I got a Ikea switch connected to Symcon via Zigbee2MQTT.
the status i got from the buttons are:
- On
- Off
- Brightness_move_up (long press I )
- Brightness_move_down (long press O)
- Brightness_stop
Is there a way to register the duration of the time Brightness_move_up & down is pressed.
So i can use that as a dimmer.
Use case:
- press I or O long
- dimmer start to raise/lower the brightness with 10% every second
- until i stop the button press
thanx!
KaiS
2
Hi!
Thanx,
i created this script, this is also working.
$lop=false;
$status=GetValue(30822); // disable on change trigger
$cnt=0;
if ($status == „“) return;
if ($status==„brightness_move_up“)
$lop = true;
IPS_SetEventActive(37830, false);
$val = round(GetValue(57826)*2.55);
if ($status==„off“)
PHUE_DimSet(30687,false);
if ($status==„on“)
PHUE_DimSet(30687,(90*2.55));
while($lop==true)
$a = IPS_GetVariable(30822);
$cnt++;
if ($cnt>2)
$cnt=0;
$val+=40;
PHUE_DimSet(30687,$val);
if ($val>=255) $lop=false;
IPS_Sleep(50);
elseif ($status==„brightness_move_down“)
// TODO
IPS_Sleep(25);
else
$lop=false;
SetValue(30822, „“);
IPS_SetEventActive(37830, true);
