Moin zusammen,
aktuelle public IPS-Installation.
Ich habe testweise mein USB-Gateway (TCM120) angestöpselt (COM4).
Bringt mir im Log ständig Meldungen:
09.04.2013 19:19:39.248 | 42925 | WARNING | Serial Port | '$¥Z' is not a valid integer value
09.04.2013 19:19:39.263 | 42925 | WARNING | Serial Port | '$©' is not a valid integer value
09.04.2013 19:19:51.712 | 42925 | WARNING | Serial Port | '$¥Z' is not a valid integer value
09.04.2013 19:19:51.728 | 42925 | WARNING | Serial Port | '$öd' is not a valid integer value
09.04.2013 19:19:52.227 | 42925 | WARNING | Serial Port | '$¥Z' is not a valid integer value
09.04.2013 19:19:52.242 | 42925 | WARNING | Serial Port | '$g' is not a valid integer value
09.04.2013 19:19:52.828 | 42925 | WARNING | Serial Port | '$¥Z' is not a valid integer value
09.04.2013 19:19:52.844 | 42925 | WARNING | Serial Port | '$a' is not a valid integer value
09.04.2013 19:19:53.546 | 42925 | WARNING | Serial Port | '$¥Z' is not a valid integer value
09.04.2013 19:19:54.217 | 42925 | WARNING | Serial Port | '$¥Z' is not a valid integer value
09.04.2013 19:19:54.232 | 42925 | WARNING | Serial Port | '$ÿþ' is not a valid integer value
09.04.2013 19:19:54.716 | 42925 | WARNING | Serial Port | '$¥Z' is not a valid integer value
09.04.2013 19:19:54.731 | 42925 | WARNING | Serial Port | '$
Hat jemand auch dieses Verhalten?
