Der Titel sagt im Prinzip alles, was es dazu zu sagen gibt…
// Script by AAG
// This script creates a PostgreSQL copy of all archived IPS variables.
// For performance reasons, variables are stored in 4 distinct tables depending on their type.
// A further table is created to host all variable definitions. Outer joins to the value tables are created as appropriate.
// Note 1: if the script is run more than once, any tables created by previous iterations will be automatically removed
// and replaced with the new tables.
// Note 2: the primary key of each table combines each variable's ID with its timestamp. The underlying assumption is
// that one and the same variable cannot be assigned two values at exactly the same time (even if the two values are identical).
// If such records are encountered, the script will log an error to "TransferSqLitePostgresLog.txt".
// In my experience, IPS can produce such implausible values, but they occur in <0.01% of records.
$ArchiveHandlerId = 53419; //replace number with ID of your archive handler
// do not change anything below here
//redirects ECHO to file
echo "output redirected to file";
{unlink('TransferSqLiteToPostgresLog.html');
$ob_file = fopen('TransferSqLiteToPostgresLog.html','w');
ob_start('ob_file_callback');
echo "Start of debug file <br>";
//this function creates a table containing all IPS objects
EnumerateIpsObjects();
set_time_limit (600); //it takes a long time, hence allow script to run for 10 minutes!
$dbconn = pg_connect("host=localhost
port=5432
dbname=IpsLogging
user=IPS
password=ips")
or die ('connection aborted: ' . pg_last_error().chr(13));
//remove old logging tables if existing
$QueryResult = pg_query($dbconn,
"DROP TABLE loggingdb_ips_boolean;
DROP TABLE loggingdb_ips_integer;
DROP TABLE loggingdb_ips_float;
DROP TABLE loggingdb_ips_string;");
if (!$QueryResult)
echo "PG Error: ". pg_last_error().chr(13);
else
echo "tables successfully dropped! <br>";
//creates 4 tables for int, float, boolean, and string, respectively
$createTransferTables = "
CREATE TABLE loggingdb_ips_integer (
IPSTIMESTAMP timestamp without time zone,
VARID integer not null,
IPSLASTTIME timestamp without time zone,
IPSVALUE INTEGER,
PRIMARY KEY(IPSTIMESTAMP, VARID)
CREATE TABLE loggingdb_ips_float (
IPSVALUE NUMERIC,
CREATE TABLE loggingdb_ips_boolean (
IPSVALUE BOOLEAN,
CREATE TABLE loggingdb_ips_string (
IPSVALUE TEXT,
$createIndexes = "
CREATE INDEX idx_float1
ON loggingdb_ips_float
USING btree
(ipstimestamp );
CREATE INDEX idx_float2
USING btree
(varid );
CREATE INDEX idx_integer1
ON loggingdb_ips_integer
USING btree
(ipstimestamp );
CREATE INDEX idx_integer2
USING btree
(varid );
CREATE INDEX idx_boolean1
ON loggingdb_ips_boolean
USING btree
(ipstimestamp );
CREATE INDEX idx_boolean2
USING btree
(varid );
CREATE INDEX idx_string1
ON loggingdb_ips_string
USING btree
(ipstimestamp );
CREATE INDEX idx_string2
USING btree
(varid );";
$QueryResult=pg_query ($dbconn, $createTransferTables);
if (!$QueryResult) echo "PG Error: ". pg_last_error().chr(13);
$QueryResult=pg_query($dbconn, $createIndexes);
FetchArchivedData($ArchiveHandlerId);
pg_close($dbconn);
Function FetchArchivedData($ArchiveHandlerId)
{ // fetch all archived data (script modified from khc)
$EndTime = time()+(24*60*60); // tomorrow, to be on the safe side
$StartTime = $EndTime - 3650*24*60*60; // past 10 years
(int) $VarCounter=0;
(int) $RecordCounter =0;
global $dbconn ;
$SqlInsertString = "IPSTIMESTAMP,
VARID,
IPSLASTTIME,
IPSVALUE ";
// get all logged variables
$VariablesArray = AC_GetAggregationVariables($ArchiveHandlerId, false );
foreach($VariablesArray as $Var)
{ $VarCounter=$VarCounter+1;
$VariableId = $Var["VariableID"];
$Location = IPS_GetLocation($VariableId) ;
(array) $variable = IPS_GetVariable($VariableId);
(int) $varType = $variable['VariableValue']['ValueType']; //Variablentyp (0: Boolean, 1: Integer, 2: Float, 3: String)
//data will be written to different tables depending on variable type
switch ($varType)
case 0:
$IpsTable = "loggingdb_ips_boolean";
break;
case 1:
$IpsTable = "loggingdb_ips_integer";
break;
case 2:
$IpsTable = "loggingdb_ips_float";
break;
case 3:
$IpsTable = "loggingdb_ips_string";
break;
// read from loggingdb database
$LoggedData = AC_GetLoggedValues($ArchiveHandlerId, $VariableId, $StartTime, $EndTime, 0);
if ($LoggedData==false) continue;
// transpose to postgres
$SqlErrors =0;
foreach($LoggedData as $V)
$RecordCounter =$RecordCounter +1;
//setup value string
$SqlValueString =
$setSQL = "INSERT INTO
$IpsTable
($SqlInsertString)
VALUES (
to_timestamp(".$V['TimeStamp']. "), ".
$VariableId . ', '.
'to_timestamp('.$V['LastTime'].') , '.
$V['Value'].');'
.chr(13);
// echo $setSQL;
$QueryResult = pg_query($dbconn, $setSQL);
if (!$QueryResult)
$SqlErrors = $SqlErrors +1;
echo "PG Error on record #$RecordCounter, error #$SqlErrors: ". pg_last_error().chr(13)."<br";
//echo "Record #$RecordCounter appended <br>".chr(13);
echo "Variable #$VarCounter appended".chr(13);
//end of function FetchArchivedData
ob_end_flush();
function ob_file_callback($buffer)
{ //redirects ECHO output to a log file
global $ob_file;
fwrite($ob_file,$buffer);
function EnumerateIpsObjects()
$IpsObjectList = IPS_GetObjectList();
$CountIpsObjects = count($IpsObjectList);
echo $CountIpsObjects. " ips objects"."<br>";
//print_r($IpsObjectList);
$dbconn = pg_connect("host=localhost port=5432 dbname=IpsLogging user=IPS password=ips") or die ('Verbindungsaufbau fehlgeschlagen: ' . pg_last_error().chr(13));
echo $dbconn . "<br>";
if ($dbconn==0) {die ("no odbc connection");}
//create table only if it does not yet exist, Primary key is ObjectID
$createTable = " CREATE TABLE IF NOT EXISTS IpsObjects (
CHILDRENIDS TEXT,
HASCHILDREN BOOLEAN,
ISPERSISTENT BOOLEAN,
OBJECTICON TEXT,
OBJECTID INTEGER UNIQUE,
OBJECTIDENT TEXT,
OBJECTINFO TEXT,
OBJECTISHIDDEN BOOLEAN,
OBJECTISREADONLY BOOLEAN,
OBJECTNAME TEXT,
OBJECTPOSITION TEXT,
OBJECTSUMMARY TEXT,
OBJECTTYPE INTEGER,
PARENTID INTEGER,
ID SERIAL,
PRIMARY KEY(OBJECTID)
$QueryResult= pg_query($dbconn, $createTable);
if (!$QueryResult) echo "Postgres error:". pg_last_error().chr(13);
$SqlExecuteString ="";
ChildrenIDs
, HasChildren
, IsPersistent
, ObjectIcon
, ObjectID
, ObjectIdent
, ObjectInfo
, ObjectIsHidden
, ObjectIsReadOnly
, ObjectName
, ObjectPosition
, ObjectSummary
, ObjectType
, ParentID";
//$SqlValueString = "0,0,0,0,0,0,0,0,0,0, 0,0,0,0";
$IpsObjectCounter =0;
$SqlErrors = 0;
foreach ($IpsObjectList as $key1 => $value1)
$IpsObjectCounter =$IpsObjectCounter+1;
echo "<br> [$key1] => $value1 ";
$IpsObject=IPS_GetObject($value1);
(string)$ChildrenIDs = utf8_encode(SqlNull(implode(",",$IpsObject['ChildrenIDs'])));
(bool)$HasChildren = SqlNull($IpsObject['HasChildren']);
(bool)$IsPersistent= $IpsObject['IsPersistent'];
(string)$ObjectIcon=utf8_encode(SqlNull($IpsObject['ObjectIcon']));
(int)$ObjectID=SqlNull($IpsObject['ObjectID']);
(string)$ObjectIdent=utf8_encode(SqlNull($IpsObject['ObjectIdent']));
(string)$ObjectInfo=utf8_encode(SqlNull($IpsObject['ObjectInfo']));
(bool)$ObjectIsHidden= SqlNull($IpsObject['ObjectIsHidden']);
(bool)$ObjectIsReadOnly= SqlNull($IpsObject['ObjectIsReadOnly']);
(string)$ObjectName=utf8_encode($IpsObject['ObjectName']);
(string)$ObjectPosition=utf8_encode(SqlNull($IpsObject['ObjectPosition']));
(string)$ObjectSummary=utf8_encode(SqlNull($IpsObject['ObjectSummary']));
(int)$ObjectType=SqlNull($IpsObject['ObjectType']);
(int)$ParentID=SqlNull($IpsObject['ParentID']);
$SqlValueString =
"'".$ChildrenIDs."',".
$HasChildren . ",".
$IsPersistent . ",".
"'" .$ObjectIcon."'" . ",".
$ObjectID . ",".
"'" .$ObjectIdent."'" . ",".
"'".$ObjectInfo."'". ",".
$ObjectIsHidden . ",".
$ObjectIsReadOnly . ",".
"'".$ObjectName. "'".",".
$ObjectPosition . ",".
"'".$ObjectSummary. "'".",".
$ObjectType . ",".
$ParentID;
$UpsertFields =
" SET ChildrenIDs = '$ChildrenIDs'
, HASCHILDREN = $HasChildren
, IsPersistent = $IsPersistent
, ObjectIcon = '$ObjectIcon'
, ObjectIdent = '$ObjectIdent'
, ObjectInfo = '$ObjectInfo'
, ObjectIsHidden = $ObjectIsHidden
, ObjectIsReadOnly = $ObjectIsReadOnly
, ObjectName = '$ObjectName'
, ObjectPosition = '$ObjectPosition'
, ObjectSummary = '$ObjectSummary'
, ObjectType = $ObjectType
, ParentID = $ParentID";
$SqlUpsertString2 = "
ChildrenIDs
, HasChildren
, IsPersistent
, ObjectIcon
, ObjectIdent
, ObjectInfo
, ObjectIsHidden
, ObjectIsReadOnly
, ObjectName
, ObjectPosition
, ObjectSummary
, ObjectType
, ParentID ";
$SqlUpsertString3 =
"'". $ChildrenIDs."'"
.", ". $HasChildren
.", ". $IsPersistent
.", ". "'". $ObjectIcon. "'"
.", ". "'". $ObjectIdent. "'"
.", ". "'". $ObjectInfo. "'"
.", ". $ObjectIsHidden
.", ". $ObjectIsReadOnly
.", ". "'".$ObjectName. "'"
.", ". "'". $ObjectPosition. "'"
.", ". "'". $ObjectSummary. "'"
.", ". $ObjectType
.", ". $ParentID ." " ;
/* $SqlUpsertString =
"UPDATE IpsObjects field='C', field2='Z' WHERE OBJECTID = $ObjectID;
INSERT INTO IpsObjects (OBJECTID, field, field2)
SELECT $ObjectID, 'C', 'Z'
WHERE NOT EXISTS (SELECT 1 FROM IpsObjects WHERE OBJECTID = $ObjectID); ";
$SqlUpsert =
"UPDATE IpsObjects $UpsertFields WHERE OBJECTID = $ObjectID;
INSERT INTO IpsObjects (OBJECTID, $SqlUpsertString2)
SELECT $ObjectID, $SqlUpsertString3
echo "record #$IpsObjectCounter processed ";
$QueryResult = pg_query($dbconn, $SqlUpsert);
$makeIpsObjectIndex = "
DROP INDEX IF EXISTS idx_IpsObject;
CREATE INDEX idx_IpsObject
ON IpsObjects
USING btree
(ObjectID);";
$QueryResult = pg_query($dbconn, $makeIpsObjectIndex);
pg_close($dbconn);
echo "<br> <br> -------------------------- <br> <br> ";
function SqlNull($SqlValue)
// insert the string "Null" into a null variable, for compatibility with Access SQL.
if (((string)$SqlValue==""))
{(string)$SqlValue='NULL';return ($SqlValue);}
else
{return ($SqlValue);}
