ich dachte der Fehler wäre längs bekannt
Hier noch einige Stellen die Tommis Module und IPSView betreffen:
WARNING | PHPLibrary | Parameter file in function IPSView_RestoreByFileName has no type hint. Please use either 'bool', 'int', 'float' or 'string'.
PHPLibrary | Parameter idx in function IPSView_RestoreByFileIdx has no type hint. Please use either 'bool', 'int', 'float' or 'string'.
WARNING | PHPLibrary | Parameter Data in function APCUPSD_SendDataToChildren has no type hint. Please use either 'bool', 'int', 'float' or 'string'.
WARNING | PHPLibrary | Parameter Data in function END_SendDataToParent has no type hint. Please use either 'bool', 'int', 'float' or 'string'.
WARNING | PHPLibrary | Parameter rainpercount in function WUE_SetRainPerCount has no type hint. Please use either 'bool', 'int', 'float' or 'string'.
WARNING | PHPLibrary | Parameter Data in function WUE_SendDataToParent has no type hint. Please use either 'bool', 'int', 'float' or 'string'.
WARNING | PHPLibrary | Parameter Data in function NUT_SendDataToChildren has no type hint. Please use either 'bool', 'int', 'float' or 'string'.
WARNING | PHPLibrary | Parameter Data in function SWD_SendDataToParent has no type hint. Please use either 'bool', 'int', 'float' or 'string'.
WARNING | PHPLibrary | Parameter Data in function TE923_SendDataToChildren has no type hint. Please use either 'bool', 'int', 'float' or 'string'.
WARNING | PHPLibrary | Parameter rainpercount in function WDE1_SetRainPerCount has no type hint. Please use either 'bool', 'int', 'float' or 'string'.
WARNING | PHPLibrary | Parameter Data in function WDE1_SendDataToParent has no type hint. Please use either 'bool', 'int', 'float' or 'string'.
WARNING | PHPLibrary | Parameter Data in function WS2500PC_SendDataToChildren has no type hint. Please use either 'bool', 'int', 'float' or 'string'.
WARNING | PHPLibrary | Parameter Data in function WS300PC_SendDataToChildren has no type hint. Please use either 'bool', 'int', 'float' or 'string'.
WARNING | PHPLibrary | Parameter Value in function THL_SetActive has no type hint. Please use either 'bool', 'int', 'float' or 'string'.
WARNING | PHPLibrary | Parameter JSONString in function PHT_Send has no type hint. Please use either 'bool', 'int', 'float' or 'string'.
WARNING | PHPLibrary | Parameter title in function PHT_SendMessage has no type hint. Please use either 'bool', 'int', 'float' or 'string'.
WARNING | PHPLibrary | Parameter message in function PHT_SendMessage has no type hint. Please use either 'bool', 'int', 'float' or 'string'.
WARNING | PHPLibrary | Parameter level in function PHT_SetVolume has no type hint. Please use either 'bool', 'int', 'float' or 'string'.
Hans
