bekomme bei der Modulinstallation folgenden Fehler, wenn ich mein Philips Hue in Betrieb nehmen möchte.
Fehler:
<div>Warning: Invalid argument supplied for foreach()<br> Error in Script D:\IPS\IP-Symcon\scripts\IPSLibrary\install\InstallationScripts\IPSLight_Installation.ips.php on Line 235<br> 134 in scripts\IPSLibrary\app\core\IPSLogger\IPSLogger.inc.php (call IPSLogger_Out)<br> 37 in scripts\IPSLibrary\app\core\IPSLogger\IPSLogger_PhpErrorHandler.inc.php (call IPSLogger_Err)<br> 235 in scripts\IPSLibrary\install\InstallationScripts\IPSLight_Installation.ips.php (call IPSLogger_PhpErrorHandler)<br> 673 in scripts\IPSLibrary\install\IPSModuleManager\IPSModuleManager.class.php (call include)<br> 69 in webfront\user\IPSModuleManagerGUI\IPSModuleManagerGUI_Receiver.php (call InstallModule)</div>
Konfig:
* This file is part of the IPSLibrary.
* The IPSLibrary is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published
* by the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* The IPSLibrary is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with the IPSLibrary. If not, see http://www.gnu.org/licenses/gpl.txt.
/**@defgroup ipslight_configuration IPSLight Konfiguration
* @ingroup ipslight
* @file IPSLight_Configuration.inc.php
* @author Andreas Brauneis
* @version
* Version 2.50.1, 26.07.2012<br/>
* Konfigurations File für IPSLight
* Definition der Beleuchtungs Elemente
* Die Konfiguration erfolgt in Form eines Arrays, für jedes Beleuchtungselement wird ein Eintrag im Array erzeugt.
* Für jedes Beleuchtungselement werden dann die Eigenschaften in einem gesonderten Array hinterlegt:
* IPSLIGHT_NAME - spezifiziert den Namen der Beleuchtung in der GUI, Änderungen an dieser Eigenschaft werden erst nach einem
* erneuten Ausführen der Installationsprozedur sichtbar.
* IPSLIGHT_GROUP - beinhaltet eine Liste aller Gruppen, der das Beleuchtungselement zugeordnet ist. Diese Eigenschaft kann
* jederzeit geändert werden (vorausgesetzt die Gruppe ist bereits definiert, siehe weiter unten).
* IPSLIGHT_TYPE - spezifiziert den Type der Beleuchtung, zur Zeit werden 3 Beleuchtungstypen unterstützt:
* - IPSLIGHT_TYPE_SWITCH: Normale Beleuchtung mit Ein/Aus Funktionalität
* - IPSLIGHT_TYPE_RGB: RGB Beleuchtung
* - IPSLIGHT_TYPE_DIMMER: Dimmbare Beleuchtung
* Änderungen an diesem Parameter erfordern ein Ausführen der Installations Prozedure.
* IPSLIGHT_COMPONENT - dieser Eintrag spezifiziert die Hardware, die Angabe des Component Strings muss mit dem spezifizierten
* Beleuchtungstypen (siehe oben) zusammenpassen (Type Dimmer benötigt zB eine Klasse IPSComponentDimmer).
* IPSLIGHT_POWERCIRCLE - Hier kann spezifiziert werden an welchem Stromkreis die Lampe angeschlossen ist. Dieser Parameter ist
* optional.
* IPSLIGHT_POWERWATT - Spezifiert die maximale Leistung der Beleuchtung. Zusammen mit dem Parameter IPSLIGHT_POWERCIRCLE ist es
* nun möglich die aktuelle Leistung eines Stromkreises abzufragen. Details siehe auch im WIKI.
* Eine ausführliche Beispielliste findet sich auch im Example Ordner
* Beispiel:
* @code
function IPSLight_GetLightConfiguration() {
return array(
'Kueche' => array(
IPSLIGHT_NAME => 'Küche',
IPSLIGHT_GROUPS => 'Erdgeschoss,All',
IPSLIGHT_TYPE => IPSLIGHT_TYPE_SWITCH',
IPSLIGHT_COMPONENT => 'IPSComponentSwitch_Homematic,12345',
IPSLIGHT_POWERCIRCLE => 1,
IPSLIGHT_POWERWATT => 60),
'Ambiente' => array(
IPSLIGHT_NAME => 'Ambiente',
IPSLIGHT_TYPE => IPSLIGHT_TYPE_RGB,
IPSLIGHT_COMPONENT => 'IPSComponentRGB_IPS868,12345'),
* @endcocde
* @return string Liefert Array mit Beleuchtungs Elementen
return array(
'Kinderzimmer_RGB_HUE' => array('Kinderzimmer_RGB_HUE','Kinderzimmer,All','RGB','IPSComponentRGB_PhilipsHUE,192.168.10.104,534dfdf4343230db383391639232323b3757,4,LCT001'),
* Definition der Beleuchtungs Gruppen
* Die Konfiguration erfolgt in Form eines Arrays, für jede Beleuchtungsgruppe wird ein Eintrag im Array erzeugt.
* Für jede Beleuchtungsgruppe werden dann die Eigenschaften in einem gesonderten Array hinterlegt:
* IPSLIGHT_NAME - spezifiziert den Namen der Gruppe in der GUI, Änderungen an dieser Eigenschaft werden erst nach einem
* IPSLIGHT_ACTIVATABLE - gibt an, ob die Gruppe über die GUI eingeschaltet werden kann
* Eine Liste mit diversen Beispiel Konfigurationen findet sich auch im Example Ordner
* Beispiel:
* @code
function IPSLight_GetGroupConfiguration() {
return array(
'All' => array(
IPSLIGHT_NAME => 'All',
IPSLIGHT_ACTIVATABLE => false),
'Erdgeschoss' => array(
IPSLIGHT_NAME => 'Erdgeschoss',
* @endcocde
* @return string Liefert Array mit Beleuchtungs Gruppen
return array('All' => array('All', IPSLIGHT_ACTIVATABLE => false,),
'Erdgeschoss' => array('Erdgeschoss', IPSLIGHT_ACTIVATABLE => false,),
* Definition der Beleuchtungs Programme
* Die Konfiguration erfolgt in Form eines Arrays, für jedes Beleuchtungsprogramm wird ein Eintrag im Array erzeugt.
* Für jedes Beleuchtungsprogramm werden dann die einzelnen Programme ebenfalls als Array hinterlegt, diese wiederum haben ihre
* Eigenschaften nochmals in einem Array gespeichert:
* IPSLIGHT_PROGRAMON - Liste mit Beleuchungselementen, die bei diesem Programm eingeschaltet sein sollen.
* IPSLIGHT_PROGRAMOFF - Liste mit Beleuchungselementen, die bei diesem Programm ausgeschaltet sein sollen.
* IPSLIGHT_PROGRAMLEVEL - Liste mit Beleuchungselementen, die auf einen bestimmten Dimm Level gestellt werden sollen
* Beispiel:
* @code
function IPSLight_GetProgramConfiguration() {
return array(
'Aus' => array(
IPSLIGHT_PROGRAMOFF => 'WellnessWand,WellnessDecke,WellnessSauna,WellnessDusche,WellnessAmbiente',
'TV' => array(
IPSLIGHT_PROGRAMLEVEL => 'WellnessWand,30',
IPSLIGHT_PROGRAMOFF => 'WellnessDecke,WellnessSauna,WellnessDusche,WellnessAmbiente',
'Relax' => array(
IPSLIGHT_PROGRAMON => 'WellnessSauna,WellnessDusche,WellnessAmbiente',
IPSLIGHT_PROGRAMLEVEL => 'WellnessDecke,30,WellnessWand,30',
* @endcocde
return array(
* Definition der WebFront GUI
* Die Konfiguration der WebFront Oberfläche ist NICHT dokumentiert, ist aber analog zur normalen WebFront Konfigurator GUI
* aufgebaut.
* Beispiele finden sich im Example Ordner
* @return string Liefert Array zum Aufbau des WebFronts
function IPSLight_GetWebFrontConfiguration() {
return array(
IPSLIGHT_WFCGROUP,'RGB','Light_1_CAv3','Kinderzimmer_RGB_HUE,Kinderzimmer_RGB_HUE#Color,Kinderzimmer_RGB_HUE#Level','Power,Farbe,Helligkeit'
* Definition der Mobile GUI
* Die Konfiguration der Mobile GUI ist NICHT dokumentiert
* @return string Liefert Array zum Aufbau der Mobile GUI
function IPSLight_GetMobileConfiguration() {
return array(
Sobald ich den Eintrag bei „IPSLight_GetWebFrontConfiguration“ in der Lights-Config entferne, läuft die Modulinstallation durch.
Habe ich da noch einer Fehler in meiner Konfig? Wäre super, wenn mir mal jemand seine funktionierende Hue Konfig posten könnte.
