Sorry for writing in English. Google translate is not that good at technical English I have experienced reading this forum. : o
Im new at IPS, and wonder if its possible to assign both UP and DOWN on a switch to individual booleans? As per default it is a set/reset of only one variable. I would like to use up and down for different scenarios on a few switches.
I also wonder how users controll their IPS-Xcomfort systems. Do you add scenarios in MRF or only IPS? It seems like MRF have a broadcast to use. If I (IPS) script a ALL OFF it will turn of one dimmer at the time, while MRF turns it all off at the same time.
