50 | Request Result:channels:1:objid_raw | *000000001
HEX: 10.01.2023, 21:25:50 | Request Result:channels:1:objid_raw | 2A 30 30 30 30 30 30 30 30 31
TXT: 10.01.2023, 21:25:50 | Request Result:channels:1:lastvalue | 0,52 Mbit/Sek.
HEX: 10.01.2023, 21:25:50 | Request Result:channels:1:lastvalue | 30 2C 35 32 20 4D 62 69 74 2F 53 65 6B 2E
TXT: 10.01.2023, 21:25:50 | Request Result:channels:1:lastvalue_raw | 64761,6327
HEX: 10.01.2023, 21:25:50 | Request Result:channels:1:lastvalue_raw | 36 34 37 36 31 2C 36 33 32 37
TXT: 10.01.2023, 21:25:50 | Request Result:channels:1:name | Datenverkehr Summe
HEX: 10.01.2023, 21:25:50 | Request Result:channels:1:name | 44 61 74 65 6E 76 65 72 6B 65 68 72 20 53 75 6D 6D 65
TXT: 10.01.2023, 21:25:50 | Request Result:channels:1:name_raw | Datenverkehr Summe
HEX: 10.01.2023, 21:25:50 | Request Result:channels:1:name_raw | 44 61 74 65 6E 76 65 72 6B 65 68 72 20 53 75 6D 6D 65
TXT: 10.01.2023, 21:25:50 | Request Result:channels:2:objid | -4
HEX: 10.01.2023, 21:25:50 | Request Result:channels:2:objid | 2D 34
TXT: 10.01.2023, 21:25:50 | Request Result:channels:2:objid_raw | *000000004
HEX: 10.01.2023, 21:25:50 | Request Result:channels:2:objid_raw | 2A 30 30 30 30 30 30 30 30 34
TXT: 10.01.2023, 21:25:50 | Request Result:channels:2:lastvalue |
HEX: 10.01.2023, 21:25:50 | Request Result:channels:2:lastvalue |
TXT: 10.01.2023, 21:25:50 | Request Result:channels:2:lastvalue_raw |
HEX: 10.01.2023, 21:25:50 | Request Result:channels:2:lastvalue_raw |
TXT: 10.01.2023, 21:25:50 | Request Result:channels:2:name | Ausfallzeit
HEX: 10.01.2023, 21:25:50 | Request Result:channels:2:name | 41 75 73 66 61 6C 6C 7A 65 69 74
TXT: 10.01.2023, 21:25:50 | Request Result:channels:2:name_raw | Ausfallzeit
HEX: 10.01.2023, 21:25:50 | Request Result:channels:2:name_raw | 41 75 73 66 61 6C 6C 7A 65 69 74
TXT: 10.01.2023, 21:25:50 | Request Result:channels:3:objid | 1
HEX: 10.01.2023, 21:25:50 | Request Result:channels:3:objid | 31
TXT: 10.01.2023, 21:25:50 | Request Result:channels:3:objid_raw | 1
HEX: 10.01.2023, 21:25:50 | Request Result:channels:3:objid_raw | 31
TXT: 10.01.2023, 21:25:50 | Request Result:channels:3:lastvalue | 0,11 Mbit/Sek.
HEX: 10.01.2023, 21:25:50 | Request Result:channels:3:lastvalue | 30 2C 31 31 20 4D 62 69 74 2F 53 65 6B 2E
TXT: 10.01.2023, 21:25:50 | Request Result:channels:3:lastvalue_raw | 13865,5102
HEX: 10.01.2023, 21:25:50 | Request Result:channels:3:lastvalue_raw | 31 33 38 36 35 2C 35 31 30 32
TXT: 10.01.2023, 21:25:50 | Request Result:channels:3:name | Datenverkehr ausgehend
HEX: 10.01.2023, 21:25:50 | Request Result:channels:3:name | 44 61 74 65 6E 76 65 72 6B 65 68 72 20 61 75 73 67 65 68 65 6E 64
TXT: 10.01.2023, 21:25:50 | Request Result:channels:3:name_raw | Datenverkehr ausgehend
HEX: 10.01.2023, 21:25:50 | Request Result:channels:3:name_raw | 44 61 74 65 6E 76 65 72 6B 65 68 72 20 61 75 73 67 65 68 65 6E 64
