ja, ich musste auch erstmal etwas programmieren, bis es ging:
//Variables provided by ShutterControl Module
//IPS_LogMessage("InstanceID", $_IPS['INSTANCE']); /* InstanceID */
//IPS_LogMessage("Direction", $_IPS['DIRECTION']); /* {0..2} Stop, Up, Down */
//IPS_LogMessage("Duration", $_IPS['DURATION']); /* ms */
if($_IPS['SENDER'] != "ShutterControl")
die("This script can only be started by the ShutterControl Module");
define("SC_DIRECTION_STOP", 0);
define("SC_DIRECTION_UP", 1);
define("SC_DIRECTION_DOWN", 2);
$instance = IPS_GetInstance($_IPS['INSTANCE']);
switch($instance['ModuleInfo']['ModuleID'])
case "{48FCFDC1-11A5-4309-BB0B-A0DB8042A969}": //FS20
$running = CreateVariableByName($SC_INSTANCE, "Moving", 0);
$value = GetValue(IPS_GetStatusVariableID($_IPS['INSTANCE'],"StatusVariable"));
switch($_IPS['DIRECTION'])
case SC_DIRECTION_STOP:
if(GetValue($running))
FS20_SwitchMode($_IPS['INSTANCE'], $value);
SetValue($running, false);
break;
case SC_DIRECTION_UP:
if(!GetValue($running))
FS20_SwitchMode($_IPS['INSTANCE'], true);
SetValue($running, true);
if($SC_DURATION > 0)
IPS_Sleep($_IPS['DURATION']);
break;
case SC_DIRECTION_DOWN:
FS20_SwitchMode($_IPS['INSTANCE'], false);
break;
break;
case "{1B7B5B7D-CAA9-4AB5-B9D8-EC805EC955AD}": //xComfort
MXC_ShutterStop($_IPS['INSTANCE']);
break;
MXC_ShutterMoveUp($_IPS['INSTANCE']);
if($_IPS['DURATION'] > 0)
break;
MXC_ShutterMoveDown($_IPS['INSTANCE']);
break;
break;
case "{2D871359-14D8-493F-9B01-26432E3A710F}": //LCN
$type=LCN_GetUnit($_IPS['INSTANCE']);
switch($type)
case 0: //Ausgänge
LCN_SetIntensity($_IPS['INSTANCE'],0,0);
LCN_SetIntensity($_IPS['INSTANCE2'],0,0);
break;
LCN_SetIntensity($_IPS['INSTANCE'],100,4);
break;
LCN_SetIntensity($_IPS['INSTANCE2'],100,4);
break;
break;
case 2: //Reais
LCN_SwitchRelay($_IPS['INSTANCE'],false);
break;
LCN_SwitchRelay($_IPS['INSTANCE'],true);
LCN_SwitchRelay($_IPS['INSTANCE2'],false); // Um Relaisrichtung zu ändern bitte auf true
break;
LCN_SwitchRelay($_IPS['INSTANCE2'],true);// Um Relaisrichtung zu ändern bitte auf false
break;
break;
break;
case "{101352E1-88C7-4F16-998B-E20D50779AF6}": //Z-Wave Shutter
ZW_ShutterStop($_IPS['INSTANCE']);
break;
ZW_ShutterMoveUp($_IPS['INSTANCE']);
if($_IPS['DURATION'] > 0){
break;
ZW_ShutterMoveDown($_IPS['INSTANCE']);
break;
break;
case "{9317CC5B-4E1D-4440-AF3A-5CC7FB42CCAA}": //1-Wire Shutter
OneWireShutter($_IPS['INSTANCE'], 0, $_IPS['DURATION']);
break;
if($_IPS['DURATION'] == 0)
$_IPS['DURATION'] = 120000;
break;
OneWireShutter($_IPS['INSTANCE'], 1, $_IPS['DURATION']);
break;
break;
case "{EE4A81C6-5C90-4DB7-AD2F-F6BBD521412E}": //Homematic Shutter
HM_WriteValueBoolean($_IPS['INSTANCE'], "STOP", true);
break;
HM_WriteValueFloat($_IPS['INSTANCE'], "LEVEL", 1.0);
break;
HM_WriteValueFloat($_IPS['INSTANCE'], "LEVEL", 0.0);
break;
break;
default:
die("No Handler for Module ".$instance['ModuleInfo']['ModuleName']." found");
function OneWireShutter($ins, $dir, $sec) {
@TMEX_F29_SetStrobe($ins, True);
$res = ($dir * 128) + ($sec / 1000);
@TMEX_F29_SetPort((integer)$ins, (integer)$res);
function CreateVariableByName($id, $name, $type)
if($vid===false) {
IPS_SetParent($vid, $id);
IPS_SetName($vid, $name);
IPS_SetInfo($vid, "This Variable was created by Script #".$_IPS['SELF']);
return $vid;
