Hmm. Eine Volltextsuche nach „time“ oder „zone“ ergab nichts. Hier der Dump:
<!DOCTYPE html><html lang="en"><head><meta charset="utf-8"><meta name="viewport" content="width=device-width,minimum-scale=1,initial-scale=1,user-scalable=yes"><title>IP-Symcon Management Console</title><meta name="description" content="Manage the devices and settings of your system"><meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=0"><meta name="google" content="notranslate"><meta name="apple-touch-fullscreen" content="yes"><meta name="apple-mobile-web-app-capable" content="yes"><meta name="apple-mobile-web-app-title" content="IP-Symcon Console"><meta name="apple-mobile-web-app-status-bar-style" content="black"><link rel="apple-touch-icon" href="images/touch-icon-ios.png"><meta name="msapplication-TileImage" content="images/touch-icon-ms.png"><meta name="msapplication-TileColor" content="#002F52"><link rel="icon" type="image/x-icon" href="favicon.ico"><script>(function(a){function b(a){return r.typeof="function"===typeof Symbol&&"symbol"===typeof Symbol.iterator?b=function(a){return typeof a}:b=function(a){return a&&"function"===typeof Symbol&&a.constructor===Symbol&&a!==Symbol.prototype?"symbol":typeof a},b(a)}function c(a){function b(d,e){try{var f=a[d](e),g=f.value,h=g instanceof r.AwaitValue;Promise.resolve(h?g.wrapped:g).then(function(a){return h?void b("next",a):void c(f.done?"return":"normal",a)},function(a){b("throw",a)})}catch(a){c("throw",a)}}function c(a,c){switch(a){case"return":d.resolve({value:c,done:!0});break;case"throw":d.reject(c);break;default:d.resolve({value:c,done:!1});}d=d.next,d?b(d.key,d.arg):e=null}var d,e;this._invoke=function(a,c){return new Promise(function(f,g){var h={key:a,arg:c,resolve:f,reject:g,next:null};e?e=e.next=h:(d=e=h,b(a,c))})},"function"!==typeof a.return&&(this.return=void 0)}function d(a,b,c,d,e,f,g){try{var h=a[f](g),i=h.value}catch(a){return void c(a)}h.done?b(i):Promise.resolve(i).then(d,e)}function e(a,b){for(var c,d=0;d<b.length;d++)c=b[d],c.enumerable=c.enumerable||!1,c.configurable=!0,"value"in c&&(c.writable=!0),Object.defineProperty(a,c.key,c)}function f(a,b){for(var c in b){var d=b[c];d.configurable=d.enumerable=!0,"value"in d&&(d.writable=!0),Object.defineProperty(a,c,d)}if(Object.getOwnPropertySymbols)for(var e=Object.getOwnPropertySymbols(b),f=0;f<e.length;f++){var g=e[f],d=b[g];d.configurable=d.enumerable=!0,"value"in d&&(d.writable=!0),Object.defineProperty(a,g,d)}return a}function g(a,b,c){return b in a?Object.defineProperty(a,b,{value:c,enumerable:!0,configurable:!0,writable:!0}):a[b]=c,a}function h(){return r.extends=h=Object.assign||function(a){for(var b,c=1;c<arguments.length;c++)for(var d in b=arguments[c],b)Object.prototype.hasOwnProperty.call(b,d)&&(a[d]=b[d]);return a},h.apply(this,arguments)}function i(a){return r.getPrototypeOf=i=Object.setPrototypeOf?Object.getPrototypeOf:function(a){return a.__proto__||Object.getPrototypeOf(a)},i(a)}function j(a,b){return r.setPrototypeOf=j=Object.setPrototypeOf||function(a,b){return a.__proto__=b,a},j(a,b)}function k(){if("undefined"===typeof Reflect||!Reflect.construct)return!1;if(Reflect.construct.sham)return!1;if("function"===typeof Proxy)return!0;try{return Date.prototype.toString.call(Reflect.construct(Date,[],function(){})),!0}catch(a){return!1}}function l(){return r.construct=k()?l=Reflect.construct:l=function(b,c,d){var e=[null];e.push.apply(e,c);var a=Function.bind.apply(b,e),f=new a;return d&&r.setPrototypeOf(f,d.prototype),f},l.apply(null,arguments)}function m(a){var b="function"===typeof Map?new Map:void 0;return r.wrapNativeSuper=m=function(a){function c(){return r.construct(a,arguments,r.getPrototypeOf(this).constructor)}if(null===a||!r.isNativeFunction(a))return a;if("function"!==typeof a)throw new TypeError("Super expression must either be null or a function");if("undefined"!==typeof b){if(b.has(a))return b.get(a);b.set(a,c)}return c.prototype=Object.create(a.prototype,{constructor:{value:c,enumerable:!1,writable:!0,configurable:!0}}),r.setPrototypeOf(c,a)},m(a)}function n(a,b,c){return r.get="undefined"!==typeof Reflect&&Reflect.get?n=Reflect.get:n=function(a,b,c){var d=r.superPropBase(a,b);if(d){var e=Object.getOwnPropertyDescriptor(d,b);return e.get?e.get.call(c):e.value}},n(a,b,c||a)}function o(a,b,c,d){return o="undefined"!==typeof Reflect&&Reflect.set?Reflect.set:function(a,b,c,d){var e,f=r.superPropBase(a,b);if(f){if(e=Object.getOwnPropertyDescriptor(f,b),e.set)return e.set.call(d,c),!0;if(!e.writable)return!1}if(e=Object.getOwnPropertyDescriptor(d,b),e){if(!e.writable)return!1;e.value=c,Object.defineProperty(d,b,e)}else r.defineProperty(d,b,c);return!0},o(a,b,c,d)}function p(a,b,c,d,e){var f=o(a,b,c,d||a);if(!f&&e)throw new Error("failed to set property");return c}function q(a){if(Symbol.iterator in Object(a)||"[object Arguments]"===Object.prototype.toString.call(a))return Array.from(a)}var r=a.babelHelpers={};r.typeof=b,r.asyncIterator=function(a){var b;if("function"===typeof Symbol){if(Symbol.asyncIterator&&(b=a[Symbol.asyncIterator],null!=b))return b.call(a);if(Symbol.iterator&&(b=a[Symbol.iterator],null!=b))return b.call(a)}throw new TypeError("Object is not async iterable")},r.AwaitValue=function(a){this.wrapped=a},"function"===typeof Symbol&&Symbol.asyncIterator&&(c.prototype[Symbol.asyncIterator]=function(){return this}),c.prototype.next=function(a){return this._invoke("next",a)},c.prototype.throw=function(a){return this._invoke("throw",a)},c.prototype.return=function(a){return this._invoke("return",a)},r.AsyncGenerator=c,r.wrapAsyncGenerator=function(a){return function(){return new r.AsyncGenerator(a.apply(this,arguments))}},r.awaitAsyncGenerator=function(a){return new r.AwaitValue(a)},r.asyncGeneratorDelegate=function(a,b){function c(c,d){return e=!0,d=new Promise(function(b){b(a[c](d))}),{done:!1,value:b(d)}}var d={},e=!1;return"function"===typeof Symbol&&Symbol.iterator&&(d[Symbol.iterator]=function(){return this}),d.next=function(a){return e?(e=!1,a):c("next",a)},"function"===typeof a.throw&&(d.throw=function(a){if(e)throw e=!1,a;return c("throw",a)}),"function"===typeof a.return&&(d.return=function(a){return c("return",a)}),d},r.asyncToGenerator=function(a){return function(){var b=this,c=arguments;return new Promise(function(e,f){function g(a){d(i,e,f,g,h,"next",a)}function h(a){d(i,e,f,g,h,"throw",a)}var i=a.apply(b,c);g(void 0)})}},r.classCallCheck=function(a,b){if(!(a instanceof b))throw new TypeError("Cannot call a class as a function")},r.createClass=function(a,b,c){return b&&e(a.prototype,b),c&&e(a,c),a},r.defineEnumerableProperties=f,r.defaults=function(a,b){for(var c=Object.getOwnPropertyNames(b),d=0;d<c.length;d++){var e=c[d],f=Object.getOwnPropertyDescriptor(b,e);f&&f.configurable&&a[e]===void 0&&Object.defineProperty(a,e,f)}return a},r.defineProperty=g,r.extends=h,r.objectSpread=function(a){for(var b=1;b<arguments.length;b++){var c=null==arguments[b]?{}:arguments[b],d=Object.keys(c);"function"===typeof Object.getOwnPropertySymbols&&(d=d.concat(Object.getOwnPropertySymbols(c).filter(function(a){return Object.getOwnPropertyDescriptor(c,a).enumerable}))),d.forEach(function(b){r.defineProperty(a,b,c[b])})}return a},r.inherits=function(a,b){if("function"!==typeof b&&null!==b)throw new TypeError("Super expression must either be null or a function");a.prototype=Object.create(b&&b.prototype,{constructor:{value:a,writable:!0,configurable:!0}}),b&&r.setPrototypeOf(a,b)},r.getPrototypeOf=i,r.setPrototypeOf=j,r.construct=l,r.isNativeFunction=function(a){return-1!==Function.toString.call(a).indexOf("[native code]")},r.wrapNativeSuper=m,r.instanceof=function(a,b){return null!=b&&"undefined"!==typeof Symbol&&b[Symbol.hasInstance]?b[Symbol.hasInstance](a):a instanceof b},r.interopRequireDefault=function(a){return a&&a.__esModule?a:{default:a}},r.interopRequireWildcard=function(a){if(a&&a.__esModule)return a;var b={};if(null!=a)for(var c in a)if(Object.prototype.hasOwnProperty.call(a,c)){var d=Object.defineProperty&&Object.getOwnPropertyDescriptor?Object.getOwnPropertyDescriptor(a,c):{};d.get||d.set?Object.defineProperty(b,c,d):b[c]=a[c]}return b.default=a,b},r.newArrowCheck=function(a,b){if(a!==b)throw new TypeError("Cannot instantiate an arrow function")},r.objectDestructuringEmpty=function(a){if(null==a)throw new TypeError("Cannot destructure undefined")},r.objectWithoutPropertiesLoose=function(a,b){if(null==a)return{};var c,d,e={},f=Object.keys(a);for(d=0;d<f.length;d++)c=f[d],0<=b.indexOf(c)||(e[c]=a[c]);return e},r.objectWithoutProperties=function(a,b){if(null==a)return{};var c,d,e=r.objectWithoutPropertiesLoose(a,b);if(Object.getOwnPropertySymbols){var f=Object.getOwnPropertySymbols(a);for(d=0;d<f.length;d++)c=f[d],!(0<=b.indexOf(c))&&Object.prototype.propertyIsEnumerable.call(a,c)&&(e[c]=a[c])}return e},r.assertThisInitialized=function(a){if(void 0===a)throw new ReferenceError("this hasn't been initialised - super() hasn't been called");return a},r.possibleConstructorReturn=function(a,b){return b&&("object"===typeof b||"function"===typeof b)?b:r.assertThisInitialized(a)},r.superPropBase=function(a,b){for(;!Object.prototype.hasOwnProperty.call(a,b)&&(a=r.getPrototypeOf(a),null!==a););return a},r.get=n,r.set=p,r.taggedTemplateLiteral=function(a,b){return b||(b=a.slice(0)),Object.freeze(Object.defineProperties(a,{raw:{value:Object.freeze(b)}}))},r.temporalRef=function(a,b){if(a===r.temporalUndefined)throw new ReferenceError(b+" is not defined - temporal dead zone");else return a},r.readOnlyError=function(a){throw new Error("\""+a+"\" is read-only")},r.temporalUndefined={},r.slicedToArray=function(a,b){return r.arrayWithHoles(a)||r.iterableToArrayLimit(a,b)||r.nonIterableRest()},r.toArray=function(a){return r.arrayWithHoles(a)||r.iterableToArray(a)||r.nonIterableRest()},r.toConsumableArray=function(a){return r.arrayWithoutHoles(a)||r.iterableToArray(a)||r.nonIterableSpread()},r.arrayWithoutHoles=function(a){if(Array.isArray(a)){for(var b=0,c=Array(a.length);b<a.length;b++)c[b]=a[b];return c}},r.arrayWithHoles=function(a){if(Array.isArray(a))return a},r.iterableToArray=q,r.iterableToArrayLimit=function(a,b){var c=[],d=!0,e=!1,f=void 0;try{for(var g,h=a[Symbol.iterator]();!(d=(g=h.next()).done)&&(c.push(g.value),!(b&&c.length===b));d=!0);}catch(a){e=!0,f=a}finally{try{d||null==h["return"]||h["return"]()}finally{if(e)throw f}}return c},r.nonIterableSpread=function(){throw new TypeError("Invalid attempt to spread non-iterable instance")},r.nonIterableRest=function(){throw new TypeError("Invalid attempt to destructure non-iterable instance")},r.toPropertyKey=function(a){var b=r.toPrimitive(a,"string");return"symbol"===typeof b?b:b+""}})("undefined"===typeof global?self:global);</script><script src="./node_modules/@webcomponents/webcomponentsjs/webcomponents-loader.js"></script><script src="./node_modules/web-animations-js/web-animations-next-lite.min.js"></script><script>"use strict";(function(){function a(a,b,c){var d=a;if(d.state=b,d.stateData=c,0<d.onNextStateChange.length){var e=d.onNextStateChange.slice();d.onNextStateChange.length=0;for(var f,g=0,h=e;g<h.length;g++)f=h[g],f()}return d}function b(b){function d(){try{document.head.removeChild(f)}catch(a){}}var e=a(b,"Loading",void 0),f=document.createElement("script");return f.src=b.url,null!==b.crossorigin&&f.setAttribute("crossorigin",b.crossorigin),f.onload=function(){var a,b,f;void 0===r?(b=[],f=void 0):(a=r(),b=a[0],f=a[1]),c(e,b,f),d()},f.onerror=function(){g(b,new TypeError("Failed to fetch "+b.url)),d()},document.head.appendChild(f),e}function c(b,c,e){var f=d(b,c),g=f[0],h=f[1];return a(b,"WaitingForTurn",{args:g,deps:h,moduleBody:e})}function d(a,c){for(var e,f=[],g=[],i=0,j=c;i<j.length;i++){if(e=j[i],"exports"===e){f.push(a.exports);continue}if("require"===e){f.push(function(b,c,e){var f=d(a,b),g=f[0],i=f[1];h(i,function(){c&&c.apply(null,g)},e)});continue}if("meta"===e){f.push({url:!0===a.isTopLevel?a.url.substring(0,a.url.lastIndexOf("#")):a.url});continue}var l=k(n(a.urlBase,e),a.crossorigin);f.push(l.exports),g.push(l),"Initialized"===l.state&&b(l)}return[f,g]}function e(b){var c=a(b,"WaitingOnDeps",b.stateData);return h(b.stateData.deps,function(){return f(c)},function(a){return g(c,a)}),c}function f(b){var c=b.stateData;if(null!=c.moduleBody)try{c.moduleBody.apply(null,c.args)}catch(a){return g(b,a)}return a(b,"Executed",void 0)}function g(b,c){return!0===b.isTopLevel&&setTimeout(function(){throw c}),a(b,"Failed",c)}function h(a,b,c){var d=a.shift();return void 0===d?void(b&&b()):"WaitingOnDeps"===d.state?(!1,void h(a,b,c)):void i(d,function(){h(a,b,c)},c)}function i(a,b,c){switch(a.state){case"WaitingForTurn":return e(a),void i(a,b,c);case"Failed":return void(c&&c(a.stateData));case"Executed":return void b();case"Loading":case"WaitingOnDeps":return void a.onNextStateChange.push(function(){return i(a,b,c)});case"Initialized":throw new Error("All dependencies should be loading already before pressureDependencyToExecute is called.");default:throw new Error("Impossible module state: "+a.state);}}function j(a,b){switch(a.state){case"Executed":case"Failed":return void b();default:a.onNextStateChange.push(function(){return j(a,b)});}}function k(a,b){void 0===b&&(b="anonymous");var c=q[a];return void 0===c&&(c=q[a]={url:a,urlBase:m(a),exports:Object.create(null),state:"Initialized",stateData:void 0,isTopLevel:!1,crossorigin:b,onNextStateChange:[]}),c}function l(a){return v.href=a,v.href}function m(a){return a=a.split("?")[0],a=a.split("#")[0],a.substring(0,a.lastIndexOf("/")+1)}function n(a,b){return-1===b.indexOf("://")?l("/"===b[0]?b:a+b):b}function o(){return document.baseURI||(document.querySelector("base")||window.location).href}function p(){var b=document.currentScript;if(!b)return u;if(window.HTMLImports){var c=window.HTMLImports.importForElement(b);return c?c.href:u}var d=b.ownerDocument.createElement("a");return d.href="",d.href}if(!window.define){var q=Object.create(null),r=void 0,s=0,t=void 0,u=o();window.define=function(a,b){var d=!1;r=function(){return d=!0,r=void 0,[a,b]};var f=p(),g=document.currentScript&&document.currentScript.getAttribute("crossorigin")||"anonymous";setTimeout(function(){if(!1==d){r=void 0;var h=f+"#"+s++,i=k(h,g);i.isTopLevel=!0;var l=c(i,a,b);void 0===t?e(l):j(k(t),function(){e(l)}),t=h}},0)},window.define._reset=function(){for(var a in q)delete q[a];r=void 0,s=0,t=void 0,u=o()};var v=document.createElement("a")}})();</script><script async="">define(['./src/console-app.js']);</script><script type="text/javascript">var BrowserDetect={init:function(){this.browser=this.searchString(this.dataBrowser)||"Other";this.version=this.searchVersion(navigator.userAgent)||this.searchVersion(navigator.appVersion)||"Unknown"},searchString:function(data){for(var i=0,dataString;i<data.length;i++){dataString=data[i].string;this.versionSearchString=data[i].subString;if(-1!==dataString.indexOf(data[i].subString)){return data[i].identity}}},searchVersion:function(dataString){var index=dataString.indexOf(this.versionSearchString);if(-1===index){return}var rv=dataString.indexOf("rv:");if("Trident"===this.versionSearchString&&-1!==rv){return parseFloat(dataString.substring(rv+3))}else{return parseFloat(dataString.substring(index+this.versionSearchString.length+1))}},dataBrowser:[{string:navigator.userAgent,subString:"Chrome",identity:"Chrome"},{string:navigator.userAgent,subString:"MSIE",identity:"Explorer"},{string:navigator.userAgent,subString:"Edge",identity:"Edge"},{string:navigator.userAgent,subString:"Trident",identity:"Explorer"},{string:navigator.userAgent,subString:"Firefox",identity:"Firefox"},{string:navigator.userAgent,subString:"Safari",identity:"Safari"},{string:navigator.userAgent,subString:"Opera",identity:"Opera"}]};document.addEventListener("DOMContentLoaded",function(event){BrowserDetect.init();if("Chrome"===BrowserDetect.browser&&38<=BrowserDetect.version||"Firefox"===BrowserDetect.browser&&37<=BrowserDetect.version||"Safari"===BrowserDetect.browser&&538<=BrowserDetect.version||"Opera"===BrowserDetect.browser&&27<=BrowserDetect.version||"Edge"===BrowserDetect.browser&&1<=BrowserDetect.version){document.getElementById("incompatibleBrowserOverlay").style.display="none";document.getElementById("incompatibleBrowser").style.display="none";document.getElementById("img-firefox").src="";document.getElementById("img-chrome").src="";document.getElementById("img-opera").src="";document.getElementById("img-edge").src=""}else{document.getElementById("console").style.display="none"}});</script><style>@font-face{font-family:'Sansation-bold';src:url('fonts/Sansation-Bold.ttf') format('truetype');}@font-face{font-family:"Chalk-Font";src:url(fonts/blzee.ttf) format("truetype");}body{font-family:'Roboto', 'Noto', sans-serif;margin:0;}html,
body{height:100%;width:100%;position:fixed;}console-app{height:100%;width:100%;}#incompatibleBrowserOverlay{background-color:grey;opacity:0.7;width:100%;height:100%;left:0;top:0;position:absolute;z-index:10000;}#incompatibleBrowser{z-index:10001!important;}#incompatibleBrowser h2{font-size:16px;font-weight:normal;}#incompatibleBrowser h3{position:absolute;top:46px;}#incompatibleBrowser table td{width:25%;text-align:center;}#incompatibleBrowser table td img{margin:14px 0;width:100px;}#incompatibleBrowser table td:hover img{margin:0;width:128px;}#incompatibleBrowser table td a{margin-top:10px;text-decoration:none;color:black;font-weight:bold;}.background-outer-wrapper{background:linear-gradient(to top, rgba(7,15,36,1) 0%,rgba(17,25,48,1) 100%);background-size:cover;display:block;height:100%;width:100%;}.background-inner-wrapper{height:100%;width:100%;background-image:url('images/background-image.svg');display:flex;justify-content:center;align-items:center;}.loading-container{background:white;min-width:480px;width:25%;height:360px;display:flex;flex-direction:column;justify-content:center;align-items:center;}.loading-logo{fill:#32c9ac;width:150px;height:150px;-webkit-animation:spin 2s linear infinite;-moz-animation:spin 2s linear infinite;animation:spin 2s linear infinite;}.verdana{font-family:Verdana, sans-serif;}</style></head><body><console-app><div class="background-outer-wrapper"><div class="background-inner-wrapper"><div class="loading-container"><svg class="loading-logo" viewBox="0 0 141.73 141.73"><polygon id="part1" class="logoPolygon" points="26.2,124.6 43.4,124.6 43.4,68.4 26.2,68.4"><animate begin="0s" id="zeroFrame1" dur="40ms" fill="freeze" attributeName="points" to="26.2,124.6 43.4,124.6 43.4,124.6 26.2,124.6"></animate><animate keyTimes="0;1" calcMode="spline" keySplines=".42 0 1 1" begin="0s; resetAnim9.end" id="anim1" dur="400ms" fill="freeze" attributeName="points" to="26.2,124.6 43.4,124.6 43.4,68.4 26.2,68.4"></animate><animate begin="anim5.end" id="anim7" dur="300ms" fill="freeze" attributeName="points" to="26.2,68.4 43.4,68.4 43.4,68.4 26.2,68.4"></animate><animate begin="anim7.end" id="resetAnim7" dur="50ms" fill="freeze" attributeName="points" to="26.2,124.6 43.4,124.6 43.4,124.6 26.2,124.6"></animate></polygon><polygon id="part2" class="logoPolygon" points="59.3,28.5 71.5,40.6 19.8,92.2 7.7,80.1"><animate begin="0s" id="zeroFrame2" dur="40ms" fill="freeze" attributeName="points" to="7.7,80.1 19.8,92.2 19.8,92.2 7.7,80.1"></animate><animate keyTimes="0; 1" calcMode="spline" keySplines=" 0 0 .59 1" begin="195ms; resetAnim9.end + 195ms" id="anim2" dur="700ms" fill="freeze" attributeName="points" to="59.3,28.5 71.5,40.6 19.8,92.2 7.7,80.1"></animate><animate begin="anim5.end + 150ms" id="anim8" dur="600ms" fill="freeze" attributeName="points" to="59.3,28.5 71.5,40.6 71.5,40.6 59.3,28.5"></animate><animate begin="anim8.end" id="resetAnim8" dur="50ms" fill="freeze" attributeName="points" to="7.7,80.1 19.8,92.2 19.8,92.2 7.7,80.1"></animate></polygon><polygon id="part3" class="logoPolygon" points="133.8,80.1 121.7,92.2 58.6,29.2 70.4,16.6"><animate begin="0s" id="zeroFrame3" dur="40ms" fill="freeze" attributeName="points" to="70.4,16.6 58.6,29.2 58.6,29.2 70.4,16.6 "></animate><animate begin="anim2.end" id="anim3" dur="700ms" fill="freeze" attributeName="points" to="133.8,80.1 121.7,92.2 58.6,29.2 70.4,16.6"></animate><animate begin="resetAnim8.end" id="anim9" dur="600ms" fill="freeze" attributeName="points" to="133.8,80.1 121.7,92.2 121.7,92.2 133.8,80.1"></animate><animate begin="anim9.end" id="resetAnim9" dur="50ms" fill="freeze" attributeName="points" to="70.4,16.6 58.6,29.2 58.6,29.2 70.4,16.6"></animate></polygon><polygon id="part4" class="logoPolygon" points="98.2,68.4 115.4,81 115.4,108 98.2,108"><animate begin="0s" id="zeroFrame4" dur="40ms" fill="freeze" attributeName="points" to="98.2,68.4 115.4,81 115.4,81 98.2,68.4"></animate><animate keyTimes="0;1" calcMode="spline" keySplines=".42 0 1 1" begin="anim2.end + 500ms" id="anim4" dur="400ms" fill="freeze" attributeName="points" to="98.2,68.4 115.4,81 115.4,108 98.2,108"></animate><animate keyTimes="0;1" calcMode="spline" keySplines=".42 0 1 1" begin="resetAnim8.end + 400ms" id="anim10" dur="400ms" fill="freeze" attributeName="points" to="98.2,108 115.4,108 115.4,108 98.2,108"></animate><animate begin="anim10.end" id="resetAnim10" dur="50ms" fill="freeze" attributeName="points" to="98.2,68.4 115.4,81 115.4,81 98.2,68.4"></animate></polygon><polygon id="part5" class="logoPolygon" points="78.1,107.5 78.1,124.7 115.4,124.7 115.4,107.5"><animate begin="0s" id="zeroFrame5" dur="40ms" fill="freeze" attributeName="points" to="115.4,107.5 115.4,124.7 115.4,124.7 115.4,107.5"></animate><animate begin="anim4.end" id="anim5" dur="300ms" fill="freeze" attributeName="points" to="78.1,107.5 78.1,124.7 115.4,124.7 115.4,107.5"></animate><animate keyTimes="0; 1" calcMode="spline" keySplines=" 0 0 .59 1" begin="resetAnim10.end" id="anim11" dur="300ms" fill="freeze" attributeName="points" to="78.1,107.5 78.1,124.7 78.1,124.7 78.1,107.5"></animate><animate begin="anim11.end" id="resetAnim11" dur="50ms" fill="freeze" attributeName="points" to="115.4,107.5 115.4,124.7 115.4,124.7 115.4,107.5"></animate></polygon><polygon id="part6" class="logoPolygon" points="61.8,90 61.8,124.7 79,124.7 79,90"><animate begin="0s" id="zeroFrame6" dur="40ms" fill="freeze" attributeName="points" to="61.8,124.7 61.8,124.7 79,124.7 79,124.7"></animate><animate keyTimes="0; 1" calcMode="spline" keySplines=" 0 0 .59 1" begin="anim5.end" id="anim6" dur="500ms" fill="freeze" attributeName="points" to="61.8,90 61.8,124.7 79,124.7 79,90"></animate><animate keyTimes="0; 1" calcMode="spline" keySplines=" 0 0 .59 1" begin="resetAnim11.end" id="anim12" dur="400ms" fill="freeze" attributeName="points" to="61.8,90 61.8,90 79,90 79,90"></animate><animate begin="anim12.end" id="resetAnim12" dur="50ms" fill="freeze" attributeName="points" to="61.8,124.7 61.8,124.7 79,124.7 79,124.7"></animate></polygon></svg><div class="verdana">Bitte warten Sie noch kurz. IP-Symcon wird geladen.</div></div></div></div></console-app><div id="incompatibleBrowserOverlay"></div><div id="incompatibleBrowser" class="noTitle" style="position: fixed; outline: none; z-index: 12;height: 300px;width: 700px;padding: 100px 50px; top: 50%!important;left: 50%!important;margin-top: -265px!important;margin-left: -360px!important; background: #fff;color: rgba(0, 0, 0, 0.87);margin: 32px;overflow: visible !important;box-shadow: 0 13px 25px 0 rgba(0, 0, 0, 0.3);"><h3>Leider unterstützt Ihr Browser die Verwaltungskonsole nicht.</h3><br><br><h2>Wir empfehlen Ihnen die Installation der neusten Version von einem der folgenden Browsern:</h2><br><table style="margin: 0 10%; width:80%;"><tbody><tr><td><a href="https://mozilla.org/firefox"><img id="img-firefox" src="images/Firefox.png"></a></td><td><a href="https://chrome.google.com"><img id="img-chrome" src="images/Chrome.png"></a></td><td><a href="http://www.opera.com/"><img id="img-opera" src="images/Opera.png"></a></td><td><a href="http://www.browserfordoing.com/"><img id="img-edge" src="images/Edge.png"></a></td></tr><tr><td><a href="https://mozilla.org/firefox">Mozilla Firefox</a></td><td><a href="https://chrome.google.com">Google Chrome</a></td><td><a href="http://www.opera.com/">Opera</a></td><td><a href="http://www.browserfordoing.com/">Microsoft Edge</a></td></tr></tbody></table></div></body></html>
