zum einen wird das class.IcplanUsSensor Skript benötigt;
error_reporting(E_ALL);
* This class implements the protocol of the Icplan ultrasound distance sensor.
* @author Jrn Lentes
* @see http://www.icplan.de
* @version 1.0
if (0 > version_compare(PHP_VERSION, '5')) {
die('This file was generated for PHP 5');
/* user defined includes */
// section -64--88-1-6-1950198:117da2b3893:-8000:000000000000077C-includes begin
$includeFile = IPS_GetScriptFile("class.IcplanUsSensorConfig");
require_once $includeFile;
// section -64--88-1-6-1950198:117da2b3893:-8000:000000000000077C-includes end
/* user defined constants */
// section -64--88-1-6-1950198:117da2b3893:-8000:000000000000077C-constants begin
// commands with single sensor connected
define ('GET_SENS_NR', '00000');
define ('SET_SENS_NR','00100');
define ('SEND_US','00200');
define ('SELFCALIB_ON', '00300');
define ('SELFCALIB_OFF','00400');
define ('RESET_FLOOD_COUNT','00700');
define ('GET_FLOOD_COUNT','00800');
define ('TEST_SENSOR','00900');
// commands with multiple sensors connected
define ('GETTEMP', 1000);
define ('GETDISTANCE', 2000);
define ('GETVERSION', 3000);
define ('SETMINDIST', 6000);
define ('SETSTATISTIC', 6100);
define ('SETAUTOSEND', 6200);
define ('SETHEATING', 6300);
define ('SETSENSSTART', 6400);
define ('SETSENSSTEP', 6500);
define ('SETSENSEND', 6600);
define ('SETTEST', 6700); # meaning unclear
define ('GETCONFIG', 6800);
define ('GETSERIAL', 7000);
define ('STARTCALIB', 8000);
// section -64--88-1-6-1950198:117da2b3893:-8000:000000000000077C-constants end
* @access public
* @version 1.0
class IcplanUsSensor
// --- ATTRIBUTES ---
* The sensor number addresses the sensor on the serial bus.
* @access private
* @var int
private $sensorNumber = 0;
* The IPS Com-Port instance ID defines the ID of the Com-Port instance
* IPS.
* @access private
* @var int
private $ipsComPortInstanceId = 0;
* Name of the IPS variable to read sensor anwsers from.
* @access private
* @var char
private $ipsResultVariableName = '';
* Time to wait for sensor anwser.
* @access public
* @var int
public $waitTime = 0;
// --- OPERATIONS ---
* Initializes this class and assigns parameters to attributes.
* @access public
* @param int
* @param int
* @param char
* @param int
* @return void
* @version 1.1
public function __construct($instanceId, $sensorNr, $resultVarName, $waitTime)
// section -64--88-1-6-5f6303:117da9ece9a:-8000:0000000000000857 begin
$this->ipsComPortInstanceId = $instanceId;
$this->sensorNumber = $sensorNr;
$this->ipsResultVariableName = $resultVarName;
$this->waitTime = $waitTime;
// section -64--88-1-6-5f6303:117da9ece9a:-8000:0000000000000857 end
* Initialize sensor configuration with values of parameter initConfig.
* @access public
* @param IcplanUsSensorConfig
* @return void
* @version 1.0
public function initializeSensor( IcplanUsSensorConfig $initConfig)
// section -64--88-1-6-5f6303:117f4d00600:-8000:00000000000008A9 begin
$this->setSensorMinimalDistance($initConfig->minimalDistance);
$this->setSensorStatisticalMeassuring($initConfig->enableStats);
$this->setSensorAutoSend($initConfig->enableAutoSend);
$this->setSensorHeating($initConfig->enableHeating);
$this->setSensorSensitivityStart($initConfig->sensitivityStart);
$this->setSensorSensitivityStep($initConfig->sensitivityStep);
$this->setSensorSensitivityTarget($initConfig->sensitivityEnd);
// section -64--88-1-6-5f6303:117f4d00600:-8000:00000000000008A9 end
* Sends the Icplan protocol command to the sensor.
* @access private
* @author Jrn Lentes, <joern.lentes@web.de>
* @param char
* @return void
private function sendCommand($command)
// section -64--88-1-6-5f6303:117da9ece9a:-8000:0000000000000848 begin
$len = strlen($command);
if ($len = 5)
COMPort_SendText($this->ipsComPortInstanceId, $command{0} );
IPS_Sleep(100);
COMPort_SendText($this->ipsComPortInstanceId, $command{1} );
IPS_Sleep(100);
COMPort_SendText($this->ipsComPortInstanceId, $command{2} );
IPS_Sleep(100);
COMPort_SendText($this->ipsComPortInstanceId, $command{3} );
IPS_Sleep(100);
COMPort_SendText($this->ipsComPortInstanceId, $command{4} );
// section -64--88-1-6-5f6303:117da9ece9a:-8000:0000000000000848 end
* Short description of method getResult
* @access private
* @return char
private function getResult()
$returnValue = (string) '';
// section -64--88-1-6-5f6303:117da9ece9a:-8000:000000000000084B begin
$value = GetValueString($this->ipsResultVariableName);
$array = explode(" ", $value);
$returnValue = $array[count($array)-1];
// section -64--88-1-6-5f6303:117da9ece9a:-8000:000000000000084B end
return (string) $returnValue;
* Sets the attribute sensorNumber to parameter sensorNr.
* @access public
* @param int
* @return void
public function setSensorNumber($sensorNr)
// section -64--88-1-6-1950198:117da2b3893:-8000:000000000000078F begin
if (is_int($sensorNr) && $sensorNr > 0 && $sensorNr < 10)
// section -64--88-1-6-1950198:117da2b3893:-8000:000000000000078F end
* Returns the value of attribute sensorNumber.
* @access public
* @return int
public function getSensorNumber()
$returnValue = (int) 0;
// section -64--88-1-6-1950198:117da2b3893:-8000:00000000000007AC begin
$returnValue = $this->sensorNumber;
// section -64--88-1-6-1950198:117da2b3893:-8000:00000000000007AC end
return (int) $returnValue;
* Sets the attribute ipsComPortInstanceId to parameter instanceId.
* @access public
* @param int
* @return void
public function setIpsComPortInstanceId($instanceId)
// section -64--88-1-6-1950198:117da2b3893:-8000:00000000000007B0 begin
if ( is_int($instanceId) )
// section -64--88-1-6-1950198:117da2b3893:-8000:00000000000007B0 end
* Returns the value of attribute ipsComPortInstanceId.
* @access public
* @return int
public function getIpsComPortInstanceId()
// section -64--88-1-6-1950198:117da2b3893:-8000:00000000000007B2 begin
$returnValue = $this->ipsComPortInstanceId;
// section -64--88-1-6-1950198:117da2b3893:-8000:00000000000007B2 end
* Sets the attribute ipsResultVariableName to parameter resultVarName.
* @access public
* @param char
* @return void
public function setIpsResultVariableName($resultVarName)
// section -64--88-1-6-5f6303:117da9ece9a:-8000:000000000000085E begin
if ( is_string($resultVarName) )
// section -64--88-1-6-5f6303:117da9ece9a:-8000:000000000000085E end
* Returns the value of attribute ipsResultVariableName.
* @access public
* @return char
public function getIpsResultVariableName()
// section -64--88-1-6-5f6303:117da9ece9a:-8000:0000000000000861 begin
$returnValue = $this->ipsResultVariableName;
// section -64--88-1-6-5f6303:117da9ece9a:-8000:0000000000000861 end
* Assign parameter sensorNr to connected sensor. Only one sensor must be
* to assign sensor number.
* @access public
* @param int
* @return void
public static function assignSensorNumber($sensorNr = 1)
// section -64--88-1-6-5f6303:117da9ece9a:-8000:000000000000083B begin
$result = 0;
if ( $sensorNr < 10 && $sensorNr > 0 )
$command = SET_SENS_NR + $sensorNr;
$this->sendCommand(strval($command));
IPS_Sleep($this->waitTime);
$result = intval($this->getResult());
// section -64--88-1-6-5f6303:117da9ece9a:-8000:000000000000083B end
* Read sensor number from single connected sensor.
* @access public
* @return int
* @version 1.0
public static function readSensorNumber()
// section -64--88-1-6-5f6303:117da9ece9a:-8000:0000000000000838 begin
$command = GET_SENS_NR;
$returnValue = intval($this->getResult());
// section -64--88-1-6-5f6303:117da9ece9a:-8000:0000000000000838 end
* Returns the actual temperature at the sensor.
* @access public
* @return int
* @version 1.0
public function getSensorTemperature()
// section -64--88-1-6-5f6303:117da9ece9a:-8000:0000000000000842 begin
$command = $this->sensorNumber * 10000 + GETTEMP;
// section -64--88-1-6-5f6303:117da9ece9a:-8000:0000000000000842 end
* Get actual distance the sensor meassured.
* @access public
* @return int
* @version 1.0
public function getSensorDistance()
// section -64--88-1-6-5f6303:117e3b16fcd:-8000:000000000000082E begin
$command = $this->sensorNumber * 10000 + GETDISTANCE;
// section -64--88-1-6-5f6303:117e3b16fcd:-8000:000000000000082E end
* Get software version of the sensor.
* @access public
* @return char
* @version 1.0
public function getSensorSoftwareVersion()
// section -64--88-1-6-5f6303:117e3b16fcd:-8000:0000000000000830 begin
$command = $this->sensorNumber * 10000 + GETVERSION;
$temp = $this->getResult();
$len = strlen($temp);
if ( $len = 3 )
$returnValue = $temp{$len-3} . '.' . $temp{$len-2} . $temp{$len-1};
// section -64--88-1-6-5f6303:117e3b16fcd:-8000:0000000000000830 end
* Set distance to ignore echos below that distance.
* @access public
* @param int
* @return int
* @version 1.0
public function setSensorMinimalDistance($distance)
// section -64--88-1-6-5f6303:117e3b16fcd:-8000:0000000000000832 begin
if ($distance < 100 && $distance > 0 )
$command = $this->sensorNumber * 10000 + SETMINDIST + $distance;
// section -64--88-1-6-5f6303:117e3b16fcd:-8000:0000000000000832 end
* Short description of method setSensorStatisticalMeassuring
* @access public
* @param boolean
* @return boolean
public function setSensorStatisticalMeassuring($enableStats)
$returnValue = (bool) false;
// section -64--88-1-6-5f6303:117f4d00600:-8000:0000000000000868 begin
$command = $this->sensorNumber * 10000 + SETSTATISTIC + intval($enableStats);
// section -64--88-1-6-5f6303:117f4d00600:-8000:0000000000000868 end
return (bool) $returnValue;
* Short description of method setSensorAutoSend
* @access public
* @param boolean
* @return boolean
public function setSensorAutoSend($enableAutoSend)
// section -64--88-1-6-5f6303:117f4d00600:-8000:000000000000086C begin
$command = $this->sensorNumber * 10000 + SETAUTOSEND + intval($enableAutoSend);
// section -64--88-1-6-5f6303:117f4d00600:-8000:000000000000086C end
* Short description of method setSensorHeating
* @access public
* @param boolean
* @return boolean
public function setSensorHeating($enableHeating)
// section -64--88-1-6-5f6303:117f4d00600:-8000:000000000000086F begin
$command = $this->sensorNumber * 10000 + SETHEATING + intval($enableHeating);
// section -64--88-1-6-5f6303:117f4d00600:-8000:000000000000086F end
* Short description of method setSensorSensitivityStart
* @access public
* @param int
* @return int
public function setSensorSensitivityStart($start)
// section -64--88-1-6-5f6303:117f4d00600:-8000:0000000000000872 begin
$command = $this->sensorNumber * 10000 + SETSENSSTART + $start;
// section -64--88-1-6-5f6303:117f4d00600:-8000:0000000000000872 end
* Short description of method setSensorSensitivityStep
* @access public
* @param int
* @return int
public function setSensorSensitivityStep($step)
// section -64--88-1-6-5f6303:117f4d00600:-8000:0000000000000875 begin
$command = $this->sensorNumber * 10000 + SETSENSSTEP + $step;
// section -64--88-1-6-5f6303:117f4d00600:-8000:0000000000000875 end
* Short description of method setSensorSensitivityTarget
* @access public
* @param int
* @return void
public function setSensorSensitivityTarget($target)
// section -64--88-1-6-5f6303:117f4d00600:-8000:0000000000000878 begin
$command = $this->sensorNumber * 10000 + SETSENSEND + $target;
// section -64--88-1-6-5f6303:117f4d00600:-8000:0000000000000878 end
* Short description of method getSensorConfig
* @access public
* @return IcplanUsSensorConfig
public function getSensorConfig()
$returnValue = null;
// section -64--88-1-6-5f6303:117f4d00600:-8000:000000000000087B begin
$command = $this->sensorNumber * 10000 + GETCONFIG;
// section -64--88-1-6-5f6303:117f4d00600:-8000:000000000000087B end
return $returnValue;
* Short description of method getSensorSerial
* @access public
* @return int
public function getSensorSerial()
// section -64--88-1-6-6b2d8ab3:117f4f8e2f0:-8000:0000000000000892 begin
$command = $this->sensorNumber * 10000 + GETSERIAL;
// section -64--88-1-6-6b2d8ab3:117f4f8e2f0:-8000:0000000000000892 end
* Short description of method startSensorCalibration
* @access public
* @return void
public function startSensorCalibration()
// section -64--88-1-6-6b2d8ab3:117f4f8e2f0:-8000:0000000000000894 begin
$command = $this->sensorNumber * 10000 + STARTCALIB;
// section -64--88-1-6-6b2d8ab3:117f4f8e2f0:-8000:0000000000000894 end
} /* end of class IcplanUsSensor */
Dann wird die Class.IcplanUsSensorConfig benötigt;
* This class contains the configuration values of the ultrasound sensor.
* @version 1.0
// section -64--88-1-6-5f6303:117f4d00600:-8000:000000000000087D-includes begin
// section -64--88-1-6-5f6303:117f4d00600:-8000:000000000000087D-includes end
// section -64--88-1-6-5f6303:117f4d00600:-8000:000000000000087D-constants begin
// section -64--88-1-6-5f6303:117f4d00600:-8000:000000000000087D-constants end
* @access public
* @version 1.0
class IcplanUsSensorConfig
* Short description of attribute minimalDistance
* @access public
* @var int
public $minimalDistance = 0;
* Short description of attribute enableStats
* @access public
* @var boolean
public $enableStats = false;
* Short description of attribute enableAutoSend
* @access public
* @var boolean
public $enableAutoSend = false;
* Short description of attribute enableHeating
* @access public
* @var boolean
public $enableHeating = false;
* Short description of attribute sensitivityStart
* @access public
* @var int
public $sensitivityStart = 0;
* Short description of attribute sensitivityStep
* @access public
* @var int
public $sensitivityStep = 0;
* Short description of attribute sensitivityEnd
* @access public
* @var int
public $sensitivityEnd = 0;
} /* end of class IcplanUsSensorConfig */
… und zu guter letzt das GetUsTemperatur Skript was getriggert wird. Alle 5 Minuten oder so … je nach dem für was du das brauchst.
IP-SYMCON Event Scripting
File : GetUsTemperatur.ips.php
Trigger :
Interval :
include "Konstanten.ips.php";
$instanceId = 13623 /*[Zisternen Modul]*/;
$sensorNr = 1;
$varName = 20666 /*[Nebenanlage\Zisterne\ultraschall]*/;
$waitTime = 3000;
$includeFile = IPS_GetScriptFile("class.IcplanUsSensor");
$usConfig = new IcplanUsSensorConfig();
$usConfig->minimalDistance = 20;
$usConfig->enableStats = false;
$usConfig->enableAutoSend = false;
$usConfig->enableHeating = true;
$usConfig->sensitivityStart = 31;
$usConfig->sensitivityStep = 1;
$usConfig->sensitivityEnd = 56;
$usSensor = new IcplanUsSensor($instanceId, $sensorNr, $varName, $waitTime);
$usSensor->initializeSensor($usConfig);
echo "initialized sensor!
Sleep(2);
$distance = $usSensor->getSensorDistance();
echo $distance ."
$crad = $usSensor->getSensorTemperature();
echo $crad ."
$SVersion = $usSensor->getSensorSoftwareVersion();
echo $SVersion ."
und schon haste deine Ausgabe als Echo. Hab das Skript aus hier dem Forum was netterweise erstellt wurde von einem User hier aus dem Board.
Damit das Skript läuft musst du ein SerialPort in IPS anlegen was auf den Ultraschallsensor connectet und eine Registervariable die immer überschrieben wird das als übergeordnete Instanz den SerialPort hat mit einer String Variable.
