Hallo @demel42 ,
habe jetzt noch folgende Fehlermeldung beim Token-Refresh:
16.09.2021, 18:51:00 | RefreshToken | => errno=0, httpcode=400, duration=0,17s
16.09.2021, 18:51:00 | RefreshToken | => header=HTTP/1.1 400 Bad Request<CR><LF>Date: Thu, 16 Sep 2021 16:51:00 GMT<CR><LF>Content-Type: application/json<CR><LF>Transfer-Encoding: chunked<CR><LF>Connection: keep-alive<CR><LF>Set-Cookie: INGRESSCOOKIE=1631811061.092.326.291080; Path=/am; Secure; HttpOnly<CR><LF>x-frame-options: SAMEORIGIN<CR><LF>pragma: no-cache<CR><LF>cache-control: no-store<CR><LF>accept-ranges: bytes<CR><LF>vary: Accept-Charset, Accept-Encoding, Accept-Language, Accept<CR><LF>Strict-Transport-Security: max-age=15724800; includeSubDomains<CR><LF>Access-Control-Allow-Origin: <CR><LF>Access-Control-Allow-Headers: Authorization, Origin, X-c2b-Authorization, X-c2b-mTAN, X-Requested-With, X-c2b-Sender-Id, X-c2b-External-Id, Content-Type, Accept, Cache-Control, KeyId, x-dtc<CR><LF>Access-Control-Max-Age: 3628800<CR><LF>Access-Control-Allow-Credentials: true<CR><LF>Access-Control-Allow-Methods: POST, GET, OPTIONS, PUT, DELETE, HEAD<CR><LF>Referrer-Policy: no-referrer-when-downgrade<CR><LF><CR><LF>
16.09.2021, 18:51:00 | RefreshToken | => body={"error": "invalid_request", "error_description": "The request is missing a required parameter, includes an unsupported parameter value (other than grant type), repeats a parameter, includes multiple credentials, utilizes more than one mechanism for authenticating the client, or is otherwise malformed"}
16.09.2021, 18:51:00 | RefreshToken | missing element "access_token" in "{"error": "invalid_request", "error_description": "The request is missing a required parameter, includes an unsupported parameter value (other than grant type), repeats a parameter, includes multiple credentials, utilizes more than one mechanism for authenticating the client, or is otherwise malformed"}"
Und beim Daten abholen bricht er mit dem gleichen Fehler ab.
Und er aktualisiert wieder nicht mehr. Kannst Du da helfen?
Burkhard
