leider krieg ichs nicht hin . Hab nun schon seit fast 2 Wochen diverse Sachen versucht, es geht einfach nicht.
Die Standardkonfiguration läuft, sobald ich meine eigenen Sprachbefehle einfüge und Cortana Hook bearbeite Fehler
Anbei mal meine Sorachbefehle
<? //Do not delete or modify.
include(IPS_GetKernelDirEx()."scripts/__ipsmodule.inc.php");
include("../modules/ips4Windows/ips4WinCortana/module.php");
$ips4WinCortana = new ips4WinCortana(29889 /*[ips4WinCortana\CortanaVoiceCommands]*/);
//Your code goes here...
$ips4WinCortana->EnableDebug(true);
//you can add up to 100 sections (called Commands, each need a unique name like Block1\/Block2 or what ever you like)
//each section can have up to 10 speach commands and include multiple PhraseLists (like {room}) entries
$ips4WinCortana->AddVoiceCommand("Block1","schalte das Licht im {room} {action}");
$ips4WinCortana->AddVoiceCommand("Block2","{action} das Rollo im {room}");
//each section needs a Feedback and Example entry. Feedback is used when command was processed from Cortana
//Example will shown, when user asks Cortana "What can I say?/Was kann ich sagen?"
$ips4WinCortana->AddCommandExample("Block1","schalte das Licht im Wohnzimmer an");
$ips4WinCortana->AddCommandExample("Block2","schliesse das Rollo im Büro");
$ips4WinCortana->AddCommandFeedback("Block1","ok, ich verarbeite deinen Befehl");
$ips4WinCortana->AddCommandFeedback("Block2","ich arbeite dran");
//you can add multiple PhraseLists with an total of max. 2000 entries
$ips4WinCortana->AddActionPhraseCommand("action","öffne");
$ips4WinCortana->AddActionPhraseCommand("action","schliesse");
$ips4WinCortana->AddActionPhraseCommand("action","an");
$ips4WinCortana->AddActionPhraseCommand("action","aus");
$ips4WinCortana->AddActionPhraseCommand("actor","Rollo");
$ips4WinCortana->AddActionPhraseCommand("actor","Licht");
$ips4WinCortana->AddActionPhraseCommand("actor","Radio");
$ips4WinCortana->AddActionPhraseCommand("action","schalte");
$ips4WinCortana->AddActionPhraseCommand("action","stelle");
$ips4WinCortana->AddActionPhraseCommand("action","ändere");
$ips4WinCortana->AddActionPhraseCommand("action","dimme");
$ips4WinCortana->AddActionPhraseCommand("status","an");
$ips4WinCortana->AddActionPhraseCommand("status","aus");
$ips4WinCortana->AddActionPhraseCommand("status","Hälfte");
$ips4WinCortana->AddActionPhraseCommand("status","0");
$ips4WinCortana->AddActionPhraseCommand("status","10");
$ips4WinCortana->AddActionPhraseCommand("status","17");
$ips4WinCortana->AddActionPhraseCommand("status","18");
$ips4WinCortana->AddActionPhraseCommand("status","19");
$ips4WinCortana->AddActionPhraseCommand("status","20");
$ips4WinCortana->AddActionPhraseCommand("status","21");
$ips4WinCortana->AddActionPhraseCommand("status","22");
$ips4WinCortana->AddActionPhraseCommand("status","23");
$ips4WinCortana->AddActionPhraseCommand("status","24");
$ips4WinCortana->AddActionPhraseCommand("status","30");
$ips4WinCortana->AddActionPhraseCommand("status","40");
$ips4WinCortana->AddActionPhraseCommand("status","50");
$ips4WinCortana->AddActionPhraseCommand("status","60");
$ips4WinCortana->AddActionPhraseCommand("status","70");
$ips4WinCortana->AddActionPhraseCommand("status","80");
$ips4WinCortana->AddActionPhraseCommand("status","90");
$ips4WinCortana->AddActionPhraseCommand("status","100");
$ips4WinCortana->AddActionPhraseCommand("room","Garten");
$ips4WinCortana->AddActionPhraseCommand("room","Wohnzimmer");
$ips4WinCortana->AddActionPhraseCommand("room","Küche");
$ips4WinCortana->AddActionPhraseCommand("room","Schlafzimmer");
$ips4WinCortana->AddActionPhraseCommand("room","Bad");
$ips4WinCortana->AddActionPhraseCommand("room","Kinderzimmer");
$ips4WinCortana->AddActionPhraseCommand("room","Erdgeschoss");
$ips4WinCortana->AddActionPhraseCommand("room","Obergeschoss");
$ips4WinCortana->AddActionPhraseCommand("room","Flur")
//ProcessData will convert all the entries to something readable for ips4Windows App
$ips4WinCortana->ProcessData();
kommt am Ende Fehlermeldung
Parse error: syntax error, unexpected ‚$ips4WinCortana‘ (T_VLE) in /var/lib/symcon/scripts/37449.ips.php on line 76
Scheinbar bin ich zu doof dazu.
PS entschuldige Sebimann das ich dir damit auf den Sack gehe aber ich weiss nicht mehr weiter.
