ich wollte gerade mal meine 5.0 Installation auf Ubuntu Server 18.04 auf die 5.1 updaten.
sudo apt-get update
sudo apt-get install
ergibt:
hocky@vm-ips5:~$ sudo apt-get update
[sudo] password for hocky:
Hit:1 http://apt.symcon.de stable InRelease
Get:2 http://security.ubuntu.com/ubuntu bionic-security InRelease [88.7 kB]
Hit:3 http://archive.ubuntu.com/ubuntu bionic InRelease
Get:4 http://archive.ubuntu.com/ubuntu bionic-updates InRelease [88.7 kB]
Get:5 http://archive.ubuntu.com/ubuntu bionic-backports InRelease [74.6 kB]
Fetched 252 kB in 1s (417 kB/s)
Reading package lists... Done
hocky@vm-ips5:~$ sudo apt-get upgrade
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
libboost-date-time1.65.1 libboost-filesystem1.65.1 libboost-system1.65.1 libgit2-26 libgmpxx4ldbl libhttp-parser2.7.1
libjpeg-turbo8 libjpeg8 libmcrypt4 libsodium23 libssh2-1
Use 'sudo apt autoremove' to remove them.
The following packages have been kept back:
lxd lxd-client
The following packages will be upgraded:
symcon
1 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
94 not fully installed or removed.
Need to get 0 B/49.4 MB of archives.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] Y
(Reading database ... 103823 files and directories currently installed.)
Preparing to unpack .../symcon_5.1-3137_amd64.deb ...
IP-Symcon is running.
Stopping...
IP-Symcon stopped
IP-Symcon: A valid subscription is required to install this update.
Press any key to continue...
dpkg: error processing archive /var/cache/apt/archives/symcon_5.1-3137_amd64.deb (--unpack):
new symcon package pre-installation script subprocess returned error exit status 1
IP-Symcon is not running.
Starting...
IP-Symcon started with PID 1760
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
lxd lxd-client
symcon
Do you want to continue? [Y/n] y
Stopping...
IP-Symcon stopped
Starting...
IP-Symcon started with PID 1964
hocky@vm-ips5:~$
Unlimited Subscription ist vorhanden und eingerichtet.
Any ideas?
