mit IPS 3.1 funktioniert das setzen der Timer anders.
Dadurch funktioniert der Timer aufruf vom IPSWecker nicht mehr.
Schaltuhr kommt noch.
Durch Austausch zweier Scripte UND neustellen ALLER Wecker sollte es erledigt sein.
ToDo:
- Einfach den Inhalt beider Scripte austauschen.
- Dann in jedem Wecker einfach die gewählte Uhrzeit nochmal anklicken. Dann werden die Timer neu gesetzt.
- Testen
- Fertig
Program\IPSLibrary\app\modules\IPSWecker\IPSWecker_Timer:
* This file is part of the IPSLibrary.
* The IPSLibrary is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published
* by the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* The IPSLibrary is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with the IPSLibrary. If not, see http://www.gnu.org/licenses/gpl.txt.
/**@addtogroup IPSWecker
* @file IPSWecker_Timer.ips.php
* @author André Czwalina
* @version
* Version 1.00.5, 22.04.2012<br/>
include_once "IPSWecker.inc.php";
switch ($_IPS['SENDER']) {
case 'TimerEvent':
$eventId = $_IPS['EVENT'];
if (IPS_GetName($eventId) =='Timer_Event') {
IPSWeckerChangeAktivCircle();
break;
$CircleName = substr(IPS_GetName($eventId),0, strlen(IPS_GetName($eventId))-2);
$CircleId = get_CirclyIdByCircleIdent($CircleName, WECKER_ID_WECKZEITEN);
$eventtimearr = array();
$eventtimearr=IPS_GetEvent($eventId)['CyclicTimeFrom'];
$eventTime = mktime($eventtimearr['Hour'], $eventtimearr['Minute'], 0);
// $eventTime = IPS_GetEvent($eventId)['CyclicTimeFrom'];
$wecker = AddConfiguration($CircleId);
IPSLogger_Dbg(__file__, 'Event: Auslösung prüfen für '.$wecker['Property']['Name'].' ('.$wecker['Circle']['Name'].')');
if (function_exists($CircleName)) {
IPSLogger_Dbg(__file__, 'Weckerfunktion '.$wecker['Circle']['Name'].' Existiert in IPSWecker_Custom.');
$CircleTime = mktime(substr($wecker['ActiveTime'],0,2), substr($wecker['ActiveTime'],3,2), 0);
$CircleNameMode= '';
// --------------- Weckbedingungen -------------------
if ($wecker['RetUrlaub'] == false and $wecker['RetFeiertag'] == false and $wecker['Active'] == true and $wecker['Circle'][c_Control_Global] == true){
IPSLogger_Dbg(__file__, 'Weckbedingungen für Active, Global, Urlaub, Feiertag gültig.'.$wecker['Property'][c_Property_Name]);
// --------------- FrostTime -------------------
if (get_TimeToleranz($eventTime+($wecker['Property'][c_Property_FrostTime]*60), $CircleTime)){
IPSLogger_Dbg(__file__, 'FrostTime auslösung '.$wecker['Property'][c_Property_Name]);
if ( getAviableSensor($wecker['Property'][c_Property_FrostSensor]) == 2 ) {
if ( getvalue($wecker['Property'][c_Property_FrostSensor]) < $wecker['Property'][c_Property_FrostTemp]) {
IPSLogger_Dbg(__file__, 'Temperatur < FrostTemp = Frostwecken'.$wecker['Property'][c_Property_Name]);
// --------------- Neue Eventzeit setzen -------------------
if ($wecker['Circle'][c_Control_Schlummer] == true){
$Hour = date("H", $CircleTime-($wecker['Property'][c_Property_FrostTime]*60)+($wecker['Property'][c_Property_SnoozeTime]*60));
$Minute = date("i", $CircleTime-($wecker['Property'][c_Property_FrostTime]*60)+($wecker['Property'][c_Property_SnoozeTime]*60));
IPS_SetEventCyclicTimeFrom($eventId, intval($Hour), intval($Minute), 0);
// IPS_SetEventCyclicTimeBounds($eventId, $CircleTime-($wecker['Property'][c_Property_FrostTime]*60)+($wecker['Property'][c_Property_SnoozeTime]*60), 0);
elseif($wecker['Circle'][c_Control_End] == true){
$Hour = date("H", $CircleTime-($wecker['Property'][c_Property_FrostTime]*60)+($wecker['Property'][c_Property_EndTime]*60));
$Minute = date("i", $CircleTime-($wecker['Property'][c_Property_FrostTime]*60)+($wecker['Property'][c_Property_EndTime]*60));
// IPS_SetEventCyclicTimeBounds($eventId, $CircleTime-($wecker['Property'][c_Property_FrostTime]*60)+($wecker['Property'][c_Property_EndTime]*60), 0);
IPSLogger_Dbg(__file__, 'Neue EventTime: '.Date('H:i',IPS_GetEvent($eventId)['CyclicTimeFrom']).' für '.IPS_GetName($eventId));
// --------------- Aktion -------------------
$eventMode = "FrostTime";
IPSLogger_Inf(__file__, 'Wecker ausgelöst: '.$wecker['Property'][c_Property_Name].', Aktion: '.$eventMode);
IPSWecker_Log('Wecker ausgelöst: '.$wecker['Property'][c_Property_Name].', Aktion: '.$eventMode);
$CircleName($CircleId, $wecker['Property'][c_Property_Name], $eventMode);
} else {
IPSLogger_Dbg(__file__, 'Wecker auf Normalzeit, da kein Frost '.$wecker['Property'][c_Property_Name]);
$Hour = date("H", $CircleTime);
$Minute = date("i", $CircleTime);
// IPS_SetEventCyclicTimeBounds($eventId, $CircleTime, 0);
} else {
IPSLogger_Err(__file__, 'Frostsensor '.$wecker['Property'][c_Property_FrostSensor].' nicht vorhanden '.$wecker['Property'][c_Property_Name]);
IPSWecker_Log('FEHLER: Frostsensor '.$wecker['Property'][c_Property_FrostSensor].' nicht vorhanden '.$wecker['Property'][c_Property_Name]);
// --------------- AlarmTime -------------------
if (get_TimeToleranz($eventTime, $CircleTime)){
IPSLogger_Dbg(__file__, 'AlarmTime auslösung '.$wecker['Property'][c_Property_Name]);
$Hour = date("H", $CircleTime+($wecker['Property'][c_Property_SnoozeTime]*60));
$Minute = date("i", $CircleTime+($wecker['Property'][c_Property_SnoozeTime]*60));
// IPS_SetEventCyclicTimeBounds($eventId, $CircleTime+($wecker['Property'][c_Property_SnoozeTime]*60), 0);
$Hour = date("H", $CircleTime+($wecker['Property'][c_Property_EndTime]*60));
$Minute = date("i", $CircleTime+($wecker['Property'][c_Property_EndTime]*60));
// IPS_SetEventCyclicTimeBounds($eventId, $CircleTime+($wecker['Property'][c_Property_EndTime]*60), 0);
elseif($wecker['Circle'][c_Control_Frost] == true){
$Hour = date("H", $CircleTime-($wecker['Property'][c_Property_FrostTime]*60));
$Minute = date("i", $CircleTime-($wecker['Property'][c_Property_FrostTime]*60));
// IPS_SetEventCyclicTimeBounds($eventId, $CircleTime-($wecker['Property'][c_Property_FrostTime]*60), 0);
if ($wecker['Active'] == true){
$eventMode = "AlarmTime";
// --------------- SnoozeTime -------------------
if ((get_TimeToleranz($eventTime, $CircleTime+($wecker['Property'][c_Property_SnoozeTime]*60)))
or ( get_TimeToleranz($eventTime, $CircleTime-($wecker['Property'][c_Property_FrostTime]*60)+($wecker['Property'][c_Property_SnoozeTime]*60)))){
IPSLogger_Dbg(__file__, 'SnoozeTime auslösung '.$wecker['Property'][c_Property_Name]);
if ($wecker['Circle'][c_Control_End] == true){
elseif ($wecker['Circle'][c_Control_Frost] == true) {
else {
$eventMode = "SnoozeTime";
// --------------- EndTime -------------------
if ((get_TimeToleranz($eventTime, $CircleTime+($wecker['Property'][c_Property_EndTime]*60)))
or ( get_TimeToleranz($eventTime, $CircleTime-($wecker['Property'][c_Property_FrostTime]*60)+($wecker['Property'][c_Property_EndTime]*60)))){
IPSLogger_Dbg(__file__, 'EndTime auslösung '.$wecker['Property'][c_Property_Name]);
if ($wecker['Circle'][c_Control_Frost] == true){
else {
$eventMode = "EndTime";
} else {
IPSLogger_Err(__file__, "WeckerAktion $CircleName in IPSWecker_Custom existiert nicht. ".$wecker['Property'][c_Property_Name]);
break;
case 'WebFront':
break;
case 'Execute':
break;
case 'RunScript':
break;
default:
IPSLogger_Err(__file__, 'Unknown Sender '.$_IPS['SENDER']);
break;
Program\IPSLibrary\app\modules\IPSWecker\IPSWecker:
/**@defgroup IPSWecker IPSWecker
* @ingroup modules
* IPSWecker ist ein IPS Modul, das
* @file IPSWecker.inc.php
* @version
IPSUtils_Include ("IPSLogger.inc.php", "IPSLibrary::app::core::IPSLogger");
IPSUtils_Include ("IPSInstaller.inc.php", "IPSLibrary::install::IPSInstaller");
IPSUtils_Include ("IPSComponent.class.php", "IPSLibrary::app::core::IPSComponent");
IPSUtils_Include ("IPSWecker_Constants.inc.php", "IPSLibrary::app::modules::IPSWecker");
IPSUtils_Include ("IPSWecker_Configuration.inc.php", "IPSLibrary::config::modules::IPSWecker");
IPSUtils_Include ("IPSWecker_Custom.inc.php", "IPSLibrary::config::modules::IPSWecker");
IPSUtils_Include ("IPSWecker_Logging.inc.php", "IPSLibrary::app::modules::IPSWecker");
IPSUtils_Include ("IPSWecker_IDs.inc.php", "IPSLibrary::app::modules::IPSWecker");
//$wecker = AddConfiguration(21764 /*[Objekt #21764 existiert nicht]*/ );
//print_r($wecker);
function IPSWeckerChangeAktivCircle(){
IPS_LogMessage("DEBUG", "IPSWeckerChangeAktivCircle");
$WeckerConfig = get_WeckerConfiguration();
$Ass=0;
foreach ($WeckerConfig as $WeckerName=>$WeckerData) {
IPS_LogMessage("DEBUG", "Wecker: $WeckerName Nr.: $Ass");
$WeckerCf = get_CirclyIdByCircleIdent(c_WeckerCircle.($Ass+1), WECKER_ID_WECKZEITEN);
$ConfId = get_ControlId(c_Control_Optionen, $WeckerCf);
$objectIds = explode(',',GetValue($ConfId));
if ($WeckerData[c_Property_Schichtgruppe] <> '' and count($WeckerData[c_Property_Schichtzyklus]) > 0){
IPS_LogMessage("DEBUG", "Schichtgruppe: ".$WeckerData[c_Property_Schichtgruppe]);
if (in_array((int)date("W"), $WeckerData[c_Property_Schichtzyklus])){
$objectIds[10] = "1";
} else {
$objectIds[10] = "0";
IPS_LogMessage("DEBUG", "Schichtzyklus: ".$objectIds[10]);
SetValue($ConfId, implode(",", $objectIds));
set_Overview($parentId, $WeckerCf);
set_TimerEvents($parentId, $WeckerCf);
if ($objectIds[10]) {
IPS_SetVariableProfileAssociation('IPSWecker_Name', $Ass, $WeckerData[c_Property_Name],"", 0x00FF00);
} else {
IPS_SetVariableProfileAssociation('IPSWecker_Name', $Ass, $WeckerData[c_Property_Name],"", 0xFF0000);
$parentId = IPSUtil_ObjectIDByPath('Program.IPSLibrary.data.modules.IPSWecker');
if (get_ControlValue(c_Control_Name, $parentId) == $Ass){
IPS_LogMessage("DEBUG", "ControlValue: ".get_ControlValue(c_Control_Name, $parentId));
$wecker = AddConfiguration($WeckerCf);
set_Control($wecker);
$Ass++;
function AddConfiguration($CircleId, $object=array()){
$object['Circle'] = AddActiveConfiguration($CircleId);
$object['Property'] = AddPropertyConfiguration($CircleId);
$object['Control'] = AddActiveControl();
$object['ActiveTime'] = $object['Circle']['Time_'.get_DateTranslation(Date('l'))];
$object['Global'] = $object['Circle'][c_Control_Global];
$object['Active'] = $object['Circle']['Active_'.get_DateTranslation(Date('l'))];
$object['CircleTime'] = mktime(substr($object['ActiveTime'],0,2), substr($object['ActiveTime'],3,2), 0);
$object['RetFeiertag'] = get_Feiertag($object['Circle'][c_Control_Feiertag]);
$object['RetUrlaub'] = get_Urlaub($object['Circle'][c_Control_Urlaub], $object['Circle'][c_Control_Urlaubszeit]);
return $object;
function AddActiveControl(){
$object = array();
$object['ControlId'] = $parentId;
$object[c_Control_Name] = get_ControlValue(c_Control_Name, $parentId);
$object[c_Control_LTag] = GetValueFormatted(get_ControlId(c_Control_LTag, $parentId));
$object[c_Control_LStunde] = GetValueFormatted(get_ControlId(c_Control_LStunde, $parentId));
$object[c_Control_LMinute] = GetValueFormatted(get_ControlId(c_Control_LMinute, $parentId));
$object[c_Control_Global] = get_ControlValue(c_Control_Global, $parentId);
$object[c_Control_Active] = get_ControlValue(c_Control_Active, $parentId);
$object[c_Control_Feiertag] = get_ControlValue(c_Control_Feiertag, $parentId);
$object[c_Control_Frost] = get_ControlValue(c_Control_Frost, $parentId);
$object[c_Control_Urlaub] = get_ControlValue(c_Control_Urlaub, $parentId);
$object[c_Control_Schlummer] = get_ControlValue(c_Control_Schlummer, $parentId);
$object[c_Control_End] = get_ControlValue(c_Control_End, $parentId);
// $object[c_Control_Uebersicht] = get_ControlValue(c_Control_Uebersicht, $parentId);
$object[c_Control_Urlaubszeit] = get_ControlValue(c_Control_Urlaubszeit, $parentId);
return $object;
function AddActiveConfiguration($CircleId){
$Conf = get_ControlValue(c_Control_Optionen, $CircleId);
$object = array();
for ($i = 0; $i < 12; $i++){
$objectIds[$i] = '0';
$objectIds = explode(',', $Conf);
$object['CircleId'] = $CircleId;
$object[c_Control_Name] = get_ControlType($CircleId);
$object['Time_'.c_Control_Mo] = get_ControlValue(c_Control_Mo, $CircleId);
$object['Time_'.c_Control_Di] = get_ControlValue(c_Control_Di, $CircleId);
$object['Time_'.c_Control_Mi] = get_ControlValue(c_Control_Mi, $CircleId);
$object['Time_'.c_Control_Do] = get_ControlValue(c_Control_Do, $CircleId);
$object['Time_'.c_Control_Fr] = get_ControlValue(c_Control_Fr, $CircleId);
$object['Time_'.c_Control_Sa] = get_ControlValue(c_Control_Sa, $CircleId);
$object['Time_'.c_Control_So] = get_ControlValue(c_Control_So, $CircleId);
// for ($i = 0; $i < 12; $i++){
// if ( $objectIds[$i] == '') $objectIds[$i] = '0';
$object['Active_'.c_Control_Mo] = $objectIds[0];
$object['Active_'.c_Control_Di] = $objectIds[1];
$object['Active_'.c_Control_Mi] = $objectIds[2];
$object['Active_'.c_Control_Do] = $objectIds[3];
$object['Active_'.c_Control_Fr] = $objectIds[4];
$object['Active_'.c_Control_Sa] = $objectIds[5];
$object['Active_'.c_Control_So] = $objectIds[6];
$object[c_Control_Feiertag] = $objectIds[7];
$object[c_Control_Urlaub] = $objectIds[8];
$object[c_Control_Frost] = $objectIds[9];
$object[c_Control_Global] = $objectIds[10];
$object[c_Control_Schlummer] = $objectIds[11];
$object[c_Control_End] = $objectIds[12];
$object[c_Control_Urlaubszeit] = get_ControlValue(c_Control_Urlaubszeit, $CircleId);
$object['Uebersicht'] = get_ControlValue(c_Control_Uebersicht, $CircleId);
return $object;
function AddPropertyConfiguration($CircleId){
$CircleName = get_ControlType($CircleId);
$object = array();
$object[c_Property_Name] = $WeckerConfig[$CircleName][c_Property_Name];
$object[c_Property_StopSensor] = $WeckerConfig[$CircleName][c_Property_StopSensor];
$object[c_Property_FrostTemp] = $WeckerConfig[$CircleName][c_Property_FrostTemp];
$object[c_Property_FrostSensor] = $WeckerConfig[$CircleName][c_Property_FrostSensor];
$object[c_Property_FrostTime] = $WeckerConfig[$CircleName][c_Property_FrostTime];
$object[c_Property_SnoozeTime] = $WeckerConfig[$CircleName][c_Property_SnoozeTime];
$object[c_Property_EndTime] = $WeckerConfig[$CircleName][c_Property_EndTime];
$object[c_Property_Schichtgruppe] = $WeckerConfig[$CircleName][c_Property_Schichtgruppe];
return $object;
function set_TimerEvents($parentId, $CircleId){
$ConfId = get_ControlId(c_Control_Optionen, $CircleId);
$WeckerName = IPS_GetName($CircleId);
$CircleIdent = IPS_GetName($CircleId);
$ParamsFrostTime = $WeckerConfig[$CircleIdent][c_Property_FrostTime];
$wecker_feiertag = $objectIds[7];
$wecker_urlaub = $objectIds[8];
$wecker_frost = $objectIds[9];
$wecker_aktiv_all = $objectIds[10];
$wecker_snooze = $objectIds[11];
$wecker_end = $objectIds[12];
$wecker_urlaubszeit = get_ControlValue(c_Control_Urlaubszeit, $CircleId);
$VorTag = "--:--";
$FrostTime = 0;
deaktivate_AllTimerEvents($WeckerName);
for ($tag = 0; $tag < 7; $tag++){
if ($tag == 0) $wecker_tag = c_Control_Mo;
if ($tag == 1) $wecker_tag = c_Control_Di;
if ($tag == 2) $wecker_tag = c_Control_Mi;
if ($tag == 3) $wecker_tag = c_Control_Do;
if ($tag == 4) $wecker_tag = c_Control_Fr;
if ($tag == 5) $wecker_tag = c_Control_Sa;
if ($tag == 6) $wecker_tag = c_Control_So;
$wecker_aktiv = $objectIds[$tag];
$wecker_zeit = get_ControlValue($wecker_tag, $CircleId);
if ((($wecker_aktiv) or ($wecker_urlaub) or ($wecker_feiertag)) and ($wecker_aktiv_all)){
if (($wecker_frost) and ($WeckerConfig[$CircleIdent][c_Property_FrostSensor] !=='')) $FrostTime = $ParamsFrostTime;
set_NextTimerEvent($WeckerName, $wecker_zeit, $FrostTime);
function set_NextTimerEvent($WeckerName, $wecker_zeit, $FrostTime){ //Aufruf von IPSWecker_Timer
$Toleranz =2; //Toleranzzeit in Sekunden. Timerevent auslesen hat zum Teil schwankun von 1 Sekunden. Rundungsfehler?
$Hour = substr($wecker_zeit,0,2);
$Minute =substr($wecker_zeit,3,2);
$zeit = mktime($Hour, $Minute, 0)-($FrostTime*60);
for ($i = 0; $i < 7; $i++){
$TimerId = IPS_GetEventIDByName($WeckerName."_".$i, WECKER_ID_TIMER);
$eventtimearr=IPS_GetEvent($TimerId)['CyclicTimeFrom'];
$eventtime = mktime($eventtimearr['Hour'], $eventtimearr['Minute'], 0);
$eventaktiv=IPS_GetEvent($TimerId)['EventActive'];
if ((($zeit-$Toleranz) < $eventtime) and (($zeit+$Toleranz) > $eventtime) and ($eventaktiv == true )){
break;
elseif ($eventaktiv == false ){
if (!IPS_SetEventCyclicTimeFrom($TimerId, intval($Hour), intval($Minute), 0)) {
Error ("IPS_SetEventCyclicTimeBounds $TimerId $zeit failed !!!");
if (!IPS_SetEventCyclicDateFrom($TimerId, 0, 0, 0)) {
Error ("IPS_SetEventCyclicTimeBounds $TimerId Date failed !!!");
/* if (!IPS_SetEventCyclicTimeBounds($TimerId, $zeit, 0)) {
*/ if (!IPS_SetEventActive($TimerId, true)){
Error ("IPS_SetEventActive $TimerId true failed !!!");
break;
function deaktivate_AllTimerEvents($WeckerName){
if (!IPS_SetEventActive($TimerId, false)){
Error ("IPS_SetEventActive $TimerId false failed !!!");
function set_ConfigGlobal($parentId, $CircleId){
$GlobalValue = get_ControlValue(c_Control_Global, $parentId);
$FeiertagValue = get_ControlValue(c_Control_Feiertag, $parentId);
$FrostValue = get_ControlValue(c_Control_Frost, $parentId);
$UrlaubValue = get_ControlValue(c_Control_Urlaub, $parentId);
$SchlummerValue = get_ControlValue(c_Control_Schlummer, $parentId);
$EndValue = get_ControlValue(c_Control_End, $parentId);
$objectIds[7] = ((bool)$FeiertagValue? "1": "0");
$objectIds[8] = ((bool)$UrlaubValue? "1": "0");
$objectIds[9] = ((bool)$FrostValue? "1": "0");
$objectIds[10] = ((bool)$GlobalValue? "1": "0");
$objectIds[11] = ((bool)$SchlummerValue? "1": "0");
$objectIds[12] = ((bool)$EndValue? "1": "0");
set_Overview($parentId, $CircleId);
function set_ConfigActive($parentId, $CircleId){
$ActiveValue = get_ControlValue(c_Control_Active, $parentId);
$DayId = get_ControlId(c_Control_LTag, $parentId);
switch (GetValueFormatted ($DayId)){
case c_Program_Montag:
$objectIds[0] = ((bool)$ActiveValue? "1": "0");
break;
case c_Program_Dienstag:
$objectIds[1] = ((bool)$ActiveValue? "1": "0");
break;
case c_Program_Mittwoch:
$objectIds[2] = ((bool)$ActiveValue? "1": "0");
break;
case c_Program_Donnerstag:
$objectIds[3] = ((bool)$ActiveValue? "1": "0");
break;
case c_Program_Freitag:
$objectIds[4] = ((bool)$ActiveValue? "1": "0");
break;
case c_Program_Samstag:
$objectIds[5] = ((bool)$ActiveValue? "1": "0");
break;
case c_Program_Sonntag:
$objectIds[6] = ((bool)$ActiveValue? "1": "0");
break;
case c_Program_Werktags:
break;
case c_Program_Wochenende:
break;
case c_Program_Woche:
break;
default:
Print "FEHLER (".GetValueFormatted ($ControlId).") ";
break;
function get_Config($parentId, $CircleId){
$ControlType = get_ControlType($CircleId);
// IPSWecker_Log('Config lesen für Wecker: '.$ControlType);
set_ControlValue(c_Control_Active, $parentId, $objectIds[0]);
break;
set_ControlValue(c_Control_Active, $parentId, $objectIds[1]);
break;
set_ControlValue(c_Control_Active, $parentId, $objectIds[2]);
break;
set_ControlValue(c_Control_Active, $parentId, $objectIds[3]);
break;
set_ControlValue(c_Control_Active, $parentId, $objectIds[4]);
break;
set_ControlValue(c_Control_Active, $parentId, $objectIds[5]);
break;
set_ControlValue(c_Control_Active, $parentId, $objectIds[6]);
break;
break;
break;
break;
default:
break;
set_ControlValue(c_Control_Feiertag, $parentId, $objectIds[7]);
set_ControlValue(c_Control_Urlaub, $parentId, $objectIds[8]);
set_ControlValue(c_Control_Frost, $parentId, $objectIds[9]);
set_ControlValue(c_Control_Global, $parentId, $objectIds[10]);
set_ControlValue(c_Control_Schlummer, $parentId, $objectIds[11]);
set_ControlValue(c_Control_End, $parentId, $objectIds[12]);
$UeberValue = get_ControlValue(c_Control_Uebersicht, $CircleId);
// set_ControlValue(c_Control_Uebersicht, $parentId, $UeberValue);
function IPSWecker_ChangeWecker($ControlId, $Value) {
SetValueInteger ($ControlId,$Value);
$parentId = get_CirclyIdByControlId($ControlId);
$NameValue = get_ControlValue(c_Control_Name,$parentId)+1;
$CircleId = get_CirclyIdByCircleIdent(c_WeckerCircle.$NameValue, WECKER_ID_WECKZEITEN);
$ControlType = get_ControlType($ControlId);
$ControlValue = GetValue($ControlId);
$tagId = get_ControlId(c_Control_LTag, $parentId);
$tagl = GetValueFormatted($tagId);
if (($tagl==c_Program_Werktags) or ($tagl==c_Program_Woche) or ($tagl==c_Program_Wochenende)){
SetValue($tagId, 0);
IPS_SetVariableProfileAssociation('IPSWecker_Tag', 0, c_Program_Montag,"", -1);
IPSWecker_ChangeSchicht($parentId, $CircleId, $Value);
function IPSWecker_ChangeSchicht($parentId, $CircleId, $Value) {
$NameId = get_ControlId(c_Control_Name,$parentId);
$NameValue = GetValueInteger($NameId)+1;
$CircleItem = IPS_GetName($CircleId);
$Propertyschicht = $WeckerConfig[$CircleItem][c_Property_Schichtgruppe];
$Ass=0;
if ($Propertyschicht <> ''){
if ($Propertyschicht == $WeckerData[c_Property_Schichtgruppe]) {
if ($Value == $Ass) {
} else {
} else {
$Ass++;
function set_WeckerAssociation($parentId, $CircleId) {
$Ass=1;
$CircleId = get_CirclyIdByCircleIdent(c_WeckerCircle.$Ass, WECKER_ID_WECKZEITEN);
IPS_SetVariableProfileAssociation('IPSWecker_Name', $Ass-1, $WeckerData[c_Property_Name],"", 0x00FF00);
} else {
IPS_SetVariableProfileAssociation('IPSWecker_Name', $Ass-1, $WeckerData[c_Property_Name],"", 0xFF0000);
$Ass++;
/* function get_AlarmClock($parentId, $CircleId) {
$tagl = GetValueFormatted(get_ControlId(c_Control_LTag, $parentId));
if (($tagl !== c_Program_Werktags) and ($tagl !== c_Program_Woche) and ($tagl !== c_Program_Wochenende)){
$wecker_tag = GetValueFormatted(get_ControlId(c_Control_LTag, $parentId));
set_ControlValue(c_Control_Stunde, $parentId, $Hour);
set_ControlValue(c_Control_Minute, $parentId, $Minute);
function IPSWecker_ChangeDay($ControlId, $Value) {
$DayValue = GetValue($DayId);
switch($Value){
case -1:
$DayValue--;
if ($DayValue <0) $DayValue = 9;
break;
case 100:
$DayValue++;
if ($DayValue >9) $DayValue = 0;
break;
IPSWecker_ChangeLDay($DayId, $DayValue);
function IPSWecker_ChangeLDay($ControlId, $Value) {
IPS_SetVariableProfileAssociation('IPSWecker_Tag', 0, GetValueFormatted ($ControlId),"", -1);
function set_Control($Config) {
if (($Config['Control'][c_Control_LTag]<>c_Program_Werktags) and ($Config['Control'][c_Control_LTag]<>c_Program_Woche) and ($Config['Control'][c_Control_LTag]<>c_Program_Wochenende)){
$Time = $Config['Circle']['Time_'.$Config['Control'][c_Control_LTag]];
$Active = $Config['Circle']['Active_'.$Config['Control'][c_Control_LTag]];
SetValue(get_ControlId(c_Control_LStunde, $parentId),substr($Time,0,2) );
SetValue(get_ControlId(c_Control_LMinute, $parentId),(substr($Time,3,2)/5) );
SetValue(get_ControlId(c_Control_Active, $parentId), $Active);
SetValue(get_ControlId(c_Control_Global, $parentId), $Config['Circle'][c_Control_Global]);
SetValue(get_ControlId(c_Control_Feiertag, $parentId), $Config['Circle'][c_Control_Feiertag]);
SetValue(get_ControlId(c_Control_Frost, $parentId), $Config['Circle'][c_Control_Frost]);
SetValue(get_ControlId(c_Control_Urlaub, $parentId), $Config['Circle'][c_Control_Urlaub]);
SetValue(get_ControlId(c_Control_Schlummer, $parentId), $Config['Circle'][c_Control_Schlummer]);
SetValue(get_ControlId(c_Control_End, $parentId), $Config['Circle'][c_Control_End]);
SetValue(get_ControlId(c_Control_Urlaubszeit, $parentId), $Config['Circle'][c_Control_Urlaubszeit]);
SetValue(get_ControlId(c_Control_Uebersicht, $parentId), $Config['Circle'][c_Control_Uebersicht]);
function IPSWecker_ChangeStunde($ControlId, $Value) {
$StundeId = get_ControlId(c_Control_LStunde, $parentId);
$StundeValue = GetValue($StundeId);
switch($Value){
case -1:
$StundeValue--;
if ($StundeValue <0) $StundeValue = 23;
break;
case 100:
$StundeValue++;
if ($StundeValue >23) $StundeValue = 0;
break;
IPSWecker_ChangeLStunde($StundeId, $StundeValue);
function IPSWecker_ChangeLStunde($ControlId, $Value) {
IPS_SetVariableProfileAssociation('IPSWecker_Stunde', 0, GetValueFormatted ($ControlId),"", -1);
set_ConfigTime($wecker);
$UeberValue = set_Overview($parentId, $CircleId);
set_TimerEvents($parentId, $CircleId);
function IPSWecker_ChangeMinute($ControlId, $Value) {
$MinuteId = get_ControlId(c_Control_LMinute, $parentId);
$MinuteValue = GetValue($MinuteId);
switch($Value){
case -1:
$MinuteValue--;
if ($MinuteValue <0) $MinuteValue = 11;
break;
case 100:
$MinuteValue++;
if ($MinuteValue >11) $MinuteValue = 0;
break;
IPSWecker_ChangeLMinute($MinuteId, $MinuteValue);
function IPSWecker_ChangeLMinute($ControlId, $Value) {
IPS_LogMessage("IPS_WECKER","IPSWecker_ChangeLMinute");
IPS_SetVariableProfileAssociation('IPSWecker_Minute', 0, GetValueFormatted ($ControlId),"", -1);
IPS_LogMessage("IPS_WECKER","set_TimerEvents: $parentId, $CircleId ");
function set_ConfigTime($Config){
$CircleId = $Config['Circle']['CircleId'];
$Name = $Config['Circle']['Name'];
$tagl = $Config['Control']['LTag'];
if ($tagl==c_Program_Werktags){
SetValue(get_ControlId(c_Control_Mo,$CircleId),$Config['Control']['LStunde'].':'.$Config['Control']['LMinute']);
SetValue(get_ControlId(c_Control_Di,$CircleId),$Config['Control']['LStunde'].':'.$Config['Control']['LMinute']);
SetValue(get_ControlId(c_Control_Mi,$CircleId),$Config['Control']['LStunde'].':'.$Config['Control']['LMinute']);
SetValue(get_ControlId(c_Control_Do,$CircleId),$Config['Control']['LStunde'].':'.$Config['Control']['LMinute']);
SetValue(get_ControlId(c_Control_Fr,$CircleId),$Config['Control']['LStunde'].':'.$Config['Control']['LMinute']);
} elseif ($tagl==c_Program_Wochenende){
SetValue(get_ControlId(c_Control_Sa,$CircleId),$Config['Control']['LStunde'].':'.$Config['Control']['LMinute']);
SetValue(get_ControlId(c_Control_So,$CircleId),$Config['Control']['LStunde'].':'.$Config['Control']['LMinute']);
} elseif ($tagl==c_Program_Woche) {
} else {
SetValue(get_ControlId($tagl,$CircleId),$Config['Control']['LStunde'].':'.$Config['Control']['LMinute']);
// $null = IPSWecker_Log('Neue Weckzeit gespeichert');
return;
function set_Configuration($Config) {
$objectIds = array();
$objectIds[c_ProgramId_Montag] = ((bool)$Config['Circle']['Active_'.c_Control_Mo]? "1": "0");
$objectIds[c_ProgramId_Dienstag] = ((bool)$Config['Circle']['Active_'.c_Control_Di]? "1": "0");
$objectIds[c_ProgramId_Mittwoch] = ((bool)$Config['Circle']['Active_'.c_Control_Mi]? "1": "0");
$objectIds[c_ProgramId_Donnerstag] = ((bool)$Config['Circle']['Active_'.c_Control_Do]? "1": "0");
$objectIds[c_ProgramId_Freitag] = ((bool)$Config['Circle']['Active_'.c_Control_Fr]? "1": "0");
$objectIds[c_ProgramId_Samstag] = ((bool)$Config['Circle']['Active_'.c_Control_Sa]? "1": "0");
$objectIds[c_ProgramId_Sonntag] = ((bool)$Config['Circle']['Active_'.c_Control_So]? "1": "0");
$objectIds[c_ProgramId_Feiertag] = ((bool)$Config['Control'][c_Control_Feiertag]? "1": "0");
$objectIds[c_ProgramId_Urlaub] = ((bool)$Config['Control'][c_Control_Urlaub]? "1": "0");
$objectIds[c_ProgramId_Frost] = ((bool)$Config['Control'][c_Control_Frost]? "1": "0");
$objectIds[c_ProgramId_Global] = ((bool)$Config['Control'][c_Control_Global]? "1": "0");
$objectIds[c_ProgramId_Snooze] = ((bool)$Config['Control'][c_Control_Schlummer]? "1": "0");
$objectIds[c_ProgramId_End] = ((bool)$Config['Control'][c_Control_End]? "1": "0");
$objectIds[c_ProgramId_Montag] = ((bool)$Config['Control'][c_Control_Active]? "1": "0");
$objectIds[c_ProgramId_Dienstag] = ((bool)$Config['Control'][c_Control_Active]? "1": "0");
$objectIds[c_ProgramId_Mittwoch] = ((bool)$Config['Control'][c_Control_Active]? "1": "0");
$objectIds[c_ProgramId_Donnerstag] = ((bool)$Config['Control'][c_Control_Active]? "1": "0");
$objectIds[c_ProgramId_Freitag] = ((bool)$Config['Control'][c_Control_Active]? "1": "0");
$objectIds[c_ProgramId_Samstag] = ((bool)$Config['Control'][c_Control_Active]? "1": "0");
$objectIds[c_ProgramId_Sonntag] = ((bool)$Config['Control'][c_Control_Active]? "1": "0");
} elseif ($tagl==c_Control_Mo) {
} elseif ($tagl==c_Control_Di) {
} elseif ($tagl==c_Control_Mi) {
} elseif ($tagl==c_Control_Do) {
} elseif ($tagl==c_Control_Fr) {
} elseif ($tagl==c_Control_Sa) {
} elseif ($tagl==c_Control_So) {
SetValue(get_ControlId(c_Control_Optionen, $CircleId), implode(",", $objectIds));
function IPSWecker_ChangeActive($ControlId, $Value) {
SetValueBoolean ($ControlId,$Value);
set_ConfigActive($parentId, $CircleId);
function IPSWecker_ChangeBoolean($ControlId, $Value) {
set_ConfigGlobal($parentId, $CircleId);
function IPSWecker_ChangeGlobal($ControlId, $Value) {
set_WeckerAssociation($parentId, $CircleId);
// $wecker = AddConfiguration($CircleId);
// set_Configuration($wecker);
// set_Control($wecker);
function IPSWecker_ChangeInteger($ControlId, $Value) {
$CircleId = get_CirclyIdByControlId($ControlId);
function IPSWecker_ChangeUrlaubszeit($ControlId, $Value) {
SetValue ($ControlId,$Value);
set_ControlValue(c_Control_Urlaubszeit, $CircleId, $Value);
function get_ControlType($ControlId) {
$ControlName = IPS_GetName($ControlId);
return $ControlName;
function get_CirclyIdByCircleIdent($CircleIdent, $parentId=null) {
if ($parentId==null) {
$CirclyId = IPS_GetCategoryIDByName($CircleIdent, $parentId);
return $CirclyId;
function get_CirclyNameByID($CircleId) {
return $WeckerConfig[$CircleItem][c_Property_Name];
function get_CirclyIdByControlId($ControlId) {
$CirclyId = IPS_GetParent($ControlId);
if ($CirclyId === false) {
IPSLogger_Err(__file__, "CircleId could NOT be found for ControlId=$ControlId");
exit;
return $CirclyId;
function get_ControlId($ControlName, $CircleId) {
$VariableId = IPS_GetVariableIDByName($ControlName, $CircleId);
if ($VariableId === false) {
IPSLogger_Err(__file__, "Control '$ControlName' could NOT be found for CircleId=$CircleId");
exit;
return $VariableId;
function get_ControlValue($ControlName, $CircleId) {
exit;
$VariableValue = GetValue ($VariableId);
return $VariableValue;
function set_ControlValue($ControlName, $CircleId, $Value){
exit;
SetValue ($VariableId, $Value);
function getAviableSensor($sensor){
$ret = 0;
if ($sensor !== '') $ret = 1;
if (IPS_VariableExists($sensor)) $ret = 2;
//IPS_LogMessage('DEBUG',"AviableSensor ($sensor): ".$ret);
return $ret;
function set_Overview($parentId, $CircleId){
$html ="<style type='text/css'>
$html.=" table.stundenplan { width: 100%; border-collapse: true;}
$html.=" table.stundenplan td { border: 1px solid #444455; }
$html.="</style>
$html.="<table class='stundenplan'>
$html.=" <tr>";
$html.=" <td style='width: 50px;' align='center'>".c_WFC_Tag."</td>
$html.=" <td style='width: 90px;' align='center'>".c_WFC_Stunde."</td>
$html.=" <td style='width: 200px;' align='center'>".c_WFC_Active."</td>
$html.=" <td style='width: 100px; border: 0px;' align='center'> </td>
$html.=" <td style='width: 200px;' align='center'>".c_WFC_Feature."</td>
$html.=" <td style='border: 0px;' align='center'></td>
$wecker_name = get_CirclyNameByID($CircleId);
if($wecker_aktiv_all == 0) {
$wecker_global = c_Program_Off;
$farbe_global = " <td style='background: #880000;' colspan='1' align='center'>";
else {
$wecker_global = c_Program_On;
$farbe_global = " <td style='background: #008000;' colspan='1' align='center'>";
if($wecker_feiertag == 0) {
$wecker_feiertag = c_Program_NoWeck;
if($wecker_aktiv_all) $farbe_feiertag = " <td style='background: #880000;' colspan='1' align='center'>";
if(!$wecker_aktiv_all) $farbe_feiertag = " <td style='background: #400000;' colspan='1' align='center'>";
else {
$wecker_feiertag = c_Program_Weck;
if($wecker_aktiv_all) $farbe_feiertag = " <td style='background: #008000;' colspan='1' align='center'>";
if(!$wecker_aktiv_all) $farbe_feiertag = " <td style='background: #002000;' colspan='1' align='center'>";
if($wecker_urlaub == 0) {
$wecker_urlaub = c_Program_NoWeck;
if($wecker_aktiv_all) $farbe_urlaub = " <td style='background: #880000;' colspan='1' align='center'>";
if(!$wecker_aktiv_all) $farbe_urlaub = " <td style='background: #400000;' colspan='1' align='center'>";
else {
$wecker_urlaub = c_Program_Weck;
if($wecker_aktiv_all) $farbe_urlaub = " <td style='background: #008000;' colspan='1' align='center'>";
if(!$wecker_aktiv_all) $farbe_urlaub = " <td style='background: #002000;' colspan='1' align='center'>";
if($wecker_frost == 0) {
$wecker_frost = c_Program_NormWeck;
if($wecker_aktiv_all) $farbe_frost = " <td style='background: #880000;' colspan='1' align='center'>";
if(!$wecker_aktiv_all) $farbe_frost = " <td style='background: #400000;' colspan='1' align='center'>";
else {
$wecker_frost = c_Program_PrevWeck;
if($wecker_aktiv_all) $farbe_frost = " <td style='background: #008000;' colspan='1' align='center'>";
if(!$wecker_aktiv_all) $farbe_frost = " <td style='background: #002000;' colspan='1' align='center'>";
if($wecker_snooze == 0){
$wecker_snooze = c_Program_Off;
if($wecker_aktiv_all) $farbe_schlummer = " <td style='background: #880000;' colspan='1' align='center'>";
if(!$wecker_aktiv_all) $farbe_schlummer = " <td style='background: #400000;' colspan='1' align='center'>";
else {
$wecker_snooze = c_Program_On;
if($wecker_aktiv_all) $farbe_schlummer = " <td style='background: #008000;' colspan='1' align='center'>";
if(!$wecker_aktiv_all) $farbe_schlummer = " <td style='background: #002000;' colspan='1' align='center'>";
if($wecker_end == 0) {
$wecker_end = c_Program_Off;
if($wecker_aktiv_all) $farbe_end = " <td style='background: #880000;' colspan='1' align='center'>";
if(!$wecker_aktiv_all) $farbe_end = " <td style='background: #400000;' colspan='1' align='center'>";
else {
$wecker_end = c_Program_On;
if($wecker_aktiv_all) $farbe_end = " <td style='background: #008000;' colspan='1' align='center'>";
if(!$wecker_aktiv_all) $farbe_end = " <td style='background: #002000;' colspan='1' align='center'>";
if($wecker_aktiv == 0) {
$wecker_aktiv = c_Program_NoWeck;
if($wecker_aktiv_all) $farbe_aktiv = " <td style='background: #880000;' colspan='1' align='center'>";
if(!$wecker_aktiv_all) $farbe_aktiv = " <td style='background: #400000;' colspan='1' align='center'>";
else {
$wecker_aktiv = c_Program_Weck;
if($wecker_aktiv_all) $farbe_aktiv = " <td style='background: #008000;' colspan='1' align='center'>";
if(!$wecker_aktiv_all) $farbe_aktiv = " <td style='background: #002000;' colspan='1' align='center'>";
$html.=" <tr>
$html.=" <td align='center'> $wecker_tag</td>
$html.=" <td align='center'> $wecker_zeit</td>
$html.="$farbe_aktiv $wecker_aktiv</td>
switch ($tag){
case 0:
$html.=" <td style='width: 100px; border: 0px;' align='center'></td>
$html.=" <td align='center'>".c_WFC_Global."</td>
$html.="$farbe_global $wecker_global</td>
break;
case 1:
$html.=" <td align='center'>".c_WFC_Urlaub."</td>
$html.="$farbe_urlaub $wecker_urlaub</td>
break;
case 2:
$html.=" <td align='center'>".c_WFC_Feiertag."</td>
$html.="$farbe_feiertag $wecker_feiertag</td>
break;
case 3:
$html.=" <td align='center'>".c_WFC_Frost."</td>
$html.="$farbe_frost $wecker_frost</td>
break;
case 4:
$html.=" <td align='center'>".c_WFC_Snooze."</td>
$html.="$farbe_schlummer $wecker_snooze</td>
break;
case 5:
$html.=" <td align='center'>".c_WFC_End."</td>
$html.="$farbe_end $wecker_end </td>
break;
case 6:
break;
case 7:
break;
$html.=" </tr>
$html.="</table>
$html.="
$html.="<table>
$html.=" <tr>
$html.=" <td>".c_WFC_Urlaubszeit."</td>
$html.=" <td>: ".$wecker_urlaubszeit."</td>
$html.=" </tr>
$html.="</table>
set_ControlValue(c_Control_Uebersicht, $CircleId, $html);
return $html;
function get_DateTranslation($DateItem) {
$Translation = array(
'Monday' => 'Montag',
'Tuesday' => 'Dienstag',
'Wednesday' => 'Mittwoch',
'Thursday' => 'Donnerstag',
'Friday' => 'Freitag',
'Saturday' => 'Samstag',
'Sunday' => 'Sonntag',
'Mon' => 'Mo',
'Tue' => 'Di',
'Wed' => 'Mi',
'Thu' => 'Do',
'Fri' => 'Fr',
'Sat' => 'Sa',
'Sun' => 'So',
'January' => 'Januar',
'February' => 'Februar',
'March' => 'März',
'May' => 'Mai',
'June' => 'Juni',
'July' => 'Juli',
'October' => 'Oktober',
'December' => 'Dezember',
'Montag' => 'Mo',
'Dienstag' => 'Di',
'Mittwoch' => 'Mi',
'Donnerstag' => 'Do',
'Freitag' => 'Fr',
'Samstag' => 'Sa',
'Sonntag' => 'So',
return $Translation[$DateItem];
function get_TimeToleranz($eventTime, $eventCircleTime){
$ret = false;
if ((($eventTime+2) > $eventCircleTime)
and (($eventTime-2) < $eventCircleTime))
$ret = true;
return $ret;
function get_Urlaub($active, $urlaub){
$urlaub = str_replace(" ","",$urlaub);
","",$urlaub);
$frei = false;
$nichtwecken = false;
if ($urlaub<>""){
$i=0;
$urlaubszeiten = explode(",", $urlaub);
foreach($urlaubszeiten as $urlaubszeit){
$datums = explode("-", $urlaubszeit);
if (count($datums) == 1) $datums[1] = $datums[0];
$year = date('Y');
$day1=substr($datums[0],0,2);
$month1=substr($datums[0],3,2);
$day2=substr($datums[1],0,2);
$month2=substr($datums[1],3,2);
if (mktime(0, 0, 0, $month1, $day1, $year) < time()
and mktime(23, 59, 59, $month2, $day2, $year) > time()) $frei = true;
if ($frei == true and $active == false) $nichtwecken = true;
return $nichtwecken;
function get_Feiertag($active){
// $tag = new Feiertag();
$Fdays = getHolidays(Date('Y'));
foreach($Fdays as $value) {
list($key, $value) = each($Fdays);
//Timestamp von heute
$heute = mktime (0,0,0,date("m"),date("d"),date("y"));
//schauen ob Termin auf heute($erg = 0) oder morgen fällt ($erg = -1)
$diff = $heute-$value;
$erg = $diff/((60*60)*24);
//Feiertag gefunden
if ($erg == 0 and $active == false) $nichtwecken = true;
function getEasterSundayTime($year) {
$p = floor($year/100);
$r = floor($year/400);
$o = floor(($p*8+13)/25)-2;
$w = (19*($year%19)+(13+$p-$r-$o)%30)%30;
$e = ($w==29?28:$w);
if ($w==28&&($year%19)>10) $e=27;
$day = (2*($year%4)+4*($year%7)+6*$e+(4+$p-$r)%7)%7+22+$e;
$month = ($day>31?4:3);
if ($day>31) $day-=31;
return mktime(0, 0, 0, $month, $day, $year);
function getHolidays($year) {
$bland = c_Property_Bundesland;
$time = getEasterSundayTime($year);
$days[""] = 0;
$days["Neujahr"] = mktime(0, 0, 0, 1, 1, $year);
$days["Karfreitag"] = $time-(86400*2);
$days["Ostersonntag"] = $time;
$days["Ostermontag"] = $time+(86400 /*[Objekt #20864 existiert nicht]*/);
$days["Tag der Arbeit"] = mktime(0, 0, 0, 5, 1, $year);
$days["Christi Himmelfahrt"] = $time+(86400*39);
$days["Pfingstsonntag"] = $time+(86400*49);
$days["Pfingstmontag"] = $time+(86400*50);
$days["Tag der deutschen Einheit"] = mktime(0, 0, 0, 10, 3, $year);
$days["Buß- und Bettag"] = mktime(0, 0, 0, 11, 26+(7-date('w', mktime(0, 0, 0, 11, 26, $year)))-11, $year); //!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
$days["1. Weihnachtsfeiertag"] = mktime(0, 0, 0, 12, 25, $year);
$days["2. Weihnachtsfeiertag"] = mktime(0, 0, 0, 12, 26, $year);
// Fester $Feiertag in BW, BY, ST
if (($bland == "BW") or ($bland == "BY") or ($bland == "ST")) {
$days["Heilige 3 Könige"] = mktime(0, 0, 0, 1, 6, $year); //!!!!!!!!!!!!!!!!!!!!!!!
// Fester $Feiertag in BB, MV, SA, ST, TH
if (($bland == "BB") or ($bland == "MV") or ($bland == "SA") or ($bland == "ST") or ($bland == "TH")) {
$days["Reformationstag"] = mktime(0, 0, 0, 10, 31, $year); //!!!!!!!!!!!!!!!!!!!!!
// Fester $Feiertag in BW, BY, NW, RP, SL
if (($bland == "BW") or ($bland == "BY") or ($bland == "NW") or ($bland == "RP") or ($bland == "SL")) {
$days["Allerheiligen"] = mktime(0, 0, 0, 11, 1, $year);
// Fester $Feiertag in BY (nicht überall), SL
if (($bland == "BY") or ($bland == "SL")) {
$days["Maria Himmelfahrt"] = mktime(0, 0, 0, 08, 15, $year); //!!!!!!!!!!!!!!!!!!!!!
// Bewegliche Feiertage BW, BY, HE, NW, RP, SL, (SA, TH nicht überall)
if (($bland == "BW") or ($bland == "BY") or ($bland == "HE") or ($bland == "NW") or ($bland == "RP") or ($bland == "SL") or ($bland == "SA") or ($bland == "TH")) {
$days["Fronleichnam"] = $time+(86400*60); //!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
return $days;
Wenn noch was sein sollte, bitte melden.
