USV Logfile Datenimport
ich versuche folgendes Script auf das Logfile der USV ERREPI VRX 700 anzupassen aber ich bekomme es nicht gebacken:
Einlesen des Logfile aus USV ERREPI VRX 700
Anleitung:
- LogFile und LogInterval anpassen
- Bei Bedarf auskommentierte Zeilen aktivieren und Positionen anpassen
- Execute drücken, um den automatischen Timer zu erstellen
$LogFile     = "C:\\Programme\\UPS\\UPSMAN\\upsdata.csv";
$LogInterval = 20;    // Minuten (Standard: 20)
if(file_exists($LogFile))
    $lines = file($LogFile);
    $data = explode("	", $lines[count($lines) - 1]);
    $ts = strtotime($data[0]);
    if(date("m.d.Y H:i:s", $ts) != GetValueString(CreateVariableByName($IPS_SELF, "Last Time", 1)))
        SetValueString(CreateVariableByName($IPS_SELF, "Last Time", 1), date("d.m.Y H:i:s", $ts));
        SetValueFloat(CreateVariableByName($IPS_SELF, "INPUT VOLT", 2), strToFloat($data[2]));
        SetValueFloat(CreateVariableByName($IPS_SELF, "INPUT FREQUENCY Hz", 2), strToFloat($data[3]));
        SetValueFloat(CreateVariableByName($IPS_SELF, "INPUT POWER", 2), strToFloat($data[4]));
        SetValueFloat(CreateVariableByName($IPS_SELF, "OUTPUT VOLT", 2), strToFloat($data[5]));
        SetValueFloat(CreateVariableByName($IPS_SELF, "OUTPUT FREQUENCY Hz", 2), strToFloat($data[6]));
        SetValueFloat(CreateVariableByName($IPS_SELF, "OUTPUT LOAD", 2), strToFloat($data[7]));
        SetValueFloat(CreateVariableByName($IPS_SELF, "BATTERY VOLTAGE", 2), strToFloat($data[8]));
        SetValueFloat(CreateVariableByName($IPS_SELF, "TEMPERATURE", 2), strToFloat($data[9]));
        SetValueFloat(CreateVariableByName($IPS_SELF, "BATTERY CAPACITY", 2), strToFloat($data[10]));
    // Offset berechnen und Timer stellen
   IPS_SetScriptTimer($IPS_SELF, ($ts + $LogInterval * 60 + 10) - time());
function strToFloat($value)
    return (float)(str_replace(",", ".", $value));
function CreateVariableByName($id, $name, $type)
   global $IPS_SELF;
   if($vid===false) {
      IPS_SetParent($vid, $id);
      IPS_SetName($vid, $name);
      IPS_SetInfo($vid, "This Variable was created by Script #$IPS_SELF");
   return $vid;
Auszug aus dem Logfile upsdata.csv
DATE, TIME, INPUT VOLT, INPUT FREQUENCY Hz, INPUT POWER, OUTPUT VOLT, OUTPUT FREQUENCY Hz, OUTPUT LOAD , BATTERY VOLTAGE, TEMPERATURE C°, BATTERY CAPACITY
09/11/2011,19:49:23,226.66,49.96,,227.49,50.00,25.00,28.00,33.00,100.00
09/11/2011,19:54:23,228.88,49.93,,229.44,50.00,25.00,28.00,33.00,100.00
Kann mir bitte mal ein PHP Freak Hilfestellung geben :wink:
Lukky
$data = explode(",", $lines[count($lines) - 1]);
Hallo Rainer.
danke das tut weh :D, den Trenner habe ich übersehen.
Warning:  Variablentyp Integer entspricht nicht String in C:\IP-Symcon\scripts\19292.ips.php on line 21
Warning:  Variablentyp Integer entspricht nicht String in C:\IP-Symcon\scripts\19292.ips.php on line 23
Jetzt habe ich nur noch das Problem mit den Datum + Zeit
Andreas
Entweder Du setzt eine Integervariable oder castest. (string).
Was ist mit Datum und Uhrzeit. Diese sollten in [0] und [1] stehen oder was meinst.
Hallo Rainer,
ich versuche es gerade zu begreifen.
    if(date("m.d.Y H:i:s", $ts) != GetValueString(CreateVariableByName($IPS_SELF, "Last Time", 1))) // Zeile 21
        SetValueString(CreateVariableByName($IPS_SELF, "Last Time", 1), date("d.m.Y H:i:s", $ts));  //Zeile 23
In der Zeile 21 wird doch die aktuelle Zeit mit der Zeit aus dem letzten Datensatz verglichen?
Dann liegt mein Fehler darin das aus Feld 0 und Feld 1 das Datum erst zusammensetzen muß?
Andreas
Hallo Andreas,
die 1 am Ende bedeutet daß Du eine Integervariable anlegst.
Siehe Doku
aber du erwartest ein String:
GetValueString()
Attain
Hallo Attain,
ich raff`s nicht
    if(date("m.d.Y H:i:s", $ts) != GetValueString(CreateVariableByName($IPS_SELF, "Last Time", 3)))
        SetValueString(CreateVariableByName($IPS_SELF, "Last Time", 3), date("d.m.Y H:i:s", $ts));
produziert den gleichen Fehler
Andreas
Hallo Andreas,
Du hast die Variable „Last Time“ (Typ Integer) in der Console nochmal gelöscht?
Ansonsten wird diese nicht als String angelegt.
Hallo Attain,
:loveips: das war`s
Vielen Dank!
Andreas
