I’m trying to get the combination of Fibaro Smart Implant and DC18B20 working.
When I add new device in Z-Wave convigurator, Fibaro appears but I do not see anything for connected DS18B20 temperature sensor.
Do I need to configure something in IP Symcon or should it appear automatically?
Did you klick into the sub channels and load the configuration for each subchannel ?
Then you should get the variables.
If at least channel 7 is empty, then something must be wrong inclusion. Channel 7 is a device internal temerature sensor.
Look, this is how it shoudl look like:
The DS18B20 shoudl appear in channel 8.
Channel nodes get created on the top level, not below Fibaro node
Channel nodes are empty, they have no properties.
I think I got it working, at least somewhat.
In the channel expert options, I turned on „Enforce basic class“
Then I got two properties Data (boolean) and Data (integer) for that channel, albeit with incorrect profile (showing percentage).
When I changed the profile I got the temperature reading.
But still my channel value is integer while in your screenshot it’s float.
And unfortunately it works only when I connect one sensor.
When I connect two of them, I get no updates.
