Hallo an die Symcon Gemeinde,
als Vorgeschichte, bin vor einigen Jahren von Windows auf Ubuntu 18.04 gewechselt.
Arbeite auf einem iMAC.
Das System lief ohne Probleme, bis Symcon 6.2 zwingend nur ab Ubuntu 20.04 lauffähig ist.
Habe Ubuntu in einer VM auf Synology laufen.
Auf einer anderen Synology in einer VM Ubuntu 20.04 installiert.
Versucht auf Ubuntu 18.04 wie beschrieben ( Backup erstellen ) ohne Fehlermeldung durchzuführen.
Bei der Erstellung von backup.zip viele Fehlermeldungen, wie:
adding: #
zip warning: Permission denied
zip warning: could not open for reading: #
adding: backup/settings1646521481.json
zip warning: could not open for reading: backup/settings1646521481.json
adding: backup/settings1646694307.json
zip warning: could not open for reading: backup/settings1646694307.json
adding: backup/.DS_Store
zip warning: could not open for reading: backup/.DS_Store
adding: backup/settings1645916610.json
zip warning: could not open for reading: backup/settings1645916610.json
adding: backup/settings1647385617.json
zip warning: could not open for reading: backup/settings1647385617.json
adding: backup/settings1647212770.json
zip warning: could not open for reading: backup/settings1647212770.json
adding: backup/settings1646867132.json
zip warning: could not open for reading: backup/settings1646867132.json
adding: backup/settings1645484560.json
zip warning: could not open for reading: backup/settings1645484560.json
adding: backup/settings1647126362.json
zip warning: could not open for reading: backup/settings1647126362.json
adding: backup/settings1645743786.json
zip warning: could not open for reading: backup/settings1645743786.json
adding: backup/settings1646262254.json
zip warning: could not open for reading: backup/settings1646262254.json
adding: backup/settings1647558437.json
zip warning: could not open for reading: backup/settings1647558437.json
adding: backup/settings1646953542.json
zip warning: could not open for reading: backup/settings1646953542.json
adding: backup/settings1647299179.json
zip warning: could not open for reading: backup/settings1647299179.json
adding: backup/settings1646607892.json
zip warning: could not open for reading: backup/settings1646607892.json
adding: backup/settings1646089435.json
zip warning: could not open for reading: backup/settings1646089435.json
adding: backup/settings1647039953.json
zip warning: could not open for reading: backup/settings1647039953.json
adding: backup/settings1645830198.json
zip warning: could not open for reading: backup/settings1645830198.json
adding: backup/settings1646003022.json
zip warning: could not open for reading: backup/settings1646003022.json
adding: backup/settings1645570968.json
zip warning: could not open for reading: backup/settings1645570968.json
adding: backup/settings1646780720.json
zip warning: could not open for reading: backup/settings1646780720.json
adding: backup/settings1646348662.json
zip warning: could not open for reading: backup/settings1646348662.json
adding: backup/settings1645657377.json
zip warning: could not open for reading: backup/settings1645657377.json
adding: backup/settings1646175845.json
zip warning: could not open for reading: backup/settings1646175845.json
adding: backup/settings1647472026.json
zip warning: could not open for reading: backup/settings1647472026.json
adding: backup/settings1646435073.json
zip warning: could not open for reading: backup/settings1646435073.json
adding: db/sqlite3.exe
zip warning: could not open for reading: db/sqlite3.exe
adding: db/Timestamp Converter.URL
zip warning: could not open for reading: db/Timestamp Converter.URL
adding: db/DB_überprüfen.txt
zip warning: could not open for reading: db/DB_überprüfen.txt
adding: export.html
zip warning: could not open for reading: export.html
adding: ipsfunctions.php
zip warning: could not open for reading: ipsfunctions.php
adding: logo.ico
zip warning: could not open for reading: logo.ico
adding: __MACOSX/meta/._.DS_Store
zip warning: could not open for reading: __MACOSX/meta/._.DS_Store
zip warning: could not open for reading: __MACOSX/cams/1/._.DS_Store
adding: __MACOSX/scripts/phpxmlrpc-4.3.0/tests/ci/travis/._setup_apache.sh
zip warning: could not open for reading: __MACOSX/scripts/phpxmlrpc-4.3.0/tests/ci/travis/._setup_apache.sh
..... diverse Fehlermeldungen __MACOSX/.......
adding: modules/Doku HMSysVar.pdf
zip warning: could not open for reading: modules/Doku HMSysVar.pdf
adding: modules/HMSysVar.dll
zip warning: could not open for reading: modules/HMSysVar.dll
adding: php.ini
zip warning: could not open for reading: php.ini
adding: scripts/48301.ips.php
zip warning: could not open for reading: scripts/48301.ips.php
adding: scripts/33593.ips.php
zip warning: could not open for reading: scripts/33593.ips.php
adding: scripts/37277.ips.php
zip warning: could not open for reading: scripts/37277.ips.php
adding: scripts/22997.ips.php
zip warning: could not open for reading: scripts/22997.ips.php
..... viele Fehlermeldungen scripts/......
adding: session/sess_390dbefce1dd00e568bb79f0bf663807
zip warning: could not open for reading: session/sess_390dbefce1dd00e568bb79f0bf663807
adding: session/sess_d0ef75a83b95467b16055621c02d90b9
zip warning: could not open for reading: session/sess_d0ef75a83b95467b16055621c02d90b9
adding: session/sess_407b6ef90c99435600f294f77d07af25
zip warning: could not open for reading: session/sess_407b6ef90c99435600f294f77d07af25
adding: session/sess_f837c2666b068ebec1d8ecafcb7f8d9f
zip warning: could not open for reading: session/sess_f837c2666b068ebec1d8ecafcb7f8d9f
adding: session/sess_b390c9240dd4c3c129fc1e3c8b3f5dfd
zip warning: could not open for reading: session/sess_b390c9240dd4c3c129fc1e3c8b3f5dfd
adding: session/sess_89020a019fb0965ded2f6cc031ad3bde
zip warning: could not open for reading: session/sess_89020a019fb0965ded2f6cc031ad3bde
adding: settings.crc
zip warning: could not open for reading: settings.crc
adding: settings.json
zip warning: could not open for reading: settings.json
adding: settings.v2
zip warning: could not open for reading: settings.v2
adding: settings.xml.alt
zip warning: could not open for reading: settings.xml.alt
adding: webfront/user/default.css
zip warning: could not open for reading: webfront/user/default.css
zip warning: Not all files were readable
files/entries read: 4794 (823M bytes) skipped: 531 (134M bytes)
Ist wahrscheinlich vieles noch dem Umzug und das Arbeiten am Mac geschuldet.
Es ist auch ein archive.zip File vorhanden?!
Spiele ich dieses Backup.zip auf das neue Ubuntu 20.04 ( wie beschrieben, Backup einspielen ) ein und starte ich dann Symcon auf Diesem, muss die Lizenz eingespielt werden.
Nach dem Neustart finde ich ein leeres IP-Symcon vor.
Wie bekomme ich meinen Umzug hin?!
Danke im Voraus
LG Willi
