IPSModuleManagerGUI Fehler Load Ini File
Ich bekomme mit der Version aus dem Wiki folgenden Fehler wenn ich auf Neues Modul gehe:
IPSModuleManager-Log-IPSModuleManager 2012-11-14 10:05:15.07 Module Download Ini File doesnt exists -> Load Ini File "https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary\install\DownloadListFiles\IPSHomematic_FileList.ini" IPSModuleManager-Log-IPSFileHandler 2012-11-14 10:05:15.07 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/DownloadListFiles/IPSHomematic_FileList.ini ---> C:\IP-Symcon\scripts\IPSLibrary\install\DownloadListFiles\IPSHomematic_FileList.ini
Fatal error: Uncaught exception 'IPSFileHandlerException' with message 'File C:\IP-Symcon\scripts\IPSLibrary\install\DownloadListFiles\IPSHomematic_FileList.ini could NOT be found on the Server !!!' in C:\IP-Symcon\scripts\IPSLibrary\install\IPSModuleManager\IPSFileHandler\IPSFileHandler.class.php:152 Stack trace: #0 C:\IP-Symcon\scripts\IPSLibrary\install\IPSModuleManager\IPSFileHandler\IPSFileHandler.class.php(213): IPSFileHandler->CopyFile('https://raw.git...', 'C:\IP-Symcon\sc...', true) #1 C:\IP-Symcon\scripts\IPSLibrary\install\IPSModuleManager\IPSFileHandler\IPSFileHandler.class.php(231): IPSFileHandler->CopyFiles(Array, Array) #2 C:\IP-Symcon\scripts\IPSLibrary\install\IPSModuleManager\IPSModuleManager.class.php(107): IPSFileHandler->LoadFiles(Array, Array) #3 C:\IP-Symcon\webfront\user\IPSModuleManagerGUI\IPSModuleManagerGUI_NewModule.php(43): IPSModuleManager->__construct('IPSHomematic') #4 C:\IP-Symcon\webfront\user\IPSModuleManagerGUI\IPSModuleManagerGUI.php(96): include('C:\IP-Symcon\we...') #5 {main} throw in C:\IP-Symcon\scripts\IPSLibrary\install\IPSModuleManager\IPSFileHandler\IPSFileHandler.class.php on line 152
Abort Processing during Error: Uncaught exception 'IPSFileHandlerException' with message 'File C:\IP-Symcon\scripts\IPSLibrary\install\DownloadListFiles\IPSHomematic_FileList.ini could NOT be found on the Server !!!' in C:\IP-Symcon\scripts\IPSLibrary\install\IPSModuleManager\IPSFileHandler\IPSFileHandler.class.php:152 Stack trace: #0 C:\IP-Symcon\scripts\IPSLibrary\install\IPSModuleManager\IPSFileHandler\IPSFileHandler.class.php(213): IPSFileHandler->CopyFile('https://raw.git...', 'C:\IP-Symcon\sc...', true) #1 C:\IP-Symcon\scripts\IPSLibrary\install\IPSModuleManager\IPSFileHandler\IPSFileHandler.class.php(231): IPSFileHandler->CopyFiles(Array, Array) #2 C:\IP-Symcon\scripts\IPSLibrary\install\IPSModuleManager\IPSModuleManager.class.php(107): IPSFileHandler->LoadFiles(Array, Array) #3 C:\IP-Symcon\webfront\user\IPSModuleManagerGUI\IPSModuleManagerGUI_NewModule.php(43): IPSModuleManager->__construct('IPSHomematic') #4 C:\IP-Symcon\webfront\user\IPSModuleManagerGUI\IPSModuleManagerGUI.php(96): include('C:\IP-Symcon\we...') #5 {main} throw Error in Script C:\IP-Symcon\scripts\IPSLibrary\install\IPSModuleManager\IPSFileHandler\IPSFileHandler.class.php on Line 152
Hier scheint was mit dem Repository faul zu sein? Oder liegt der Fehler bei meinem system? Bisher ist der BaseLoader das erste Script gewesen, dass ich ausgeführt hab nach der IPS Installation
ich kann den Fehler leider nur eingrenzen, da ich das gleiche Problem habe:
Hier wird, denke ich, versucht eine Datei IPSHomematic_FileList.ini zu downloaden
Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/DownloadListFiles/IPSHomematic_FileList.ini ---> C:\Programme\IP-Symcon\scripts\IPSLibrary\install\DownloadListFiles\IPSHomematic_FileList.ini
Die Datei ist im Repository nicht existent.
Habe die aktuellste Version von IP-Symcon installiert, und die IPSLibrary heute frisch installiert.
Dämmerung ging über den „alten“ Weg hervorragen zu installieren.
Vielen Dank schonmal im Voraus für die Unterstützung
neue Version ist Online -aber ACHUTNG: handelt sich um Beta Version, siehe auch hier
Gefahr erkannt, Gefahr gebannt!
Hat super funktioniert.
Einfach Baseloader drüberbügeln und Problem ist behoben.
Vielen Dank!
Hall zusammen
Ich habe jetzt mal das Baseloader Script durchlaufen lassen.
Hat soweit auch alles geklappt.
Im Webfront wird mir die Übersichtsseite vom IPSModuleManagerGUI angezeigt leider kann ich aber nicht bedienen.
Wenn ich auf die Links gehe bekomme ich eine Hand und kann draufklicken aber nichts passiert.
Vieleicht hat ja Jemand eine Idee.
Mfg Stefan
Internet ist an (jQuery für die Kommunikation wird direkt aus dem Netz geladen)?
Hallo Andreas
Ja mit dem Internet bin ich verbunden.
Kann ich sonst noch was Prüfen.
Mfg Stefan
Hallo Andreas
Ich habe es jetzt mal mit dem IE9 ,Firefox und Google Browsern ausprobiert.
Leider funktioniert es mit keinem der Browser.
Hast Du vieleicht noch eine Idee.
Mfg Stefan
Hallo Stefan,
momentan habe ich da leider keine Idee - ist irgendetwas an Deinem System anders?
Wenn Du etwas Erfahrung hast, könntest Du zB mal mit den „Entwicklertools“ von Chrome einen Blick auf die Seite machen und schauen, ob da irgend ein Javascript Fehler angezeigt wird.
Zusätzlich mal verifizieren, ob die Empfänger Seite funktioniert, versuch mal ob der Aufruf der folgenden URL einen Refresh der GUI auslöst (IP und Port anpassen):
http://192.168.0.xx:82/user/IPSModuleManagerGUI/IPSModuleManagerGUI_Receiver.php?id=x&action=Refresh&module=&info=
Hallo Andreas
Das mit den Entwickler Tools werde ich mir mal anschauen.
Das Manuelle eingeben der URL bewirkt einen Refresh das klappt also.
Mfg Stefan
Hallo Andreas
Ich wollte mich nur mal melden und meine kleine Erkenntnis mitteilen.
Also ich habe jetzt mal in IP-Symcon im Webinterface das SSL deaktiviert
und siehe da jetzt klappt das GUI einwandfrei.
Sonst habe ich leider nichts weiter rausgefunden.
Mfg Stefan
Hallo Andreas
Wie ich ja schon geschrieben habe liegt das Problem am SSL.
Dank wupperi konnte ich es jetzt lösen.
Ich habe an drei Stellen in dem Script „IPSModuleManagerGUI.php“ ein „s“ eingefügt und siehe da es klappt.
<script type="text/javascript" src="https://ajax.googleapis.com/ajax/libs/jquery/1.7.2/jquery.min.js"></script>
url: "https://"+serverAddr+"/user/IPSModuleManagerGUI/IPSModuleManagerGUI_Receiver.php",
Ich denke mal das es beim nächsten Update wieder weg ist?
Ich wollte mich noch bei Dir Bedanken für Deine Hilfe und
Dir ein Riesen Lob ausprechen für Deine wirklich tolle Arbeit.
Mfg Stefan
Hallo Stefan,
hab das Problem jetzt lösen können, in Zukunft werden beide Protokoll Typen unterstützt.
