X10 Marmitek
Hi All,
I did see some references to the Marmitek PLC module CM11, however they all seem to deal with ipsymcon 1…
Is there any way to hook up a CM11 or similar so I can control all my old x10 stuff?
There is a script that might be compatible with the 2.x releases. But probably you will have to adjust a few lines of code.
