Hiya All
After upgrade to IPS 2.2 the WebFront fails all the time, alot of *.js errors.
I get equal errors like in this post.
Tried to delete the hole webfront and installed it again, also tried to delete the configuration and let IPS to rebuild the German Weather thingie and the Clock Widget.
Same errors
Here is one of them.
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.2; Trident/4.0; .NET CLR 1.1.4322; .NET CLR 2.0.50727; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729)
Timestamp: Wed, 17 Mar 2010 21:37:34 UTC
Message: Syntax error
Line: 1
Char: 1
Code: 0
URI: http://192.168.1.10/data/lang.php?action=js&ts=1268861850
Thanks
