Hallo Fonzo,
ich wollte gerade einen IR-Code meiner Fernsehfernbedienung einlernen und erhalte seitdem eine Fehlermeldung meiner Instanz.
Ich kann diese auch nicht mehr öffnen, ein senden von IR-Codes ist per Skript aber möglich.
Hast du eine Idee?
<br />
<b>Warning</b>: Illegal string offset 'key' in <b>/var/lib/symcon/modules/.store/fonzo.ipsymconaiogateway/AIO IR Device/module.php</b> on line <b>1640</b><br />
<br />
<b>Warning</b>: Illegal string offset 'code' in <b>/var/lib/symcon/modules/.store/fonzo.ipsymconaiogateway/AIO IR Device/module.php</b> on line <b>1640</b><br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
{"elements":[{"type":"Label","caption":"AIO IR device"},{"type":"List","name":"AIOIRCommands","caption":"available commands","rowCount":2,"add":true,"delete":true,"sort":{"column":"key","direction":"ascending"},"columns":[{"name":"key","caption":"key label","width":"250px","visible":true,"add":"key label","edit":{"type":"ValidationTextBox"},"save":true},{"name":"code","caption":"code","width":"auto","visible":true,"add":"0","edit":{"type":"ValidationTextBox"},"save":true}],"values":[{"key":1,"code":"1"},{"key":"huhu","code":"XXXX"}]}],"actions":[{"type":"ExpansionPanel","caption":"Learn key","items":[{"type":"Select","name":"learnkey","caption":"key","options":[{"caption":"Please Select","value":-1},{"caption":1,"value":1},{"caption":"huhu","value":2}]},{"type":"Button","caption":"Learn","onClick":"AIOIR_LearnCommandKey($id, $learnkey);"}]},{"type":"ExpansionPanel","caption":"Send key","items":[{"type":"Select","name":"sendkey","caption":"key","options":[{"caption":"Please Select","value":-1},{"caption":1,"value":1},{"caption":"huhu","value":2}]},{"type":"Button","caption":"Send","onClick":"AIOIR_SendCommandKey($id, $sendkey);"}]}],"status":[{"code":101,"icon":"inactive","caption":"Creating instance."},{"code":102,"icon":"active","caption":"AIO IR device created"},{"code":104,"icon":"inactive","caption":"AIO IR device is inactive"},{"code":201,"icon":"inactive","caption":"Please follow the instructions."},{"code":202,"icon":"error","caption":"special errorcode."},{"code":203,"icon":"error","caption":"No active AIO I\/O."}]} (Code: -32603)
