Hallo Andrè,
OK, mit Fehlermeldung meinte ich das Browser Fenster, dass hat sich jetzt ja geklärt.
Allerdings klappt select bei mir nicht, hagelt Fehlermeldungen.
IPS-Err-PHP 2014-09-04 19:02:50.052 Notice: Undefined variable: SelectedArray
Error in Script C:\IP-Symcon_2_0\scripts\UPNP_Playlist_Handle.ips.php on Line 269
133 in IPSLibrary\app\core\IPSLogger\IPSLogger.inc.php (call IPSLogger_Out)
44 in IPSLibrary\app\core\IPSLogger\IPSLogger_PhpErrorHandler.inc.php (call IPSLogger_Err)
269 in UPNP_Playlist_Handle.ips.php (call IPSLogger_PhpErrorHandler) IPS-Err-PHP 2014-09-04 19:02:50.054 Warning: implode(): Invalid arguments passed
37 in IPSLibrary\app\core\IPSLogger\IPSLogger_PhpErrorHandler.inc.php (call IPSLogger_Err)
in IPSLogger_PhpErrorHandler
269 in UPNP_Playlist_Handle.ips.php (call implode) IPS-Err-PHP 2014-09-04 19:02:50.056 Warning: Cannot auto-convert to String from Variant. Error: Could not convert variant of type (Null) into type (String)
Error in Script C:\IP-Symcon_2_0\scripts\UPNP_Playlist_Handle.ips.php on Line 271
271 in UPNP_Playlist_Handle.ips.php (call SetValue) IPS-Err-PHP 2014-09-04 19:02:50.057 Warning: simplexml_load_string(): Entity: line 1: parser error : Start tag expected, ‚<‘ not found
Error in Script C:\IP-Symcon_2_0\scripts\UPNP_Browse_Functions.ips.php on Line 169
169 in UPNP_Browse_Functions.ips.php (call simplexml_load_string)
278 in UPNP_Playlist_Handle.ips.php (call BrowseList) IPS-Err-PHP 2014-09-04 19:02:50.059 Warning: simplexml_load_string(): a:5:{i:0;s:17591:"<?xml version=„1.0“ encoding=„UTF-8“?>
278 in UPNP_Playlist_Handle.ips.php (call BrowseList) IPS-Err-PHP 2014-09-04 19:02:50.061 Warning: simplexml_load_string(): ^
278 in UPNP_Playlist_Handle.ips.php (call BrowseList) IPS-Err-PHP 2014-09-04 19:02:50.062 Notice: Undefined variable: SelectedArray
Error in Script C:\IP-Symcon_2_0\scripts\UPNP_Playlist_Handle.ips.php on Line 292
292 in UPNP_Playlist_Handle.ips.php (call IPSLogger_PhpErrorHandler) IPS-Err-PHP 2014-09-04 19:02:50.064 Warning: Invalid argument supplied for foreach()
Error in Script C:\IP-Symcon_2_0\scripts\UPNP_Playlist_Handle.ips.php on Line 286
286 in UPNP_Playlist_Handle.ips.php (call IPSLogger_PhpErrorHandler)
292 in UPNP_Playlist_Handle.ips.php (call key_values_intersect) IPS-Err-PHP 2014-09-04 19:02:50.066 Notice: Undefined variable: key_val_int
Error in Script C:\IP-Symcon_2_0\scripts\UPNP_Playlist_Handle.ips.php on Line 290
290 in UPNP_Playlist_Handle.ips.php (call IPSLogger_PhpErrorHandler)
292 in UPNP_Playlist_Handle.ips.php (call key_values_intersect) IPS-Err-PHP 2014-09-04 19:02:50.069 Compile Error: Cannot redeclare class Array2XML
Error in Script C:\IP-Symcon_2_0\scripts\UPNP_Array2XML.inc.php on Line 37
55 in IPSLibrary\app\core\IPSLogger\IPSLogger_PhpErrorHandler.inc.php (call IPSLogger_Err)
120 in IPSLibrary\app\core\IPSLogger\IPSLogger_PhpErrorHandler.inc.php (call IPSLogger_PhpErrorHandler)
in IPSLogger_PhpFatalErrorHandler
IPS-Err-PHP 2014-09-04 19:05:12.372 Notice: Undefined variable: SelectedArray
269 in UPNP_Playlist_Handle.ips.php (call IPSLogger_PhpErrorHandler) IPS-Err-PHP 2014-09-04 19:05:12.374 Warning: implode(): Invalid arguments passed
269 in UPNP_Playlist_Handle.ips.php (call implode) IPS-Err-PHP 2014-09-04 19:05:12.376 Warning: Cannot auto-convert to String from Variant. Error: Could not convert variant of type (Null) into type (String)
271 in UPNP_Playlist_Handle.ips.php (call SetValue) IPS-Err-PHP 2014-09-04 19:05:12.377 Warning: simplexml_load_string(): Entity: line 1: parser error : Start tag expected, ‚<‘ not found
278 in UPNP_Playlist_Handle.ips.php (call BrowseList) IPS-Err-PHP 2014-09-04 19:05:12.379 Warning: simplexml_load_string(): a:5:{i:0;s:17591:"<?xml version=„1.0“ encoding=„UTF-8“?>
278 in UPNP_Playlist_Handle.ips.php (call BrowseList) IPS-Err-PHP 2014-09-04 19:05:12.381 Warning: simplexml_load_string(): ^
278 in UPNP_Playlist_Handle.ips.php (call BrowseList) IPS-Err-PHP 2014-09-04 19:05:12.382 Notice: Undefined variable: SelectedArray
292 in UPNP_Playlist_Handle.ips.php (call IPSLogger_PhpErrorHandler) IPS-Err-PHP 2014-09-04 19:05:12.384 Warning: Invalid argument supplied for foreach()
292 in UPNP_Playlist_Handle.ips.php (call key_values_intersect) IPS-Err-PHP 2014-09-04 19:05:12.386 Notice: Undefined variable: key_val_int
292 in UPNP_Playlist_Handle.ips.php (call key_values_intersect) IPS-Err-PHP 2014-09-04 19:05:12.389 Compile Error: Cannot redeclare class Array2XML
Evtl. kannst Du Dir das ja noch mal ansehen.
