I try to control my X-Comfort devices with iP-Symcom (Basic) and struggle with the /&%(&/ WebFront.
I’ve entered the WebFront Configurator but I simply cannot get to select which elements to be added. The most „detailed“ view I can get to is this:
I have struggled the whole eventing and now there are some elements there that works and some elements from an earlier try that is now illegal and does not work, but at the same time is impossible to remove…
This has to be one of the worst GUIs I’ve ever encountered… I thought I would be able to understand it by google translating the docs, but I really miss a good doc in english here.
Just delete the Configurator within the object tree and create a new one. This will fix your problem. And as ralf said. Your configuration capabilites within the configurator are very limited in the basic version. You shouldn’t have been able to drag&drop you „misplaced“ item.
So why am I allowed to open the Webfront Configurator in the first place if it’s not part of the Basic version? Without any warning or error message. It’s senseless…
I didn’t get that the Basic version didn’t support the Webfront configurator. But it seems to support Webfront. Can you please point me to where in the docs it is described how to configure Webfront without the configurator?
