schon, weil ich es am einfachsten finde, mit WinSCP. Aber auch Putty wollte mir das nicht anzeigen …
Egal (danke), jetzt habe ich die beiden Dateien im 'hidden’store geändert.
Auch nach einem Neustart der Box wirft mir ein EchoRemote_TuneInPreset jetzt aber dieses aus:
PHP-Error-Warning:
Fatal error: Uncaught TypeError: Argument 3 passed to AmazonEchoIO::SendEcho() must be of the type string or null, array given, called in /mnt/data/symcon/modules/.store/fonzo.ipsymconechoremote/Echo IO/module.php on line 759 and defined in /mnt/data/symcon/modules/.store/fonzo.ipsymconechoremote/Echo IO/module.php:1035
Stack trace:
#0 /mnt/data/symcon/modules/.store/fonzo.ipsymconechoremote/Echo IO/module.php(759): AmazonEchoIO->SendEcho(‚https://alexa.a…‘, Array, Array, NULL, ‚PUT‘)
#1 /mnt/data/symcon/modules/.store/fonzo.ipsymconechoremote/Echo IO/module.php(1166): AmazonEchoIO->TuneinQueueandplay(Array, Array)
#2 /-(3): AmazonEchoIO->ForwardData(’{„DataID“:"{8E1…’)
#3 {main}
thrown in /mnt/data/symcon/modules/.store/fonzo.ipsymconechoremote/Echo IO/module.php on line 1035
PHP-Error-Error: Uncaught TypeError: Argument 3 passed to AmazonEchoIO::SendEcho() must be of the type string or null, array given, called in /mnt/data/symcon/modules/.store/fonzo.ipsymconechoremote/Echo IO/module.php on line 759 and defined in /mnt/data/symcon/modules/.store/fonzo.ipsymconechoremote/Echo IO/module.php:1035
Stack trace:
#3 {main}
thrown
Error in Script /mnt/data/symcon/modules/.store/fonzo.ipsymconechoremote/Echo IO/module.php on Line 1035Abort Processing during Fatal-Error: Uncaught TypeError: Argument 3 passed to AmazonEchoIO::SendEcho() must be of the type string or null, array given, called in /mnt/data/symcon/modules/.store/fonzo.ipsymconechoremote/Echo IO/module.php on line 759 and defined in /mnt/data/symcon/modules/.store/fonzo.ipsymconechoremote/Echo IO/module.php:1035
Stack trace:
#3 {main}
thrown
Error in Script /mnt/data/symcon/modules/.store/fonzo.ipsymconechoremote/Echo Device/module.php on Line 405
Warning:
Stack trace:
#3 {main}
PHP-Error-Error: Uncaught TypeError: Argument 3 passed to AmazonEchoIO::SendEcho() must be of the type string or null, array given, called in /mnt/data/symcon/modules/.store/fonzo.ipsymconechoremote/Echo IO/module.php on line 759 in /mnt/data/symcon/modules/.store/fonzo.ipsymconechoremote/Echo Device/module.php on line 405
PHP-Error-Notice: Trying to access array offset on value of type null
Error in Script /mnt/data/symcon/modules/.store/fonzo.ipsymconechoremote/Echo Device/module.php on Line 1072
Notice: Trying to access array offset on value of type null in /mnt/data/symcon/modules/.store/fonzo.ipsymconechoremote/Echo Device/module.php on line 1072
… und die Ratlosigkeit ist immer noch da … (in den ‚angemeckerten‘ Zeilen habe ich ja eigentlich keine Änderungen gemacht)
Grüß, Uwe
