nach dem Update kommen jetzt sogar in der Stream Instanz Bilder.
Allerdings kann ich die Instanz nicht öffnen es kommt nachfolgende Fehlermeldung
Method 'ns1:GetConfiguration' not implemented: method name or namespace not recognized
{"elements":[{"type":"Select","name":"VideoSource","caption":"Videosource","width":"300px","options":[{"caption":"VideoSourceConfig1","value":"VideoSourceConfigSourceToken0"}],"onChange":"IPS_RequestAction($id,'RefreshProfileForm',$VideoSource);"},{"type":"Select","name":"Profile","caption":"Stream-Profile","width":"300px","options":[{"caption":"none","value":""},{"caption":"VideoEncoderConfig0","value":"IPCProfilesToken0"},{"caption":"VideoEncoderConfig1","value":"IPCProfilesToken1"}]},{"type":"ValidationTextBox","name":"EventTopic","caption":"Events of videosource","width":"300px","enabled":true},{"type":"PopupButton","name":"ConfigurePTZ","caption":"Configure PTZ","width":"300px","enabled":true,"popup":{"caption":"Pan\/Tilt\/Zoom","items":[{"type":"ExpansionPanel","caption":"Control behavior","expanded":false,"items":[{"type":"RowLayout","items":[{"type":"CheckBox","name":"InvertPanControl","caption":"Invert Pan","width":"250px"},{"type":"CheckBox","name":"InvertZoomControl","caption":"Invert Zoom","width":"250px"}]},{"type":"RowLayout","items":[{"type":"CheckBox","name":"InvertTiltControl","caption":"Invert Tilt","width":"250px"},{"type":"Label","caption":"","width":"250px"}]}]},{"type":"ExpansionPanel","caption":"HTML-Box (Stream & Control)","expanded":true,"items":[{"type":"RowLayout","items":[{"type":"CheckBox","name":"EnablePanTiltHTML","caption":"Enable Pan\/Tilt","width":"250px"},{"type":"CheckBox","name":"EnableZoomHTML","caption":"Enable Zoom","width":"250px"}]},{"type":"RowLayout","items":[{"type":"NumberSpinner","name":"PanTiltControlWidth","caption":"Width Pan\/Tilt-Control","digits":0,"width":"250px","minimum":0},{"type":"NumberSpinner","name":"ZoomControlWidth","caption":"Width Zoom-Control","digits":0,"width":"250px","minimum":0}]},{"type":"RowLayout","items":[{"type":"NumberSpinner","name":"PanTiltControlHeight","caption":"Height Pan\/Tilt-Control","digits":0,"width":"250px","minimum":0},{"type":"NumberSpinner","name":"ZoomControlHeight","caption":"Height Zoom-Control","digits":0,"width":"250px","minimum":0}]},{"type":"RowLayout","items":[{"type":"NumberSpinner","name":"PanTiltControlOpacity","caption":"Opacity Pan\/Tilt-Control","digits":0,"suffix":"%","width":"250px","minimum":0,"maximum":100},{"type":"NumberSpinner","name":"ZoomControlOpacity","caption":"Opacity Zoom-Control","digits":0,"suffix":"%","width":"250px","minimum":0,"maximum":100}]}]},{"type":"ExpansionPanel","caption":"Control Variables","expanded":true,"items":[{"type":"RowLayout","items":[{"type":"CheckBox","name":"EnablePanTiltVariable","caption":"Enable Pan\/Tilt","width":"250px"},{"type":"CheckBox","name":"EnableZoomVariable","caption":"Enable Zoom","width":"250px"}]},{"type":"RowLayout","items":[{"type":"CheckBox","name":"EnableSpeedVariable","caption":"Enable Speed","width":"250px"},{"type":"CheckBox","name":"EnableTimeVariable","caption":"Enable Time","width":"250px"}]}]},{"type":"ExpansionPanel","caption":"Default Speeds","expanded":false,"items":[{"type":"RowLayout","items":[{"type":"NumberSpinner","name":"PanDefaultSpeed","caption":"Pan speed","digits":2,"width":"250px","minimum":0.01,"maximum":1},{"type":"NumberSpinner","name":"ZoomDefaultSpeed","caption":"Zoom speed","digits":2,"width":"250px","minimum":0.01,"maximum":1}]},{"type":"RowLayout","items":[{"type":"NumberSpinner","name":"TiltDefaultSpeed","caption":"Tilt speed","digits":2,"width":"250px","minimum":0.01,"maximum":1}]}]}]}},{"type":"PopupButton","name":"ConfigurePrePositions","caption":"Configure pre-positions","width":"300px","enabled":false,"popup":{"caption":"Pre-positions","items":[{"type":"RowLayout","items":[{"type":"CheckBox","name":"EnablePresetVariable","caption":"Enable Preset Variable","width":"250px","onChange":"IPS_RequestAction($id,'RefreshEnablePresetProfileForm',$EnablePresetVariable);"},{"type":"CheckBox","name":"EnablePresetProfile","caption":"Variableprofile uses pre-position name","width":"250px"}]},{"type":"List","caption":"Select pre-positions","name":"PresetProfile","add":false,"delete":true,"sort":{"column":"VariableValue","direction":"ascending"},"columns":[{"caption":"Value","name":"VariableValue","width":"70px","add":0,"edit":{"type":"NumberSpinner","minimum":0,"maximum":255}},{"caption":"Active","name":"PresetActive","width":"70px","add":true,"edit":{"type":"CheckBox"}},{"caption":"Pre-position name","name":"PresetName","width":"auto","add:":"","edit":{"type":"ValidationTextBox"}},{"caption":"Pre-position token","name":"PresetToken","width":"125px","save":true}],"values":[],"visible":false}]}}],"actions":[{"type":"ExpansionPanel","caption":"Stream properties","items":[{"type":"RowLayout","items":[{"type":"Label","width":"200px","caption":"Videosource-Name:"},{"type":"Label","caption":"VideoSourceConfig1"}]},{"type":"RowLayout","items":[{"type":"Label","width":"200px","caption":"Videoencoder-Profilename:"},{"type":"Label","width":"200px","caption":"VideoEncoderConfig0"},{"type":"PopupButton","width":"300px","caption":"Show Stream","popup":{"caption":"Image","items":[{"type":"Image","center":true,"mediaID":13452}]}}]},{"type":"RowLayout","items":[{"type":"Label","width":"200px","caption":"Encoding:"},{"type":"Label","caption":"H264"}]},{"type":"RowLayout","items":[{"type":"Label","width":"200px","caption":"Resolution:"},{"type":"Label","caption":"1280 x 960"}]},{"type":"RowLayout","items":[{"type":"Label","width":"200px","caption":"Framerate:"},{"type":"Label","caption":30}]},{"type":"RowLayout","items":[{"type":"Label","width":"200px","caption":"Encoding-Interval:"},{"type":"Label","caption":1}]},{"type":"RowLayout","items":[{"type":"Label","width":"200px","caption":"Bitratelimit:"},{"type":"Label","caption":1200}]}]},{"type":"ExpansionPanel","caption":"PTZ properties","items":[{"type":"RowLayout","items":[{"type":"Label","width":"200px","caption":"Token:"},{"type":"Label","width":"200px","caption":"PTZConfigToken"}]},{"type":"RowLayout","items":[{"type":"Label","width":"200px","caption":"Pre-positions:"},{"type":"Label","width":"200px","caption":0},{"type":"PopupButton","caption":"No pre-positions","width":"300px","popup":[],"enabled":false}]},{"type":"RowLayout","items":[{"type":"Label","width":"200px","caption":"max. pre-positions:"},{"type":"Label","width":"200px","caption":0}]},{"type":"RowLayout","items":[{"type":"Label","width":"200px","caption":"Has Home Position:"},{"type":"Label","width":"200px","caption":"No"}]}]},{"type":"ExpansionPanel","caption":"Testcenter","items":[{"type":"TestCenter"}]},{"type":"Label","caption":"This module is free for non-commercial use,\r\nDonations in support of the author are accepted here:"},{"type":"RowLayout","items":[{"type":"Image","onClick":"echo 'https:\/\/www.paypal.com\/donate?hosted_button_id=G2SLW2MEMQZH2';","image":"data:image\/png;base64,iVBORw0KGgoAAAANSUhEUgAAAIAAAACACAYAAADDPmHLAAAABGdBTUEAALGPC\/xhBQAAAAFzUkdCAK7OHOkAAAAgY0hSTQAAeiYAAICEAAD6AAAAgOgAAHUwAADqYAAAOpgAABdwnLpRPAAAAAZiS0dEAP8A\/wD\/oL2nkwAAAAlwSFlzAAALiQAAC4kBN8nLrQAADDpJREFUeNrtmnmMXXUVxz\/n994sXaalrdCq2CIw1A2mLmhcwlbcorYVxKgxxC3uG0btYKKJGOkgLsEF1ESjJIq7HcQaUSKoCAW0fYVq6bQVSm1tS5l2pp03b957v+Mf577Offe9genMCzR4Psmk6bv3\/u5vOb9zvuf8LjiO4ziO4ziO4ziO4ziO4ziO4ziO4ziO4ziO4ziO4ziO4ziO4ziO4ziO4ziO4ziO4ziO4ziO4ziO4ziO4ziO4ziO4ziO4ziO4ziO8\/ghrWoo9G1ECQj6bOD1CrMAzbysAhwG9gM7gV3AHjSUkCqxd9kTPR91dPcPAcwBLgROanKLAmVgEPhv8rc3BkZEYduKOS3px3O\/MMDYWQsBTgDOANqSS\/tBtwFxYOXcKbWdb910CYLOB64Dzn0Uy4pAFSgBB4B7kPg1CHeEvkKMvT2t69I06O4fQkEEeoFPYJOuE9xeG88gsCVEvg2s6+4fKg2snL4RJIvfDlwFvBUI2Oa9D2QFsHeqbYcWz9vJwHMn8c42YDawBLgY+CnoKpUcoW9ji7s0dQS6gHOBjqTfuQn+2rF7FwOvAn4I9CJ0JF6kFTwVeGXynlnATOsiY9NptNUGcDbmprKUgJHk32a76OnAFaLVxS2MSq3gROAZTX6P2MSXJxhPF3AZyssATr+pJUZwStKfNH9TiYcmdkyPTUtCQOgrgGpA5Jwmba4Hvoi5xxnAmcCHgFMz93UDPZg2IKzZhKCiQjvQie2yHONxtwiMAhp7e8xziCKENtQMWyGiUgaIl59VP\/ArC+TGoNxJPmkXQFCqorGc6tOCTD8PJuO5F\/NkS4B3AC+k3nrnAm9E9TapSjzjxoOAouTaUDowr1Kbq0oyltGoY9UgnQysnA3A0l8fIto952Fes0YVuFM0xKrEJ9YAbOqkCxMoacrAV4DfgIAooSJ\/iDn9F3BDMkk12oFFAKGv0Am6UuHVmHeYhxlPHtt9tXh7P3BD6CusB8ZQWaRwZfKMAiOIfitWcreEqwrE1aYvQl+BSCR2hucDl2HuVYEcwr0q4TPDg8MjXfO6lmOuNs1NIN8ALYlCNUBQ\/gCsBZ6duXcZIjNARlTD2cCbMKM6MVnMmpgbA4aBnUHab4R48xk3Dh6MsY1oi9sGvCDT9jCwHWDHihOOAwOwQZ2c+e0gsAUg9iY7sK8AcB\/wSMYA0rwT+HKTyc9yAfAW4FqFK8R26+uoV+yLQr66AeWR+kfDYuA7WNhKc3t85FBxznNO7VTVszLXIvBH0JJKYGDlbLr7DwE8ALKdRgPIoSiipwLXA0snMY8XA7eo5j4oEncmv83FQkCafcDuqSxU3SxMt4EUS2l0l7uBPU3uXUC9OwPzFvsRAraI6cWvYLuk2qStecCHBV4MPIwZXZol6X6FvgJiLv8jwIsy9\/4L+MH80xerqs5Pnk1zGNgKsG1F0n0VUOmgufbZobkwirnv01K\/V5PxNhtPZzL+dwekFlIWJX9ptkLWqI+daXuAcNVGqOYgVJdjbjrNXZirhi8XCBXAFv7DNAqa\/cAWlDmYxe8A\/g78BasXlDBxtRzb9V2pZ+cmE3w3tjPSoWgO5hEG8l\/ZTCxXUHg+8DbqY3YJuDooO+afOA\/Mmy3M9HEf8FDtP939QzzQ8winFOZfCDwvc28F+H2IMSbv24\/phj8D2zAN05k893bgmZnnz4\/o1ZjR9WCGnuZPCEWmHv6BVoQAFQjVmrjLcihZAEKFGcDp2OKvaHLvDcnEALwfGFLYp51akjFBP91jYhN+ie3gd6WejUAF0RIquzLtzgCeBhDLFTDPsrr2W4pbgbVRQIIAvILGEFVM3j2zu3+oA5h\/SmH+RcDHaPQAm4HbEn3+NeAa4D9oKILqwKouKzSp\/gyRO4GfUG\/UJaA6K7RxJJbPZVwvgAnG+1AYWDW9OkOrNEAzdwnwXmzHajK4kzCDyOZ6tyUTVIm9PeSvLGyudCqhJHkZlTlAl\/QV5ibPPoXG3TIK7EYFTF+kyQFnBIVob30NJi7TDGJFlsEl3YtRIS\/KS5v0cynwKyylnZGMZ1FmccB2+2c1yEOhqmxdNWd7d\/8QEhCNcQYwu7t\/yDydyGzgpU3auFuU4pFYnkWjdhgkyZamS6sMYDHNS6VzMPc3EWVgHfBJEtca+jbmIjwjjMkrES5kPIZ3JZPegWUMaQ6kJuQubIHSGuLsqtAu1p9PUr\/TAK5HuB2FfD5HEoZOo5F2GtV4ln8Dq0HXSTQH2d0\/NB84WyMrMaF4IuYxZibj6WA8Fa3Ny91mzyygUVzvZhrVvzTTMgC5akOtBnEOEyv6LJaeWXbwLWAtyKB5cTkJ5BPAJVgBpm2SbT6IxWcwvTBMvQGckiz+O2lU\/duA61DGYm8PWOVuEY0h4tGoJO+\/MRnTP0EiZjCXAB\/FKqSzJtneIZIUD9tcWb20HuVQK2pm0zMADWCL9JIml4uYpZaTCRoBHgD+BmwAtqC6H1AbiCwEvosp4PRuGMQW6Z+Yq1+GLWI6g\/lTyMXhWA1g3uBh6gXcAuDlwHsyYy4DX43t5fvDWJ2tLaNRdMWk3SKm3kexjGMTJuw2ADtUdUxMvOexc4RPUZ\/xHMa83QAmCoexs4a0B93DePZ0DvUeKwK3I0SpTL0CWKMVIWAujVW9MvA54MdJ6K0CYwrFQBxDhOrqZQBIXwFFJKAfB15P\/cL+FfhMMlGHkVBF46ewlK\/GGHB3svgkE7qX+jOJhcA3aNzVdwC\/CGNtxN4eutceQmNVJOTOpzHM\/B5b0EHGq5EjwIiWpCqzlIHXmSBL6v8vw1LN9OJvAi7HspuDCiWx+P6xzLvuSd6TpzFVPVoA2nrx1E4A07TCABZhlbQ0+4B+YLf29tRVqrOJrwCCLgBeS\/3iHwA+DdyhVkSEGNsQXky9ODuIxV0QUBgVJZsJtNFY0x8C1mC1h6OdEQnNRFcF+D6wSVTZumriie9eO4SoBhW5FBOs6Ta+hLJOg5BTrWVwPZiIrhExUVzBPFdW8O4H\/tOCdQNaUwh6AY3u8kGOTaTMozHOjWBGYItvZdrzMcWcZjd2Dk+Mo4iiwEYe+4Tkp9hEHy0RJ+b4FCzupjmIuexHXXww0RdFOmgUkXYKKiCqVCQPtrjvw0RgjcNYiRvMc2U31zZaUACqMWUPENYUEEVUOI9GsXZrnPHgkBSXTKHlozwN+Cbws+T\/59P8w4y7VGRQVOHyl9RKzRswA5pIdO0Evg4U6RjNXjuN+p0LZmB7mDyK7eC6KcNCyDxgZ9DKC7F6SLZ8vA+OerAzaVoA0hG0NUXcqYcAc7ddNLrLMnBXKC7hGD7u2I+58XSMzmHn3xekfsuefUfgz6JazWz3PZiLb2YAVeAaQTYrSrzM9Gv3r4dNuKssb\/LcP5Q4KJOS3cJMLY0WpX09ZrBplgJXJ\/3OA0do9FRbgAMdMwKlYjyPei1SAu5FhYGVXbSC6ZrRTMbTv5gMZgem2CeF2pdEB7F4vKvJLQHbFVdgbjvNQ5hAROuNbZCJ3eQ9wA2Kap2BBiCGPI2CdgT4rRDKUR5bdW9b2UVR2sEOmm6jcYFzmCH\/HBOJg6lrJexUsVgqxjYaS9H3H8vcToYpe4BkVAfESru141QF7kfZPtkcVXvPQs1t\/w64CLgUS\/PakslZB9yssEVMyN2SXIvAFlU2S+O7jtDcAI4AawT2ZEvoilINoZJX\/RJwMzV9at7kVoDtkz12FSGWqw+FfLgUeDOW3czFUsj1wG+wghWYvjghedfDtXcFjeUo4fOYQeQwz7VRYWcrP5k5bj6\/Wfi93ezdt5dAyCPMwvZkKZk0nWw4Sc4LZmMG9YrM5R8jvBflyOPx7WFyVCwgs4AOhDGNjJALVdm1i4EPPOvxmt4JOW4MoCX0bSKYb1qOicd0erUbeAPwD5WArj5zCi948tHqbwKf4MEomKtdTWNufS3oRsAXP8WTxgDCmkLt84lLaHT9m4DrQY6bz86PF540BoCAKidjojT9YUoR6CP1IYczzpPDAK78O8kBzNuwL2yU8Y9Hf4RlEsdSl\/i\/oZUfhT5xhFrGpjdjYq+Wez8M3IkyTNv0T84cx3Ecx3Ecx3Ecx3Ecx3Ecx3Ecx3Ecx3Ecx3Ecx3Ecx3Ecx3Ecx3Ecx3Ecx3Ecx3Ecx3Ecx3Ecx3Ecx3Ecx3Ecx3Ecx3Ecx3Ecx3Gmx\/8AQ1faHO6uaXsAAAAldEVYdGRhdGU6Y3JlYXRlADIwMTgtMDUtMjVUMTI6NDA6MTArMDI6MDB4\/FYOAAAAJXRFWHRkYXRlOm1vZGlmeQAyMDE4LTA1LTI1VDEyOjQwOjEwKzAyOjAwCaHusgAAAEZ0RVh0c29mdHdhcmUASW1hZ2VNYWdpY2sgNi43LjgtOSAyMDE2LTA2LTE2IFExNiBodHRwOi8vd3d3LmltYWdlbWFnaWNrLm9yZ+a\/NLYAAAAYdEVYdFRodW1iOjpEb2N1bWVudDo6UGFnZXMAMaf\/uy8AAAAYdEVYdFRodW1iOjpJbWFnZTo6aGVpZ2h0ADUxMsDQUFEAAAAXdEVYdFRodW1iOjpJbWFnZTo6V2lkdGgANTEyHHwD3AAAABl0RVh0VGh1bWI6Ok1pbWV0eXBlAGltYWdlL3BuZz+yVk4AAAAXdEVYdFRodW1iOjpNVGltZQAxNTI3MjQ0ODEwnCKKMAAAABN0RVh0VGh1bWI6OlNpemUAMTIuOEtCQhoRQ10AAABCdEVYdFRodW1iOjpVUkkAZmlsZTovLy4vdXBsb2Fkcy81Ni9rSWZ4SUF5LzE0ODcvODM5My1wYXlwYWxfMTAyNDYxLnBuZ6xvuXsAAAAASUVORK5CYII="},{"type":"Image","onClick":"echo 'https:\/\/www.amazon.de\/hz\/wishlist\/ls\/YU4AI9AQT9F?ref_=wl_share';","image":"data:image\/png;base64,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"}]}],"status":[{"code":102,"icon":"active","caption":"Configuration is valid"},{"code":104,"icon":"inactive","caption":"Configuration is invalid"},{"code":201,"icon":"error","caption":"Stream could not be determined"}]} (Code: -32603)
