Ich war es langsam satt, bei jedem neuen Gerät DNS, DHCP, etc. einzustellen. Also habe ich eine Access-Datenbank erstellt.
Ein VBA-Skript produziert folgende Dateien:
[ul]
[li].cfg files für Nagios [/li][li].cfg files für Munin, [/li][li]eine webpage mit allen anklickbaren Geräten[/li][li]DNS-Tables für Windows Server (forward und reverse). [/li][li]DHCP-Tables für Windows Server. [/li][/ul]
Ich lege den Skript hier bei. Falls jemand ans *.accdb Dokument interessiert ist, bitte PM.
Option Compare Database
Sub configLan()
Dim testSQL As String
Dim qd As DAO.QueryDef
Dim db As Database
Dim rstDynaset As Recordset
Dim rstSnapshot As Recordset
Dim rstForwardOnly As Recordset
Dim rstHostGroups As Recordset
Dim rstTableNetAssets As Recordset
Dim rstServicesPerHostgroup As Recordset
Dim rstServices As Recordset
Dim rstTextBlocks As Recordset
Dim rstLoop As Recordset
Dim prpLoop As Property
Set dbNetAssets = CurrentDb
' check if the environment exists; if not then change path
FileLocation = DropboxPath() & "Bellaria\BellariaNetwork\"
With dbNetAssets
' export a CSV file containing the hostgroup names
Set rstTableNetAssets = .OpenRecordset("qryNetAssets", dbOpenSnapshot)
Set rstHostGroups = .OpenRecordset("qryNagiosHostGroups", dbOpenSnapshot)
Set rstServicesPerHostgroup = .OpenRecordset("qryServicesPerHostgroup", dbOpenSnapshot)
Set rstServices = .OpenRecordset("tblNagiosServiceDefinitions", dbOpenSnapshot)
Set rstTextBlocks = .OpenRecordset("tblNagiosServiceDefinitions", dbOpenSnapshot)
Set webPageBlock = .OpenRecordset("SELECT tblTxtBlocks.txtContent FROM tblTxtBlocks WHERE (((tblTxtBlocks.txtDescription)='webPageNetAssets'));")
End With
'write cfg files
Dim fso As Object
Set fso = CreateObject("Scripting.FileSystemObject")
Dim hostgroupsFile As Object
Dim hostsFile As Object
Dim servicesFile As Object
Dim dnsFile As Object
Dim dhcpFile As Object
Set hostgroupsFile = fso.CreateTextFile(FileLocation & "bellaria_hostgroups.cfg")
Set hostsFile = fso.CreateTextFile(FileLocation & "bellaria_hosts.cfg")
Set servicesFile = fso.CreateTextFile(FileLocation & "bellaria_services.cfg")
Set dnsFile = fso.CreateTextFile(FileLocation & "dns_table_lan.cfg")
Set dhcpFile = fso.CreateTextFile(FileLocation & "dhcp_table_lan.cfg")
Set netAssetsWebPage = fso.CreateTextFile(FileLocation & "netAssetsWebPage.html")
'write nagios configuration files
hostgroupsFile.Writeline createHostgroupCfg(rstHostGroups)
hostgroupsFile.Writeline createTemplatesCfg(rstHostGroups)
hostsFile.Writeline createHostsCfg(rstTableNetAssets)
hostsFile.Writeline generic_host()
servicesFile.Writeline createServicesCfg(rstServices)
servicesFile.Writeline generic_service()
servicesFile.Writeline generic_contact()
netAssetsWebPage.Writeline webPageBlock!txtContent & MakeNetAssetsWebPage(rstTableNetAssets)
'write dns and dhcp configuration files
'dhcpFile.Writeline createDhcpTable(rstTableNetAssets)
dnsFile.Writeline createDnsTable(rstTableNetAssets)
hostgroupsFile.Close
Set fso = Nothing
Set hostgroupsFile = Nothing
Set hostsFile = Nothing
Set servicesFile = Nothing
' run powershell command to assign dhcp and dns entries
finish = runPowershell()
End Sub
Function DropboxPath()
'set file location to Dropbox
'first find the info.json file
dropboxEnv1 = Environ("AppData") & "\Dropbox\info.json"
dropboxEnv2 = Environ("LocalAppData") & "\Dropbox\info.json"
If Dir(dropboxEnv1) <> "" Then
Debug.Print "5" & Dir(dropboxEnv1)
dropboxJson = readLine(dropboxEnv1)
Else
Debug.Print "6: " & Dir(dropboxEnv2)
If Dir(dropboxEnv2) <> "" Then
Debug.Print "7" & dropboxEnv2
dropboxJson = readLine(dropboxEnv2)
Else
Debug.Print ("no dropbox")
Exit Function
End If
End If
' then extract the path
pathPosition = InStr(dropboxJson, Chr(34) & "path" & Chr(34) & ":")
dBoxPathTemp = Mid(dropboxJson, pathPosition + 9)
dBoxPath = Left(dBoxPathTemp, InStr(dBoxPathTemp, ", ") - 2)
dBoxPath = Replace(dBoxPath, "\\", "\") & "\"
Debug.Print "dBoxPath*" & dBoxPath & "*"
DropboxPath = dBoxPath
End Function
Function readLine(fileInputName)
Dim FileNum As Integer
Dim DataLine As String
Debug.Print fileInputName
FileNum = FreeFile()
Open fileInputName For Input As #FileNum
While Not EOF(FileNum)
Line Input #FileNum, DataLine ' read in data 1 line at a time
readLine = readLine & DataLine
' decide what to do with dataline,
' depending on what processing you need to do for each case
Wend
End Function
Function createHostgroupCfg(rstHostGroups As Recordset)
' prepare hostgroup and templates table
'Check to see if the recordset actually contains rows
If Not (rstHostGroups.EOF And rstHostGroups.BOF) Then
rstHostGroups.MoveFirst 'Unnecessary in this case, but still a good habit
Do Until rstHostGroups.EOF = True
vHostgroupDef = "define hostgroup {" & vbCrLf & _
vbTab & "hostgroup_name " & rstHostGroups!NagiosHostGroups & vbCrLf & _
vbTab & "# alias " & vbCrLf & _
vbTab & "}" & vbCrLf & vbCrLf
vHostgroupDefs = vHostgroupDefs & vHostgroupDef
'Move to the next record. Don't ever forget to do this.
rstHostGroups.MoveNext
Loop
Else
MsgBox "There are no records in the recordset."
End If
'MsgBox "Finished looping through records."
' Debug.Print vHostgroupDefs
createHostgroupCfg = vHostgroupDefs
End Function
Function createTemplatesCfg(rstHostGroups As Recordset)
' templates are for each hostgroup (same)
vHostgroupDef = "define host { ; THIS IS A TEMPLATE" & vbCrLf & _
vbTab & "name " & rstHostGroups!NagiosHostGroups & "_template" & vbCrLf & _
vbTab & "use generic-host" & vbCrLf & _
vbTab & "register 0 ; DO NOT REGISTER BECAUSE THIS IS JUST A TEMPLATE" & vbCrLf & _
Loop
Else
End If
createTemplatesCfg = vHostgroupDefs
End Function
Function createHostsCfg(rstTableNetAssets As Recordset)
' prepare host table
vHostsCounter = 0
With rstTableNetAssets
If Not (.EOF And .BOF) Then
Do Until .EOF = True
If (Trim(!HostName) = "" Or IsNull(!HostName)) Then
Debug.Print "hostname is null!"
Debug.Print vHostDefs
Exit Do
End If
vHostsCounter = vHostsCounter + 1
vHostDef = "# record " & vHostsCounter & vbCrLf & _
"define host {" & vbCrLf & _
vbTab & "host_name " & !HostName & vbCrLf & _
vbTab & "address " & !ip_address & vbCrLf & _
vbTab & "use " & !NagiosHostGroups & "_template" & vbCrLf & _
vbTab & "hostgroups " & !NagiosHostGroups & vbCrLf & _
vbTab & "notifications_enabled " & IIf(!nagios_alert, 1, 0) & vbCrLf & _
vbTab & "check_command check_ping!100.0,20%!500.0,60%" & vbCrLf & _
vHostDefs = vHostDefs & vHostDef
rstTableNetAssets.MoveNext
Loop
Else
End If
createHostsCfg = vHostDefs
' write text file with all hosts
End With
'Set rstTableNetAssets = Nothing 'Clean up
'rstTableNetAssets.Close
End Function
Function createServicesCfg(rstServices As Recordset)
rstSql1 = "SELECT tblServicesPerHostgroup.HostGroupName, tblServicesPerHostgroup.IdService " & _
"FROM qryNagiosHostgroups INNER JOIN (tblServicesPerHostgroup LEFT JOIN tblNagiosServiceDefinitions " & _
"ON tblServicesPerHostgroup.IdService = tblNagiosServiceDefinitions.ID) " & _
"ON qryNagiosHostgroups.NagiosHostGroups = tblServicesPerHostgroup.HostGroupName " & _
"WHERE (((tblServicesPerHostgroup.IdService)= "
rstSql2 = " ));"
vServicesCounter = 0
With rstServices
vServicesCounter = vServicesCounter + 1
' find all applicable hosts for this service
rstSql = rstSql1 & !ID & rstSql2
'Debug.Print rstSql
Set rstHostgroupsPerService = CurrentDb.OpenRecordset(rstSql, dbOpenSnapshot)
With rstHostgroupsPerService
hostgroupsCollection = ""
hostgroupsCollection = hostgroupsCollection & ", " & !HostGroupName
.MoveNext
Loop
hostgroupsCollection = Mid(hostgroupsCollection, 2)
End If
End With
Debug.Print vServicesCounter, hostgroupsCollection
'if the service is not in use by any hostgroup, put together service definition
If (Len(hostgroupsCollection) > 3) Then
vServicesDef = "# record " & vServicesCounter & vbCrLf & _
"# " & !nagios_description & vbCrLf & _
"define service {" & vbCrLf & _
vbTab & "hostgroup_name " & hostgroupsCollection & vbCrLf & _
vbTab & "check_command " & !check_command & vbCrLf & _
vbTab & "service_description " & !service_description & vbCrLf & _
vbTab & "use " & !nagios_use & vbCrLf & _
vbTab & "notification_options " & !notification_options & vbCrLf & _
vbTab & "notification_interval " & !notification_interval & vbCrLf & _
End If
' vbTab & "host_name localhost" & vbCrLf &
vServicesDefs = vServicesDefs & vServicesDef
.MoveNext
Loop
Else
End If
createServicesCfg = vServicesDefs
.Close 'Close the recordset
End With
Set rstServicesPerHostgroup = Nothing 'Clean up
End Function
Function ExistsFile(ByVal fName As String) As Boolean
'Returns TRUE if the provided name points to an existing file.
'Returns FALSE if not existing, or if it's a folder
On Error Resume Next
ExistsFile = ((GetAttr(fName) And vbDirectory) <> vbDirectory)
End Function
Function generic_host()
generic_host = vbCrLf & _
"# Generic host definition template - This is NOT a real host, just a template! " & vbCrLf & _
"define host{ " & vbCrLf & _
"name generic-host ; The name of this host template " & vbCrLf & _
"notifications_enabled 1 ; Host notifications are enabled " & vbCrLf & _
"event_handler_enabled 1 ; Host event handler is enabled " & vbCrLf & _
"flap_detection_enabled 1 ; Flap detection is enabled " & vbCrLf & _
"process_perf_data 1 ; Process performance data " & vbCrLf & _
"retain_status_information 1 ; Retain status information across program restarts " & vbCrLf & _
"retain_nonstatus_information 1 ; Retain non-status information across program restarts " & vbCrLf & _
"check_command check-host-alive ; Default command to check if routers are alive " & vbCrLf & _
"max_check_attempts 10 ;" & vbCrLf & _
"check_period 24x7 ; By default, switches are monitored round the clock " & vbCrLf & _
"check_interval 5 ; Switches are checked every 5 minutes " & vbCrLf & _
"retry_interval 1 ; Schedule host check retries at 1 minute intervals " & vbCrLf & _
"notification_interval 1440 " & vbCrLf & _
"notification_period 24x7 ; Send host notifications at any time " & vbCrLf & _
"register 0 ; DONT REGISTER THIS DEFINITION - ITS NOT A REAL HOST, JUST A TEMPLATE! " & vbCrLf & _
"contact_groups admins ; Notifications get sent to the admins by default " & vbCrLf & _
"} " & vbCrLf & vbCrLf
End Function
Function generic_service()
generic_service = vbCrLf & _
"# Generic service definition template - This is NOT a real service, just a template!" & vbCrLf & _
"define service{" & vbCrLf & _
" name generic-service ; The 'name' of this service template " & vbCrLf & _
" active_checks_enabled 1 ; Active service checks are enabled " & vbCrLf & _
" passive_checks_enabled 1 ; Passive service checks are enabled/accepted " & vbCrLf & _
" parallelize_check 1 ; Active service checks should be parallelized (disabling this can lead to major performance problems) " & vbCrLf & _
" obsess_over_service 1 ; We should obsess over this service (if necessary) " & vbCrLf & _
" check_freshness 0 ; Default is to NOT check service 'freshness' " & vbCrLf & _
" notifications_enabled 1 ; Service notifications are enabled " & vbCrLf & _
" event_handler_enabled 1 ; Service event handler is enabled " & vbCrLf & _
" flap_detection_enabled 1 ; Flap detection is enabled " & vbCrLf & _
" process_perf_data 1 ; Process performance data " & vbCrLf & _
" retain_status_information 1 ; Retain status information across program restarts " & vbCrLf & _
" retain_nonstatus_information 1 ; Retain non-status information across program restarts " & vbCrLf & _
" is_volatile 0 ; The service is not volatile " & vbCrLf & _
" check_period 24x7 ; The service can be checked at any time of the day " & vbCrLf & _
" max_check_attempts 3 ; Re-check the service up to 3 times in order to determine its final (hard) state " & vbCrLf & _
" normal_check_interval 10 ; Check the service every 10 minutes under normal conditions " & vbCrLf & _
" retry_check_interval 2 ; Re-check the service every two minutes until a hard state can be determined " & vbCrLf & _
" contact_groups admins ; Notifications get sent out to everyone in the 'admins' group " & vbCrLf & _
" notification_options u,c ; Send notifications about warning, unknown, critical, and recovery events " & vbCrLf & _
" notification_interval 1440 ; Re-notify about service problems every hour " & vbCrLf & _
" notification_period 24x7 ; Notifications can be sent out at any time " & vbCrLf & _
" register 0 ; DONT REGISTER THIS DEFINITION - ITS NOT A REAL SERVICE, JUST A TEMPLATE! " & vbCrLf & "} " & vbCrLf & vbCrLf
End Function
Function generic_contact()
generic_contact = "define contact{ " & vbCrLf & _
" name generic-contact ; The name of this contact template " & vbCrLf & _
" service_notification_period 24x7 ; service notifications can be sent anytime " & vbCrLf & _
" host_notification_period 24x7 ; host notifications can be sent anytime " & vbCrLf & _
" service_notification_options w,u,c,r,f,s ; send notifications for all service states, flapping events, and scheduled downtime events " & vbCrLf & _
" host_notification_options d,u ; send notifications for all host states, flapping events, and scheduled downtime events " & vbCrLf & _
" service_notification_commands notify-service-by-email ; send service notifications via email " & vbCrLf & _
" host_notification_commands notify-host-by-email ; send host notifications via email " & vbCrLf & _
" register 0 ; DONT REGISTER THIS DEFINITION - ITS NOT A REAL CONTACT, JUST A TEMPLATE! " & vbCrLf & _
End Function
Function createDnsTable(rstTableNetAssets As Recordset)
vHostsCounter = 0
vHostDefs = "record_no," & String(4, " ") & "operation, host_name," & String(21, " ") & "ip_address " & vbCrLf
Exit Do
End If
vHostDef = "# record " & vHostsCounter & "," & String(3 - Len(vHostsCounter), " ") & _
" add_dns, " & _
!HostName & "," & String(30 - Len(!HostName), " ") & _
!ip_address & _
vbCrLf
'check if additional names are present for this host, and add respective dns entries
If Len(!DnsNames) > 1 Then
splitDns = Split(!DnsNames, ",")
For lngPosition = LBound(splitDns) To UBound(splitDns)
addDnsEntry = Trim(splitDns(lngPosition))
vAddDns = "# record " & vHostsCounter & "." & lngPosition & "," & _
" add_dns, " & _
addDnsEntry & "," & String(30 - Len(addDnsEntry), " ") & _
!ip_address & _
vbCrLf
vHostDefs = vHostDefs & vAddDns
Next lngPosition
End If
Loop
End If
createDnsTable = vHostDefs
End With
End Function
Function createDhcpTable(rstTableNetAssets As Recordset)
' prepare dhcp table
vHostsCounter = 0
vHostDefs = "record_no," & String(4, " ") & "operation," & String(13, " ") & "host_name," & String(21, " ") _
& "ip_address," & String(8, " ") & "mac_address" & vbCrLf
Exit Do
End If
" add_dhcp_reservation, " & _
!ip_address & "," & String(15 - Len(!ip_address), " ") & _
!mac_address & _
vbCrLf
Loop
End If
createDhcpTable = vHostDefs
Debug.Print createDhcpTable
End With
End Function
Function runPowershell()
Dim retval As Variant
powershellCommand = "\\xyz\\C_xy\Users\aag\Dropbox\Bellaria\BellariaNetwork\refresh_lan.ps1"
storeCredentials = " " & _
"$Username = 'xy'" & _
"$Password = 'xy' " & _
"$pass = ConvertTo-SecureString -AsPlainText $Password -Force " & _
"$Cred = New-Object System.Management.Automation.PSCredential -ArgumentList $Username,$pass" & _
"Invoke-Command -ComputerName wskeller -ScriptBlock { invoke-expression -Command \\WSKELLER\\C_wskeller\Users\aag\Dropbox\Bellaria\BellariaNetworkxxx.ps1 } -credential $Cred"
retval = Shell("PowerShell ""C:\MyScript.ps1""", vbNormalFocus)
End Function
Function MakeNetAssetsWebPage(rstTableNetAssets)
' prepare web page table
vHostsCounter = 0
vWebPage = "record_no," & String(4, " ") & "operation," & String(13, " ") & "host_name," & String(21, " ") _
Exit Do
End If
vWebPageDef = "<tr><td width='25'> <a href='http://" & !HostName & ".lan' >" & !HostName & " </a></td>" & vbCrLf & _
"<td width='71'><a href='http://ip_address' title='host'>" & !ip_address & " </td>" & vbCrLf & _
"<td width='94'>" & !mac_address & " </td>" & vbCrLf & _
"<td width='254'>" & !Description & " </td>" & vbCrLf
vWebPage = vWebPage & vWebPageDef
Loop
End If
MakeNetAssetsWebPage = vWebPage
End With
End Function
