Do iP-Symcon support the Xcomfort CHAZ-01/01 electric panel heating actuator? Can I control a panel heater with just a gateway and the actuator?
As far as i can tell, it is compatible with IP-Symcon. Though i am not sure if this device will do, what you want it to do. Looking at the specs you will only be able to enable/disable the Economy Mode in the device.
No. You need the programming interface as well to connect it via comfort mode.
