$ sudo apt-get upgrade
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Calculating upgrade... Done
The following packages will be upgraded:
distro-info-data git git-man libfastjson4 libgnutls30 libluajit-5.1-2 libluajit-5.1-common libpam-modules libpam-modules-bin
libpam-runtime libpam-systemd libpam0g libssl1.1 libsystemd0 libtiff5 libudev1 libudisks2-0 libxml2 luajit openssl symcon systemd
systemd-sysv systemd-timesyncd udev udisks2 wireless-regdb
27 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 68.7 MB of archives.
After this operation, 20.5 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://apt.symcon.de stable/rpi arm64 symcon arm64 8.1-580 [48.5 MB]
Get:2 http://security.debian.org/debian-security bullseye-security/main arm64 libpam0g arm64 1.4.0-9+deb11u2 [129 kB]
Get:3 http://security.debian.org/debian-security bullseye-security/main arm64 libpam-modules-bin arm64 1.4.0-9+deb11u2 [108 kB]
Get:4 http://security.debian.org/debian-security bullseye-security/main arm64 libpam-modules arm64 1.4.0-9+deb11u2 [319 kB]
Get:5 http://security.debian.org/debian-security bullseye-security/main arm64 libpam-runtime all 1.4.0-9+deb11u2 [208 kB]
Get:6 http://security.debian.org/debian-security bullseye-security/main arm64 systemd-sysv arm64 247.3-7+deb11u7 [114 kB]
Get:7 http://security.debian.org/debian-security bullseye-security/main arm64 libpam-systemd arm64 247.3-7+deb11u7 [275 kB]
Get:8 http://security.debian.org/debian-security bullseye-security/main arm64 libsystemd0 arm64 247.3-7+deb11u7 [355 kB]
Get:9 http://security.debian.org/debian-security bullseye-security/main arm64 systemd-timesyncd arm64 247.3-7+deb11u7 [130 kB]
Get:10 http://security.debian.org/debian-security bullseye-security/main arm64 systemd arm64 247.3-7+deb11u7 [4,155 kB]
Get:11 http://security.debian.org/debian-security bullseye-security/main arm64 udev arm64 247.3-7+deb11u7 [1,425 kB]
Get:12 http://security.debian.org/debian-security bullseye-security/main arm64 libudev1 arm64 247.3-7+deb11u7 [164 kB]
Get:13 http://security.debian.org/debian-security bullseye-security/main arm64 libgnutls30 arm64 3.7.1-5+deb11u8 [1,264 kB]
Get:14 http://security.debian.org/debian-security bullseye-security/main arm64 libssl1.1 arm64 1.1.1w-0+deb11u4 [1,396 kB]
Get:15 http://security.debian.org/debian-security bullseye-security/main arm64 distro-info-data all 0.51+deb11u9 [8,592 B]
Get:16 http://security.debian.org/debian-security bullseye-security/main arm64 git-man all 1:2.30.2-1+deb11u5 [1,831 kB]
Get:17 http://security.debian.org/debian-security bullseye-security/main arm64 git arm64 1:2.30.2-1+deb11u5 [5,480 kB]
Get:18 http://security.debian.org/debian-security bullseye-security/main arm64 libfastjson4 arm64 0.99.9-1+deb11u1 [27.3 kB]
Get:19 http://security.debian.org/debian-security bullseye-security/main arm64 luajit arm64 2.1.0~beta3+dfsg-5.3+deb11u1 [232 kB]
Get:20 http://security.debian.org/debian-security bullseye-security/main arm64 libluajit-5.1-2 arm64 2.1.0~beta3+dfsg-5.3+deb11u1 [226 kB]
Get:21 http://security.debian.org/debian-security bullseye-security/main arm64 libluajit-5.1-common all 2.1.0~beta3+dfsg-5.3+deb11u1 [47.3 kB]
Get:22 http://security.debian.org/debian-security bullseye-security/main arm64 libtiff5 arm64 4.2.0-1+deb11u7 [278 kB]
Get:23 http://security.debian.org/debian-security bullseye-security/main arm64 libudisks2-0 arm64 2.9.2-2+deb11u3 [146 kB]
Get:24 http://security.debian.org/debian-security bullseye-security/main arm64 libxml2 arm64 2.9.10+dfsg-6.7+deb11u9 [630 kB]
Get:25 http://security.debian.org/debian-security bullseye-security/main arm64 openssl arm64 1.1.1w-0+deb11u4 [837 kB]
Get:26 http://security.debian.org/debian-security bullseye-security/main arm64 udisks2 arm64 2.9.2-2+deb11u3 [392 kB]
Get:27 http://security.debian.org/debian-security bullseye-security/main arm64 wireless-regdb all 2025.07.10-1~deb11u1 [17.4 kB]
Fetched 68.7 MB in 8s (8,864 kB/s)
Reading changelogs... Done
Preconfiguring packages ...
(Reading database ... 44883 files and directories currently installed.)
Preparing to unpack .../libpam0g_1.4.0-9+deb11u2_arm64.deb ...
Unpacking libpam0g:arm64 (1.4.0-9+deb11u2) over (1.4.0-9+deb11u1+rpt2) ...
Setting up libpam0g:arm64 (1.4.0-9+deb11u2) ...
Preparing to unpack .../libpam-modules-bin_1.4.0-9+deb11u2_arm64.deb ...
Unpacking libpam-modules-bin (1.4.0-9+deb11u2) over (1.4.0-9+deb11u1+rpt2) ...
Setting up libpam-modules-bin (1.4.0-9+deb11u2) ...
Preparing to unpack .../libpam-modules_1.4.0-9+deb11u2_arm64.deb ...
Unpacking libpam-modules:arm64 (1.4.0-9+deb11u2) over (1.4.0-9+deb11u1+rpt2) ...
Setting up libpam-modules:arm64 (1.4.0-9+deb11u2) ...
Installing new version of config file /etc/security/namespace.init ...
Preparing to unpack .../libpam-runtime_1.4.0-9+deb11u2_all.deb ...
Unpacking libpam-runtime (1.4.0-9+deb11u2) over (1.4.0-9+deb11u1+rpt2) ...
Setting up libpam-runtime (1.4.0-9+deb11u2) ...
Preparing to unpack .../systemd-sysv_247.3-7+deb11u7_arm64.deb ...
Unpacking systemd-sysv (247.3-7+deb11u7) over (247.3-7+deb11u6) ...
Preparing to unpack .../libpam-systemd_247.3-7+deb11u7_arm64.deb ...
Unpacking libpam-systemd:arm64 (247.3-7+deb11u7) over (247.3-7+deb11u6) ...
Preparing to unpack .../libsystemd0_247.3-7+deb11u7_arm64.deb ...
Unpacking libsystemd0:arm64 (247.3-7+deb11u7) over (247.3-7+deb11u6) ...
Setting up libsystemd0:arm64 (247.3-7+deb11u7) ...
Preparing to unpack .../systemd-timesyncd_247.3-7+deb11u7_arm64.deb ...
Unpacking systemd-timesyncd (247.3-7+deb11u7) over (247.3-7+deb11u6) ...
Preparing to unpack .../systemd_247.3-7+deb11u7_arm64.deb ...
Unpacking systemd (247.3-7+deb11u7) over (247.3-7+deb11u6) ...
Preparing to unpack .../udev_247.3-7+deb11u7_arm64.deb ...
Unpacking udev (247.3-7+deb11u7) over (247.3-7+deb11u6) ...
Preparing to unpack .../libudev1_247.3-7+deb11u7_arm64.deb ...
Unpacking libudev1:arm64 (247.3-7+deb11u7) over (247.3-7+deb11u6) ...
Setting up libudev1:arm64 (247.3-7+deb11u7) ...
Preparing to unpack .../libgnutls30_3.7.1-5+deb11u8_arm64.deb ...
Unpacking libgnutls30:arm64 (3.7.1-5+deb11u8) over (3.7.1-5+deb11u7) ...
Setting up libgnutls30:arm64 (3.7.1-5+deb11u8) ...
Preparing to unpack .../libssl1.1_1.1.1w-0+deb11u4_arm64.deb ...
Unpacking libssl1.1:arm64 (1.1.1w-0+deb11u4) over (1.1.1w-0+deb11u3+rpt1) ...
Setting up libssl1.1:arm64 (1.1.1w-0+deb11u4) ...
Preparing to unpack .../00-distro-info-data_0.51+deb11u9_all.deb ...
Unpacking distro-info-data (0.51+deb11u9) over (0.51+deb11u8) ...
Preparing to unpack .../01-git-man_1%3a2.30.2-1+deb11u5_all.deb ...
Unpacking git-man (1:2.30.2-1+deb11u5) over (1:2.30.2-1+deb11u4) ...
Preparing to unpack .../02-git_1%3a2.30.2-1+deb11u5_arm64.deb ...
Unpacking git (1:2.30.2-1+deb11u5) over (1:2.30.2-1+deb11u4) ...
Preparing to unpack .../03-libfastjson4_0.99.9-1+deb11u1_arm64.deb ...
Unpacking libfastjson4:arm64 (0.99.9-1+deb11u1) over (0.99.9-1) ...
Preparing to unpack .../04-luajit_2.1.0~beta3+dfsg-5.3+deb11u1_arm64.deb ...
Unpacking luajit (2.1.0~beta3+dfsg-5.3+deb11u1) over (2.1.0~beta3+dfsg-5.3) ...
Preparing to unpack .../05-libluajit-5.1-2_2.1.0~beta3+dfsg-5.3+deb11u1_arm64.deb ...
Unpacking libluajit-5.1-2:arm64 (2.1.0~beta3+dfsg-5.3+deb11u1) over (2.1.0~beta3+dfsg-5.3) ...
Preparing to unpack .../06-libluajit-5.1-common_2.1.0~beta3+dfsg-5.3+deb11u1_all.deb ...
Unpacking libluajit-5.1-common (2.1.0~beta3+dfsg-5.3+deb11u1) over (2.1.0~beta3+dfsg-5.3) ...
Preparing to unpack .../07-libtiff5_4.2.0-1+deb11u7_arm64.deb ...
Unpacking libtiff5:arm64 (4.2.0-1+deb11u7) over (4.2.0-1+deb11u6) ...
Preparing to unpack .../08-libudisks2-0_2.9.2-2+deb11u3_arm64.deb ...
Unpacking libudisks2-0:arm64 (2.9.2-2+deb11u3) over (2.9.2-2+deb11u2) ...
Preparing to unpack .../09-libxml2_2.9.10+dfsg-6.7+deb11u9_arm64.deb ...
Unpacking libxml2:arm64 (2.9.10+dfsg-6.7+deb11u9) over (2.9.10+dfsg-6.7+deb11u7) ...
Preparing to unpack .../10-openssl_1.1.1w-0+deb11u4_arm64.deb ...
Unpacking openssl (1.1.1w-0+deb11u4) over (1.1.1w-0+deb11u3+rpt1) ...
Preparing to unpack .../11-symcon_8.1-580_arm64.deb ...
IP-Symcon is running.
Stopping...
IP-Symcon stopped
At least Debian (Bookworm) is required to install this update!
Press any key to continue...
dpkg: error processing archive /tmp/apt-dpkg-install-iR0QZJ/11-symcon_8.1-580_arm64.deb (--unpack):
new symcon package pre-installation script subprocess returned error exit status 1
IP-Symcon is not running.
Starting...
IP-Symcon started with PID 2353721
Open the console to start configuration:
http://192.168.6.15:3777/console/
Preparing to unpack .../12-udisks2_2.9.2-2+deb11u3_arm64.deb ...
Unpacking udisks2 (2.9.2-2+deb11u3) over (2.9.2-2+deb11u2) ...
Preparing to unpack .../13-wireless-regdb_2025.07.10-1~deb11u1_all.deb ...
Unpacking wireless-regdb (2025.07.10-1~deb11u1) over (2025.02.20-1~deb11u1) ...
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
pi@symconraspi:~ $ sudo apt-get dist-upgrade
symcon
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
18 not fully installed or removed.
Need to get 0 B/48.5 MB of archives.
After this operation, 0 B of additional disk space will be used.
Setting up systemd (247.3-7+deb11u7) ...
Preparing to unpack .../symcon_8.1-580_arm64.deb ...
Stopping...
IP-Symcon stopped
dpkg: error processing archive /var/cache/apt/archives/symcon_8.1-580_arm64.deb (--unpack):
Starting...
IP-Symcon started with PID 2354174
Hallo
Was muss ich machen damit es durchläuft?
