Hello, I’m new to this. I’ve had xcomfort for several years, and want to update it and control via GalaxyTab.
Is anything preprogrammed? Or do you need to code everything yourself?
Is it only the USB intreface you need? Or the program. interface also?
I dont want to spend 99eur if its a bunch of scripting.
I quess there is no demo version?
You will need the programming interface and gateway to get everything set up easily. Then you will be able to export the datapoint list, which in turn you can import to IP-Symcon. The last step is to sort/order you devices as you wish and you are set.
If you just want to visualize/control you won’t need to script anything.
