Hab mal bei allen 3 Gateways über das WebInterface die Helligkeit geändert.
Debug Log von Splitter1
TXT: 26.02.2018 21:25:12.00 | Receive | {"cmd":"heartbeat","model":"gateway","sid":"7811dcb07667","short_id":"0","token":"K8OJ7NlWs6m2xJld","data":"{\"ip\":\"192.168.178.159\"}"}
TXT: 26.02.2018 21:25:16.00 | Receive | {"cmd":"heartbeat","model":"gateway","sid":"7811dcb208da","short_id":"0","token":"TyBUVUxkoYIyd5gj","data":"{\"ip\":\"192.168.178.157\"}"}
TXT: 26.02.2018 21:25:16.00 | Receive | {"cmd":"heartbeat","model":"gateway","sid":"7811dcb25215","short_id":"0","token":"eEr99PwdadlCnGVE","data":"{\"ip\":\"192.168.178.158\"}"}
TXT: 26.02.2018 21:25:22.00 | Receive | {"cmd":"heartbeat","model":"gateway","sid":"7811dcb07667","short_id":"0","token":"kPEY0h2hoPRimacR","data":"{\"ip\":\"192.168.178.159\"}"}
TXT: 26.02.2018 21:25:26.00 | Receive | {"cmd":"heartbeat","model":"gateway","sid":"7811dcb208da","short_id":"0","token":"rnAKNkQrBRyjqIRq","data":"{\"ip\":\"192.168.178.157\"}"}
TXT: 26.02.2018 21:25:26.00 | Forward:cmd | write
TXT: 26.02.2018 21:25:26.00 | Forward:sid | 7811dcb07667
TXT: 26.02.2018 21:25:26.00 | Forward:data:rgb | 67108864
TXT: 26.02.2018 21:25:26.00 | Forward:model | gateway
TXT: 26.02.2018 21:25:26.00 | Send:cmd | write
TXT: 26.02.2018 21:25:26.00 | Send:sid | 7811dcb07667
TXT: 26.02.2018 21:25:26.00 | Send:model | gateway
TXT: 26.02.2018 21:25:26.00 | Send:data | {"rgb":67108864,"key":"24D4D13FD5D3EADCA9D418DFB42496C5"}
TXT: 26.02.2018 21:25:26.00 | Receive | {"cmd":"heartbeat","model":"gateway","sid":"7811dcb25215","short_id":"0","token":"NqGCPdlNX5HGMvDS","data":"{\"ip\":\"192.168.178.158\"}"}
TXT: 26.02.2018 21:25:31.00 | Result | FALSE
TXT: 26.02.2018 21:25:32.00 | Receive | {"cmd":"heartbeat","model":"gateway","sid":"7811dcb07667","short_id":"0","token":"PcNTyhxp1KHDtYrt","data":"{\"ip\":\"192.168.178.159\"}"}
TXT: 26.02.2018 21:25:32.00 | Receive | {"cmd":"report","model":"gateway","sid":"7811dcb25215","short_id":0,"data":"{\"rgb\":167748864,\"illumination\":369}"}
TXT: 26.02.2018 21:25:36.00 | Receive | {"cmd":"heartbeat","model":"gateway","sid":"7811dcb208da","short_id":"0","token":"zsXdwkrsyKBsVihJ","data":"{\"ip\":\"192.168.178.157\"}"}
TXT: 26.02.2018 21:25:36.00 | Receive | {"cmd":"report","model":"gateway","sid":"7811dcb208da","short_id":0,"data":"{\"rgb\":134194432,\"illumination\":341}"}
TXT: 26.02.2018 21:25:37.00 | Receive | {"cmd":"heartbeat","model":"gateway","sid":"7811dcb25215","short_id":"0","token":"ccON8Qp0GSXti0xQ","data":"{\"ip\":\"192.168.178.158\"}"}
TXT: 26.02.2018 21:25:42.00 | Receive | {"cmd":"heartbeat","model":"gateway","sid":"7811dcb07667","short_id":"0","token":"wRLhQRW1SOf3KFUj","data":"{\"ip\":\"192.168.178.159\"}"}
TXT: 26.02.2018 21:25:46.00 | Receive | {"cmd":"heartbeat","model":"gateway","sid":"7811dcb208da","short_id":"0","token":"YNBwoFusZzc4tzgQ","data":"{\"ip\":\"192.168.178.157\"}"}
TXT: 26.02.2018 21:25:46.00 | Receive | {"cmd":"heartbeat","model":"gateway","sid":"7811dcb25215","short_id":"0","token":"mfQeU6K5LXBcDu3G","data":"{\"ip\":\"192.168.178.158\"}"}
TXT: 26.02.2018 21:25:52.00 | Receive | {"cmd":"heartbeat","model":"gateway","sid":"7811dcb07667","short_id":"0","token":"IXzTGwfuLOs3DGfx","data":"{\"ip\":\"192.168.178.159\"}"}
TXT: 26.02.2018 21:25:56.00 | Receive | {"cmd":"heartbeat","model":"gateway","sid":"7811dcb208da","short_id":"0","token":"zZ9l8794ktoMDW7G","data":"{\"ip\":\"192.168.178.157\"}"}
TXT: 26.02.2018 21:25:56.00 | Receive | {"cmd":"heartbeat","model":"gateway","sid":"7811dcb25215","short_id":"0","token":"Fkl29Ip0cbwEvvBE","data":"{\"ip\":\"192.168.178.158\"}"}
Debug Log von Splitter2
TXT: 26.02.2018 21:25:26.00 | Receive | {"cmd":"write_ack","model":"gateway","sid":"7811dcb07667","short_id":0,"data":"{\"rgb\":67108864,\"illumination\":432,\"proto_version\":\"1.0.9\"}"}
TXT: 26.02.2018 21:25:32.00 | Forward:cmd | write
TXT: 26.02.2018 21:25:32.00 | Forward:sid | 7811dcb25215
TXT: 26.02.2018 21:25:32.00 | Forward:data:rgb | 167748864
TXT: 26.02.2018 21:25:32.00 | Forward:model | gateway
TXT: 26.02.2018 21:25:32.00 | Send:cmd | write
TXT: 26.02.2018 21:25:32.00 | Send:sid | 7811dcb25215
TXT: 26.02.2018 21:25:32.00 | Send:model | gateway
TXT: 26.02.2018 21:25:32.00 | Send:data | {"rgb":167748864,"key":"BAC8966A3170F448B25936F3D658E027"}
TXT: 26.02.2018 21:25:32.00 | Receive | {"cmd":"write_ack","model":"gateway","sid":"7811dcb25215","short_id":0,"data":"{\"rgb\":167748864,\"illumination\":369,\"proto_version\":\"1.0.9\"}"}
TXT: 26.02.2018 21:25:32.00 | Result:rgb | 167748864
TXT: 26.02.2018 21:25:32.00 | Result:illumination | 369
TXT: 26.02.2018 21:25:32.00 | Result:proto_version | 1.0.9
TXT: 26.02.2018 21:25:32.00 | Result:model | gateway
TXT: 26.02.2018 21:25:36.00 | Receive | {"cmd":"write_ack","model":"gateway","sid":"7811dcb208da","short_id":0,"data":"{\"rgb\":134194432,\"illumination\":341,\"proto_version\":\"1.0.9\"}"}
TXT: 26.02.2018 21:25:37.00 | Receive | {"cmd":"report","model":"gateway","sid":"7811dcb208da","short_id":0,"data":"{\"rgb\":134194432,\"illumination\":341}"}
TXT: 26.02.2018 21:26:02.00 | Receive | {"cmd":"heartbeat","model":"gateway","sid":"7811dcb07667","short_id":"0","token":"IYcZ9zVavIsB4tM4","data":"{\"ip\":\"192.168.178.159\"}"}
TXT: 26.02.2018 21:26:06.00 | Receive | {"cmd":"heartbeat","model":"gateway","sid":"7811dcb208da","short_id":"0","token":"dLXgcrGOeMlfJ04C","data":"{\"ip\":\"192.168.178.157\"}"}
TXT: 26.02.2018 21:26:06.00 | Receive | {"cmd":"heartbeat","model":"gateway","sid":"7811dcb25215","short_id":"0","token":"Oa8jQYsD3VvLznId","data":"{\"ip\":\"192.168.178.158\"}"}
Debug Log von Splitter3
TXT: 26.02.2018 21:25:36.00 | Forward:cmd | write
TXT: 26.02.2018 21:25:36.00 | Forward:sid | 7811dcb208da
TXT: 26.02.2018 21:25:36.00 | Forward:data:rgb | 134194432
TXT: 26.02.2018 21:25:36.00 | Forward:model | gateway
TXT: 26.02.2018 21:25:36.00 | Send:cmd | write
TXT: 26.02.2018 21:25:36.00 | Send:sid | 7811dcb208da
TXT: 26.02.2018 21:25:36.00 | Send:model | gateway
TXT: 26.02.2018 21:25:36.00 | Send:data | {"rgb":134194432,"key":"30038440992DC4E7E562686F679BA878"}
TXT: 26.02.2018 21:25:41.00 | Result | FALSE
TXT: 26.02.2018 21:26:12.00 | Receive | {"cmd":"heartbeat","model":"gateway","sid":"7811dcb07667","short_id":"0","token":"WD3ND1xTQDYDT3zo","data":"{\"ip\":\"192.168.178.159\"}"}
