I am quite new to IP-Symcon just purchased the basic version so I am sorry if this is a newbie question.
My Raspberry Pi 2B is now running IP Symcon with kernel version 4.0 and liveupdate version 26.02.2016. (from ips console).
As interface I am using the CKOZ-00/14 usb stick. I now manage to controll all connected dimmers & switches in the system. But the status for the dimmers is not updating.
I have enabled in the MRC to send „old status“ to the USB interface and I can see in the traffic view that the status is sendt. But the IPS will not update status for dimmers only the switching actuators.
I experience the same issue.
Hardware; Raspberry Pi 3 (Raspian) and xComfort CKOZ-00/14.
IP-Symcon: Kernel Version 4.00, update version 11.03.2016 - professional license.
The dimmer module is an CDAU-01/03 (125W LED dimmer)
Which firmware on the CI do you have? Did you update it recently? (Maybe the same time as IP-Symcon 4.0?)
I think the problem is in the CI firmware… Using an old (bulky) CI works flawlessly and your screenshot of the data shows no signs of a dimmer status value. And using your mentioned CI stick with IP-Symcon 3.4 has the same issue.
OK. I already send some debug information to Eaton. Hopefully they will find the root cause of the problem, as it doesn’t seem related to IP-Symcon at the moment. I’ll update this thread as soon as i get an answer.
Eaton confirmed the problem and already send me a fixed firmware. After i will validate that it is working properly, i will try to get an ETA of the public release and if i can supply you with the current test version.
