Bei mir hat sich durch das Update leider nichts geändert. Für ein paar Sekunden geht’s, dann hängt’s wieder auf „Aktualisieren“ bzw. „Keine Antwort“ fest.
Debug der Homebridge spuckt folgendes aus:
(Anmerkung: „Bilderrahmen“ ist ein Switch -> Homematic Steckdose, „Wohnung“ eine eigene Bool-Variable)
[2017-02-09 22:42:50] Loaded plugin: homebridge-ip-symcon-beta
[2017-02-09 22:42:50] Registering accessory 'homebridge-ip-sycmon.IP-Symcon'
[2017-02-09 22:42:50] ---
express:application set "x-powered-by" to true +0ms
express:application set "etag" to 'weak' +3ms
express:application set "etag fn" to [Function: wetag] +1ms
express:application set "env" to 'development' +0ms
express:application set "query parser" to 'extended' +0ms
express:application set "query parser fn" to [Function: parseExtendedQueryString] +1ms
express:application set "subdomain offset" to 2 +0ms
express:application set "trust proxy" to false +0ms
express:application set "trust proxy fn" to [Function: trustNone] +0ms
express:application booting in development mode +1ms
express:application set "view" to [Function: View] +0ms
express:application set "views" to '/Users/claus/views' +0ms
express:application set "jsonp callback name" to 'callback' +0ms
[2017-02-09 22:42:51] Loaded plugin: homebridge-websocket
homebridge API version: 2.1
[2017-02-09 22:42:51] Registering platform 'homebridge-websocket.websocket'
[2017-02-09 22:42:51] ---
[2017-02-09 22:42:51] Loaded config.json with 0 accessories and 1 platforms.
[2017-02-09 22:42:51] Loading 1 platforms...
[2017-02-09 22:42:51] [websocket] Initializing websocket platform...
[2017-02-09 22:42:51] [websocket] storagePath = /Users/claus/.homebridge
[2017-02-09 22:42:51] [websocket] config = {"platform":"websocket","name":"websocket","port":4533}
[2017-02-09 22:42:51] [websocket] homebridge-websocket v0.1.11
[2017-02-09 22:42:51] [websocket] Accessory.configureAccessory Def {"name":"Bilderrahmen","service":"Switch"}
[2017-02-09 22:42:51] [websocket] Accessory.configureAccessory Def {"name":"Monitore","service":"Switch"}
[2017-02-09 22:42:51] [websocket] Accessory.configureAccessory Def {"name":"Kino","service":"Switch"}
[2017-02-09 22:42:51] [websocket] Accessory.configureAccessory Def {"name":"Wohnung","service":"Switch"}
Scan this code with your HomeKit App on your iOS device to pair with Homebridge:
│ 031-45-154 │
[2017-02-09 22:42:51] [websocket] Plugin - DidFinishLaunching
[2017-02-09 22:42:51] [websocket] Number of chaced Accessories: 4
[2017-02-09 22:42:51] [websocket] Number of Accessories: 4
EventedHTTPServer Server listening on port 51826 +0ms
[2017-02-09 22:42:51] Homebridge is running on port 51826.
[2017-02-09 22:42:51] [websocket] url {"address":"::","family":"IPv6","port":4533}
EventedHTTPServer [::ffff:192.168.178.43] New connection from client +29s
EventedHTTPServer [::ffff:192.168.178.43] HTTP server listening on port 60348 +1ms
EventedHTTPServer [::ffff:192.168.178.43] HTTP request: /pair-verify +9ms
HAPServer [CC:22:3D:E3:CE:30] HAP Request: POST /pair-verify +0ms
HAPServer [CC:22:3D:E3:CE:30] Pair verify step 1/2 +4ms
EventedHTTPServer [::ffff:192.168.178.43] HTTP Response is finished +12ms
EventedHTTPServer [::ffff:192.168.178.43] HTTP request: /pair-verify +140ms
HAPServer [CC:22:3D:E3:CE:30] HAP Request: POST /pair-verify +1ms
HAPServer [CC:22:3D:E3:CE:30] Pair verify step 2/2 +1ms
HAPServer [CC:22:3D:E3:CE:30] Client 2D62D45D-0AD4-487F-979C-C82E3D649170 verification complete +2ms
EventedHTTPServer [::ffff:192.168.178.43] HTTP Response is finished +1ms
EventedHTTPServer [::ffff:192.168.178.43] HTTP request: /accessories +11ms
HAPServer [CC:22:3D:E3:CE:30] HAP Request: GET /accessories +0ms
EventedHTTPServer [::ffff:192.168.178.43] HTTP Response is finished +4ms
EventedHTTPServer [::ffff:192.168.178.43] HTTP request: /characteristics +152ms
HAPServer [CC:22:3D:E3:CE:30] HAP Request: PUT /characteristics +0ms
Accessory [Homebridge] Processing characteristic set: [{"aid":2,"iid":11,"ev":true},{"aid":2,"iid":14,"ev":true},{"aid":3,"iid":11,"ev":true},{"aid":3,"iid":14,"ev":true},{"aid":4,"iid":11,"ev":true},{"aid":4,"iid":14,"ev":true},{"aid":5,"iid":11,"ev":true},{"aid":5,"iid":14,"ev":true}] +1ms
Accessory [Homebridge] Registering Characteristic "Reachable" for events +1ms
Accessory [Homebridge] Registering Characteristic "Category" for events +0ms
Accessory [Homebridge] Registering Characteristic "Reachable" for events +0ms
EventedHTTPServer [::ffff:192.168.178.43] HTTP request: /characteristics +65ms
Accessory [Homebridge] Processing characteristic set: [{"aid":2,"iid":9,"ev":true}] +0ms
Accessory [Homebridge] Registering Characteristic "On" for events +0ms
EventedHTTPServer [::ffff:192.168.178.43] HTTP request: /characteristics +11ms
HAPServer [CC:22:3D:E3:CE:30] HAP Request: PUT /characteristics +1ms
Accessory [Homebridge] Processing characteristic set: [{"aid":3,"iid":9,"ev":true}] +0ms
EventedHTTPServer [::ffff:192.168.178.43] HTTP request: /characteristics +5ms
Accessory [Homebridge] Processing characteristic set: [{"aid":3,"iid":9,"ev":true}] +1ms
EventedHTTPServer [::ffff:192.168.178.43] HTTP request: /characteristics +3ms
Accessory [Homebridge] Processing characteristic set: [{"aid":4,"iid":9,"ev":true}] +1ms
EventedHTTPServer [::ffff:192.168.178.43] HTTP Response is finished +0ms
Accessory [Homebridge] Processing characteristic set: [{"aid":4,"iid":9,"ev":true}] +0ms
EventedHTTPServer [::ffff:192.168.178.43] HTTP request: /characteristics +7ms
Accessory [Homebridge] Processing characteristic set: [{"aid":5,"iid":9,"ev":true}] +2ms
EventedHTTPServer [::ffff:192.168.178.43] HTTP request: /characteristics +12ms
Accessory [Homebridge] Processing characteristic set: [{"aid":5,"iid":9,"ev":true}] +1ms
Accessory [Homebridge] Registering Characteristic "On" for events +1ms
EventedHTTPServer [::ffff:192.168.178.43] HTTP request: /characteristics?id=4.9,3.9,5.9,2.9 +429ms
HAPServer [CC:22:3D:E3:CE:30] HAP Request: GET /characteristics?id=4.9,3.9,5.9,2.9 +0ms
Accessory [Homebridge] Getting value for Characteristic "On" +2ms
[2017-02-09 22:43:21] [websocket] get client disconnected.
Accessory [Homebridge] Got Characteristic "On" value: undefined +1ms
Accessory [Homebridge] Error getting value for Characteristic "On": undefined +0ms
Accessory [Homebridge] Getting value for Characteristic "On" +0ms
Accessory [Homebridge] Got Characteristic "On" value: undefined +0ms
Accessory [Homebridge] Error getting value for Characteristic "On": undefined +1ms
[2017-02-09 22:43:42] [websocket] client ip ::ffff:192.168.178.29 connected
EventedHTTPServer [::ffff:192.168.178.43] HTTP request: /characteristics?id=2.9 +39s
HAPServer [CC:22:3D:E3:CE:30] HAP Request: GET /characteristics?id=2.9 +0ms
Accessory [Homebridge] Getting value for Characteristic "On" +1ms
[2017-02-09 22:44:00] [websocket] sendData {"topic":"get","service":"Switch","payload":{"name":"Bilderrahmen","characteristic":"On"}}
[2017-02-09 22:44:00] [websocket] callback {"name":"Bilderrahmen","characteristic":"On","value":false}
Accessory [Homebridge] Got Characteristic "On" value: false +169ms
EventedHTTPServer [::ffff:192.168.178.43] HTTP request: /characteristics +11s
Accessory [Homebridge] Processing characteristic set: [{"aid":2,"iid":9,"value":1}] +1ms
Accessory [Homebridge] Setting Characteristic "On" to value 1 +0ms
[2017-02-09 22:44:12] [websocket] set Bilderrahmen On true
[2017-02-09 22:44:12] [websocket] sendData {"topic":"set","service":"Switch","payload":{"name":"Bilderrahmen","characteristic":"On","value":true}}
EventedHTTPServer [::ffff:192.168.178.43] Muting event '2.9' notification for this connection since it originated here. +6ms
[2017-02-09 22:44:12] [websocket] setValue {"name":"Bilderrahmen","characteristic":"On","value":true}
EventedHTTPServer [::ffff:192.168.178.43] Sending HTTP event '2.9' with data: {"characteristics":[{"aid":2,"iid":9,"value":true}]} +396ms
EventedHTTPServer [::ffff:192.168.178.43] HTTP request: /characteristics +31s
Accessory [Homebridge] Processing characteristic set: [{"aid":2,"iid":9,"value":0}] +0ms
Accessory [Homebridge] Setting Characteristic "On" to value 0 +0ms
[2017-02-09 22:44:43] [websocket] set Bilderrahmen On false
[2017-02-09 22:44:43] [websocket] sendData {"topic":"set","service":"Switch","payload":{"name":"Bilderrahmen","characteristic":"On","value":false}}
EventedHTTPServer [::ffff:192.168.178.43] Muting event '2.9' notification for this connection since it originated here. +2ms
[2017-02-09 22:44:44] [websocket] setValue {"name":"Bilderrahmen","characteristic":"On","value":false}
EventedHTTPServer [::ffff:192.168.178.43] Sending HTTP event '2.9' with data: {"characteristics":[{"aid":2,"iid":9,"value":false}]} +416ms
EventedHTTPServer [::ffff:192.168.178.43] HTTP request: /characteristics?id=3.9 +26s
HAPServer [CC:22:3D:E3:CE:30] HAP Request: GET /characteristics?id=3.9 +1ms
[2017-02-09 22:45:10] [websocket] sendData {"topic":"get","service":"Switch","payload":{"name":"Monitore","characteristic":"On"}}
[2017-02-09 22:45:10] [websocket] callback {"name":"Monitore","characteristic":"On","value":false}
Accessory [Homebridge] Got Characteristic "On" value: false +174ms
EventedHTTPServer [::ffff:192.168.178.43] HTTP request: /characteristics?id=5.9 +11s
HAPServer [CC:22:3D:E3:CE:30] HAP Request: GET /characteristics?id=5.9 +0ms
[2017-02-09 22:45:21] [websocket] sendData {"topic":"get","service":"Switch","payload":{"name":"Wohnung","characteristic":"On"}}
[2017-02-09 22:45:21] [websocket] callback {"name":"Wohnung","characteristic":"On","value":true}
Accessory [Homebridge] Got Characteristic "On" value: true +165ms
EventedHTTPServer [::ffff:192.168.178.43] HTTP request: /characteristics +13s
Accessory [Homebridge] Processing characteristic set: [{"aid":5,"iid":9,"value":0}] +0ms
[2017-02-09 22:45:34] [websocket] set Wohnung On false
[2017-02-09 22:45:34] [websocket] sendData {"topic":"set","service":"Switch","payload":{"name":"Wohnung","characteristic":"On","value":false}}
EventedHTTPServer [::ffff:192.168.178.43] Muting event '5.9' notification for this connection since it originated here. +1ms
[2017-02-09 22:45:34] [websocket] setValue {"name":"Wohnung","characteristic":"On","value":false}
EventedHTTPServer [::ffff:192.168.178.43] Sending HTTP event '5.9' with data: {"characteristics":[{"aid":5,"iid":9,"value":false}]} +183ms
Außerdem ist mir in IPS aufgefallen, dass der Socket ganz schön schnell viele Fehler schmeißt:
22:43:38 | 41071 | MESSAGE | Client Socket | Öffne Socket...
22:43:38 | 41071 | MESSAGE | Event Control | Wiederverbinden [WebsocketClient Socket] erfolgreich
22:43:38 | 00000 | DEBUG | ScriptEngine | Skriptausführung (Text) - Länge: 242 ~ Absender: RunScript
22:43:38 | 41071 | MESSAGE | Client Socket | Einstellungen gespeichert
22:43:38 | 41071 | MESSAGE | Client Socket | Schließe Socket...
22:43:38 | 41071 | WARNING | Client Socket | Fehler beim Lesen: The file handle supplied is not valid
22:43:38 | 00000 | DEBUG | ScriptEngine | Skript ausgeführt (Text) - Länge: 0 ~ Absender: RunScript
22:43:39 | 41071 | MESSAGE | Client Socket | Einstellungen gespeichert
22:43:39 | 41071 | MESSAGE | Client Socket | Schließe Socket...
22:43:39 | 41071 | WARNING | Client Socket | Fehler beim Lesen: The file handle supplied is not valid
22:43:39 | 00000 | DEBUG | ScriptEngine | Skriptausführung (Text) - Länge: 242 ~ Absender: RunScript
22:43:39 | 00000 | DEBUG | ScriptEngine | Skript ausgeführt (Text) - Länge: 0 ~ Absender: RunScript
22:43:39 | 41071 | MESSAGE | Client Socket | Öffne Socket...
22:43:39 | 49790 | DEBUG | ScriptEngine | Skriptausführung - Ereignis: 24120 ~ Absender: TimerEvent
22:43:39 | 12385 | DEBUG | VariableManager | [_to_sort\Wartung\Server\DMX Interface\DMX Interface connection] = 2
22:43:39 | 49790 | DEBUG | ScriptEngine | Skript ausgeführt - Ereignis: 24120 ~ Absender: TimerEvent
22:43:39 | 28089 | DEBUG | ScriptEngine | Skriptausführung - Ereignis: 28670 ~ Absender: TimerEvent
22:43:39 | 19262 | DEBUG | VariableManager | [root\Geräte\IT\PIs\PI - Diele - Kommode\var\PIR Socket Connection] = true
22:43:39 | 28089 | DEBUG | ScriptEngine | Skript ausgeführt - Ereignis: 28670 ~ Absender: TimerEvent
22:43:39 | 10734 | DEBUG | ScriptEngine | Skriptausführung - Ereignis: 41903 ~ Absender: TimerEvent
22:43:39 | 10734 | DEBUG | ScriptEngine | Skript ausgeführt - Ereignis: 41903 ~ Absender: TimerEvent
22:43:39 | 48784 | DEBUG | ScriptEngine | Skriptausführung - Ereignis: 48529 ~ Absender: TimerEvent
22:43:39 | 48784 | DEBUG | ScriptEngine | Skript ausgeführt - Ereignis: 48529 ~ Absender: TimerEvent
22:43:39 | 22288 | DEBUG | ScriptEngine | Skriptausführung - Ereignis: 55390 ~ Absender: TimerEvent
22:43:39 | 57977 | DEBUG | VariableManager | [root\Geräte\IT\PIs\PI - Diele - Kommode\var\LED Socket Connection] = true
22:43:39 | 22288 | DEBUG | ScriptEngine | Skript ausgeführt - Ereignis: 55390 ~ Absender: TimerEvent
22:43:40 | 41071 | MESSAGE | Client Socket | Einstellungen gespeichert
22:43:40 | 41071 | MESSAGE | Client Socket | Schließe Socket...
22:43:40 | 41071 | WARNING | Client Socket | Fehler beim Lesen: The file handle supplied is not valid
22:43:40 | 00000 | DEBUG | ScriptEngine | Skriptausführung (Text) - Länge: 242 ~ Absender: RunScript
22:43:40 | 00000 | DEBUG | ScriptEngine | Skript ausgeführt (Text) - Länge: 0 ~ Absender: RunScript
22:43:40 | 41071 | MESSAGE | Client Socket | Öffne Socket...
22:43:40 | 43259 | DEBUG | ScriptEngine | Skriptausführung - Ereignis: 25861 ~ Absender: TimerEvent
22:43:40 | 43259 | DEBUG | ScriptEngine | Skript ausgeführt - Ereignis: 25861 ~ Absender: TimerEvent
22:43:40 | 49950 | DEBUG | ScriptEngine | Skriptausführung - Ereignis: 26052 ~ Absender: TimerEvent
22:43:40 | 49950 | DEBUG | ScriptEngine | Skript ausgeführt - Ereignis: 26052 ~ Absender: TimerEvent
22:43:41 | 00000 | DEBUG | ScriptEngine | Skript ausgeführt (Text) - Länge: 0 ~ Absender: RunScript
22:43:41 | 41071 | MESSAGE | Client Socket | Öffne Socket...
22:43:41 | 00000 | DEBUG | ScriptEngine | Skriptausführung (Text) - Länge: 242 ~ Absender: RunScript
22:43:41 | 41071 | MESSAGE | Client Socket | Einstellungen gespeichert
22:43:41 | 41071 | MESSAGE | Client Socket | Schließe Socket...
22:43:41 | 41071 | WARNING | Client Socket | Fehler beim Lesen: The file handle supplied is not valid
22:43:41 | 10721 | DEBUG | ScriptEngine | Skriptausführung - Ereignis: 28786 ~ Absender: TimerEvent
22:43:41 | 55706 | DEBUG | ScriptEngine | Skriptausführung - Ereignis: 42537 ~ Absender: TimerEvent
22:43:42 | 00000 | DEBUG | ScriptEngine | Skript ausgeführt (Text) - Länge: 0 ~ Absender: RunScript
22:43:42 | 00000 | DEBUG | ScriptEngine | Skriptausführung (Text) - Länge: 242 ~ Absender: RunScript
22:43:42 | 41071 | MESSAGE | Client Socket | Einstellungen gespeichert
22:43:42 | 41071 | MESSAGE | Client Socket | Schließe Socket...
22:43:42 | 41071 | WARNING | Client Socket | Fehler beim Lesen: The file handle supplied is not valid
22:43:42 | 41071 | MESSAGE | Client Socket | Öffne Socket...
22:43:42 | 10721 | DEBUG | ScriptEngine | Skript ausgeführt - Ereignis: 28786 ~ Absender: TimerEvent
EDIT: Ich glaube, die vielen Einträge vom Socket stammen daher, dass in der Zeit die Homebridge nicht lief. Denn wenige Sekunden danach als die Bridge wieder gestartet wurde scheinen die Einträge nicht mehr aufzutauchen. Trotzdem krass in welch kurzer Zeit die Meldungen da auftauchen … :o
