Hello again. Will ips work on Win XP EMBEDDED? I know it wont on CE and win embedded, but it should on XP right?
Sent from my GT-I9295 using Tapatalk
It might work, but we have not tested it, nor can we provide any assistance if you encounter problems that are solely owed to the xp embedded platform. AFAIK there are some limitations regarding media player playback.
Thanx. Ill test it when i get the beckhoff plc.
I run it for a while on my beckhoff cx1030 on win xp embedded, and it works very well!
Sweet. How do you link between beckhoff and ips? Ads or modbus?
I take modbus, because i have no idea how to use it over ads. Last month i switched over with ips to a regular pc system, because with big data sources like power consumption for a month, it takes to long until it will show it.
Thanx for the input.
