Hallo Zusammen,
hat einer von Euch schon den WIFFI Pulsecounter von Eugen Stall in IPS eingebunden?
Ich habe hier im Forum nur etwas über den WIFFI Wohnzimmersensor gefunden, aber ich kann es nicht auf den Pulsecounter übertragen.
https://www.symcon.de/forum/threads/33291-WIFFI-WZ-direkt-in-Symcon-nutzen
Den ServerSocket habe ich am Laufen (Port 8181), eine RegVar angelegt und der Counter sendet regelmäßig Daten.
Es sind laut Doku json-Daten, aber das mit dem Cutter und json_decode() funktioniert nicht richtig.
$buf = $_IPS['VALUE'];
$data = json_decode($buf, true);
Hier die Daten:
05.08.2019, 23:09:59 | RECEIVED [10.1.1.197:25347] | {"modultyp":"PULSECOUNTER","vars":[{"name":"0","homematic_name":"w_counter_ip","desc":"ip des pulsecounters","type":"string","unit":"","value":"10.1.1.197"},{"name":"11","homematic_name":"w_counter_1","desc":"w_counter_1","type":"number","unit":"KWh","value":1111.11},{"name":"12","homematic_name":"w_power_1","desc":"w_power_1","type":"number","unit":"KW","value":"inf"},{"name":"13","homematic_name":"w_counter_2","desc":"w_counter_2","type":"number","unit":"KWh","value":2222.22},{"name":"14","homematic_name":"w_power_2","desc":"w_power_2","type":"number","unit":"KW","value":"inf"},
05.08.2019, 23:09:59 | RECEIVED [10.1.1.197:25347] | {"name":"15","homematic_name":"w_counter_3","desc":"w_counter_3","type":"number","unit":"KWh","value":3333.33},{"name":"16","homematic_name":"w_power_3","desc":"w_power_3","type":"number","unit":"KW","value":0.006},{"name":"17","homematic_name":"w_counter_4","desc":"w_counter_4","type":"number","unit":"m3","value":4444.44},{"name":"18","homematic_name":"w_power_4","desc":"w_power_4","type":"number","unit":"m3/h","value":0.001}],
05.08.2019, 23:09:59 | RECEIVED [10.1.1.197:25347] | "Systeminfo":{"MAC-Adresse":"xx:xx:xx:xx:xx:xx","Homematic_CCU_ip":"x.x.x.x","WLAN_ssid":"WLAN2","WLAN_Signal_dBm":-67,"sec_seit_reset":52578,"zeitpunkt":"2019.08.05/23:09:58","firmware":"wiffi_counter_29"}}
Die kommen leider in drei Blöcken?
Kann jemand helfen?
Viele Grüße aus dem Unterallgäu
Harry
