Moin Peter,
grundsätzlich funktioniert der neue genauso wie der alte Thermostat, nur dass die Profile jetzt in der Hauptinstanz zu finden sind. Ich habe mal qick and dirty die hmxml.inc.php für den neuen Thermostat umgebastelt. Funktioniert bei mir tadellos.
/* HMXML v1.1
* 2013 by Silberstreifen for the IPS Community
* neuen Thermostat HM-CC-RT-DN aufgenommen
* Basis 2011 by Zapp for the IPS Community
* This library is free software; you can redistribute it and/or modify it
* under the terms of the GNU Library General Public License as published by
* the Free Software Foundation; either version 2 of the License, or (at your
* option) any later version.
* This library is distributed in the hope that it will be useful, but WITHOUT
* ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
* FITNESS FOR A PARTICULAR PURPOSE. See the GNU Library General Public
* License for more details.
* You should have received a copy of the GNU Library General Public License
* along with this library; if not, write to the Free Software Foundation,
define("HMXML_VERSION", "0.2");
include "xmlrpc.inc.php" ;
// USAGE:
// The HMXML library requires the xmlrpc library. Copy the library and
// xmlrpc.inc.php in the IPS script directory
// It should automatically detect the BidCos Service and create a XMLRPC client
// for every request.
// If you get an error message from HMXML_init or if you have performance
// problems, please add the following line at the start of your script:
// HMXML_init(YOUR_BIDCOS_SERVER_IP);
// All functions accept either the IPS Instance ID or the HM Address as parameter
// Examples:
// -- Get a full list of HM Devices
// $devices = HMXML_DevicesList();
// print_r($devices);
// -- Get a full list of HM Interfaces
// $interfaces = HMXML_InterfacesList();
// print_r($interfaces);
// -- Get all Parameters for a given HM device using the IPS instance ID
// $HM_Device_Parameters = HMXML_getParamSet($IPS_Instance_ID, 2);
// -- Get the Parameter Description
// $HM_Device_Parameters_Desc = HMXML_getParamSetDesc($IPS_Instance_ID, 2);
// -- Get one specific Parameter
// $TC_Mode = HMXML_getParamSet($IPS_Instance_ID, 2, 'MODE_TEMPERATUR_REGULATOR');
// -- The Mode of a HM Thermostat can also be retrived with
// HMXML_getTCMode($IPS_DeviceID);
// -- To set the Mode
// HMXML_setTCMode($IPS_DeviceID, $Mode);
// where 0 = MANUAL; 1 = AUTO; 2=CENTRAL; 3 = PARTY
// -- Get the Tempareature Profile of a Thermostat in a better Human-readable array
// $tempProfile = HMXML_getTempProfile($IPS_Instance_ID);
// print_r($tempProfile);
// -- Setting a temperature for a given Day / Profile Index
// Note: The transfer of data to the TC might take some time (few minutes).
// $tempProfileNew = array();
// $tempProfileNew['MONDAY']['EndTimes'] = array("06:30","08:30","16:30","22:00","24:00");
// $tempProfileNew['MONDAY']['Values'] = array(17.0,20.0,17.0,19.5,17.0);
// HMXML_setTempProfile(29146, $tempProfileNew);
// Remarks:
// Init XMLRPC client with address to speed up process
// HMXML_init($BidCosServiceIP);
// HMXML functions
function HMXML_init($BidCosServiceIP = false, $debug = false, $port = "2001") {
// $BidCosServiceIP: The IP Address of the BidCos Server. If not provided or false, will be detected via IPS
global $xml_client;
if ($xml_client !== false) {
if ($BidCosServiceIP === false) { // We did not provide an IP for the BidCos Service
$nbOfHMSockets = 0;
foreach ( IPS_GetInstanceListByModuleID("{A151ECE9-D733-4FB9-AA15-7F7DD10C58AF}") as $id ) // HomeMatic Socket
if (($nbOfHMSockets++) > 1) {
die ("Error: HMXML_init() More than one HM Socket found. Please init XMLRPC Socket manually with HMXML_init(BidCos_Service_IP). <br>
$HMSocketObject = IPS_GetObject($id);
//print_r($HMSocketObject);
if ($HMSocketObject['ObjectSummary'] == "localhost") { // Don't know why the address is in ObjectSummary...
$IP = gethostbyname('localhost'); // Not an efficient method. Replace if needed. $_SERVER['SERVER_ADDR'] not working
$BidCosServiceIP = $IP;
else $BidCosServiceIP = $HMSocketObject['ObjectSummary'];
if ($debug) echo "Debug: Found HomeMatic Socket (BidCos Service) at IP $BidCosServiceIP
$xml_client = new xmlrpc_client("http://".$BidCosServiceIP.":".$port);
// XMLRPC Debug values: 0, 1 and 2 are supported (2 = echo sent msg too, before received response)
if ($debug !== false) $xml_client->setDebug(2);
else $xml_client->setDebug(0);
if ($xml_client !== false) return true;
else return false;
// Instance of XML_Client already exists
return false;
function HMXML_DevicesList() {
$request = new xmlrpcmsg('listDevices');
$devices = HMXML_send($request);
return $devices;
function HMXML_InterfacesList() {
$request = new xmlrpcmsg('listBidcosInterfaces');
return $devices;
// Gets the Type of HM device (HM terminology)
function HMXML_getType($IPS_DeviceID) {
// $IPS_DeviceID: IPS Instance ID
$HMAddressFull = explode(":", HM_GetAddress($IPS_DeviceID));
$HMAddress = $HMAddressFull[0];
$HMAddressChannel = $HMAddressFull[1];
$type = false;
foreach($devices as $device) {
if (strpos($device['ADDRESS'], $HMAddress) !== false) {
$type = $device['TYPE'];
break; // We stop at the first one we find
return $type;
function HMXML_getTempProfile($IPS_DeviceID, $day = false, $echo = false) {
// Gets the Temperature Profile of a Thermostat for a given day or all days
// Returns the result in an array
// $day: STRING - Name of day in english (not case-sensitive) or false for all days
// $echo: BOOL - if true, the Temperature profiles is output in readable format with time values
$dayArray = array("MONDAY","TUESDAY","WEDNESDAY","THURSDAY","FRIDAY","SATURDAY","SUNDAY");
$tempArray = array();
if ($day != false) {
if (!in_array($day, $dayArray)) die("Error: Unknown Day parameter in function HMXML_getTempProfile<br>
"); // HMXML_SetTempProfile
$dayArray = array($day);
$type = HMXML_getType($IPS_DeviceID);
$params = HMXML_getParamSet($IPS_DeviceID, $HMAddressChannel);
if ($type == "HM-CC-TC") {
foreach($dayArray as $day) {
if ($echo) echo "$day
$thisEndTimesArray = array();
$thisTempValuesArray = array();
$timePrevious = "00:00";
for ($index = 1; $index <= 24; $index++) {
$keyTemp = "TEMPERATUR_".strtoupper($day)."_".$index;
$keyTO = "TIMEOUT_".strtoupper($day)."_".$index;
$Temp = $params[$keyTemp];
$TO = $params[$keyTO];
$Time = date('H:i', mktime(0, $TO)); // $timePassed + TO
if ($TO >= 1440) $Time = "24:00";
if ($echo) echo "$index: $timePrevious -> $Time = $Temp °C
"; //if ($echo) echo "$index: $timePrevious -> $Time = $Temp °C
$timePrevious = $Time;
array_push($thisEndTimesArray, $Time);
array_push($thisTempValuesArray, $Temp);
if ($TO >= 1440) break;
$tempArray[$day]['EndTimes'] = $thisEndTimesArray;
$tempArray[$day]['Values'] = $thisTempValuesArray;
return $tempArray;
} elseif ($type == "HM-CC-RT-DN") {
for ($index = 1; $index <= 13; $index++) {
$keyTemp = "TEMPERATURE_".strtoupper($day)."_".$index;
$keyTO = "ENDTIME_".strtoupper($day)."_".$index;
return $tempArray;
} else {
die("Error: TC_getTempProfile() Device $HMAddress ($IPS_DeviceID) is not of Type HM-CC-xx<br>
function HMXML_setTempProfile($IPS_DeviceID, $tempProfileArray) {
// $tempProfileArray: ARRAY of type returned by HMXML_getTempProfile()
$HMAddress = IPSid_2_HMAddress($IPS_DeviceID);
$values = new xmlrpcval();
foreach ($tempProfileArray as $day => $valuesArray) {
$previousTimeEnd = "00:00";
for ($index=1; $index <= count($valuesArray['EndTimes']); $index++) {
$key = "TEMPERATUR_".strtoupper($day)."_".$index;
$paramTemp = array($key => new xmlrpcval($valuesArray['Values'][$index-1], "double"));
$values->addStruct($paramTemp);
$key = "TIMEOUT_".strtoupper($day)."_".$index;
if ($valuesArray['EndTimes'][$index-1] > $previousTimeEnd) {
// Convert end time to Timeout
$thisDayStart = mktime(0, 0);
$timeEndArray = explode(":", $valuesArray['EndTimes'][$index-1]);
if ($timeEndArray[1] % 10) die("Error: Invalid End Time (must be 10mn increments) for $day at index $index in TC_setTempProfile()<br>
$timeEndts = mktime($timeEndArray[0], $timeEndArray[1]);
$timeout = ($timeEndts - $thisDayStart)/60; // TODO, works ?
$paramTime = array($key => new xmlrpcval("$timeout", "int")); // i4
$values->addStruct($paramTime);
} else
die("Error: Invalid End Time for $day at index $index in TC_setTempProfile()<br>
$previousTimeEnd = $valuesArray['EndTimes'][$index-1];
$content = new xmlrpcmsg("putParamset",
array( new xmlrpcval("$HMAddress:2", "string"),
new xmlrpcval("MASTER", "string"),
$values ) );
$result = HMXML_send($content);
return true;
}elseif ($type == "HM-CC-RT-DN") {
$key = "TEMPERATURE_".strtoupper($day)."_".$index;
$key = "ENDTIME_".strtoupper($day)."_".$index;
if ($timeEndArray[1] % 10) die("Error: Invalid End Time (must be 10mn increments) for $day at index $index in RT_setTempProfile()<br>
} else
die("Error: Invalid End Time for $day at index $index in RT_setTempProfile()<br>
array( new xmlrpcval("$HMAddress", "string"),
$values ) );
return true;
} else {
die("Error: TC_setTempProfile() Device $HMAddress ($IPS_DeviceID) is not of Type HM-CC-TC<br>
function HMXML_getParamSet($IPS_DeviceID, $channel = null, $param = false) {
// $channel: INTEGER - if null the channel is taken from IPS
// $param: STRING - A specific parameter to return (see HomeMatic Specficiation), returns all if false
// Output: An array of Parameters for the Device
$thisChannel = isset($channel) ? $channel : $HMAddressChannel;
$request = new xmlrpcmsg("getParamset",
array(new xmlrpcval("$HMAddress:$thisChannel", "string"),
new xmlrpcval("MASTER", "string")) );
array(new xmlrpcval("$HMAddress", "string"),
$messages = HMXML_send($request);
if ($param !== false) return $messages[$param];
return $messages;
function HMXML_getParamSetDesc($IPS_DeviceID, $channel = null, $param = false) {
// $channel: INTEGER - default is null. Should already be included in HM Address
// Output: Array of Parameter Descriptions for the Device
$request = new xmlrpcmsg("getParamsetDescription",
return $messages;
function HMXML_setParamFloat($IPS_DeviceID, $param, $value) {
// $IPS_DeviceID: IPS Instance ID or HM Address
// $param: STRING - The parameter to set
// $value: DOUBLE - The value to set. If not double, will not be set on device
$params = array($param => new xmlrpcval("$value", "double"));
$values->addStruct($params);
if ($type == "HM-CC-TC") {$HMAddress="$HMAddress:2";}
$values ) );
function HMXML_setParamInt($IPS_DeviceID, $param, $value) {
$params = array($param => new xmlrpcval("$value", "string"));
$values ) );
// Gets the Mode of a VD (Valve) Device
function HMXML_getTCValveMode($IPS_DeviceID) {
// Output: INTEGER - Mode 0 = AUTO, 1 = CLOSE VALVE, 2 = OPEN VALVE
$value = HMXML_getParamSet($IPS_DeviceID, 2, 'MODE_TEMPERATUR_VALVE');
return $value;
} else {
die("Error: HMXML_getTCValveMode() Device $IPS_DeviceID is not of Type HM-CC-TC<br>
// Sets the Mode on a VD (Valve) Device
function HMXML_setTCValveMode($IPS_DeviceID, $nMode) {
// $nMode: INTEGER - 0 = AUTO, 1 = CLOSE VALVE, 2 = OPEN VALVE
$params = array("MODE_TEMPERATUR_VALVE" => new xmlrpcval("$nMode", "i4"));
$values ) );
return $result;
} else {
die("Error: HMXML_setTCValveMode() Device $HMAddress ($IPS_DeviceID) is not of Type HM-CC-TC<br>
// Sets the Error Position on a VD (Valve) Device
function HMXML_setVDErrorPos($IPS_DeviceID, $nErrorPosition) {
// $nErrorPosition: INTEGER - Position in %, between 0 and 99 included
if ($type == "HM-CC-VD") {
$params = array("VALVE_ERROR_POSITION" => new xmlrpcval("$nErrorPosition", "i4"));
$values ) );
return $result;
} else {
die("Error: HMXML_setVDErrorPos() Device $HMAddress ($IPS_DeviceID) is not of Type HM-CC-VD<br>
function HMXML_setVDOffset($IPS_DeviceID, $nOffset) {
// $nOffset: INTEGER - Offset Position in %, between 0 and 25 included
$params = array("VALVE_OFFSET_VALUE" => new xmlrpcval("$nOffset", "i4"));
$values ) );
return $result;
} else {
die("Error: HMXML_setVDOffset() Device $HMAddress ($IPS_DeviceID) is not of Type HM-CC-VD<br>
// Gets the Mode on a TC (Thermostat) Device
function HMXML_getTCMode($IPS_DeviceID) {
// Output: INTEGER - Mode: 0 = MANUAL, 1 = AUTO, 2=CENTRAL, 3 = PARTY
$value = HMXML_getParamSet($IPS_DeviceID, 2, 'MODE_TEMPERATUR_REGULATOR');
return $value;
} else {
die("Error: HMXML_getTCMode() Device $IPS_DeviceID is not of Type HM-CC-TC<br>
// Sets the Mode on a TC (Thermostat) Device
function HMXML_setTCMode($IPS_DeviceID, $nMode) {
// $nMode: INTEGER - Mode 0 = MANUAL, 1 = AUTO, 2=CENTRAL, 3 = PARTY
$params = array("MODE_TEMPERATUR_REGULATOR" => new xmlrpcval("$nMode", "i4"));
$values ) );
return $result;
} else {
die("Error: HMXML_setTCMode() Device $HMAddress ($IPS_DeviceID) is not of Type HM-CC-TC<br>
// Sets Temperature Comfort Value
function HMXML_setTempComfortValue($IPS_DeviceID, $temp) {
// $temp: FLOAT - Temperature Value
$result = HMXML_setParamFloat($IPS_DeviceID, "TEMPERATUR_COMFORT_VALUE", $temp);
return $result;
$result = HMXML_setParamFloat($IPS_DeviceID, "[TEMPERATURE_COMFORT", $temp);
return $result;
} else {
die("Error: HMXML_SetTempComfortValue() Device $IPS_DeviceID is not of Type HM-CC-xx<br>
// Sets Temperature Lowering (Absenk) Value
function HMXML_setTempLoweringValue($IPS_DeviceID, $temp) {
$result = HMXML_setParamFloat($IPS_DeviceID, "TEMPERATUR_LOWERING_VALUE", $temp);
return $result;
$result = HMXML_setParamFloat($IPS_DeviceID, "TEMPERATURE_LOWERING", $temp);
return $result;
} else {
die("Error: HMXML_SetTempLoweringValue() Device $IPS_DeviceID is not of Type HM-CC-xx<br>
function HMXML_setTempPartyValue($IPS_DeviceID, $temp) {
$result = HMXML_setParamFloat($IPS_DeviceID, "TEMPERATUR_PARTY_VALUE", $temp);
return $result;
} else {
die("Error: HMXML_SetTempPartyValue() Device $IPS_DeviceID is not of Type HM-CC-TC<br>
// Sets Temperature Offset
function HMXML_setTempOffset($IPS_DeviceID, $temp) {
// $temp: FLOAT - Temperature Offset
$temp = ($temp+3.5)*2;
if (($temp<0)||($temp>14)){die("Error: HMXML_setTempOffset() Temp out of range(+-3.5°C)<br>
$result = HMXML_setParamInt($IPS_DeviceID, "TEMPERATURE_OFFSET", $temp);
return $result;
} else {
die("Error: HMXML_setTempOffset() Device $IPS_DeviceID is not of Type HM-CC-RT-DN<br>
function HMXML_getTempOffset($IPS_DeviceID) {
$result = HMXML_getParamSet($IPS_DeviceID,null, "TEMPERATURE_OFFSET");
if ($result<>""){$result=$result*0.5-3.5;}
return $result;
} else {
die("Error: HMXML_getTempOffset() Device $IPS_DeviceID is not of Type HM-CC-RT-DN<br>
// Sets Party Time
function HMXML_setPartyEnd($IPS_DeviceID, $day, $hour, $minute) {
// $day: number of days (0 to 200 max)
// $hour: the hour (0 to 23 included)
// $minute: 0 = 00, 1 = 30
if ($day < 0 or $day > 200) die("Error: HMXML_SetPartyEnd() Number of Days must be between 0 and 200<br>
if ($hour < 0 or $day > 23) die("Error: HMXML_SetPartyEnd() Hour must be between 0 and 23<br>
if ($minute < 0 or $minute > 1) die("Error: HMXML_SetPartyEnd() Minute must be 0 (00) or 1 (30)<br>
$paramDay = array("PARTY_END_DAY" => new xmlrpcval("$day", "double"));
$values->addStruct($paramDay);
$paramHour = array("PARTY_END_HOUR" => new xmlrpcval("$hour", "i4"));
$values->addStruct($paramHour);
$paramMinute = array("PARTY_END_MINUTE" => new xmlrpcval("$minute", "i4"));
$values->addStruct($paramMinute);
$values ) );
return $result;
} else {
die("Error: HMXML_SetPartyEnd() Device $IPS_DeviceID is not of Type HM-CC-TC<br>
// Gets Reception Levels between 2 HM Devices in dbm
function HMXML_getRFLevelsAB($IPS_DeviceID_A, $IPS_DeviceID_B) {
// $IPS_DeviceID_A: IPS Instance ID of first device
// $IPS_DeviceID_B: IPS Instance ID of second device
// Output: Array with Reception Levels in dbm
// Note: 65536 means unknown level
$HMAddressA = IPSid_2_HMAddress($IPS_DeviceID_A);
$HMAddressB = IPSid_2_HMAddress($IPS_DeviceID_B);
$request = new xmlrpcmsg('rssiInfo');
//$result = array();
//array_push($result, $devices[$HMAddressA][$HMAddressB]);
//array_push($result, $devices[$HMAddressB][$HMAddressA]);
//return $result;
return $devices[$HMAddressA][$HMAddressB];
// Converts IPS Instance ID to HM Address or leaves Address if provided as such
function IPSid_2_HMAddress($IPS_DeviceID) {
// output: HM Address
if (preg_match ("/^[A-Z]{3}[0-9]*/", $IPS_DeviceID)) {
// The provided ID is a HM Address. Leave as it is.
return $IPS_DeviceID;
} else {
// The provided ID is a IPS Instance ID. Convert and extract HM Address.
$HMAddressFull = HM_GetAddress($IPS_DeviceID);
if ($HMAddressFull === false) echo "Eror: Invalid IPS Instance ID in IPSid_2_HMAddress()";
$HMAddressArray = explode(":", $HMAddressFull);
$HMAddress = $HMAddressArray[0];
return $HMAddress;
// Creates XMLRPC Client Instance and sends request
function HMXML_send($request) {
global $xml_client, $BidCosServiceIP;
// If the client does not exist, initialise it here
if ($xml_client == false) {
$init_result = HMXML_init();
if ($init_result !== false) echo "XMLRPC INIT SUCCESS!
"; else "XMLRPC INIT FAILED!
echo "
$response = $xml_client->send($request);
if ( $response->errno == 0 )
$messages = php_xmlrpc_decode($response->value());
else
die("Error: HMXML_send() Request to BidCos-Service failed ($BidCosServiceIP) -> $response->errstr<br>
return $messages;
Probiers einfach mal aus.
Viel Erfolg
Silberstreifen
