Hallo Joachim,
dann spiel später direkt ein Update ein und teste es!
Edit: Ich glaube da ist doch noch ein Fehler, Fix kommt mit der neuen testing Version.
Hallo Joachim,
…gerade Update gemacht und läuft aktuell hier nicht - ich warte mal auf Deine Anweisungen![emoji6]
Joachim
Server-Log:
[2017-02-17 16:04:38] [websocket] Plugin - DidFinishLaunching
[2017-02-17 16:04:38] [websocket] Number of Accessories: 6
[2017-02-17 16:04:38] Homebridge is running on port 51826.
[2017-02-17 16:04:38] [websocket] url {„address“:"::",„family“:„IPv6“,„port“:4050}
[2017-02-17 16:04:41] [websocket] A new version 0.1.12 is avaiable
[2017-02-17 16:05:31] [websocket] client ip ::ffff:192.168.178.50 connected
[2017-02-17 17:04:50] Loaded plugin: homebridge-websocket
homebridge API version: 2.1
[2017-02-17 17:04:50] Registering platform ‚homebridge-websocket.websocket‘
[2017-02-17 17:04:50] —
[2017-02-17 17:04:50] Loaded config.json with 0 accessories and 1 platforms.
[2017-02-17 17:04:50] Loading 1 platforms…
[2017-02-17 17:04:50] [websocket] Initializing websocket platform…
[2017-02-17 17:04:50] [websocket] homebridge-websocket v0.1.11
[2017-02-17 17:04:51] Loading 0 accessories…
Scan this code with your HomeKit App on your iOS device to pair with Homebridge:+------------+ ¦ 031-45-154 ¦ +------------+
[2017-02-17 17:04:51] [websocket] Plugin - DidFinishLaunching
[2017-02-17 17:04:51] [websocket] Number of Accessories: 6
[2017-02-17 17:04:51] Homebridge is running on port 51826.
[2017-02-17 17:04:51] [websocket] url {„address“:"::",„family“:„IPv6“,„port“:4050}
[2017-02-17 17:04:53] [websocket] A new version 0.1.12 is avaiable
[2017-02-17 17:05:31] [websocket] client ip ::ffff:192.168.178.50 connected
Error-Log
Fri, 17 Feb 2017 16:19:12 GMT EventedHTTPServer [::ffff:192.168.178.62] New connection from client
Fri, 17 Feb 2017 16:19:12 GMT EventedHTTPServer [::ffff:192.168.178.62] HTTP server listening on port 33398
Fri, 17 Feb 2017 16:19:12 GMT EventedHTTPServer [::ffff:192.168.178.62] HTTP request: /pair-verify
Fri, 17 Feb 2017 16:19:12 GMT HAPServer [CC:22:3D:E3:CE:30] HAP Request: POST /pair-verify
Fri, 17 Feb 2017 16:19:12 GMT HAPServer [CC:22:3D:E3:CE:30] Pair verify step 1/2
Fri, 17 Feb 2017 16:19:12 GMT EventedHTTPServer [::ffff:192.168.178.62] HTTP Response is finished
Fri, 17 Feb 2017 16:19:12 GMT HAPServer [CC:22:3D:E3:CE:30] Pair verify step 2/2
Fri, 17 Feb 2017 16:19:12 GMT HAPServer [CC:22:3D:E3:CE:30] Client 7E9C2C3F-37C8-4AE4-9A76-EFA98716D628 verification complete
Fri, 17 Feb 2017 16:19:12 GMT EventedHTTPServer [::ffff:192.168.178.62] HTTP request: /accessories
Fri, 17 Feb 2017 16:19:12 GMT HAPServer [CC:22:3D:E3:CE:30] HAP Request: GET /accessories
Fri, 17 Feb 2017 16:19:12 GMT EventedHTTPServer [::ffff:192.168.178.62] HTTP request: /characteristics
Fri, 17 Feb 2017 16:19:12 GMT HAPServer [CC:22:3D:E3:CE:30] HAP Request: PUT /characteristics
Fri, 17 Feb 2017 16:19:12 GMT Accessory [Homebridge] Processing characteristic set: [{„aid“:2,„iid“:11,„ev“:true},{„aid“:2,„iid“:14,„ev“:true},{„aid“:3,„iid“:12,„ev“:true},{„aid“:3,„iid“:15,„ev“:true},{„aid“:4,„iid“:12,„ev“:true},{„aid“:4,„iid“:15,„ev“:true},{„aid“:5,„iid“:11,„ev“:true},{„aid“:5,„iid“:14,„ev“:true},{„aid“:6,„iid“:11,„ev“:true},{„aid“:6,„iid“:14,„ev“:true},{„aid“:7,„iid“:11,„ev“:true},{„aid“:7,„iid“:14,„ev“:true}]
Fri, 17 Feb 2017 16:19:12 GMT Accessory [Homebridge] Registering Characteristic „Reachable“ for events
Fri, 17 Feb 2017 16:19:12 GMT Accessory [Homebridge] Registering Characteristic „Category“ for events
…irgendwie sieht es so aus, als ob die „accessories“ nicht mehr geladen werden…
Halo Joachim,
es gibt eine neue Version im testing Branch.
Da sollte das Problem mit dem Dimmer für dich gelöst sein.
Versuch es doch nochmal.
…habe das Update durchgeführt, scheint jetzt zu laufen![emoji1303][emoji2]
Werde das mal beobachten…
Danke erst einmal
Joachim
Erstmal Danke für dein Modul
Ich habe nur leider das Problem das ich per Home App nicht schalten kann. Wenn ich per IPS schalte wird der Status in der Home App aktualisert.
Hier der Fehler in IPS:
18.02.2017 00:38:22*| FlowHandler*| Kann Daten nicht zur Instanz #10551 weiterleiten: <br />
<b>Notice</b>: Undefined property: stdClass::$service in <b>/var/lib/symcon/modules/IPS-Homebridge/IPS-HomebridgeSplitter/module.php</b> on line <b>25</b><br />
WebsocketClient:
TXT: 18.02.2017 00:40:52.00 | ReceivePacket | L{"topic":"set","payload":{"name":"Test","characteristic":"On","value":true}}
HEX: 18.02.2017 00:40:52.00 | ReceivePacket | 81 4C 7B 22 74 6F 70 69 63 22 3A 22 73 65 74 22 2C 22 70 61 79 6C 6F 61 64 22 3A 7B 22 6E 61 6D 65 22 3A 22 54 65 73 74 22 2C 22 63 68 61 72 61 63 74 65 72 69 73 74 69 63 22 3A 22 4F 6E 22 2C 22 76 61 6C 75 65 22 3A 74 72 75 65 7D 7D
TXT: 18.02.2017 00:40:52.00 | Receive FIN | true
HEX: 18.02.2017 00:40:52.00 | Receive FIN | 74 72 75 65
TXT: 18.02.2017 00:40:52.00 | Receive OpCode | text
HEX: 18.02.2017 00:40:52.00 | Receive OpCode | 74 65 78 74
TXT: 18.02.2017 00:40:52.00 | Receive Mask | false
HEX: 18.02.2017 00:40:52.00 | Receive Mask | 66 61 6C 73 65
TXT: 18.02.2017 00:40:52.00 | Receive Payload | {"topic":"set","payload":{"name":"Test","characteristic":"On","value":true}}
HEX: 18.02.2017 00:40:52.00 | Receive Payload | 7B 22 74 6F 70 69 63 22 3A 22 73 65 74 22 2C 22 70 61 79 6C 6F 61 64 22 3A 7B 22 6E 61 6D 65 22 3A 22 54 65 73 74 22 2C 22 63 68 61 72 61 63 74 65 72 69 73 74 69 63 22 3A 22 4F 6E 22 2C 22 76 61 6C 75 65 22 3A 74 72 75 65 7D 7D
Hier der Homebridge Splitter:
TXT: 18.02.2017 00:40:52.00 | JSON | {"DataID":"{018EF6B5-AB94-40C6-AA53-46943E824ACF}","Buffer":"{\"topic\":\"set\",\"payload\":{\"name\":\"Test\",\"characteristic\":\"On\",\"value\":true}}"}
HEX: 18.02.2017 00:40:52.00 | JSON | 7B 22 44 61 74 61 49 44 22 3A 22 7B 30 31 38 45 46 36 42 35 2D 41 42 39 34 2D 34 30 43 36 2D 41 41 35 33 2D 34 36 39 34 33 45 38 32 34 41 43 46 7D 22 2C 22 42 75 66 66 65 72 22 3A 22 7B 5C 22 74 6F 70 69 63 5C 22 3A 5C 22 73 65 74 5C 22 2C 5C 22 70 61 79 6C 6F 61 64 5C 22 3A 7B 5C 22 6E 61 6D 65 5C 22 3A 5C 22 54 65 73 74 5C 22 2C 5C 22 63 68 61 72 61 63 74 65 72 69 73 74 69 63 5C 22 3A 5C 22 4F 6E 5C 22 2C 5C 22 76 61 6C 75 65 5C 22 3A 74 72 75 65 7D 7D 22 7D
TXT: 18.02.2017 00:40:52.00 | ReceiveData JSON | {"DataID":"{018EF6B5-AB94-40C6-AA53-46943E824ACF}","Buffer":"{\"topic\":\"set\",\"payload\":{\"name\":\"Test\",\"characteristic\":\"On\",\"value\":true}}"}
HEX: 18.02.2017 00:40:52.00 | ReceiveData JSON | 7B 22 44 61 74 61 49 44 22 3A 22 7B 30 31 38 45 46 36 42 35 2D 41 42 39 34 2D 34 30 43 36 2D 41 41 35 33 2D 34 36 39 34 33 45 38 32 34 41 43 46 7D 22 2C 22 42 75 66 66 65 72 22 3A 22 7B 5C 22 74 6F 70 69 63 5C 22 3A 5C 22 73 65 74 5C 22 2C 5C 22 70 61 79 6C 6F 61 64 5C 22 3A 7B 5C 22 6E 61 6D 65 5C 22 3A 5C 22 54 65 73 74 5C 22 2C 5C 22 63 68 61 72 61 63 74 65 72 69 73 74 69 63 5C 22 3A 5C 22 4F 6E 5C 22 2C 5C 22 76 61 6C 75 65 5C 22 3A 74 72 75 65 7D 7D 22 7D
TXT: 18.02.2017 00:40:52.00 | ReceiveData set | Service: DeviceName: Test Characteristic: On Value: 1
HEX: 18.02.2017 00:40:52.00 | ReceiveData set | 53 65 72 76 69 63 65 3A 20 20 44 65 76 69 63 65 4E 61 6D 65 3A 20 54 65 73 74 20 43 68 61 72 61 63 74 65 72 69 73 74 69 63 3A 20 4F 6E 20 56 61 6C 75 65 3A 20 31
TXT: 18.02.2017 00:40:52.00 | setValue SendDataToChildren | {"DataID":"{018EF6B5-AB94-40C6-AA53-46943E824ACF}","Buffer":"{\"Service\": \"\", \"Device\": \"Test\", \"Action\": \"set\", \"Characteristic\": \"On\", \"Value\": \"1\"}"}
HEX: 18.02.2017 00:40:52.00 | setValue SendDataToChildren | 7B 22 44 61 74 61 49 44 22 3A 22 7B 30 31 38 45 46 36 42 35 2D 41 42 39 34 2D 34 30 43 36 2D 41 41 35 33 2D 34 36 39 34 33 45 38 32 34 41 43 46 7D 22 2C 22 42 75 66 66 65 72 22 3A 22 7B 5C 22 53 65 72 76 69 63 65 5C 22 3A 20 5C 22 5C 22 2C 20 5C 22 44 65 76 69 63 65 5C 22 3A 20 5C 22 54 65 73 74 5C 22 2C 20 5C 22 41 63 74 69 6F 6E 5C 22 3A 20 5C 22 73 65 74 5C 22 2C 20 5C 22 43 68 61 72 61 63 74 65 72 69 73 74 69 63 5C 22 3A 20 5C 22 4F 6E 5C 22 2C 20 5C 22 56 61 6C 75 65 5C 22 3A 20 5C 22 31 5C 22 7D 22 7D
Hast du eine Idee was da falsch läuft?
Timo
Hallo Timo,
Service scheint nicht übermittelt zu werden.
Welches Homebridge Plugin hast du installiert? Ich hoffe die Version die bei mir im Git ist.
So, habe gerade folgdendes gemacht:
anbei die Logs:
Homebridge
2017-02-18 12:56:01,stdout,"[37m[2/18/2017, 12:56:01 PM][39m [36m[websocket][39m [90mcallback {\"name\":\"Feuchtigkeit Bad\",\"characteristic\":\"CurrentRelativeHumidity\",\"value\":47}[39m"
2017-02-18 12:55:59,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP Response is finished [35m+0ms[0m
2017-02-18 12:55:59,stdout, [33;1mAccessory [0m[Homebridge] Error getting value for Characteristic "Current Relative Humidity": undefined [33m+1ms[0m
2017-02-18 12:55:59,stdout, [33;1mAccessory [0m[Homebridge] Got Characteristic "Current Relative Humidity" value: undefined [33m+1s[0m
2017-02-18 12:55:59,stdout,"[37m[2/18/2017, 12:55:59 PM][39m [36m[websocket][39m [90mget timeout Feuchtigkeit Bad CurrentRelativeHumidity[39m"
2017-02-18 12:55:58,stdout,"[37m[2/18/2017, 12:55:58 PM][39m [36m[websocket][39m [90msendData {\"topic\":\"get\",\"service\":\"HumiditySensor\",\"payload\":{\"name\":\"Feuchtigkeit Bad\",\"characteristic\":\"CurrentRelativeHumidity\"}}[39m"
2017-02-18 12:55:58,stdout, [33;1mAccessory [0m[Homebridge] Getting value for Characteristic "Current Relative Humidity" [33m+0ms[0m
2017-02-18 12:55:58,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: GET /characteristics?id=2.9 [35m+0ms[0m
2017-02-18 12:55:58,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP request: /characteristics?id=2.9 [35m+5m[0m
2017-02-18 12:55:25,stdout,"[37m[2/18/2017, 12:55:25 PM][39m [36m[websocket][39m [90msendData {\"topic\":\"response\",\"payload\":{\"ack\":false,\"message\":\"name 'Temperatur Dach' undefined.\"}}[39m"
2017-02-18 12:55:25,stdout,"[37m[2/18/2017, 12:55:25 PM][39m [36m[websocket][39m [33msetValue name 'Temperatur Dach' undefined.[39m"
2017-02-18 12:55:25,stdout,"[37m[2/18/2017, 12:55:25 PM][39m [36m[websocket][39m [90msetValue {\"name\":\"Temperatur Dach\",\"characteristic\":\"CurrentTemperature\",\"value\":18.4}[39m"
2017-02-18 12:54:47,stdout,"[37m[2/18/2017, 12:54:47 PM][39m [36m[websocket][39m [90msetValue {\"name\":\"Feuchtigkeit Bad\",\"characteristic\":\"CurrentRelativeHumidity\",\"value\":47}[39m"
2017-02-18 12:54:47,stdout,"[37m[2/18/2017, 12:54:47 PM][39m [36m[websocket][39m [90msendData {\"topic\":\"response\",\"payload\":{\"ack\":false,\"message\":\"name 'Temperatur Bad' undefined.\"}}[39m"
2017-02-18 12:54:47,stdout,"[37m[2/18/2017, 12:54:47 PM][39m [36m[websocket][39m [33msetValue name 'Temperatur Bad' undefined.[39m"
2017-02-18 12:54:47,stdout,"[37m[2/18/2017, 12:54:47 PM][39m [36m[websocket][39m [90msetValue {\"name\":\"Temperatur Bad\",\"characteristic\":\"CurrentTemperature\",\"value\":19.6}[39m"
2017-02-18 12:52:35,stdout,"[37m[2/18/2017, 12:52:35 PM][39m [36m[websocket][39m [90msendData {\"topic\":\"response\",\"payload\":{\"ack\":false,\"message\":\"name 'Temperatur Bad' undefined.\"}}[39m"
2017-02-18 12:52:35,stdout,"[37m[2/18/2017, 12:52:35 PM][39m [36m[websocket][39m [33msetValue name 'Temperatur Bad' undefined.[39m"
2017-02-18 12:52:35,stdout,"[37m[2/18/2017, 12:52:35 PM][39m [36m[websocket][39m [90msetValue {\"name\":\"Temperatur Bad\",\"characteristic\":\"CurrentTemperature\",\"value\":19.8}[39m"
2017-02-18 12:52:35,stdout,"[37m[2/18/2017, 12:52:35 PM][39m [36m[websocket][39m [90msetValue {\"name\":\"Feuchtigkeit Bad\",\"characteristic\":\"CurrentRelativeHumidity\",\"value\":49}[39m"
2017-02-18 12:52:25,stdout,"[37m[2/18/2017, 12:52:25 PM][39m [36m[websocket][39m [90msendData {\"topic\":\"response\",\"payload\":{\"ack\":false,\"message\":\"name 'Temperatur Dach' undefined.\"}}[39m"
2017-02-18 12:52:25,stdout,"[37m[2/18/2017, 12:52:25 PM][39m [36m[websocket][39m [33msetValue name 'Temperatur Dach' undefined.[39m"
2017-02-18 12:52:25,stdout,"[37m[2/18/2017, 12:52:25 PM][39m [36m[websocket][39m [90msetValue {\"name\":\"Temperatur Dach\",\"characteristic\":\"CurrentTemperature\",\"value\":18.5}[39m"
2017-02-18 12:51:23,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP Response is finished [35m+2ms[0m
2017-02-18 12:51:23,stdout, [33;1mAccessory [0m[Homebridge] Unregistering Characteristic "Current Relative Humidity" for events [33m+0ms[0m
2017-02-18 12:51:23,stdout," [33;1mAccessory [0m[Homebridge] Processing characteristic set: [{\"aid\":2,\"iid\":9,\"ev\":false}] [33m+1ms[0m"
2017-02-18 12:51:23,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: PUT /characteristics [35m+1ms[0m
2017-02-18 12:51:23,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP request: /characteristics [35m+5s[0m
2017-02-18 12:51:18,stdout,"[37m[2/18/2017, 12:51:18 PM][39m [36m[websocket][39m [90mcallback {\"name\":\"Feuchtigkeit Bad\",\"characteristic\":\"CurrentRelativeHumidity\",\"value\":50}[39m"
2017-02-18 12:51:18,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP Response is finished [35m+0ms[0m
2017-02-18 12:51:18,stdout, [33;1mAccessory [0m[Homebridge] Error getting value for Characteristic "Current Relative Humidity": undefined [33m+0ms[0m
2017-02-18 12:51:18,stdout, [33;1mAccessory [0m[Homebridge] Got Characteristic "Current Relative Humidity" value: undefined [33m+1s[0m
2017-02-18 12:51:18,stdout,"[37m[2/18/2017, 12:51:18 PM][39m [36m[websocket][39m [90mget timeout Feuchtigkeit Bad CurrentRelativeHumidity[39m"
2017-02-18 12:51:17,stdout,"[37m[2/18/2017, 12:51:17 PM][39m [36m[websocket][39m [90msendData {\"topic\":\"get\",\"service\":\"HumiditySensor\",\"payload\":{\"name\":\"Feuchtigkeit Bad\",\"characteristic\":\"CurrentRelativeHumidity\"}}[39m
2017-02-18 12:51:17,stdout, [33;1mAccessory [0m[Homebridge] Getting value for Characteristic "Current Relative Humidity" [33m+1ms[0m
2017-02-18 12:51:17,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: GET /characteristics?id=2.9 [35m+1ms[0m
2017-02-18 12:51:17,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP request: /characteristics?id=2.9 [35m+6s[0m
2017-02-18 12:51:11,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.29] HTTP Response is finished [35m+0ms[0m
2017-02-18 12:51:11,stdout, [33;1mAccessory [0m[Homebridge] Registering Characteristic "Category" for events [33m+0ms[0m
2017-02-18 12:51:11,stdout, [33;1mAccessory [0m[Homebridge] Registering Characteristic "Reachable" for events [33m+0ms[0m
2017-02-18 12:51:11,stdout," [33;1mAccessory [0m[Homebridge] Processing characteristic set: [{\"aid\":2,\"iid\":11,\"ev\":true},{\"aid\":2,\"iid\":14,\"ev\":true}] [33m+1ms[0m"
2017-02-18 12:51:11,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: PUT /characteristics [35m+0ms[0m
2017-02-18 12:51:11,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.29] HTTP request: /characteristics [35m+22ms[0m
2017-02-18 12:51:11,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.29] HTTP Response is finished [35m+31ms[0m
2017-02-18 12:51:11,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: GET /accessories [35m+0ms[0m
2017-02-18 12:51:11,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.29] HTTP request: /accessories [35m+4s[0m
2017-02-18 12:51:09,stdout,"[37m[2/18/2017, 12:51:09 PM][39m [36m[websocket][39m [90mcallback {\"name\":\"Feuchtigkeit Bad\",\"characteristic\":\"CurrentRelativeHumidity\",\"value\":50}[39m"
2017-02-18 12:51:07,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP Response is finished [35m+2ms[0m
2017-02-18 12:51:07,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] Muting event '2.9' notification for this connection since it originated here. [35m+1ms[0m
2017-02-18 12:51:07,stdout, [33;1mAccessory [0m[Homebridge] Got Characteristic "Current Relative Humidity" value: 50 [33m+247ms[0m
2017-02-18 12:51:07,stdout,"[37m[2/18/2017, 12:51:07 PM][39m [36m[websocket][39m [90mcallback {\"name\":\"Feuchtigkeit Bad\",\"characteristic\":\"CurrentRelativeHumidity\",\"value\":50}[39m"
2017-02-18 12:51:07,stdout,"[37m[2/18/2017, 12:51:07 PM][39m [36m[websocket][39m [90msendData {\"topic\":\"get\",\"service\":\"HumiditySensor\",\"payload\":{\"name\":\"Feuchtigkeit Bad\",\"characteristic\":\"CurrentRelativeHumidity\"}}[39m"
2017-02-18 12:51:07,stdout, [33;1mAccessory [0m[Homebridge] Getting value for Characteristic "Current Relative Humidity" [33m+1ms[0m
2017-02-18 12:51:07,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: GET /characteristics?id=2.9 [35m+0ms[0m
2017-02-18 12:51:07,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP request: /characteristics?id=2.9 [35m+125ms[0m
2017-02-18 12:51:07,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP Response is finished [35m+1ms[0m
2017-02-18 12:51:07,stdout, [33;1mAccessory [0m[Homebridge] Error getting value for Characteristic "Current Relative Humidity": undefined [33m+0ms[0m
2017-02-18 12:51:07,stdout, [33;1mAccessory [0m[Homebridge] Got Characteristic "Current Relative Humidity" value: undefined [33m+1s[0m
2017-02-18 12:51:07,stdout,"[37m[2/18/2017, 12:51:07 PM][39m [36m[websocket][39m [90mget timeout Feuchtigkeit Bad CurrentRelativeHumidity[39m"
2017-02-18 12:51:06,stdout,"[37m[2/18/2017, 12:51:06 PM][39m [36m[websocket][39m [90msendData {\"topic\":\"get\",\"service\":\"HumiditySensor\",\"payload\":{\"name\":\"Feuchtigkeit Bad\",\"characteristic\":\"CurrentRelativeHumidity\"}}[39m"
2017-02-18 12:51:06,stdout, [33;1mAccessory [0m[Homebridge] Getting value for Characteristic "Current Relative Humidity" [33m+2ms[0m
2017-02-18 12:51:06,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: GET /characteristics?id=2.9 [35m+1ms[0m
2017-02-18 12:51:06,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP request: /characteristics?id=2.9 [35m+14ms[0m
2017-02-18 12:51:06,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP Response is finished [35m+1ms[0m
2017-02-18 12:51:06,stdout, [33;1mAccessory [0m[Homebridge] Registering Characteristic "Current Relative Humidity" for events [33m+0ms[0m
2017-02-18 12:51:06,stdout," [33;1mAccessory [0m[Homebridge] Processing characteristic set: [{\"aid\":2,\"iid\":9,\"ev\":true}] [33m+0ms[0m"
2017-02-18 12:51:06,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: PUT /characteristics [35m+0ms[0m
2017-02-18 12:51:06,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP request: /characteristics [35m+185ms[0m
2017-02-18 12:51:05,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP Response is finished [35m+0ms[0m
2017-02-18 12:51:05,stdout, [33;1mAccessory [0m[Homebridge] Registering Characteristic "Category" for events [33m+1ms[0m
2017-02-18 12:51:05,stdout, [33;1mAccessory [0m[Homebridge] Registering Characteristic "Reachable" for events [33m+0ms[0m
2017-02-18 12:51:05,stdout," [33;1mAccessory [0m[Homebridge] Processing characteristic set: [{\"aid\":2,\"iid\":11,\"ev\":true},{\"aid\":2,\"iid\":14,\"ev\":true}] [33m+1ms[0m"
2017-02-18 12:51:05,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: PUT /characteristics [35m+0ms[0m
2017-02-18 12:51:05,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP request: /characteristics [35m+17ms[0m
2017-02-18 12:51:05,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.2] HTTP Response is finished [35m+1ms[0m
2017-02-18 12:51:05,stdout, [33;1mAccessory [0m[Homebridge] Registering Characteristic "Category" for events [33m+0ms[0m
2017-02-18 12:51:05,stdout," [33;1mAccessory [0m[Homebridge] Processing characteristic set: [{\"aid\":2,\"iid\":11,\"ev\":true},{\"aid\":2,\"iid\":14,\"ev\":true}] [33m+0ms[0m"
2017-02-18 12:51:05,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: PUT /characteristics [35m+1ms[0m
2017-02-18 12:51:05,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.2] HTTP request: /characteristics [35m+8ms[0m
2017-02-18 12:51:05,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP Response is finished [35m+2ms[0m
2017-02-18 12:51:05,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: GET /accessories [35m+1ms[0m
2017-02-18 12:51:05,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP request: /accessories [35m+3ms[0m
2017-02-18 12:51:05,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.2] HTTP Response is finished [35m+2ms[0m
2017-02-18 12:51:05,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.2] HTTP request: /accessories [35m+49ms[0m
2017-02-18 12:51:05,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.25] HTTP Response is finished [35m+1ms[0m
2017-02-18 12:51:05,stdout, [33;1mAccessory [0m[Homebridge] Registering Characteristic "Reachable" for events [33m+2ms[0m
2017-02-18 12:51:05,stdout," [33;1mAccessory [0m[Homebridge] Processing characteristic set: [{\"aid\":2,\"iid\":11,\"ev\":true},{\"aid\":2,\"iid\":14,\"ev\":true}] [33m+4ms[0m"
2017-02-18 12:51:05,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.25] HTTP request: /characteristics [35m+30ms[0m
2017-02-18 12:51:05,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.25] HTTP Response is finished [35m+20ms[0m
2017-02-18 12:51:05,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: GET /accessories [35m+0ms[0m
2017-02-18 12:51:05,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.25] HTTP request: /accessories [35m+2m[0m
2017-02-18 12:51:04,stdout,"[37m[2/18/2017, 12:51:04 PM][39m [36m[websocket][39m [90msendData {\"topic\":\"response\",\"payload\":{\"ack\":true,\"message\":\"accessory 'Feuchtigkeit Bad' is added.\"}}[39m"
2017-02-18 12:51:04,stdout,"[37m[2/18/2017, 12:51:04 PM][39m [36m[websocket][39m addAccessory accessory 'Feuchtigkeit Bad' is added."
2017-02-18 12:51:04,stdout,"[37m[2/18/2017, 12:51:04 PM][39m [36m[websocket][39m [90mAccessory.configureAccessory Def {\"name\":\"Feuchtigkeit Bad\",\"service\":\"HumiditySensor\"}[39m"
2017-02-18 12:51:04,stdout,}[39m
2017-02-18 12:51:04,stdout, "service": "HumiditySensor"
2017-02-18 12:51:04,stdout," \"name\": \"Feuchtigkeit Bad\","
2017-02-18 12:51:04,stdout,"[37m[2/18/2017, 12:51:04 PM][39m [36m[websocket][39m [90monMessage add {"
2017-02-18 12:50:17,stdout,"[37m[2/18/2017, 12:50:17 PM][39m [36m[websocket][39m client ip ::ffff:192.168.5.56 connected"
2017-02-18 12:50:16,stdout,"[37m[2/18/2017, 12:50:16 PM][39m [36m[websocket][39m on.close client ip ::ffff:192.168.5.56 disconnected"
2017-02-18 12:50:14,stdout,"[37m[2/18/2017, 12:50:14 PM][39m [36m[websocket][39m client ip ::ffff:192.168.5.56 connected"
2017-02-18 12:50:13,stdout,"[37m[2/18/2017, 12:50:13 PM][39m [36m[websocket][39m on.close client ip ::ffff:192.168.5.56 disconnected"
2017-02-18 12:50:08,stdout,"[37m[2/18/2017, 12:50:08 PM][39m [36m[websocket][39m client ip ::ffff:192.168.5.56 connected"
2017-02-18 12:49:12,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.2] HTTP Response is finished [35m+26ms[0m
2017-02-18 12:49:12,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: GET /accessories [35m+0ms[0m
2017-02-18 12:49:12,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.2] HTTP request: /accessories [35m+4ms[0m
2017-02-18 12:49:12,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.2] HTTP Response is finished [35m+1ms[0m
2017-02-18 12:49:12,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] Client DA5CF7A5-CE5C-4285-A2C2-1901D7BB005A verification complete [35m+5ms[0m
2017-02-18 12:49:12,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] Pair verify step 2/2 [35m+0ms[0m
2017-02-18 12:49:12,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: POST /pair-verify [35m+1ms[0m
2017-02-18 12:49:12,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.2] HTTP request: /pair-verify [35m+14ms[0m
2017-02-18 12:49:12,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.2] HTTP server was closed [35m+1ms[0m
2017-02-18 12:49:12,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.2] HTTP Response is finished [35m+6ms[0m
2017-02-18 12:49:12,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] Pair verify step 1/2 [35m+1ms[0m
2017-02-18 12:49:12,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: POST /pair-verify [35m+0ms[0m
2017-02-18 12:49:12,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.2] HTTP request: /pair-verify [35m+1ms[0m
2017-02-18 12:49:12,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.2] HTTP connection was closed [35m+1ms[0m
2017-02-18 12:49:12,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.2] Client connection closed [35m+2ms[0m
2017-02-18 12:49:12,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.2] HTTP server listening on port 41489 [35m+0ms[0m
2017-02-18 12:49:12,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.2] New connection from client [35m+1ms[0m
2017-02-18 12:49:12,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.2] HTTP server listening on port 34361 [35m+0ms[0m
2017-02-18 12:49:12,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.2] New connection from client [35m+5s[0m
2017-02-18 12:49:08,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.29] HTTP Response is finished [35m+28ms[0m
2017-02-18 12:49:08,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: GET /accessories [35m+1ms[0m
2017-02-18 12:49:08,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.29] HTTP request: /accessories [35m+3ms[0m
2017-02-18 12:49:08,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.29] HTTP Response is finished [35m+2ms[0m
2017-02-18 12:49:08,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] Client B93EF4B1-29B7-476A-8195-AFA8B9298CA5 verification complete [35m+1ms[0m
2017-02-18 12:49:08,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] Pair verify step 2/2 [35m+0ms[0m
2017-02-18 12:49:08,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: POST /pair-verify [35m+1ms[0m
2017-02-18 12:49:08,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.29] HTTP request: /pair-verify [35m+13ms[0m
2017-02-18 12:49:08,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.29] HTTP Response is finished [35m+4ms[0m
2017-02-18 12:49:08,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] Pair verify step 1/2 [35m+1ms[0m
2017-02-18 12:49:08,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: POST /pair-verify [35m+0ms[0m
2017-02-18 12:49:08,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.29] HTTP request: /pair-verify [35m+1ms[0m
2017-02-18 12:49:08,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.29] HTTP server was closed [35m+0ms[0m
2017-02-18 12:49:08,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.29] HTTP connection was closed [35m+1ms[0m
2017-02-18 12:49:08,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.29] Client connection closed [35m+1ms[0m
2017-02-18 12:49:08,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.29] HTTP server listening on port 41613 [35m+0ms[0m
2017-02-18 12:49:08,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.29] New connection from client [35m+1ms[0m
2017-02-18 12:49:08,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.29] HTTP server listening on port 40636 [35m+0ms[0m
2017-02-18 12:49:08,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.29] New connection from client [35m+18s[0m
2017-02-18 12:48:50,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP Response is finished [35m+2ms[0m
2017-02-18 12:48:50,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: GET /accessories [35m+0ms[0m
2017-02-18 12:48:50,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP request: /accessories [35m+4ms[0m
2017-02-18 12:48:50,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP Response is finished [35m+1ms[0m
2017-02-18 12:48:50,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] Client B93EF4B1-29B7-476A-8195-AFA8B9298CA5 verification complete [35m+2ms[0m
2017-02-18 12:48:50,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] Pair verify step 2/2 [35m+2ms[0m
2017-02-18 12:48:50,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: POST /pair-verify [35m+0ms[0m
2017-02-18 12:48:50,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP request: /pair-verify [35m+6ms[0m
2017-02-18 12:48:50,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.25] HTTP Response is finished [35m+20ms[0m
2017-02-18 12:48:50,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.25] HTTP request: /accessories [35m+5ms[0m
2017-02-18 12:48:50,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.25] HTTP Response is finished [35m+1ms[0m
2017-02-18 12:48:50,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] Pair verify step 2/2 [35m+1ms[0m
2017-02-18 12:48:50,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.25] HTTP request: /pair-verify [35m+2ms[0m
2017-02-18 12:48:50,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP server was closed [35m+2ms[0m
2017-02-18 12:48:50,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP Response is finished [35m+9ms[0m
2017-02-18 12:48:50,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] Pair verify step 1/2 [35m+1ms[0m
2017-02-18 12:48:50,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP request: /pair-verify [35m+3ms[0m
2017-02-18 12:48:50,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP connection was closed [35m+2ms[0m
2017-02-18 12:48:50,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] Client connection closed [35m+3ms[0m
2017-02-18 12:48:50,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP server listening on port 44897 [35m+0ms[0m
2017-02-18 12:48:50,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] New connection from client [35m+2ms[0m
2017-02-18 12:48:50,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP server listening on port 42315 [35m+1ms[0m
2017-02-18 12:48:50,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] New connection from client [35m+3ms[0m
2017-02-18 12:48:50,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.25] HTTP Response is finished [35m+22ms[0m
2017-02-18 12:48:49,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] Pair verify step 1/2 [35m+7ms[0m
2017-02-18 12:48:49,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: POST /pair-verify [35m+0ms[0m
2017-02-18 12:48:49,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.25] HTTP request: /pair-verify [35m+14ms[0m
2017-02-18 12:48:49,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.25] HTTP server listening on port 49228 [35m+2ms[0m
2017-02-18 12:48:49,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.25] New connection from client [35m+2s[0m
2017-02-18 12:48:49,stdout,"[37m[2/18/2017, 12:48:49 PM][39m [36m[websocket][39m A new version 0.1.12 is avaiable
2017-02-18 12:48:48,stdout,"[37m[2/18/2017, 12:48:48 PM][39m [36m[websocket][39m url {\"address\":\"::\",\"family\":\"IPv6\",\"port\":4050}"
2017-02-18 12:48:48,stdout,"[37m[2/18/2017, 12:48:48 PM][39m Homebridge is running on port 51826."
2017-02-18 12:48:48,stdout, [35;1mEventedHTTPServer [0mServer listening on port 51826 [35m+0ms[0m
2017-02-18 12:48:48,stdout,"[37m[2/18/2017, 12:48:48 PM][39m [36m[websocket][39m Number of Accessories: 0"
2017-02-18 12:48:48,stdout,"[37m[2/18/2017, 12:48:48 PM][39m [36m[websocket][39m [90mNumber of chaced Accessories: 0[39m"
2017-02-18 12:48:48,stdout,"[37m[2/18/2017, 12:48:48 PM][39m [36m[websocket][39m Plugin - DidFinishLaunching"
2017-02-18 12:48:47,stdout,[30m[47m [49m[39m
2017-02-18 12:48:47,stdout,[30m[47m └────────────┘ [49m[39m
2017-02-18 12:48:47,stdout,[30m[47m │ 031-45-154 │ [49m[39m
2017-02-18 12:48:47,stdout,[30m[47m ┌────────────┐ [49m[39m
2017-02-18 12:48:47,stdout,Scan this code with your HomeKit App on your iOS device to pair with Homebridge:
2017-02-18 12:48:47,stdout,"[37m[2/18/2017, 12:48:47 PM][39m [36m[websocket][39m homebridge-websocket v0.1.11"
2017-02-18 12:48:47,stdout,"[37m[2/18/2017, 12:48:47 PM][39m [36m[websocket][39m [90mconfig = {\"platform\":\"websocket\",\"name\":\"websocket\",\"port\":4050}[39m"
2017-02-18 12:48:47,stdout,"[37m[2/18/2017, 12:48:47 PM][39m [36m[websocket][39m [90mstoragePath = /root/.homebridge[39m"
2017-02-18 12:48:47,stdout,"[37m[2/18/2017, 12:48:47 PM][39m [36m[websocket][39m Initializing websocket platform..."
2017-02-18 12:48:47,stdout,"[37m[2/18/2017, 12:48:47 PM][39m Loading 1 platforms..."
2017-02-18 12:48:47,stdout,"[37m[2/18/2017, 12:48:47 PM][39m ---"
2017-02-18 12:48:47,stdout,"[37m[2/18/2017, 12:48:47 PM][39m Loaded config.json with 0 accessories and 1 platforms."
2017-02-18 12:48:47,stdout,"[37m[2/18/2017, 12:48:47 PM][39m Registering platform 'homebridge-websocket.websocket'"
2017-02-18 12:48:47,stdout,homebridge API version: 2.1
2017-02-18 12:48:47,stdout,"[37m[2/18/2017, 12:48:47 PM][39m Loaded plugin: homebridge-websocket"
2017-02-18 12:48:47,stdout, [36;1mexpress:application [0mset "view cache" to [33mtrue[39m[36m +0ms[0m
2017-02-18 12:48:47,stdout, [36;1mexpress:application [0mset "jsonp callback name" to [32m'callback'[39m[36m +0ms[0m
2017-02-18 12:48:47,stdout, [36;1mexpress:application [0mset "views" to [32m'/root/.homebridge/views'[39m[36m +1ms[0m
2017-02-18 12:48:47,stdout, [36;1mexpress:application [0mset "view" to [36m[Function: View][39m[36m +0ms[0m
2017-02-18 12:48:47,stdout, [36;1mexpress:application [0mbooting in production mode[36m +0ms[0m
2017-02-18 12:48:47,stdout, [36;1mexpress:application [0mset "trust proxy fn" to [36m[Function: trustNone][39m[36m +1ms[0m
2017-02-18 12:48:47,stdout, [36;1mexpress:application [0mset "trust proxy" to [33mfalse[39m[36m +1ms[0m
2017-02-18 12:48:47,stdout, [36;1mexpress:application [0mset "subdomain offset" to [33m2[39m[36m +0ms[0m
2017-02-18 12:48:47,stdout, [36;1mexpress:application [0mset "query parser fn" to [36m[Function: parseExtendedQueryString][39m[36m +1ms[0m
2017-02-18 12:48:47,stdout, [36;1mexpress:application [0mset "query parser" to [32m'extended'[39m[36m +0ms[0m
2017-02-18 12:48:47,stdout, [36;1mexpress:application [0mset "env" to [32m'production'[39m[36m +1ms[0m
2017-02-18 12:48:47,stdout, [36;1mexpress:application [0mset "etag fn" to [36m[Function: wetag][39m[36m +3ms[0m
2017-02-18 12:48:47,stdout, [36;1mexpress:application [0mset "etag" to [32m'weak'[39m[36m +8ms[0m
2017-02-18 12:48:47,stdout, [36;1mexpress:application [0mset "x-powered-by" to [33mtrue[39m[36m +0ms[0m
2017-02-18 12:48:45,stdout,*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=nodejs&f=DNSServiceRegister>
2017-02-18 12:48:45,stdout,*** WARNING *** Please fix your application to use the native API of Avahi!
2017-02-18 12:48:45,stdout,*** WARNING *** The program 'nodejs' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
2017-02-18 12:48:45,stdout,*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=nodejs>
2017-02-18 12:48:45,stdout,*** WARNING *** The program 'nodejs' uses the Apple Bonjour compatibility layer of Avahi.
2017-02-18 12:48:45,stdout,`-- [40m[33mhomebridge-websocket@0.1.11[39m[49m (git+https://github.com/Schnittcher/homebridge-websocket.git#21e0c9d1df10fd81ee237151b1bd1e019f670447)
2017-02-18 12:48:45,stdout,"[?25l[[90m..................[0m] - normalizeTree: [7msill[0m [35minstall[0m loadCurrentTree[K
[[90m..................[0m] \ normalizeTree: [7msill[0m [35minstall[0m loadCurrentTree[K
[K[?25h[?25l[[90m..................[0m] \ normalizeTree: [32minfo[0m [35mgit[0m [ 'submodule', '-q', 'update', '[K
[[90m..................[0m] - normalizeTree: [32minfo[0m [35mgit[0m [ 'submodule', '-q', 'update', '[K
[[7m [27m[90m...............[0m] \ cloneCurrentTree: [7msill[0m [35mcloneCurrentTree[0m Finishing[K
[[7m [27m[90m..............[0m] \ loadRequestedDeps: [7msill[0m [35minstall[0m loadAllDepsIntoIdealTree[K
[[7m [27m[90m..............[0m] | fetchMetadata: [7msill[0m [35mmapToRegistry[0m uri https://registry.n[K
[[7m [27m[90m..............[0m] \ fetchMetadata: [7msill[0m [35mmapToRegistry[0m uri https://registry.n[K
[[7m [27m[90m..............[0m] - fetchMetadata: [7msill[0m [35mmapToRegistry[0m uri https://registry.n[K
[[7m [27m[90m..............[0m] / fetchMetadata: [7msill[0m [35mmapToRegistry[0m uri https://registry.n[K
[[7m [27m[90m..............[0m] \ fetchMetadata: [34;40mverb[0m [35mafterAdd[0m /root/.npm/negotiator/0.6.1[K
[[7m [27m[90m.............[0m] | fetchMetadata: [7msill[0m [35mmapToRegistry[0m uri https://registry.n[K
[[7m [27m[90m.............[0m] / fetchMetadata: [7msill[0m [35mmapToRegistry[0m uri https://registry.n[K
[[7m [27m[90m.............[0m] | fetchMetadata: [34;40mverb[0m [35mafterAdd[0m /root/.npm/setprototypeof/1[K
[[7m [27m[90m.............[0m] - fetchMetadata: [7msill[0m [35mmapToRegistry[0m uri https://registry.n[K
[[7m [27m[90m.............[0m] \ fetchMetadata: [7msill[0m [35mmapToRegistry[0m uri https://registry.n[K
[[7m [27m[90m.............[0m] \ fetchMetadata: [34;40mverb[0m [35mafterAdd[0m /root/.npm/uuid/3.0.1/packa[K
[[7m [27m[90m.............[0m] \ fetchMetadata: [34;40mverb[0m [35mafterAdd[0m /root/.npm/delayed-stream/1[K
[[7m [27m[90m.............[0m] - fetchMetadata: [34;40mverb[0m [35mafterAdd[0m /root/.npm/supports-color/2[K
[[7m [27m[90m.............[0m] \ fetchMetadata: [34;40mverb[0m [35mafterAdd[0m /root/.npm/ansi-regex/2.1.1[K
[[7m [27m[90m.............[0m] | fetchMetadata: [34;40mverb[0m [35mafterAdd[0m /root/.npm/is-property/1.0.[K
[[7m [27m[90m.............[0m] | fetchMetadata: [34;40mverb[0m [35mafterAdd[0m /root/.npm/assert-plus/1.0.[K
[[7m [27m[90m............[0m] / fetchMetadata: [34;40mverb[0m [35mafterAdd[0m /root/.npm/assert-plus/1.0.[K
[[7m [27m[90m............[0m] \ fetchMetadata: [7msill[0m [35mmapToRegistry[0m uri https://registry.n[K
[[7m [27m[90m............[0m] / fetchMetadata: [7msill[0m [35mmapToRegistry[0m uri https://registry.n[K
[[7m [27m[90m............[0m] | fetchMetadata: [34;40mverb[0m [35mafterAdd[0m /root/.npm/nan/2.5.1/packag[K
[[7m [27m[90m............[0m] / fetchMetadata: [34;40mverb[0m [35mafterAdd[0m /root/.npm/nan/2.5.1/packag[K
[[7m [27m[90m........[0m] \ diffTrees: [7msill[0m [35minstall[0m generateActionsToTake[K
[[7m [27m[90m.....[0m] / fetch: [7msill[0m [35mdoParallel[0m fetch 1[K
[[7m [27m[90m.....[0m] \ extract:homebridge-websocket: [7msill[0m [35mdoParallel[0m extract 1[K
[[7m [27m[90m...[0m] | postinstall:homebridge-websocket: [7msill[0m [35mdoSerial[0m postinst[K
[K[?25h/usr/lib"
2017-02-18 12:48:37,stdout,Installing plugins from /root/.homebridge/install.sh.
2017-02-18 12:48:37,stdout,[?25l[[90m..................[0m] - : [32minfo[0m [35musing[0m node@v6.7.0[K
[[90m..................[0m] \ : [32minfo[0m [35musing[0m node@v6.7.0[K
[[90m..................[0m] | : [32minfo[0m [35musing[0m node@v6.7.0[K
[K[?25h/root/.homebridge/package.json not found.
2017-02-18 12:48:32,stdout,Updating Homebridge.
2017-02-18 12:48:32,stdout,Environment is set to debug.
2017-02-18 12:48:32,stdout,Including environment variables from /root/.homebridge/.env.
2017-02-18 12:48:32,stdout,root
2017-02-18 12:48:32,stdout,Logged in as:
WebSocketClient
TXT: 18.02.2017 13:55:59.00 | ReceivePacket | {{"topic":"get","service":"HumiditySensor","payload":{"name":"Feuchtigkeit Bad","characteristic":"CurrentRelativeHumidity"}}
HEX: 18.02.2017 13:55:59.00 | ReceivePacket | 81 7B 7B 22 74 6F 70 69 63 22 3A 22 67 65 74 22 2C 22 73 65 72 76 69 63 65 22 3A 22 48 75 6D 69 64 69 74 79 53 65 6E 73 6F 72 22 2C 22 70 61 79 6C 6F 61 64 22 3A 7B 22 6E 61 6D 65 22 3A 22 46 65 75 63 68 74 69 67 6B 65 69 74 20 42 61 64 22 2C 22 63 68 61 72 61 63 74 65 72 69 73 74 69 63 22 3A 22 43 75 72 72 65 6E 74 52 65 6C 61 74 69 76 65 48 75 6D 69 64 69 74 79 22 7D 7D
TXT: 18.02.2017 13:55:59.00 | Receive FIN | true
HEX: 18.02.2017 13:55:59.00 | Receive FIN | 74 72 75 65
TXT: 18.02.2017 13:55:59.00 | Receive OpCode | text
HEX: 18.02.2017 13:55:59.00 | Receive OpCode | 74 65 78 74
TXT: 18.02.2017 13:55:59.00 | Receive Mask | false
HEX: 18.02.2017 13:55:59.00 | Receive Mask | 66 61 6C 73 65
TXT: 18.02.2017 13:55:59.00 | Receive Payload | {"topic":"get","service":"HumiditySensor","payload":{"name":"Feuchtigkeit Bad","characteristic":"CurrentRelativeHumidity"}}
HEX: 18.02.2017 13:55:59.00 | Receive Payload | 7B 22 74 6F 70 69 63 22 3A 22 67 65 74 22 2C 22 73 65 72 76 69 63 65 22 3A 22 48 75 6D 69 64 69 74 79 53 65 6E 73 6F 72 22 2C 22 70 61 79 6C 6F 61 64 22 3A 7B 22 6E 61 6D 65 22 3A 22 46 65 75 63 68 74 69 67 6B 65 69 74 20 42 61 64 22 2C 22 63 68 61 72 61 63 74 65 72 69 73 74 69 63 22 3A 22 43 75 72 72 65 6E 74 52 65 6C 61 74 69 76 65 48 75 6D 69 64 69 74 79 22 7D 7D
TXT: 18.02.2017 13:56:01.00 | Send FIN | true
HEX: 18.02.2017 13:56:01.00 | Send FIN | 74 72 75 65
TXT: 18.02.2017 13:56:01.00 | Send OpCode | text
HEX: 18.02.2017 13:56:01.00 | Send OpCode | 74 65 78 74
TXT: 18.02.2017 13:56:01.00 | Send Mask | true
HEX: 18.02.2017 13:56:01.00 | Send Mask | 74 72 75 65
TXT: 18.02.2017 13:56:01.00 | Send MaskKey | <VT>èåù
HEX: 18.02.2017 13:56:01.00 | Send MaskKey | 0B E8 E5 F9
TXT: 18.02.2017 13:56:01.00 | Send Payload | pÊ??{?Û1ÈÇ?j???j??Û'ÈÇ?j???j?ÇÃ+?Ç?j??Û1ÈÇ¿n??<DEL>??n?ÙI?Û'ÈÇ?c???h???b??hÊßÙ)«?y?Y??<DEL>??C?o??)ÄÅÛ}???nÊßÙ?ßËÉ;??
HEX: 18.02.2017 13:56:01.00 | Send Payload | 70 CA 91 96 7B 81 86 DB 31 C8 C7 9A 6A 84 89 9B 6A 8B 8E DB 27 C8 C7 89 6A 91 89 96 6A 8C C7 C3 2B 93 C7 97 6A 85 80 DB 31 C8 C7 BF 6E 9D 86 91 7F 81 82 92 6E 81 91 D9 49 89 81 DB 27 C8 C7 9A 63 89 97 98 68 9C 80 8B 62 9B 91 90 68 CA DF D9 29 AB 90 8B 79 8D 8B 8D 59 8D 89 98 7F 81 93 9C 43 9D 88 90 6F 81 91 80 29 C4 C5 DB 7D 89 89 8C 6E CA DF D9 3F DF CB C9 3B 95 98
TXT: 18.02.2017 13:56:01.00 | Send PayloadRAW | {"topic": "callback", "payload": {"name": "Feuchtigkeit Bad", "characteristic": "CurrentRelativeHumidity", "value": 47.00}}
HEX: 18.02.2017 13:56:01.00 | Send PayloadRAW | 7B 22 74 6F 70 69 63 22 3A 20 22 63 61 6C 6C 62 61 63 6B 22 2C 20 22 70 61 79 6C 6F 61 64 22 3A 20 7B 22 6E 61 6D 65 22 3A 20 22 46 65 75 63 68 74 69 67 6B 65 69 74 20 42 61 64 22 2C 20 22 63 68 61 72 61 63 74 65 72 69 73 74 69 63 22 3A 20 22 43 75 72 72 65 6E 74 52 65 6C 61 74 69 76 65 48 75 6D 69 64 69 74 79 22 2C 20 22 76 61 6C 75 65 22 3A 20 34 37 2E 30 30 7D 7D
TXT: 18.02.2017 13:56:01.00 | Send Packet | û<VT>èåùpÊ??{?Û1ÈÇ?j???j??Û'ÈÇ?j???j?ÇÃ+?Ç?j??Û1ÈÇ¿n??<DEL>??n?ÙI?Û'ÈÇ?c???h???b??hÊßÙ)«?y?Y??<DEL>??C?o??)ÄÅÛ}???nÊßÙ?ßËÉ;??
HEX: 18.02.2017 13:56:01.00 | Send Packet | 81 FB 0B E8 E5 F9 70 CA 91 96 7B 81 86 DB 31 C8 C7 9A 6A 84 89 9B 6A 8B 8E DB 27 C8 C7 89 6A 91 89 96 6A 8C C7 C3 2B 93 C7 97 6A 85 80 DB 31 C8 C7 BF 6E 9D 86 91 7F 81 82 92 6E 81 91 D9 49 89 81 DB 27 C8 C7 9A 63 89 97 98 68 9C 80 8B 62 9B 91 90 68 CA DF D9 29 AB 90 8B 79 8D 8B 8D 59 8D 89 98 7F 81 93 9C 43 9D 88 90 6F 81 91 80 29 C4 C5 DB 7D 89 89 8C 6E CA DF D9 3F DF CB C9 3B 95 98
WebSoceektClientSocket
TXT: 18.02.2017 13:55:58.00 | RECEIVED | {{"topic":"get","service":"HumiditySensor","payload":{"name":"Feuchtigkeit Bad","characteristic":"CurrentRelativeHumidity"}}
HEX: 18.02.2017 13:55:58.00 | RECEIVED | 81 7B 7B 22 74 6F 70 69 63 22 3A 22 67 65 74 22 2C 22 73 65 72 76 69 63 65 22 3A 22 48 75 6D 69 64 69 74 79 53 65 6E 73 6F 72 22 2C 22 70 61 79 6C 6F 61 64 22 3A 7B 22 6E 61 6D 65 22 3A 22 46 65 75 63 68 74 69 67 6B 65 69 74 20 42 61 64 22 2C 22 63 68 61 72 61 63 74 65 72 69 73 74 69 63 22 3A 22 43 75 72 72 65 6E 74 52 65 6C 61 74 69 76 65 48 75 6D 69 64 69 74 79 22 7D 7D
TXT: 18.02.2017 13:56:01.00 | TRANSMIT | û<VT>èåùpÊ??{?Û1ÈÇ?j???j??Û'ÈÇ?j???j?ÇÃ+?Ç?j??Û1ÈÇ¿n??<DEL>??n?ÙI?Û'ÈÇ?c???h???b??hÊßÙ)«?y?Y??<DEL>??C?o??)ÄÅÛ}???nÊßÙ?ßËÉ;??
HEX: 18.02.2017 13:56:01.00 | TRANSMIT | 81 FB 0B E8 E5 F9 70 CA 91 96 7B 81 86 DB 31 C8 C7 9A 6A 84 89 9B 6A 8B 8E DB 27 C8 C7 89 6A 91 89 96 6A 8C C7 C3 2B 93 C7 97 6A 85 80 DB 31 C8 C7 BF 6E 9D 86 91 7F 81 82 92 6E 81 91 D9 49 89 81 DB 27 C8 C7 9A 63 89 97 98 68 9C 80 8B 62 9B 91 90 68 CA DF D9 29 AB 90 8B 79 8D 8B 8D 59 8D 89 98 7F 81 93 9C 43 9D 88 90 6F 81 91 80 29 C4 C5 DB 7D 89 89 8C 6E CA DF D9 3F DF CB C9 3B 95 98
Ich werde das gleiche auch noch mal für Temperatursensoren machen, bei denen ich das gleiche Verhalten habe.
und hier zwei zusätzlich registrierte Temperatursensoren:
Temeratur Bad = Homematic
Temperatur Dach = Dummy Instanz + Float (Solarsensor UVR1611)
Nach dem aktivieren der WebSocketClient Socket sind beide Sensoren zügig in EVE angezeigt worden, aber noch ohne Wert. Nach ca. 1 Minute ist dann ein Wert für Bad erschienen.
Abfrage Temp. Bad Siri: Das kann ich leider nicht machen
Abfrage Temp Dach Siri: Das kann ich leider nciht machen (wurde in EVE aber auch noch kein Wert angezeigt)
Homebridge:
2017-02-18 13:29:10,stdout,"[37m[2/18/2017, 1:29:10 PM][39m [36m[websocket][39m [90mcallback {\"name\":\"Temperatur Dach\",\"characteristic\":\"CurrentTemperature\",\"value\":17.6}[39m"
2017-02-18 13:29:09,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP Response is finished [35m+1ms[0m
2017-02-18 13:29:09,stdout, [33;1mAccessory [0m[Homebridge] Error getting value for Characteristic "Current Temperature": undefined [33m+0ms[0m
2017-02-18 13:29:09,stdout, [33;1mAccessory [0m[Homebridge] Got Characteristic "Current Temperature" value: undefined [33m+1s[0m
2017-02-18 13:29:09,stdout,"[37m[2/18/2017, 1:29:09 PM][39m [36m[websocket][39m [90mget timeout Temperatur Dach CurrentTemperature[39m"
2017-02-18 13:29:08,stdout,"[37m[2/18/2017, 1:29:08 PM][39m [36m[websocket][39m [90msendData {\"topic\":\"get\",\"service\":\"TemperatureSensor\",\"payload\":{\"name\":\"Temperatur Dach\",\"characteristic\":\"CurrentTemperature\"}}[39m"
2017-02-18 13:29:08,stdout, [33;1mAccessory [0m[Homebridge] Getting value for Characteristic "Current Temperature" [33m+1ms[0m
2017-02-18 13:29:08,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: GET /characteristics?id=4.9 [35m+0ms[0m
2017-02-18 13:29:08,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP request: /characteristics?id=4.9 [35m+6s[0m
2017-02-18 13:29:02,stdout,"[37m[2/18/2017, 1:29:02 PM][39m [36m[websocket][39m [90mcallback {\"name\":\"Temperatur Bad\",\"characteristic\":\"CurrentTemperature\",\"value\":18.2}[39m"
2017-02-18 13:29:02,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP Response is finished [35m+1ms[0m
2017-02-18 13:29:02,stdout, [33;1mAccessory [0m[Homebridge] Error getting value for Characteristic "Current Temperature": undefined [33m+0ms[0m
2017-02-18 13:29:02,stdout, [33;1mAccessory [0m[Homebridge] Got Characteristic "Current Temperature" value: undefined [33m+1s[0m
2017-02-18 13:29:02,stdout,"[37m[2/18/2017, 1:29:02 PM][39m [36m[websocket][39m [90mget timeout Temperatur Bad CurrentTemperature[39m"
2017-02-18 13:29:01,stdout,"[37m[2/18/2017, 1:29:01 PM][39m [36m[websocket][39m [90msendData {\"topic\":\"get\",\"service\":\"TemperatureSensor\",\"payload\":{\"name\":\"Temperatur Bad\",\"characteristic\":\"CurrentTemperature\"}}[39m"
2017-02-18 13:29:01,stdout, [33;1mAccessory [0m[Homebridge] Getting value for Characteristic "Current Temperature" [33m+0ms[0m
2017-02-18 13:29:01,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: GET /characteristics?id=3.9 [35m+1ms[0m
2017-02-18 13:29:01,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP request: /characteristics?id=3.9 [35m+51s[0m
2017-02-18 13:28:09,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.29] HTTP Response is finished [35m+0ms[0m
2017-02-18 13:28:09,stdout, [33;1mAccessory [0m[Homebridge] Registering Characteristic "Category" for events [33m+0ms[0m
2017-02-18 13:28:09,stdout, [33;1mAccessory [0m[Homebridge] Registering Characteristic "Reachable" for events [33m+0ms[0m
2017-02-18 13:28:09,stdout, [33;1mAccessory [0m[Homebridge] Registering Characteristic "Category" for events [33m+1ms[0m
2017-02-18 13:28:09,stdout," [33;1mAccessory [0m[Homebridge] Processing characteristic set: [{\"aid\":2,\"iid\":11,\"ev\":true},{\"aid\":2,\"iid\":14,\"ev\":true},{\"aid\":3,\"iid\":11,\"ev\":true},{\"aid\":3,\"iid\":14,\"ev\":true},{\"aid\":4,\"iid\":11,\"ev\":true},{\"aid\":4,\"iid\":14,\"ev\":true}] [33m+1ms[0m"
2017-02-18 13:28:09,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: PUT /characteristics [35m+0ms[0m
2017-02-18 13:28:09,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.29] HTTP request: /characteristics [35m+48ms[0m
2017-02-18 13:28:09,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.29] HTTP Response is finished [35m+37ms[0m
2017-02-18 13:28:09,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: GET /accessories [35m+3ms[0m
2017-02-18 13:28:09,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.29] HTTP request: /accessories [35m+7ms[0m
2017-02-18 13:28:09,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.29] HTTP Response is finished [35m+1ms[0m
2017-02-18 13:28:09,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] Client B93EF4B1-29B7-476A-8195-AFA8B9298CA5 verification complete [35m+1ms[0m
2017-02-18 13:28:09,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] Pair verify step 2/2 [35m+1ms[0m
2017-02-18 13:28:09,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: POST /pair-verify [35m+0ms[0m
2017-02-18 13:28:09,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.29] HTTP request: /pair-verify [35m+21ms[0m
2017-02-18 13:28:09,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.29] HTTP Response is finished [35m+2ms[0m
2017-02-18 13:28:09,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] Pair verify step 1/2 [35m+1ms[0m
2017-02-18 13:28:09,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.29] HTTP request: /pair-verify [35m+1ms[0m
2017-02-18 13:28:09,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.29] HTTP server was closed [35m+1ms[0m
2017-02-18 13:28:09,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.29] HTTP connection was closed [35m+1ms[0m
2017-02-18 13:28:09,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.29] Client connection closed [35m+2ms[0m
2017-02-18 13:28:09,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.29] HTTP server listening on port 59578 [35m+0ms[0m
2017-02-18 13:28:09,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.29] New connection from client [35m+6ms[0m
2017-02-18 13:28:09,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.29] HTTP server listening on port 54139 [35m+1ms[0m
2017-02-18 13:28:09,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.29] New connection from client [35m+13s[0m
2017-02-18 13:28:01,stdout,"[37m[2/18/2017, 1:28:01 PM][39m [36m[websocket][39m [90mcallback {\"name\":\"Temperatur Dach\",\"characteristic\":\"CurrentTemperature\",\"value\":17.6}[39m"
2017-02-18 13:27:58,stdout,"[37m[2/18/2017, 1:27:58 PM][39m [36m[websocket][39m [90mcallback {\"name\":\"Temperatur Bad\",\"characteristic\":\"CurrentTemperature\",\"value\":18.2}[39m"
2017-02-18 13:27:58,stdout,"[37m[2/18/2017, 1:27:58 PM][39m [36m[websocket][39m [90mcallback {\"name\":\"Feuchtigkeit Bad\",\"characteristic\":\"CurrentRelativeHumidity\",\"value\":45}[39m"
2017-02-18 13:27:56,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP Response is finished [35m+1ms[0m
2017-02-18 13:27:56,stdout, [33;1mAccessory [0m[Homebridge] Error getting value for Characteristic "Current Temperature": undefined [33m+0ms[0m
2017-02-18 13:27:56,stdout, [33;1mAccessory [0m[Homebridge] Got Characteristic "Current Temperature" value: undefined [33m+1s[0m
2017-02-18 13:27:56,stdout,"[37m[2/18/2017, 1:27:56 PM][39m [36m[websocket][39m [90mget timeout Temperatur Dach CurrentTemperature[39m"
2017-02-18 13:27:55,stdout,"[37m[2/18/2017, 1:27:55 PM][39m [36m[websocket][39m [90msendData {\"topic\":\"get\",\"service\":\"TemperatureSensor\",\"payload\":{\"name\":\"Temperatur Dach\",\"characteristic\":\"CurrentTemperature\"}}[39m"
2017-02-18 13:27:55,stdout, [33;1mAccessory [0m[Homebridge] Getting value for Characteristic "Current Temperature" [33m+0ms[0m
2017-02-18 13:27:55,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: GET /characteristics?id=4.9 [35m+0ms[0m
2017-02-18 13:27:55,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP request: /characteristics?id=4.9 [35m+6ms[0m
2017-02-18 13:27:55,stdout,"[37m[2/18/2017, 1:27:55 PM][39m [36m[websocket][39m [90mcallback {\"name\":\"Temperatur Dach\",\"characteristic\":\"CurrentTemperature\",\"value\":17.6}[39m"
2017-02-18 13:27:55,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP Response is finished [35m+0ms[0m
2017-02-18 13:27:55,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] Muting event '3.9' notification for this connection since it originated here. [35m+2ms[0m
2017-02-18 13:27:55,stdout, [33;1mAccessory [0m[Homebridge] Got Characteristic "Current Temperature" value: 18.2 [33m+124ms[0m
2017-02-18 13:27:55,stdout,"[37m[2/18/2017, 1:27:55 PM][39m [36m[websocket][39m [90mcallback {\"name\":\"Temperatur Bad\",\"characteristic\":\"CurrentTemperature\",\"value\":18.2}[39m"
2017-02-18 13:27:55,stdout,"[37m[2/18/2017, 1:27:55 PM][39m [36m[websocket][39m [90msendData {\"topic\":\"get\",\"service\":\"TemperatureSensor\",\"payload\":{\"name\":\"Temperatur Bad\",\"characteristic\":\"CurrentTemperature\"}}[39m"
2017-02-18 13:27:55,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: GET /characteristics?id=3.9 [35m+0ms[0m
2017-02-18 13:27:55,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP request: /characteristics?id=3.9 [35m+3ms[0m
2017-02-18 13:27:55,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP Response is finished [35m+2ms[0m
2017-02-18 13:27:55,stdout, [33;1mAccessory [0m[Homebridge] Error getting value for Characteristic "Current Relative Humidity": undefined [33m+0ms[0m
2017-02-18 13:27:55,stdout, [33;1mAccessory [0m[Homebridge] Got Characteristic "Current Relative Humidity" value: undefined [33m+1s[0m
2017-02-18 13:27:55,stdout,"[37m[2/18/2017, 1:27:55 PM][39m [36m[websocket][39m [90mget timeout Feuchtigkeit Bad CurrentRelativeHumidity[39m"
2017-02-18 13:27:54,stdout,"[37m[2/18/2017, 1:27:54 PM][39m [36m[websocket][39m [90msendData {\"topic\":\"get\",\"service\":\"HumiditySensor\",\"payload\":{\"name\":\"Feuchtigkeit Bad\",\"characteristic\":\"CurrentRelativeHumidity\"}}[39m"
2017-02-18 13:27:54,stdout, [33;1mAccessory [0m[Homebridge] Getting value for Characteristic "Current Relative Humidity" [33m+1ms[0m
2017-02-18 13:27:54,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: GET /characteristics?id=2.9 [35m+0ms[0m
2017-02-18 13:27:54,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP request: /characteristics?id=2.9 [35m+20ms[0m
2017-02-18 13:27:54,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP Response is finished [35m+0ms[0m
2017-02-18 13:27:54,stdout, [33;1mAccessory [0m[Homebridge] Error getting value for Characteristic "Current Temperature": undefined [33m+0ms[0m
2017-02-18 13:27:54,stdout, [33;1mAccessory [0m[Homebridge] Got Characteristic "Current Temperature" value: undefined [33m+1s[0m
2017-02-18 13:27:54,stdout,"[37m[2/18/2017, 1:27:54 PM][39m [36m[websocket][39m [90mget timeout Temperatur Dach CurrentTemperature[39m"
2017-02-18 13:27:53,stdout,"[37m[2/18/2017, 1:27:53 PM][39m [36m[websocket][39m [90mcallback {\"name\":\"Feuchtigkeit Bad\",\"characteristic\":\"CurrentRelativeHumidity\",\"value\":45}[39m"
2017-02-18 13:27:53,stdout,"[37m[2/18/2017, 1:27:53 PM][39m [36m[websocket][39m [90msendData {\"topic\":\"get\",\"service\":\"TemperatureSensor\",\"payload\":{\"name\":\"Temperatur Dach\",\"characteristic\":\"CurrentTemperature\"}}[39m"
2017-02-18 13:27:53,stdout, [33;1mAccessory [0m[Homebridge] Getting value for Characteristic "Current Temperature" [33m+0ms[0m
2017-02-18 13:27:53,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: GET /characteristics?id=4.9 [35m+0ms[0m
2017-02-18 13:27:53,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP request: /characteristics?id=4.9 [35m+5ms[0m
2017-02-18 13:27:53,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP Response is finished [35m+0ms[0m
2017-02-18 13:27:53,stdout, [33;1mAccessory [0m[Homebridge] Error getting value for Characteristic "Current Temperature": undefined [33m+0ms[0m
2017-02-18 13:27:53,stdout, [33;1mAccessory [0m[Homebridge] Got Characteristic "Current Temperature" value: undefined [33m+1s[0m
2017-02-18 13:27:53,stdout,"[37m[2/18/2017, 1:27:53 PM][39m [36m[websocket][39m [90mget timeout Temperatur Bad CurrentTemperature[39m"
2017-02-18 13:27:52,stdout,"[37m[2/18/2017, 1:27:52 PM][39m [36m[websocket][39m [90msendData {\"topic\":\"get\",\"service\":\"TemperatureSensor\",\"payload\":{\"name\":\"Temperatur Bad\",\"characteristic\":\"CurrentTemperature\"}}[39m"
2017-02-18 13:27:52,stdout, [33;1mAccessory [0m[Homebridge] Getting value for Characteristic "Current Temperature" [33m+1ms[0m
2017-02-18 13:27:52,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: GET /characteristics?id=3.9 [35m+0ms[0m
2017-02-18 13:27:52,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP request: /characteristics?id=3.9 [35m+4ms[0m
2017-02-18 13:27:52,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP Response is finished [35m+1ms[0m
2017-02-18 13:27:52,stdout, [33;1mAccessory [0m[Homebridge] Error getting value for Characteristic "Current Relative Humidity": undefined [33m+1ms[0m
2017-02-18 13:27:52,stdout, [33;1mAccessory [0m[Homebridge] Got Characteristic "Current Relative Humidity" value: undefined [33m+1s[0m
2017-02-18 13:27:52,stdout,"[37m[2/18/2017, 1:27:52 PM][39m [36m[websocket][39m [90mget timeout Feuchtigkeit Bad CurrentRelativeHumidity[39m"
2017-02-18 13:27:51,stdout,"[37m[2/18/2017, 1:27:51 PM][39m [36m[websocket][39m [90msendData {\"topic\":\"get\",\"service\":\"HumiditySensor\",\"payload\":{\"name\":\"Feuchtigkeit Bad\",\"characteristic\":\"CurrentRelativeHumidity\"}}[39m"
2017-02-18 13:27:51,stdout, [33;1mAccessory [0m[Homebridge] Getting value for Characteristic "Current Relative Humidity" [33m+3ms[0m
2017-02-18 13:27:51,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: GET /characteristics?id=2.9 [35m+0ms[0m
2017-02-18 13:27:51,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP request: /characteristics?id=2.9 [35m+3ms[0m
2017-02-18 13:27:51,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP Response is finished [35m+1ms[0m
2017-02-18 13:27:51,stdout, [33;1mAccessory [0m[Homebridge] Registering Characteristic "Current Temperature" for events [33m+0ms[0m
2017-02-18 13:27:51,stdout," [33;1mAccessory [0m[Homebridge] Processing characteristic set: [{\"aid\":4,\"iid\":9,\"ev\":true}] [33m+0ms[0m"
2017-02-18 13:27:51,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: PUT /characteristics [35m+0ms[0m
2017-02-18 13:27:51,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP request: /characteristics [35m+36ms[0m
2017-02-18 13:27:51,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP Response is finished [35m+0ms[0m
2017-02-18 13:27:51,stdout," [33;1mAccessory [0m[Homebridge] Processing characteristic set: [{\"aid\":3,\"iid\":9,\"ev\":true}] [33m+1ms[0m"
2017-02-18 13:27:51,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP request: /characteristics [35m+35ms[0m
2017-02-18 13:27:51,stdout, [33;1mAccessory [0m[Homebridge] Registering Characteristic "Current Relative Humidity" for events [33m+1ms[0m
2017-02-18 13:27:51,stdout," [33;1mAccessory [0m[Homebridge] Processing characteristic set: [{\"aid\":2,\"iid\":9,\"ev\":true}] [33m+1ms[0m"
2017-02-18 13:27:51,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP request: /characteristics [35m+64ms[0m
2017-02-18 13:27:51,stdout, [33;1mAccessory [0m[Homebridge] Registering Characteristic "Category" for events [33m+1ms[0m
2017-02-18 13:27:51,stdout, [33;1mAccessory [0m[Homebridge] Registering Characteristic "Reachable" for events [33m+0ms[0m
2017-02-18 13:27:51,stdout, [33;1mAccessory [0m[Homebridge] Registering Characteristic "Category" for events [33m+0ms[0m
2017-02-18 13:27:51,stdout," [33;1mAccessory [0m[Homebridge] Processing characteristic set: [{\"aid\":3,\"iid\":11,\"ev\":true},{\"aid\":3,\"iid\":14,\"ev\":true},{\"aid\":4,\"iid\":11,\"ev\":true},{\"aid\":4,\"iid\":14,\"ev\":true}] [33m+1ms[0m"
2017-02-18 13:27:51,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP request: /characteristics [35m+5ms[0m
2017-02-18 13:27:51,stdout, [33;1mAccessory [0m[Homebridge] Registering Characteristic "Current Relative Humidity" for events [33m+0ms[0m
2017-02-18 13:27:51,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: PUT /characteristics [35m+1ms[0m
2017-02-18 13:27:51,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP request: /characteristics [35m+2ms[0m
2017-02-18 13:27:51,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.2] HTTP Response is finished [35m+1ms[0m
2017-02-18 13:27:51,stdout," [33;1mAccessory [0m[Homebridge] Processing characteristic set: [{\"aid\":3,\"iid\":11,\"ev\":true},{\"aid\":3,\"iid\":14,\"ev\":true},{\"aid\":4,\"iid\":11,\"ev\":true},{\"aid\":4,\"iid\":14,\"ev\":true}] [33m+0ms[0m"
2017-02-18 13:27:51,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.2] HTTP request: /characteristics [35m+2ms[0m
2017-02-18 13:27:51,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.25] HTTP Response is finished [35m+0ms[0m
2017-02-18 13:27:51,stdout, [33;1mAccessory [0m[Homebridge] Registering Characteristic "Reachable" for events [33m+1ms[0m
2017-02-18 13:27:51,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.25] HTTP request: /characteristics [35m+0ms[0m
2017-02-18 13:27:51,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.25] HTTP request: /characteristics [35m+21ms[0m
2017-02-18 13:27:51,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP Response is finished [35m+5ms[0m
2017-02-18 13:27:51,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: GET /accessories [35m+0ms[0m
2017-02-18 13:27:51,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP request: /accessories [35m+17ms[0m
2017-02-18 13:27:51,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.2] HTTP Response is finished [35m+4ms[0m
2017-02-18 13:27:51,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.2] HTTP request: /accessories [35m+30ms[0m
2017-02-18 13:27:51,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP Response is finished [35m+4ms[0m
2017-02-18 13:27:51,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP request: /accessories [35m+0ms[0m
2017-02-18 13:27:51,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.25] HTTP Response is finished [35m+3ms[0m
2017-02-18 13:27:51,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: GET /accessories [35m+1ms[0m
2017-02-18 13:27:51,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.25] HTTP request: /accessories [35m+11ms[0m
2017-02-18 13:27:51,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.2] HTTP Response is finished [35m+9ms[0m
2017-02-18 13:27:51,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.2] HTTP request: /accessories [35m+50ms[0m
2017-02-18 13:27:50,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.25] HTTP Response is finished [35m+43ms[0m
2017-02-18 13:27:50,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: GET /accessories [35m+0ms[0m
2017-02-18 13:27:50,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.25] HTTP request: /accessories [35m+5s[0m
2017-02-18 13:27:50,stdout,"[37m[2/18/2017, 1:27:50 PM][39m [36m[websocket][39m [90msendData {\"topic\":\"response\",\"payload\":{\"ack\":true,\"message\":\"accessory 'Temperatur Dach' is added.\"}}[39m"
2017-02-18 13:27:50,stdout,"[37m[2/18/2017, 1:27:50 PM][39m [36m[websocket][39m addAccessory accessory 'Temperatur Dach' is added."
2017-02-18 13:27:50,stdout,"[37m[2/18/2017, 1:27:50 PM][39m [36m[websocket][39m [90mAccessory.configureAccessory Def {\"name\":\"Temperatur Dach\",\"service\":\"TemperatureSensor\",\"CurrentTemperature\":{\"minValue\":-100,\"maxValue\":100,\"minStep\":0.1}}[39m"
2017-02-18 13:27:50,stdout,}[39m
2017-02-18 13:27:50,stdout, }
2017-02-18 13:27:50,stdout, "minStep": 0.1
2017-02-18 13:27:50,stdout," \"maxValue\": 100,"
2017-02-18 13:27:50,stdout," \"minValue\": -100,"
2017-02-18 13:27:50,stdout, "CurrentTemperature": {
2017-02-18 13:27:50,stdout," \"service\": \"TemperatureSensor\","
2017-02-18 13:27:50,stdout," \"name\": \"Temperatur Dach\","
2017-02-18 13:27:50,stdout,"[37m[2/18/2017, 1:27:50 PM][39m [36m[websocket][39m [90monMessage add {"
2017-02-18 13:27:49,stdout,"[37m[2/18/2017, 1:27:49 PM][39m [36m[websocket][39m [90msendData {\"topic\":\"response\",\"payload\":{\"ack\":true,\"message\":\"accessory 'Temperatur Bad' is added.\"}}[39m"
2017-02-18 13:27:49,stdout,"[37m[2/18/2017, 1:27:49 PM][39m [36m[websocket][39m addAccessory accessory 'Temperatur Bad' is added."
2017-02-18 13:27:49,stdout,"[37m[2/18/2017, 1:27:49 PM][39m [36m[websocket][39m [90mAccessory.configureAccessory Def {\"name\":\"Temperatur Bad\",\"service\":\"TemperatureSensor\",\"CurrentTemperature\":{\"minValue\":-100,\"maxValue\":100,\"minStep\":0.1}}[39m"
2017-02-18 13:27:49,stdout,}[39m
2017-02-18 13:27:49,stdout, }
2017-02-18 13:27:49,stdout, "minStep": 0.1
2017-02-18 13:27:49,stdout," \"maxValue\": 100,"
2017-02-18 13:27:49,stdout," \"minValue\": -100,"
2017-02-18 13:27:49,stdout, "CurrentTemperature": {
2017-02-18 13:27:49,stdout," \"service\": \"TemperatureSensor\","
2017-02-18 13:27:49,stdout," \"name\": \"Temperatur Bad\","
2017-02-18 13:27:49,stdout,"[37m[2/18/2017, 1:27:49 PM][39m [36m[websocket][39m [90monMessage add {"
2017-02-18 13:27:46,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.2] HTTP Response is finished [35m+0ms[0m
2017-02-18 13:27:46,stdout, [33;1mAccessory [0m[Homebridge] Registering Characteristic "Category" for events [33m+0ms[0m
2017-02-18 13:27:46,stdout, [33;1mAccessory [0m[Homebridge] Registering Characteristic "Reachable" for events [33m+1ms[0m
2017-02-18 13:27:46,stdout," [33;1mAccessory [0m[Homebridge] Processing characteristic set: [{\"aid\":2,\"iid\":11,\"ev\":true},{\"aid\":2,\"iid\":14,\"ev\":true}] [33m+3ms[0m"
2017-02-18 13:27:46,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: PUT /characteristics [35m+0ms[0m
2017-02-18 13:27:46,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.2] HTTP request: /characteristics [35m+23ms[0m
2017-02-18 13:27:45,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.2] HTTP Response is finished [35m+30ms[0m
2017-02-18 13:27:45,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: GET /accessories [35m+0ms[0m
2017-02-18 13:27:45,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.2] HTTP request: /accessories [35m+3ms[0m
2017-02-18 13:27:45,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.2] HTTP Response is finished [35m+1ms[0m
2017-02-18 13:27:45,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] Client DA5CF7A5-CE5C-4285-A2C2-1901D7BB005A verification complete [35m+1ms[0m
2017-02-18 13:27:45,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] Pair verify step 2/2 [35m+0ms[0m
2017-02-18 13:27:45,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: POST /pair-verify [35m+0ms[0m
2017-02-18 13:27:45,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.2] HTTP request: /pair-verify [35m+14ms[0m
2017-02-18 13:27:45,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.2] HTTP Response is finished [35m+2ms[0m
2017-02-18 13:27:45,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] Pair verify step 1/2 [35m+0ms[0m
2017-02-18 13:27:45,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: POST /pair-verify [35m+1ms[0m
2017-02-18 13:27:45,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.2] HTTP request: /pair-verify [35m+1ms[0m
2017-02-18 13:27:45,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.2] HTTP server listening on port 43603 [35m+1ms[0m
2017-02-18 13:27:45,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.2] New connection from client [35m+3m[0m
2017-02-18 13:27:34,stdout,"[37m[2/18/2017, 1:27:34 PM][39m [36m[websocket][39m [90msendData {\"topic\":\"response\",\"payload\":{\"ack\":false,\"message\":\"name 'Temperatur Dach' undefined.\"}}[39m"
2017-02-18 13:27:34,stdout,"[37m[2/18/2017, 1:27:34 PM][39m [36m[websocket][39m [33msetValue name 'Temperatur Dach' undefined.[39m"
2017-02-18 13:27:34,stdout,"[37m[2/18/2017, 1:27:34 PM][39m [36m[websocket][39m [90msetValue {\"name\":\"Temperatur Dach\",\"characteristic\":\"CurrentTemperature\",\"value\":17.6}[39m"
2017-02-18 13:26:14,stdout,"[37m[2/18/2017, 1:26:14 PM][39m [36m[websocket][39m client ip ::ffff:192.168.5.56 connected"
2017-02-18 13:26:13,stdout,"[37m[2/18/2017, 1:26:13 PM][39m [36m[websocket][39m on.close client ip ::ffff:192.168.5.56 disconnected"
2017-02-18 13:25:48,stdout,"[37m[2/18/2017, 1:25:48 PM][39m [36m[websocket][39m client ip ::ffff:192.168.5.56 connected"
2017-02-18 13:25:47,stdout,"[37m[2/18/2017, 1:25:47 PM][39m [36m[websocket][39m on.close client ip ::ffff:192.168.5.56 disconnected"
2017-02-18 13:25:47,stdout,"[37m[2/18/2017, 1:25:47 PM][39m [36m[websocket][39m client ip ::ffff:192.168.5.56 connected"
2017-02-18 13:25:46,stdout,"[37m[2/18/2017, 1:25:46 PM][39m [36m[websocket][39m on.close client ip ::ffff:192.168.5.56 disconnected"
2017-02-18 13:25:45,stdout,"[37m[2/18/2017, 1:25:45 PM][39m [36m[websocket][39m client ip ::ffff:192.168.5.56 connected"
2017-02-18 13:25:44,stdout,"[37m[2/18/2017, 1:25:44 PM][39m [36m[websocket][39m on.close client ip ::ffff:192.168.5.56 disconnected"
2017-02-18 13:25:43,stdout,"[37m[2/18/2017, 1:25:43 PM][39m [36m[websocket][39m client ip ::ffff:192.168.5.56 connected"
2017-02-18 13:25:43,stdout,"[37m[2/18/2017, 1:25:43 PM][39m [36m[websocket][39m on.close client ip ::ffff:192.168.5.56 disconnected"
2017-02-18 13:25:42,stdout,"[37m[2/18/2017, 1:25:42 PM][39m [36m[websocket][39m client ip ::ffff:192.168.5.56 connected"
2017-02-18 13:25:42,stdout,"[37m[2/18/2017, 1:25:42 PM][39m [36m[websocket][39m on.close client ip ::ffff:192.168.5.56 disconnected"
2017-02-18 13:25:41,stdout,"[37m[2/18/2017, 1:25:41 PM][39m [36m[websocket][39m client ip ::ffff:192.168.5.56 connected"
2017-02-18 13:25:40,stdout,"[37m[2/18/2017, 1:25:40 PM][39m [36m[websocket][39m on.close client ip ::ffff:192.168.5.56 disconnected"
2017-02-18 13:25:39,stdout,"[37m[2/18/2017, 1:25:39 PM][39m [36m[websocket][39m client ip ::ffff:192.168.5.56 connected"
2017-02-18 13:25:39,stdout,"[37m[2/18/2017, 1:25:39 PM][39m [36m[websocket][39m on.close client ip ::ffff:192.168.5.56 disconnected"
2017-02-18 13:25:38,stdout,"[37m[2/18/2017, 1:25:38 PM][39m [36m[websocket][39m client ip ::ffff:192.168.5.56 connected"
2017-02-18 13:25:37,stdout,"[37m[2/18/2017, 1:25:37 PM][39m [36m[websocket][39m on.close client ip ::ffff:192.168.5.56 disconnected"
2017-02-18 13:25:37,stdout,"[37m[2/18/2017, 1:25:37 PM][39m [36m[websocket][39m client ip ::ffff:192.168.5.56 connected"
2017-02-18 13:25:36,stdout,"[37m[2/18/2017, 1:25:36 PM][39m [36m[websocket][39m on.close client ip ::ffff:192.168.5.56 disconnected"
2017-02-18 13:25:36,stdout,"[37m[2/18/2017, 1:25:36 PM][39m [36m[websocket][39m client ip ::ffff:192.168.5.56 connected"
2017-02-18 13:25:35,stdout,"[37m[2/18/2017, 1:25:35 PM][39m [36m[websocket][39m on.close client ip ::ffff:192.168.5.56 disconnected"
2017-02-18 13:25:34,stdout,"[37m[2/18/2017, 1:25:34 PM][39m [36m[websocket][39m client ip ::ffff:192.168.5.56 connected"
2017-02-18 13:25:14,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP Response is finished [35m+0ms[0m
2017-02-18 13:25:14,stdout, [33;1mAccessory [0m[Homebridge] Registering Characteristic "Current Relative Humidity" for events [33m+1ms[0m
2017-02-18 13:25:14,stdout," [33;1mAccessory [0m[Homebridge] Processing characteristic set: [{\"aid\":2,\"iid\":9,\"ev\":true}] [33m+0ms[0m"
2017-02-18 13:25:14,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: PUT /characteristics [35m+1ms[0m
2017-02-18 13:25:14,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP request: /characteristics [35m+58ms[0m
2017-02-18 13:25:14,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP Response is finished [35m+1ms[0m
2017-02-18 13:25:14,stdout, [33;1mAccessory [0m[Homebridge] Registering Characteristic "Category" for events [33m+0ms[0m
2017-02-18 13:25:14,stdout, [33;1mAccessory [0m[Homebridge] Registering Characteristic "Reachable" for events [33m+0ms[0m
2017-02-18 13:25:14,stdout," [33;1mAccessory [0m[Homebridge] Processing characteristic set: [{\"aid\":2,\"iid\":11,\"ev\":true},{\"aid\":2,\"iid\":14,\"ev\":true}] [33m+1ms[0m"
2017-02-18 13:25:14,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: PUT /characteristics [35m+0ms[0m
2017-02-18 13:25:14,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP request: /characteristics [35m+29ms[0m
2017-02-18 13:25:14,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP Response is finished [35m+28ms[0m
2017-02-18 13:25:14,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: GET /accessories [35m+0ms[0m
2017-02-18 13:25:14,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP request: /accessories [35m+5ms[0m
2017-02-18 13:25:14,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] Client B93EF4B1-29B7-476A-8195-AFA8B9298CA5 verification complete [35m+1ms[0m
2017-02-18 13:25:14,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] Pair verify step 2/2 [35m+1ms[0m
2017-02-18 13:25:14,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: POST /pair-verify [35m+1ms[0m
2017-02-18 13:25:14,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP request: /pair-verify [35m+17ms[0m
2017-02-18 13:25:14,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP Response is finished [35m+5ms[0m
2017-02-18 13:25:14,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] Pair verify step 1/2 [35m+3ms[0m
2017-02-18 13:25:14,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: POST /pair-verify [35m+0ms[0m
2017-02-18 13:25:14,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP request: /pair-verify [35m+5ms[0m
2017-02-18 13:25:14,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] HTTP server listening on port 42022 [35m+0ms[0m
2017-02-18 13:25:14,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.3] New connection from client [35m+967ms[0m
2017-02-18 13:25:13,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.25] HTTP Response is finished [35m+0ms[0m
2017-02-18 13:25:13,stdout, [33;1mAccessory [0m[Homebridge] Registering Characteristic "Category" for events [33m+1ms[0m
2017-02-18 13:25:13,stdout, [33;1mAccessory [0m[Homebridge] Registering Characteristic "Reachable" for events [33m+1ms[0m
2017-02-18 13:25:13,stdout," [33;1mAccessory [0m[Homebridge] Processing characteristic set: [{\"aid\":2,\"iid\":11,\"ev\":true},{\"aid\":2,\"iid\":14,\"ev\":true}] [33m+2ms[0m"
2017-02-18 13:25:13,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: PUT /characteristics [35m+1ms[0m
2017-02-18 13:25:13,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.25] HTTP request: /characteristics [35m+33ms[0m
2017-02-18 13:25:13,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.25] HTTP Response is finished [35m+26ms[0m
2017-02-18 13:25:13,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: GET /accessories [35m+0ms[0m
2017-02-18 13:25:13,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.25] HTTP request: /accessories [35m+5ms[0m
2017-02-18 13:25:13,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.25] HTTP Response is finished [35m+2ms[0m
2017-02-18 13:25:13,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] Client B93EF4B1-29B7-476A-8195-AFA8B9298CA5 verification complete [35m+4ms[0m
2017-02-18 13:25:13,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] Pair verify step 2/2 [35m+1ms[0m
2017-02-18 13:25:13,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: POST /pair-verify [35m+1ms[0m
2017-02-18 13:25:13,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.25] HTTP request: /pair-verify [35m+20ms[0m
2017-02-18 13:25:13,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.25] HTTP Response is finished [35m+23ms[0m
2017-02-18 13:25:13,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] Pair verify step 1/2 [35m+7ms[0m
2017-02-18 13:25:13,stdout, [35;1mHAPServer [0m[CC:22:3D:E3:CE:30] HAP Request: POST /pair-verify [35m+0ms[0m
2017-02-18 13:25:13,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.25] HTTP request: /pair-verify [35m+15ms[0m
2017-02-18 13:25:13,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.25] HTTP server listening on port 55229 [35m+1ms[0m
2017-02-18 13:25:13,stdout, [35;1mEventedHTTPServer [0m[::ffff:192.168.6.25] New connection from client [35m+2s[0m
2017-02-18 13:25:12,stdout,"[37m[2/18/2017, 1:25:12 PM][39m [36m[websocket][39m A new version 0.1.12 is avaiable"
2017-02-18 13:25:11,stdout,"[37m[2/18/2017, 1:25:11 PM][39m [36m[websocket][39m url {\"address\":\"::\",\"family\":\"IPv6\",\"port\":4050}"
2017-02-18 13:25:11,stdout,"[37m[2/18/2017, 1:25:11 PM][39m Homebridge is running on port 51826."
2017-02-18 13:25:11,stdout, [35;1mEventedHTTPServer [0mServer listening on port 51826 [35m+0ms[0m
2017-02-18 13:25:11,stdout,"[37m[2/18/2017, 1:25:11 PM][39m [36m[websocket][39m Number of Accessories: 1"
2017-02-18 13:25:11,stdout,"[37m[2/18/2017, 1:25:11 PM][39m [36m[websocket][39m [90mNumber of chaced Accessories: 1[39m"
2017-02-18 13:25:11,stdout,"[37m[2/18/2017, 1:25:11 PM][39m [36m[websocket][39m Plugin - DidFinishLaunching"
2017-02-18 13:25:11,stdout,[30m[47m [49m[39m
2017-02-18 13:25:11,stdout,[30m[47m └────────────┘ [49m[39m
2017-02-18 13:25:11,stdout,[30m[47m │ 031-45-154 │ [49m[39m
2017-02-18 13:25:11,stdout,[30m[47m ┌────────────┐ [49m[39m
WebSocketClient
TXT: 18.02.2017 14:29:01.00 | ReceivePacket | w{"topic":"get","service":"TemperatureSensor","payload":{"name":"Temperatur Bad","characteristic":"CurrentTemperature"}}
HEX: 18.02.2017 14:29:01.00 | ReceivePacket | 81 77 7B 22 74 6F 70 69 63 22 3A 22 67 65 74 22 2C 22 73 65 72 76 69 63 65 22 3A 22 54 65 6D 70 65 72 61 74 75 72 65 53 65 6E 73 6F 72 22 2C 22 70 61 79 6C 6F 61 64 22 3A 7B 22 6E 61 6D 65 22 3A 22 54 65 6D 70 65 72 61 74 75 72 20 42 61 64 22 2C 22 63 68 61 72 61 63 74 65 72 69 73 74 69 63 22 3A 22 43 75 72 72 65 6E 74 54 65 6D 70 65 72 61 74 75 72 65 22 7D 7D
TXT: 18.02.2017 14:29:01.00 | Receive FIN | true
HEX: 18.02.2017 14:29:01.00 | Receive FIN | 74 72 75 65
TXT: 18.02.2017 14:29:01.00 | Receive OpCode | text
HEX: 18.02.2017 14:29:01.00 | Receive OpCode | 74 65 78 74
TXT: 18.02.2017 14:29:01.00 | Receive Mask | false
HEX: 18.02.2017 14:29:01.00 | Receive Mask | 66 61 6C 73 65
TXT: 18.02.2017 14:29:01.00 | Receive Payload | {"topic":"get","service":"TemperatureSensor","payload":{"name":"Temperatur Bad","characteristic":"CurrentTemperature"}}
HEX: 18.02.2017 14:29:01.00 | Receive Payload | 7B 22 74 6F 70 69 63 22 3A 22 67 65 74 22 2C 22 73 65 72 76 69 63 65 22 3A 22 54 65 6D 70 65 72 61 74 75 72 65 53 65 6E 73 6F 72 22 2C 22 70 61 79 6C 6F 61 64 22 3A 7B 22 6E 61 6D 65 22 3A 22 54 65 6D 70 65 72 61 74 75 72 20 42 61 64 22 2C 22 63 68 61 72 61 63 74 65 72 69 73 74 69 63 22 3A 22 43 75 72 72 65 6E 74 54 65 6D 70 65 72 61 74 75 72 65 22 7D 7D
TXT: 18.02.2017 14:29:02.00 | Send FIN | true
HEX: 18.02.2017 14:29:02.00 | Send FIN | 74 72 75 65
TXT: 18.02.2017 14:29:02.00 | Send OpCode | text
HEX: 18.02.2017 14:29:02.00 | Send OpCode | 74 65 78 74
TXT: 18.02.2017 14:29:02.00 | Send Mask | true
HEX: 18.02.2017 14:29:02.00 | Send Mask | 74 72 75 65
TXT: 18.02.2017 14:29:02.00 | Send MaskKey | <ETB><ETX>?<BEL>
HEX: 18.02.2017 14:29:02.00 | Send MaskKey | 17 03 9F 07
TXT: 18.02.2017 14:29:02.00 | Send Payload | l!ëhgjü%-#½dvoóev`ô%;#½wvzóhvg½=7x½ivnú%-#½Srnïbebëre#Ýfs!³'5`÷febüsrqötcjü%-#½DbqíbywËbzsúuvwêur!³'5uþkbf½=72§)%3âz
HEX: 18.02.2017 14:29:02.00 | Send Payload | 6C 21 EB 68 67 6A FC 25 2D 23 BD 64 76 6F F3 65 76 60 F4 25 3B 23 BD 77 76 7A F3 68 76 67 BD 3D 37 78 BD 69 76 6E FA 25 2D 23 BD 53 72 6E EF 62 65 62 EB 72 65 23 DD 66 73 21 B3 27 35 60 F7 66 65 62 FC 73 72 71 F6 74 63 6A FC 25 2D 23 BD 44 62 71 ED 62 79 77 CB 62 7A 73 FA 75 76 77 EA 75 72 21 B3 27 35 75 FE 6B 62 66 BD 3D 37 32 A7 29 25 33 E2 7A
TXT: 18.02.2017 14:29:02.00 | Send PayloadRAW | {"topic": "callback", "payload": {"name": "Temperatur Bad", "characteristic": "CurrentTemperature", "value": 18.20}}
HEX: 18.02.2017 14:29:02.00 | Send PayloadRAW | 7B 22 74 6F 70 69 63 22 3A 20 22 63 61 6C 6C 62 61 63 6B 22 2C 20 22 70 61 79 6C 6F 61 64 22 3A 20 7B 22 6E 61 6D 65 22 3A 20 22 54 65 6D 70 65 72 61 74 75 72 20 42 61 64 22 2C 20 22 63 68 61 72 61 63 74 65 72 69 73 74 69 63 22 3A 20 22 43 75 72 72 65 6E 74 54 65 6D 70 65 72 61 74 75 72 65 22 2C 20 22 76 61 6C 75 65 22 3A 20 31 38 2E 32 30 7D 7D
TXT: 18.02.2017 14:29:02.00 | Send Packet | ô<ETB><ETX>?<BEL>l!ëhgjü%-#½dvoóev`ô%;#½wvzóhvg½=7x½ivnú%-#½Srnïbebëre#Ýfs!³'5`÷febüsrqötcjü%-#½DbqíbywËbzsúuvwêur!³'5uþkbf½=72§)%3âz
HEX: 18.02.2017 14:29:02.00 | Send Packet | 81 F4 17 03 9F 07 6C 21 EB 68 67 6A FC 25 2D 23 BD 64 76 6F F3 65 76 60 F4 25 3B 23 BD 77 76 7A F3 68 76 67 BD 3D 37 78 BD 69 76 6E FA 25 2D 23 BD 53 72 6E EF 62 65 62 EB 72 65 23 DD 66 73 21 B3 27 35 60 F7 66 65 62 FC 73 72 71 F6 74 63 6A FC 25 2D 23 BD 44 62 71 ED 62 79 77 CB 62 7A 73 FA 75 76 77 EA 75 72 21 B3 27 35 75 FE 6B 62 66 BD 3D 37 32 A7 29 25 33 E2 7A
TXT: 18.02.2017 14:29:09.00 | ReceivePacket | x{"topic":"get","service":"TemperatureSensor","payload":{"name":"Temperatur Dach","characteristic":"CurrentTemperature"}}
HEX: 18.02.2017 14:29:09.00 | ReceivePacket | 81 78 7B 22 74 6F 70 69 63 22 3A 22 67 65 74 22 2C 22 73 65 72 76 69 63 65 22 3A 22 54 65 6D 70 65 72 61 74 75 72 65 53 65 6E 73 6F 72 22 2C 22 70 61 79 6C 6F 61 64 22 3A 7B 22 6E 61 6D 65 22 3A 22 54 65 6D 70 65 72 61 74 75 72 20 44 61 63 68 22 2C 22 63 68 61 72 61 63 74 65 72 69 73 74 69 63 22 3A 22 43 75 72 72 65 6E 74 54 65 6D 70 65 72 61 74 75 72 65 22 7D 7D
TXT: 18.02.2017 14:29:09.00 | Receive FIN | true
HEX: 18.02.2017 14:29:09.00 | Receive FIN | 74 72 75 65
TXT: 18.02.2017 14:29:09.00 | Receive OpCode | text
HEX: 18.02.2017 14:29:09.00 | Receive OpCode | 74 65 78 74
TXT: 18.02.2017 14:29:09.00 | Receive Mask | false
HEX: 18.02.2017 14:29:09.00 | Receive Mask | 66 61 6C 73 65
TXT: 18.02.2017 14:29:09.00 | Receive Payload | {"topic":"get","service":"TemperatureSensor","payload":{"name":"Temperatur Dach","characteristic":"CurrentTemperature"}}
HEX: 18.02.2017 14:29:09.00 | Receive Payload | 7B 22 74 6F 70 69 63 22 3A 22 67 65 74 22 2C 22 73 65 72 76 69 63 65 22 3A 22 54 65 6D 70 65 72 61 74 75 72 65 53 65 6E 73 6F 72 22 2C 22 70 61 79 6C 6F 61 64 22 3A 7B 22 6E 61 6D 65 22 3A 22 54 65 6D 70 65 72 61 74 75 72 20 44 61 63 68 22 2C 22 63 68 61 72 61 63 74 65 72 69 73 74 69 63 22 3A 22 43 75 72 72 65 6E 74 54 65 6D 70 65 72 61 74 75 72 65 22 7D 7D
TXT: 18.02.2017 14:29:10.00 | Send FIN | true
HEX: 18.02.2017 14:29:10.00 | Send FIN | 74 72 75 65
TXT: 18.02.2017 14:29:10.00 | Send OpCode | text
HEX: 18.02.2017 14:29:10.00 | Send OpCode | 74 65 78 74
TXT: 18.02.2017 14:29:10.00 | Send Mask | true
HEX: 18.02.2017 14:29:10.00 | Send Mask | 74 72 75 65
TXT: 18.02.2017 14:29:10.00 | Send MaskKey | rPV¤
HEX: 18.02.2017 14:29:10.00 | Send MaskKey | 72 50 56 A4
TXT: 18.02.2017 14:29:10.00 | Send Payload | <HT>r"Ë<STX>95?HptÇ<DC3><:Æ<DC3>3=?^ptÔ<DC3>):Ë<DC3>4t?R+tÊ<DC3>=3?Hptð<ETB>=&Á<NUL>1"Ñ<NUL>p<DC2>Å<DC1>8t?Rr5Ì<DC3>"7Ç<ACK>5$Í<SOH>$?ÇPjv?1%$Ö<ETB>>"ð<ETB>=&Á<NUL>1"Ñ<NUL>5t?Rr Å<RS>%3?Hpg?\ffÙ<SI>
HEX: 18.02.2017 14:29:10.00 | Send Payload | 09 72 22 CB 02 39 35 86 48 70 74 C7 13 3C 3A C6 13 33 3D 86 5E 70 74 D4 13 29 3A CB 13 34 74 9E 52 2B 74 CA 13 3D 33 86 48 70 74 F0 17 3D 26 C1 00 31 22 D1 00 70 12 C5 11 38 74 88 52 72 35 CC 13 22 37 C7 06 35 24 CD 01 24 3F C7 50 6A 76 86 31 25 24 D6 17 3E 22 F0 17 3D 26 C1 00 31 22 D1 00 35 74 88 52 72 20 C5 1E 25 33 86 48 70 67 93 5C 66 66 D9 0F
TXT: 18.02.2017 14:29:10.00 | Send PayloadRAW | {"topic": "callback", "payload": {"name": "Temperatur Dach", "characteristic": "CurrentTemperature", "value": 17.60}}
HEX: 18.02.2017 14:29:10.00 | Send PayloadRAW | 7B 22 74 6F 70 69 63 22 3A 20 22 63 61 6C 6C 62 61 63 6B 22 2C 20 22 70 61 79 6C 6F 61 64 22 3A 20 7B 22 6E 61 6D 65 22 3A 20 22 54 65 6D 70 65 72 61 74 75 72 20 44 61 63 68 22 2C 20 22 63 68 61 72 61 63 74 65 72 69 73 74 69 63 22 3A 20 22 43 75 72 72 65 6E 74 54 65 6D 70 65 72 61 74 75 72 65 22 2C 20 22 76 61 6C 75 65 22 3A 20 31 37 2E 36 30 7D 7D
TXT: 18.02.2017 14:29:10.00 | Send Packet | õrPV¤<HT>r"Ë<STX>95?HptÇ<DC3><:Æ<DC3>3=?^ptÔ<DC3>):Ë<DC3>4t?R+tÊ<DC3>=3?Hptð<ETB>=&Á<NUL>1"Ñ<NUL>p<DC2>Å<DC1>8t?Rr5Ì<DC3>"7Ç<ACK>5$Í<SOH>$?ÇPjv?1%$Ö<ETB>>"ð<ETB>=&Á<NUL>1"Ñ<NUL>5t?Rr Å<RS>%3?Hpg?\ffÙ<SI>
HEX: 18.02.2017 14:29:10.00 | Send Packet | 81 F5 72 50 56 A4 09 72 22 CB 02 39 35 86 48 70 74 C7 13 3C 3A C6 13 33 3D 86 5E 70 74 D4 13 29 3A CB 13 34 74 9E 52 2B 74 CA 13 3D 33 86 48 70 74 F0 17 3D 26 C1 00 31 22 D1 00 70 12 C5 11 38 74 88 52 72 35 CC 13 22 37 C7 06 35 24 CD 01 24 3F C7 50 6A 76 86 31 25 24 D6 17 3E 22 F0 17 3D 26 C1 00 31 22 D1 00 35 74 88 52 72 20 C5 1E 25 33 86 48 70 67 93 5C 66 66 D9 0F
TXT: 18.02.2017 14:29:01.00 | RECEIVED | w{"topic":"get","service":"TemperatureSensor","payload":{"name":"Temperatur Bad","characteristic":"CurrentTemperature"}}
HEX: 18.02.2017 14:29:01.00 | RECEIVED | 81 77 7B 22 74 6F 70 69 63 22 3A 22 67 65 74 22 2C 22 73 65 72 76 69 63 65 22 3A 22 54 65 6D 70 65 72 61 74 75 72 65 53 65 6E 73 6F 72 22 2C 22 70 61 79 6C 6F 61 64 22 3A 7B 22 6E 61 6D 65 22 3A 22 54 65 6D 70 65 72 61 74 75 72 20 42 61 64 22 2C 22 63 68 61 72 61 63 74 65 72 69 73 74 69 63 22 3A 22 43 75 72 72 65 6E 74 54 65 6D 70 65 72 61 74 75 72 65 22 7D 7D
TXT: 18.02.2017 14:29:02.00 | TRANSMIT | ô<ETB><ETX>?<BEL>l!ëhgjü%-#½dvoóev`ô%;#½wvzóhvg½=7x½ivnú%-#½Srnïbebëre#Ýfs!³'5`÷febüsrqötcjü%-#½DbqíbywËbzsúuvwêur!³'5uþkbf½=72§)%3âz
HEX: 18.02.2017 14:29:02.00 | TRANSMIT | 81 F4 17 03 9F 07 6C 21 EB 68 67 6A FC 25 2D 23 BD 64 76 6F F3 65 76 60 F4 25 3B 23 BD 77 76 7A F3 68 76 67 BD 3D 37 78 BD 69 76 6E FA 25 2D 23 BD 53 72 6E EF 62 65 62 EB 72 65 23 DD 66 73 21 B3 27 35 60 F7 66 65 62 FC 73 72 71 F6 74 63 6A FC 25 2D 23 BD 44 62 71 ED 62 79 77 CB 62 7A 73 FA 75 76 77 EA 75 72 21 B3 27 35 75 FE 6B 62 66 BD 3D 37 32 A7 29 25 33 E2 7A
TXT: 18.02.2017 14:29:08.00 | RECEIVED | x{"topic":"get","service":"TemperatureSensor","payload":{"name":"Temperatur Dach","characteristic":"CurrentTemperature"}}
HEX: 18.02.2017 14:29:08.00 | RECEIVED | 81 78 7B 22 74 6F 70 69 63 22 3A 22 67 65 74 22 2C 22 73 65 72 76 69 63 65 22 3A 22 54 65 6D 70 65 72 61 74 75 72 65 53 65 6E 73 6F 72 22 2C 22 70 61 79 6C 6F 61 64 22 3A 7B 22 6E 61 6D 65 22 3A 22 54 65 6D 70 65 72 61 74 75 72 20 44 61 63 68 22 2C 22 63 68 61 72 61 63 74 65 72 69 73 74 69 63 22 3A 22 43 75 72 72 65 6E 74 54 65 6D 70 65 72 61 74 75 72 65 22 7D 7D
TXT: 18.02.2017 14:29:10.00 | TRANSMIT | õrPV¤<HT>r"Ë<STX>95?HptÇ<DC3><:Æ<DC3>3=?^ptÔ<DC3>):Ë<DC3>4t?R+tÊ<DC3>=3?Hptð<ETB>=&Á<NUL>1"Ñ<NUL>p<DC2>Å<DC1>8t?Rr5Ì<DC3>"7Ç<ACK>5$Í<SOH>$?ÇPjv?1%$Ö<ETB>>"ð<ETB>=&Á<NUL>1"Ñ<NUL>5t?Rr Å<RS>%3?Hpg?\ffÙ<SI>
HEX: 18.02.2017 14:29:10.00 | TRANSMIT | 81 F5 72 50 56 A4 09 72 22 CB 02 39 35 86 48 70 74 C7 13 3C 3A C6 13 33 3D 86 5E 70 74 D4 13 29 3A CB 13 34 74 9E 52 2B 74 CA 13 3D 33 86 48 70 74 F0 17 3D 26 C1 00 31 22 D1 00 70 12 C5 11 38 74 88 52 72 35 CC 13 22 37 C7 06 35 24 CD 01 24 3F C7 50 6A 76 86 31 25 24 D6 17 3E 22 F0 17 3D 26 C1 00 31 22 D1 00 35 74 88 52 72 20 C5 1E 25 33 86 48 70 67 93 5C 66 66 D9 0F
Herzlichen Dank und beste Grüße,
Frank
edit sagt:
Die Bulbs und Switches funktionieren ausgesprochen schnell und zuverlässig!
Hallo Frank,
laut Logs kommen die Werte aber zurück.
Bennen die Sensoren in Eve mal um und versuch es dann nochmal, Siri weiß manchmal nicht wie sie reagieren soll wenn der Raumname mit in dem Sirinamen ist.
Du kannst in Eve den Sirinamen einstellen.
Siri : „Wie ist die Temperatur im Badezimmer“,
wenn der Bad Wert da ist, und im Raum Badezimmer liegt, geht ohne Probleme
Mal ne Frage in die Runde,
welche Dinge würdet ihr gerne per HomeKit einbauen ?
Für mich habe ich schon einige Dinge am LCN im Test wie :
AirQualitySensor(für ppm), ContactSensor (einfache Fensterkontakte abfragen), LightSensor (LuxWerte abfragen), GarageDoorOpener ( da muss ich aber noch ein skript basteln, um es zu steuern, da ich nur einen Impuls am Tor habe, der einfach den vorhandenen Taster kurz betätig, und ich nur die Meldung „geschlossen“ im LCN habe…)
So mal eine Bemerkung von mir.
Der KaiS programmiert hier eine schöne Sache. Damit er das auch weiter so tut sollten wir Ihm was spenden.
10 Euro tun keinem weh wenn man sieht was es für einen Nutzen bringt. …also los Leute!!
Was muss man bei dem Fenstermodul einstellen damit ein Homematic Jalousieaktor bedient wird?
Welche VAR’s hat dein Homematic Modul ?
Welche Werte stehen drin ?
Na die Standard Variable Level sonst nichts.
Wir haben hier kein Homematic !
Daher müssen wir die Werte mal von Euch bekommen.
Kai hat nur zwave und LCN life zur Verfügung.
Bezüglich Rollläden hab ich bei meiner Wago SPS nur hoch runter und Position. Wollte das Modul testen und hab auf Grund der überwältigenden Anzahl an Variablen die man verwenden soll direkt aufgegeben [emoji848]
das Window Modul ist eigentlich für Fensterantriebe. Noch funktioniert Homematic nicht.
Für Rollos wird es noch ein eigenes Modul geben.
Ist nicht ganz so Kai.
Das kann man auch als Rollladen Modul nutzen.Und auch im Homekit so anzeigen…
ich möchte mich als aller erstes mal bei 35zman0801 für die Spende die ich gerade von ihm erhalten habe bedanken.
Mit sowas hätte ich niemals gerechnet, wie ich auch dir schon gesagt habe, mache ich das alles, weil ich spaß daran habe und nicht weil, ich etwas damit verdienen möchte.
Wir haben gerade erfolgreich das Modul für die Fenster mit Winmatic getestet.
Unter Status muss die Variable direction angegeben werden.
Decreasing Value: 2
Increasing Value: 1
Stopped Value: 3
Target und Current jeweils die Variable level
MaxValue jeweils 1.
Viel Spaß beim testen!
